Nova GtI nu porneste
mrkiry |
2 Dec 2010, 22:58
Din tara unde nici apocalipsa nu ajunge... Group: Members Posts: 1.818 Joined: 2 December 10 From: Bucuresti |
Megane2
2004 Lux Privilege
- GR85KYR Renault Megane 2,1.6 16v,113 cp,an 2004
Kiraly |
3 Dec 2010, 11:55
Membru autentic Group: Members Posts: 921 Joined: 21 May 10 |
sefu nu aici cauta rezolvarea vezi acolo la dacia injectie Berlina/nova.
1310 Li
- BH 90 PUP sufli in jigler pui o sarma si gata!!!
Merced |
3 Dec 2010, 12:06
No fear. No limit. No equal. Group: Members Posts: 8.230 Joined: 24 June 07 |
Care-i carburatorul ala la masina pe injectie?
Ka
Ov |
3 Dec 2010, 12:12
catalizator infundat (de la apa din benzina inghetata) ?
demonteaza-i sonda lambda si da-i o cheie cu ea scoasa (implicit gaura in evacuare unde a fost sonda). Aia e inainte de catalizator si asa verifici daca nu cumva e infundat This post has been edited by Ov: 3 Dec 2010, 12:13 |
krapcarasu |
3 Dec 2010, 12:15
Membru autentic Group: Members Posts: 1.912 Joined: 25 November 08 From: Suceava |
e incepator, cred ca de refera la corp clapeta cand spune carb
http://www.daciaclub.ro/dacia-injectie-t9010.html |
Megane 1.4 16 v
- sv
x.fun |
3 Dec 2010, 12:21
Membru autentic Group: Members Posts: 401 Joined: 26 October 10 |
Fiat
Stilo SW
2006 , 1.9 MJT
- VN - ?? - ???
mrkiry |
3 Dec 2010, 13:14
Intr-adevar,la corpul clapeta ma refeream...si nu,presiune pompei trb sa fie intre 0,9-1,1 barri....O sa incerc chestia cu sonda lambda...Unde se afla mai exact???
3 Dec 2010, 13:16: Dar daca porneste cand ii torn benzina in corp,mai este posibil sa fie de vina sonda lambda...adica ma gandesc ca nu ar fii pornit.... This post has been edited by mrkiry: 3 Dec 2010, 13:16 |
Megane2
2004 Lux Privilege
Ov |
3 Dec 2010, 13:33
eu n-am zis ca ar avea sonda ceva. Ziceam s-o scoti ca sa obtii o gaura in evacuare undeva INAINTE de catalizator pe care-l suspectez inghetat. Sonda lambda e singura "chestie" insurubata in galeria de evacuare chiar inainte de catalizator.
moise |
4 Dec 2010, 05:15
Membru incepator Group: Members Posts: 38 Joined: 2 December 06 |
am patit si eu ,pe corp clapeta sunt 2 furtune cu sageti ptr benzina pe cel cu sageata de intrare scoatel si punel intr-o stica apoi pune contactul dt cateva ori pompa de benzina va merge de fiecare darta 2 secunde si verifica daca benzina din sticla are apa la fund se vede de obicei clar,eu cel putin a trebuit apoi sa desfac capacul la rezervor si sa aspir cu o pompa apa si era destula
Dacia Nova
GTI
2000 CU INJECTIE
- CT05TWM
mrkiry |
28 Dec 2010, 11:41
Am dus masina la mecanic si mi-a dat verdictul:e calculatorul..calculatorul nu mai trimite semnal in injector...deci...CUMPAR CALCULATOR INJECTIE MONO-MOTRONIC MA 1.7 (de dacia nova,papuc injectie,berlina injectie-se potrivesc la nova).Are cineva asa ceva???0764545715
Megane2
2004 Lux Privilege
mrkiry |
29 Dec 2010, 12:54
Am mai deschis un topic dar moderatorii l-au sters si au dreptate...problema e ca nu e nici calculatorul de vina,nici pompa,nici sigurantele,nici releele,nici injectorul,nici senzourul de turatie...nu mai stiu ce sa ii mai fac...am dus-o la doi "doctori" dar niciunu nu i-a dat de cap..unul dintre ei m-a pus sa cumpar calculator...noroc ca l-am incercat pe al meu pe alta masina si merge...are idee cineva ce ar putea fi?
Megane2
2004 Lux Privilege
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 7th May 2024 - 00:17 |
