[VAND] diverse piese noi de Logan, vand
evali22 |
#361
![]() Membru autentic Group: Members Posts: 535 Joined: 18 January 11 From: Bucuresti ![]() |
2005 laureate
evali22 |
#362
Valabil in continuare.....
2005 laureate
ionutz72 |
#363
![]() Membru autentic Group: Members Posts: 211 Joined: 19 October 07 From: Brasov ![]() |
Discuri frana neventilate ai?
evali22 |
#364
ionutz72, am discuri neventilate marca Ferodo la pretul de 170 ron setul, sau Brembo la 180 ron setul.
2005 laureate
evali22 |
#365
2005 laureate
catageo |
#366
![]() Membru autentic Group: Members Posts: 206 Joined: 29 May 07 ![]() |
Pompa de benzina logan 1,4 ?
1981
- PH XX RZC BMW E46 Touring
evali22 |
#367
catageo, imi pare rau pompa nu aduc ca nu pot sa dau garantie la ea
2005 laureate
evali22 |
#368
Anunt valabil in continuare:
- maneta stergatoare cu buton Cb la------------- 65 ron/buc - bloc lumini cu proiector model Valeo------------ 130 ron - bucsi bascule de origine la---------------------- 20 ron/buc - bujii Equiem------------------------------------ 55 ron/set - termostat (producator) LG diesel--------------- 115 ron - cap bara Lemforder ----------------------------- 90 ron/buc - bieleta directie Lemforder------------------------ 90 ron/buc - cap bara de origine------------------------------ 75 ron/buc - bielete directie de origine------------------------ 75 ron/buc - termostat benzina------------------------------- 35 ron - pivoti TRW------------------------------------- 35 ron - pivoti Lemforder--------------------------------- 35 ron - bascula de origine------------------------------- 115 ron - set saboti (ATE)-------------------------------- 135 ron - nuca schimbator Prestige normala------ ---------- 35 ron - bucsi bara stabilizatore mijloc -------------------- 20 ron/buc - bielete antiruliu de origine ------------------------ 25 ron/buc - rulmenti roata FAG fara ABS ---------------------- 95 ron/buc - rulmenti de spate originali la ---------------------- 75 ron/buc. - rulmenti fata originali pentru model fara ABS la ----- 75 ron - rulment roata cu ABS model 2007 ---------------- 140 ron - filtru ulei original Purflux benzina ------------------- 15 ron - filtru ulei original Motorina ------------------------- 20 ron - filtru aer benzina si motorina ----------------------- 25 ron - filtru aer 16 valve --------------------------------- 30 ron - filtru motorina EURO 3 ---------------------------- 115 ron - filtru motorina EURO 4 ---------------------------- 130 ron - filtru polen Valeo ---------------------------------- 25 ron - oglinzi Prestige electrice ---------------------------270 ron/set - proiectoare ceata Logan Ph1 Valeo ----------------- 70 ron/buc - buton reglaj oglinzi electrice ------------------------35 ron - buton deschidere usa -------------------------------10 ron - amortizoare Monroe fata ----------------------------125 ro/buc - amortizoare Monroe spate --------------------------105 ron/buc - amortizoare Bilstein B4 fata -------------------------145 ron/buc - amortizoare Bilstein B4 spate ------------------------125 ron/buc - flanse amortizor originale -----------------------------35 ron/buc - rulmenti amortizor SNR -------------------------------25 ron/buc - bieleta antirasturnare --------------------------------75 ron - carcasa cheie cu telecomanda ----------------------- 50 ron - discuri frana VAN Brembo --------------------------- 135 ron/buc - placute frana VAN Ferodo SL ------------------------125 ron/set - discuri frana 259 pline Ferodo ------------------------175 ron/set - discuri frana 259 ventilate Ferodo --------------------190 ron/set - placute frana TRW ----------------------------------- 60 ron/set - placute frana Ferodo FQT ----------------------------125 ron/set - cablu ambreiaj MPI-DCI -------------------------------45 ron - cablu acceleratie MPI -------------------------------- 35 ron - sonda servodirectie -----------------------------------50 ron - sonda mers inapoi -------------------------------------35 ron - plafoniera 3 becuri ------------------------------------35 ron - plafoniera 1 bec ---------------------------------------30 ron - contactor lumina pedala frana ------------------------- 20 ron - spirala airbag volan ------------------------------------ 80 ron - kit distributie MPI -------------------------------------185 ron - pompa apa de origine MPI -----------------------------220 ron - pompa apa HEPU pt benzina ---------------------------175 ron - kit distributie DCI ------------------------------------- 320 ron - pompa apa DCI ----------------------------------------215 ron - kit ambreiaj EXEDY 1.4 MPI ---------------------------- 285 ron/set - kit ambreiaj EXEDY 1.6 MPI -----------------------------385 ron/set - curele accesorii ---------------------------------------- 55 ron - kit accesorii MPI model cu AC de origine -----------------235 ron - kit accesorii DCI model cu AC de origine -----------------255 ron - spray luciu anvelope ------------------------------------24 ron - autocolante stalpi Prestige ------------------------------35 ron/set - aeratoare Prestige argintii -------------------------------65 ron/set - ulei motor, ELF, CASTROL, MOBIL-------------------------Intrebati si multe altele...se pot aduce si piese pentru masini straine evali_daniel este id-ul meu |
2005 laureate
evali22 |
#369
Attached thumbnail(s) IMG_1058.JPG ( Size: 1.56mb ) Number of downloads: 294 IMG_1062.JPG ( Size: 1.77mb ) Number of downloads: 311 |
2005 laureate
evali22 |
#370
2005 laureate
B-64-MVP |
#371
![]() ::: M V P ::: Group: Members Posts: 183 Joined: 14 May 09 From: BUCURESTI ![]() |
Multumesc Daniel pentru bujii ! ! ! Apelati cu incredere, user serios cu marfa de origine, de calitate si promt !!! Nu este prima oara cand iau de la el si sunt super multumit !!!
2006 / AMBITION
- B 64 M V P
sano |
#372
sano Group: Members Posts: 399 Joined: 9 August 09 From: Bucuresti ![]() |
salut,
ai codul acesta 713630950 - e un rulment. cat ma costa? |
megane 2.1
hatchback
2005/1.5dci / 74kw / 101cp
- VF1 SMR205 33920325 Stiu ca sunt prost; insa cand privesc in jur, prind curaj!
evali22 |
#373
Sano, ai PM
2005 laureate
evali22 |
#374
Valabil in continuare...filtre si uleiuri la preturi convenabile...
2005 laureate
evali22 |
#375
2005 laureate
evali22 |
#376
un mic up date, bielete directie si capete bara producator RTS facute in Spania, calitate/pret foarte bun:
- kit ambreiaj SACHS pt. logan 1,6 -------- 390 ron - bielete directie RTS ---------------------50 ron buc - cap bara RTS ---------------------------50 ron buc Attached thumbnail(s) IMG_1644.jpg ( Size: 193.8k ) Number of downloads: 218 IMG_1645.jpg ( Size: 177.62k ) Number of downloads: 205 IMG_1646.jpg ( Size: 191.99k ) Number of downloads: 204 IMG_1647.jpg ( Size: 203.35k ) Number of downloads: 33 |
2005 laureate
evali22 |
#377
Anunt valabil in continuare, citeva repere noi:
- maneta stergatoare cu buton Cb la------------- 60 ron/buc - bloc lumini cu proiector model Valeo------------ 120 ron - bucsi bascule de origine ------------------------ 25 ron/buc - bujii Equiem------------------------------------ 60 ron/set - termostat (producator) LG diesel--------------- 115 ron - cap bara Lemforder ----------------------------- 90 ron/buc - bieleta directie Lemforder------------------------ 90 ron/buc - cap bara de origine------------------------------ 90 ron/buc - bielete directie de origine------------------------ 80 ron/buc - cap bara RTS------------------------------------50 ron/buc - bielete directie RTS-------------------------------50 ron/buc - termostat benzina------------------------------- 35 ron - pivoti (LEMFORDER)------------------------------ 35 ron - bascula de origine------------------------------- 110 ron - set saboti (ATE)-------------------------------- 135 ron - nuca schimbator Prestige normala------ ---------- 35 ron - bucsi bara stabilizatore mijloc -------------------- 20 ron/buc - bielete antiruliu de origine ------------------------ 25 ron/buc - rulmenti roata FAG fara ABS ---------------------- 80 ron/buc - rulmenti de spate originali la ---------------------- 70 ron/buc. - rulmenti fata originali pentru model fara ABS la ----- 80 ron - rulment roata cu ABS pana in model 2007 -------- 140 ron - rulment roata cu ABS dupa model 2007------------165 ron - filtru ulei original Purflux benzina ------------------- 15 ron - filtru ulei original Motorina ------------------------- 20 ron - filtru aer benzina si motorina ----------------------- 25 ron - filtru aer 16 valve --------------------------------- 30 ron - filtru motorina EURO 3 ---------------------------- 115 ron - filtru motorina EURO 4 ---------------------------- 125 ron - filtru polen Valeo ---------------------------------- 25 ron - oglinzi Prestige electrice ---------------------------270 ron/set - proiectoare ceata Logan Ph1 Valeo ----------------- 70 ron/buc - buton reglaj oglinzi electrice ------------------------35 ron - buton deschidere usa -------------------------------10 ron - amortizoare Monroe fata ----------------------------120 ro/buc - amortizoare Monroe spate --------------------------105 ron/buc - amortizoare Bilstein B4 fata -------------------------145 ron/buc - amortizoare Bilstein B4 spate ------------------------125 ron/buc - flanse amortizor originale -----------------------------35 ron/buc - rulmenti amortizor SNR -------------------------------25 ron/buc - bieleta antirasturnare --------------------------------75 ron - bieleta antirasturnare VAN----------------------------80 ron - carcasa cheie cu telecomanda ----------------------- 50 ron - discuri frana VAN Brembo --------------------------- 135 ron/buc - placute frana VAN Ferodo SL ------------------------125 ron/set - discuri frana 259 pline Ferodo ------------------------175 ron/set - discuri frana 259 ventilate Ferodo --------------------190 ron/set - placute frana TRW ----------------------------------- 60 ron/set - placute frana Ferodo FQT ----------------------------125 ron/set - cablu ambreiaj MPI-DCI -------------------------------45 ron - cablu acceleratie MPI -------------------------------- 35 ron - sonda servodirectie -----------------------------------50 ron - sonda mers inapoi -------------------------------------35 ron - plafoniera 3 becuri ------------------------------------35 ron - plafoniera 1 bec ---------------------------------------30 ron - contactor lumina pedala frana ------------------------- 20 ron - spirala airbag volan ------------------------------------ 60 ron - kit distributie MPI -------------------------------------175 ron - pompa apa de origine MPI -----------------------------215 ron - pompa apa HEPU pt benzina ---------------------------175 ron - kit distributie DCI ------------------------------------- 315 ron - pompa apa DCI ----------------------------------------215 ron - kit ambreiaj EXEDY 1.4 MPI ---------------------------- 285 ron/set - kit ambreiaj SACHS 1.6 MPI ---------------------------- 390 ron/set - curele accesorii ---------------------------------------- 55 ron - kit accesorii MPI model cu AC de origine -----------------240 ron - kit accesorii DCI model cu AC de origine -----------------255 ron - role ghidaj MPI/DCI------------------------------------- 35 ron - spray luciu anvelope ------------------------------------24 ron - autocolante stalpi Prestige ------------------------------35 ron/set - aeratoare Prestige argintii -------------------------------65 ron/set - ulei motor, ELF, CASTROL, MOBIL-------------------------Intrebati si multe altele...se pot aduce si piese pentru masini straine, mentionez ca piesele sunt de origine, nu facaturi. evali_daniel este id-ul meu |
2005 laureate
Pioul |
#378
![]() [IrefutabiluL] Group: Members Posts: 215 Joined: 14 December 06 From: Bucuresti ![]() |
un pret pentru: brate stergatare + motoras oglinda electrica dreapta, logan prestige 2006
Prestige™
1.6
16v
evali22 |
#379
valabil in continuare...
2005 laureate
evali22 |
#380
2005 laureate
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 24th July 2025 - 01:04 |
