152 Pages < 1 2 3 4 > »
> Smartphone, comparativ
kum
post 18 Jan 2011, 22:18
Banat
Sa ma bag si io?
Laguna 2.0T 2006 - GL-15-...
post 18 Jan 2011, 22:19
QUOTE(kum @ 18 Jan 2011, 22:18)
Marty
post 18 Jan 2011, 22:23
Membru cu privire de ansamblu
QUOTE(Un site de specialitate)
Apple has issued a statement in an attempt to explain the reported reception problems with the new iPhone 4. The company acknowledged that "some" customers reported that signal strength on the iPhone 4 can drop by 4 or 5 bars when tightly held in a way which covers the black strip in the lower left corner of the phone's metal band. This is a far bigger drop than normal, the company said, noting most phones lose only 1 bar when held in certain ways. However, contrary to suggestions that the drop in signal strength is the result of an antenna flaw in the phone, Apple said the problem is how the signal strength is measured. The company said it was "stunned" to find that the formula it uses to calculate how many bars of signal strength to display is "totally wrong". The Apple formula, in many instances, mistakenly displays 2 more bars than it should for a given signal strength. This means that users users who see a drop of several bars when they grip their iPhone in a certain way are most likely in an area with very weak signal strength, but they don't know it because the phone is erroneously displaying 4 or 5 bars. The company will issue a free software update in the next few weeks that corrects the formula for displaying the signal strength. The update will also apply for previous versions of the iPhone, which had the same fault.
Deci nu-si pierde semnalu', NU-L ARE! radmasa.gif radmasa.gif radmasa.gif radmasa.gif
Sursa
This post has been edited by Marty: 18 Jan 2011, 22:25
post 18 Jan 2011, 22:25
Eu folosesc de vreo 3 ani o pîrnaie de N78 (bine, acu' 3 ani nu era chiar pîrnaie). Al naibii, nu da deloc semne de deces sad.gif
Oricum, am pus ochii pe un Desire HD, îmi place mult, cred ca urmeaza în curand wub.gif
neumann
post 18 Jan 2011, 22:27
QUOTE(kum @ 18 Jan 2011, 23:18)
Sa ma bag si io?
o basina de 1000 de euro.
Videocall? Nexam, vorbesti doar cu aia de au la randu lor ifan for radmasa.gif
Americanii il vor pe Ciolos.. i-au dat si viza!
post 18 Jan 2011, 22:30
QUOTE(Marty @ 18 Jan 2011, 23:23)
Adica, in franceza. l'indique.
kum
Banat
Ma, poate o sa apuc si io ziua cand o sa-nteleaga toata lumea diferenta dintre un smartfon si un telefon!
Unii vor telefon doar pentru a vorbi la el (eventual sa-l mai foloseasca pe post de ceas desteptator) iar altii, cu mai mult bau-bau la cap (asa ca mine) vor altceva!
Asa cum se rade unii cacalitatea semnalului e de 2 lei fara sa fie in posesia unui astfel de divais (sa-mi moara la intrare daca am vazut diferenta intre 3G-ul ala batran si 4-le asta), asa pot sa ma rad si io ca un nochea 1100 (bun telefon, poate the best) nu are ecran color! Da' io consider ca fiecare doreste ceva anume de la telefon/masina/femeie/... you name it. Si isi ia ceva care sa-l satisfaca in proportie cat mai mare (adica dupa putirinta).
Fara nici o legatura, am colegi care au masini de peste 20.000 de euro care folosesc cu incredere inca batranul nochean 1100. Aia se rad de mine ca mereu can'ma urc in logan (cu aifonu') ii dublez valoarea. O fi!
<span class='edit'>18 Jan 2011, 23:32:</span>
QUOTE(neumann @ 18 Jan 2011, 23:27)
Zi sa mori tu ca ai facut la videocaluri de la inceputul anului de te-ai cocosat! Ma tarane, io videociat fac cu fomeia acasa, pe scaip, nu pe ștrase.
Si spre stiinta lu' matale, nu numai cu aia care au aifon! Po' sa fac videocall si cu fiu-miu, pe aipod!
This post has been edited by kum: 18 Jan 2011, 22:33
Marty
post 18 Jan 2011, 22:36
Nokea 1100 e prea avansat pentru mine! Eu folosesc cu incredere Motorola F3, 60 de roni nou, din magazin, cu 2 ani garantie. Se pisa cu zgomot pe aifan far!
kum
post 18 Jan 2011, 22:38
Banat
Pasarelele tale sunt de alta natura!
This post has been edited by kum: 18 Jan 2011, 22:38
post 18 Jan 2011, 22:40
kum
post 18 Jan 2011, 22:41
Banat
QUOTE(ady77 @ 18 Jan 2011, 23:40)
This post has been edited by kum: 18 Jan 2011, 22:41
Marty
QUOTE(ady77 @ 18 Jan 2011, 22:40)
Ficioratu tine cu stoaia, deci e clar ca nu are discernamint inca!
This post has been edited by Marty: 18 Jan 2011, 22:43
Filip
post 18 Jan 2011, 22:43
Forumist
QUOTE(Marty @ 18 Jan 2011, 22:36)
Corect, vrei internet, folosesti device dedicat, mai ales ca au aparut si laptop-uri mai mici, netbook parca le zice, ceva de genul asta, facute pentru navigat pe internet. Pentru ca sunt destul de rare momentele in care sa ai nevoie pe strada de internet. Iar cand stai sa te documentezi pentru ceva, de obicei stai intr-o incapere, nu afara in viscol/canicula etc. Deci smartphone-ul devine redundant. Totusi, un aparat foto este util in autoturism, in caz de accident usor.
Fara Dacie viata e pustiu.
post 18 Jan 2011, 22:44
pai poti tine unul în torpedou.
QUOTE(Marty @ 18 Jan 2011, 22:41)
This post has been edited by ady77: 18 Jan 2011, 22:45
GoGu
post 18 Jan 2011, 22:48
Prea de la tara
Daca ar fi avut radioul portabil Ric un tuciscrin, pai spargea aifonu'...
@Markos: ia mai spune de LGul ala, are vreo urma de soft Vodafone? Merge netu pe wifi? Un iGo se misca bine?
post 18 Jan 2011, 22:55
Eu chiar nu l-am luat de la vomafone. Netul merge de rupe pe wifi. iGo nu cred ca a testat înca fii-mea tongue.gif
La banii aia, mi s-a parut destul de bine legat, ca aspect. Plus ca pare sa mearga ok. Cred ca e cea mai ieftina jucarie cu Froyo, cu un ecran suficient de mare si cu un aspect decent.
Richelieu
altă scursură umană
Eu mi-as lua unul din asta:
0.00 % :((
Teacher's, e valabil citatul filozofului Marty! Ia incet sa nu te ineci!
Dacia_47_akm
post 18 Jan 2011, 22:56
Samsung epic 4g, asta e tatal lor
Dacia 1310 1992 - b-35-dis
FDF Fan Dacia Forever
neumann
post 18 Jan 2011, 22:59
QUOTE(kum @ 18 Jan 2011, 23:30)
Mah, nokea cu ecran color se exista, ifan cu semnal, nu!
Are un amic, si cica tre sa fie atent de unde-l tine. Eh, imagineaza-ti ca navighezi pe net, tastezi, si tre sa fii atent ce parti ale antenelor exterioare sa nu atingi! Dej nu numai ca n-ai tastatura fizica si tre sa pictezi pe bobul de orez cu buricele degetelor, da tre sa fii atent si cum tii divaisul si sa nu-l scapi din mana.
muama! ejti tare rau!
Tu ej diliu. Adica smartphone e ala la care telefonu n'are semnal? Poi atunci iei pda si gata, cu nochea cu blustuts modem langa. Ideea e sa ai un singur device care... e in primul rand telefon mobil. Mah, crezi ca luam eo dupa mine a636n-ul? Sau doar E50-ul?
Despre scaip pa telefonu mobil, cu video cu tot... Ce faci? Ai ora fixa la care vorbesti cu nevasta-ta? Sau va dati telefon, gen, Al, esti acasa? Nu puiu, in 30 de minute intru pe scaip. Acu am serviciile integrate asa bine, incat nu stiu de unde vine call-ul smile.gif Si de asemenea, cand sunt, imi aleg din pagina contactului cum vreau sa il sun. Daca frei, vez ca-s pe scaip, pots sa ma suni cu ifan-ul ala al tau sa-ts arat ceva frumox. Bine, its arat si daca ma suni de pe calculator, de-abia poti vedea mai bine!
post 18 Jan 2011, 23:03
QUOTE(neumann @ 18 Jan 2011, 22:59)
FLP
post 18 Jan 2011, 23:06
Sef de trib
Sustin economia romaneasca:
Mi-am cumparat asa ceva: http://www.dandragomir.biz/wp-content/P1070198-013.jpg
PS:L-am scapat deja de 2 ori, coafura rezista.
This post has been edited by FLP: 18 Jan 2011, 23:07
Ex Dacia Berlina 1998 Carburatie
Half Man, Half Pig, Half Bear
GoGu
post 18 Jan 2011, 23:07
Prea de la tara
Mersi Markos...
Am vazut jucaria si m-ar cam interesa...
post 18 Jan 2011, 23:08
QUOTE(paul_p @ 18 Jan 2011, 20:43)
Iti posti lua un iPhone 4 sau un Desire. HTC Touch 2 este modest rau.
QUOTE(Filip @ 18 Jan 2011, 22:43)
vrei internet, folosesti device dedicat ...
Filipe am lectoc pe care ma dau pe internet dedicat.
In masina e buna tare o camera foto ... pai am pe fiecare din cele doua Nokii, am pe MIO si in caz de nevoie scot si deviceul dedicat. Exact o camera foto in plus imi lipsea. nedumerire.gif
Ca o paranteza - ce face un copil de 12 ani în prima ora de smartfoneala:
1. Configureaza wifi-ul domestic
2. Isi face cont de gmail (cerut de Market)
3. Descarca YM
4. Descarca vreo 14 jocuri
5. Schimba poza de fundal si soneria de apel
6. Mai descarca 24 de jocuri
Bine, era obisnuita cu touchscreen, ca avusese un zamzung cu dracie de-asta înainte. Oricum, eu ma uitam ca prostu' blush.gif
post 18 Jan 2011, 23:11
Al meu are 4 ani jumate si are rabdare sa o invete pe nevasta-mea sa umble pe aifon far tongue.gif
This post has been edited by ady77: 18 Jan 2011, 23:11
kum
Banat
QUOTE(neumann @ 18 Jan 2011, 23:59)
Ba tanpitule!
Daca vreau sa am un video-chat pot sa o fac de pe scaip sau de pe mesinger, ambele fiind instalate pe aifon! Numai ca sa mor io de inteleg rostul videocall sau videociat de pe telefon! Poate sunt io mai bou asa, dar nici in juru' meu nu pria vad uameni folosind acest ficiăr! Nici in rromanica, nici prin celelalte bataturi pe unde am mai fost! Da' poate ca la voi acolo se foloseste cu incredere asta! Io nu sufar ca nu po'sa fac videocall de pe aifon, cum nu sufar ca nu pot sa ma rad cu aifonu'! Poate unele telefoane au si obtiunea asta, mai stii?
Doi la mana: zi sa-ti coacăcucu c-ai tinut un aifon 4 in brate si n-avea semnal! Hai zi, te rog frumos! Ca io am panarama asta de vreo 2 saptamani, da' nicicodata nu am avut problerme cu semnalu'! Si chiar am urmarit aspectu' ca am citit si io pe net!
Ma tarane: problema ar putea exista acolo unde un telefon normal ar avea semnal foarte slab! In acele zone aifonu' ar putea pierde semnalu' dac tii deștu' la imbinarea antenei! Bine, ca si un nochian ar putea pati la fel daca tii destu in zona unde e antena! Numai ca la aifon, din cauza de dizain, au ales solutia asta nefericita! Ete fleosc! De asta nu mai pot io!
Repet: smartfonul nu are ca functie primara telefonia! Daca o sa fiti capabili vreodata sa intelegeti asta, atunci considerati ca ati mai facut un levălap pe scara evolutiei!
Numa' o intrebare va mai pun si dup-aia gata: cate telefoane pardon, smartfoane cunoasteti care sunt capabile sa redea muzica in format losseles?
Multumesc!
This post has been edited by kum: 18 Jan 2011, 23:18
post 18 Jan 2011, 23:15
QUOTE(kum @ 18 Jan 2011, 23:11)
Io il am de 3 luni si n-am avut probleme cu semnalul.
kum
post 18 Jan 2011, 23:17
Banat
Sa mai zic despre 3G-ul ala batran, care avea semnal full peste tot pe unde e51 avea si el? Nu mai zic!
post 18 Jan 2011, 23:18
Lo-Fi Version  Harta site  Parteneri  Jocuri online  Curs Valutar  HRH Haine din lana merinos Time is now: 8th June 2025 - 01:11
