Premium Autoparts - Magazinul de piese auto, Piese auto de origine si aftermarket, consumabile
ALIN-ADRIAN |
#91
Membru incepator Group: Members Posts: 15 Joined: 11 December 10 ![]() |
LAGUNA 3 1,5DCI
SebyG |
#92
![]() Membru incepator Group: Members Posts: 41 Joined: 24 January 11 From: Bucuresti ![]() |
@ALIN-ADRIAN:
Din pacate nu iti pot furniza reperele cerute (avem o problema cu furnizorul de piese de origine), iar aftermarket oferta de piese pentru Laguna 3 e destul de mica. 28 Dec 2011, 11:19: Asa cum spuneam intr-un post anterior, suntem distribuitori ai produselor WURTH. Pentru a marca acest eveniment, va punem la dispozitie cateva oferte de sezon: 1. Lichid spalat parbriz la flacon 1 litru - 20lei Super concentrat, temperatura -63'C, poate fi diluat in functie de nevoie. Poate fi folosit si ca solutie pentru dezghetat parbrizul. 2. Lichid spalat parbrizul la bidon 5 litri - 85lei/bidon Super concentrat, temperatura -63'C, poate fi diluat in functie de nevoie. Poate fi folosit si ca solutie pentru dezghetat parbrizul. 3. Pachet de iarna - 125lei Compus din: - 1 bucata lichid spalat parbriz 1 litru; - 1 bucata spray dezghetat parbriz 500ml; - 1 bucata spray dezghetat yale 50ml; - 1 bucata spray intretinere cauciuc 300ml - 1 bucata razuitor parbriz 4. Spray curatat climatizare 300ml - 95lei Distruge bacteriile si ciupercile, previne aparitia mirosurilor neplacute in habitaclu. La aceste oferte nu se aplica reducere de 10%! This post has been edited by SebyG: 28 Dec 2011, 11:19 Attached thumbnail(s) 12_buc_detergent_parbriz_mod.JPG ( Size: 480.9k ) Number of downloads: 449 detergent_SCHEIBENKLAR_5_l_mod.JPG ( Size: 438.06k ) Number of downloads: 437 pachet_iarna_mod.JPG ( Size: 518.21k ) Number of downloads: 441 IMG00214_20111228_1110.jpg ( Size: 427.63k ) Number of downloads: 444 |
Megane II Estate
ionutz_87 |
#93
![]() ionutz_87 Group: Members Posts: 1.029 Joined: 21 February 09 From: pantelimon(ilfov)-roman(neamt) ![]() |
kit ambreiaj
bielete antiruliu RENAULT CLIO Symbol I VF1LB0BC529696760 Tip auto : RENAULT CLIO Symbol I, 1.4 An fabricatie : 2003 Tip caroserie : Berlina Nr. identificare : VF1LB0BC529696760 Observatii : AC, ABS, SD, 4 USI Cilindree ( cmc ) : 1390 Putere max. ( kw ) : 55 / 75 Tip motor : K7J-A7 Serie motor : R192727 oferta pe privat |
CLIO
2003/LB0C5/CLIO
- IF 03 DAP Grand scenic 2004 1.6
SebyG |
#94
@ionutz_87: Ai PM!
Megane II Estate
cristio_79 |
#95
Proiector ceata original Valeo pentru Solenza cu suport pentru partea stanga si eventual mufa care intra in bec se pot gasi ?
Citroen / Peugeot
C3 / 308
sk0rpion |
#96
Membru autentic Group: Members Posts: 475 Joined: 5 October 11 ![]() |
salut, ma intereseaza un pret pentru kit ambreiaj + rulment valeo sau ceva alternative
5 ulei elf 10w40 1 filtru ulei 1 filtru motorina 1 filtru aer 1 filtru polem 1 injector delphi euro 3 82 cp Megane 2.1 1.5 dci euro 3 2003 82 cp k9k 722 This post has been edited by sk0rpion: 5 Mar 2012, 01:09 |
renault
megane 2
2003/ hatchback 1.5DCI
george_scala_2004 |
#97
Pentru un coleg:
Datele masinii PEUGEOT 206 Hatchback, 1.4 HDi eco 70 – 2002 1398 cm3 50Kw 68 cai Serie VF32A8HXF42161552 Tip motor : 8HX Piese necesare ar fi: 1) 1844A1 2) 1844A2 3) 184483 4) 1807CQ Acestea fiind codurile pe original Primele 3 piese reprezinta 3 mici tampoane din partea dreapta sus a masinii, in locul prinderii motorului in caroserie, iar piesa 4 care reprezinta tampon antibalans si se afla intre motor si caroserie, undeva sub motor si trece planetara dreapta prin el. Ma intereseaza, in principal, daca pot gasi ultima piesa... Multumesc, |
- Antonio Gramsci. |
dumi888 |
#98
Membru incepator Group: Members Posts: 8 Joined: 14 October 10 ![]() |
Salut,
Amortizoare spate LAGUNA II FAZA1 AN 2001 ; 1,8L/16V 88KW/120CP VF1BG0M0525244745 BG0M S 066715 E3 SAN 913 SAN 513 TEBG4 TICVI2 DECOO 0/ACHK NRT W |
Laguna II
2001 1,8/16V 88kW Privilege
madalinbm |
#99
![]() Membru Group: Members Posts: 143 Joined: 22 September 06 From: Bucuresti ![]() |
Am si eu nevoie de un set de stergatoare pentru un renault megane hatchback 2.2, 1.5 dci, fabricat in 2007, cel de 82 cp.
Multumesc anticipat. |
Megane bicorp 2.2, 1.5 dci
- B-93-MSB Renault.......
L!nuX |
#100
![]() Membru decent Group: Members Posts: 1.316 Joined: 4 January 08 From: Bucuresti ![]() |
Salut
Pentru un megane 1.6.16v 2007 82kw vf1lm1r0h38979174 placute frana fata pe sistem ATE - ma intereseaza ce producatori si preturi aferente aveti filtru polen - idem mai sus ![]() |
Megane
1.6 16v - 2007
- Numar personalizat !
SebyG |
#101
Salut,
Aveti PM! |
Megane II Estate
CrysMM |
#102
![]() Membru autentic Group: Members Posts: 473 Joined: 11 March 09 From: Braila - Ulmu ![]() |
Pentru Dacia Supernova:
- telescoape fata + spate, marca si pret te rog. Multumesc. |
1310 + SuperNova + Ford Focus combi 1,6b
1999 / 2001 / 2010
semit |
#103
![]() Private Spice Group: Moderatori Posts: 5.972 Joined: 27 September 05 From: Bucuresti ![]() |
VF1LM0FC531305930
Megane Sedan 1.5dCi 2004- 60kw necesar: ulei ELf 5w40 5 litri filtru ulei filtru aer filtru polen placute fata spate discuri fata-spate ma intereseaza pret de la mai multi producatori pentru piesele solicitate. multumesc |
Megane GT line 1.5dCi
'13 nu-ti face iluzii ca sa n-ai deziluzii.
SebyG |
#104
Salut,
Din dorinta de a va oferi permanent marci si produse noi, am placerea sa va anunt faptul ca suntem mai nou, distribuitori ai marcii de uleiuri ENEOS SUSTINA. Uleiurile ENEOS SUSTINA oferă SOLUȚII EXCELENTE oricarei provocări !! Uleiul de motor revoluționar Industria lubrifianților avansează într-un ritm foarte rapid, și de aceea dezvoltarea unui produs nou, revoluționar, care să ofere performanțe superioare utilizatorilor, devine o provocare din ce în ce mai mare. Protejarea îmbunătățită a motorului, lubrifierea mai bună și asigurarea unei funcționări mai ușoare sunt astăzi cerințe de bază pentru orice ulei de calitate. Pentru a oferi o soluție de lubrifiere într-adevăr revoluționară, un asemenea ulei trebuie să ofere calități care se resimt și în viața de zi cu zi a utilizatorilor. Care sunt aceste calități? -oferă motorului performanță îmbunătățită și consum redus de combustibil -reduce costurile de întreținere și asigură performanță pentru un număr mai mare de kilometri -reducerea emisiilor de noxe = PROTEJAREA MEDIULUI Mai jos, cateva preturi o parte din uleiurile comercializate: 1. ENEOS SUSTINA: - 0W-50 65lei/litru; - 5W-30 55lei/litru si 200lei/bidon 4 litri; - 5W-40 45lei/litru si 175lei/bidon 4 litri. 2. ENEOS PREMIUM HYPER: - 5W-30 35lei/litru si 135lei/bidon 4 litri; - 5W-40 35lei/litru si 135lei/bidon 4 litri. 3. ENEOS PREMIUM: - 10W-40 25lei/litru si 95lei/bidon 4 litri. La aceste preturi nu se aplica discount-ul de 10%! eneospoharbro.jpg |
Megane II Estate
iulian h |
#105
Membru incepator Group: Members Posts: 20 Joined: 7 October 11 ![]() |
Buna ziua
Radiator aer conditionat pt clio simbol 2007, 50 kw, vf1lb290537481021 Ma intereseaza pretul cel mai mic Multumesc |
Symbol
- B-101-HAN
SebyG |
#106
@iulianh: ai PM!
Megane II Estate
Vallybz |
#107
![]() Membru autentic Group: Members Posts: 1.475 Joined: 26 October 08 From: Buzau/Bucuresti ![]() |
Marca: RENAULT
Tip, varianta: MEGANE Caroserie: COUPE Numar de identificare: VF1DA040520540166 Luna, an fabricatie: 06/1999 Tip motor: K4MA7-00 Combustibil: BENZINA Capacitate: 1596 Putere KW: 79 Putere CP: 106 Detalii: PLACUTA OVALA da04 e009904 e2 san913 san513 nv676 drap06 harm01 0/ acgk mrtw Salut. Amortizor spate kyb gas a just? Astept raspuns pe PM.Mersi. |
Megane 1 Facelift, 1.6, 16v
Coupe 1999 K4M-A7-00
- BZ 87 BVM
cristian_rusanu |
#108
Membru incepator Group: Members Posts: 23 Joined: 30 November 10 From: Bucuresti ![]() |
Tip auto : RENAULT CLIO Symbol I, 1.4 16V
An fabricatie : 2008 Nr. identificare : VF1LB8D0539224063 Salut ma intereseaza si pe mine cat costa kit distributie + pompa apa (si tot ce mai trebuie pt ca nu ma pricep ![]() Multumesc anticipat. |
Grand scenic
2011 1.9 dci 130cp
soryngs |
#109
![]() Gabriel Sorin Group: Members Posts: 172 Joined: 20 April 11 From: Otopeni, Romania ![]() |
Salut !
Bieleta anticuplu ai pe stoc? Renault Megane Sedan 1.5 dci, motor K9K 722, 60 kw, an de fabricatie 2005. Merci anticipat ! |
Megane 2.1 - Privilege
- IF-66-SXN
SebyG |
#110
Stimati colegi,
Am placerea sa va anunt faptul ca, am revenit dupa o perioada de reorganizare si dezvoltare. Incepand din acest an oferim in afara de comercializarea de piese auto, si servicii de mecanica, tinichigerie, vopsitorie si statie ITP. Service-ul este localizat in Sos. Eroilor; nr. 15; Voluntari; Ilfov. Mai jos, un extras de preturi la manopera, pentru serviciile si lucrarile efectuate: - Revizie (schimb filtre si ulei) - 100lei; - Schimb placute frana - 50lei; - Schimb distributie - 300 - 400lei; - Schimb kit ambreiaj - 250 - 450lei; - Vopsitorie - 300 - 500 lei/per reper Pentru oferte de piese si manopera, ne puteti contacta pe topic, PM, pe e-mail sau la telefon. Cu stima Echipa Premium Autoparts SRL |
Megane II Estate
SebyG |
#111
Oferta speciala!
Set placute frana ATE pentru Clio I, Clio II, Logan, Megane. Pret special: 99lei Attached thumbnail(s) 602834.jpg ( Size: 21.96k ) Number of downloads: 142 |
Megane II Estate
Flavinho |
#112
Membru autentic Group: Members Posts: 349 Joined: 21 September 09 ![]() |
Salut,
Renault Megane sport tourer 1,5 dci 81 kw din 2010 vin vf1kz1g0643954120 Ma intereseaza Discuri frana fata spate Placute frana fata spate Kit distribute si pompa apa Kit cure accesorii Daca se poate doi-trei producatori din gama medie de pret. Multumesc |
Megane sport tourer
2010 1.5 110 cai privilege
- AR-75-DMP
dr.nils |
#113
![]() Membru autentic Group: Members Posts: 398 Joined: 5 October 08 From: Bucuresti ![]() |
Buna ziua,
Ma intereseaza un pret pentru set ambreiaj (disc, placa si rulment presiune) pentru Renault Megane motor 1,6 16V, 83 kW, an 2005, serie sasiu VF1LM0C0H34741372 Multumesc |
Megane 2.1
2005 Sedan 1.6 16V Pack Autentique Renault Megane 2.1 2004 Bicorp 1.4 16V Confort Dynamique
Ford Focus Mk4 2021 1.0 EcoBoost Titanium |
SebyG |
#114
@Flavinho: am primit datele suplimentare.
@dr.nils: Ai PM! |
Megane II Estate
SebyG |
#115
Comercializam la preturi competitive, intreaga gama de elemente de suspensie si articulatii SWAG.
Attached thumbnail(s) Suspensii_SWAG.jpg ( Size: 24.21k ) Number of downloads: 12 |
Megane II Estate
Silk |
#116
![]() Membru autentic Group: Members Posts: 387 Joined: 1 November 11 From: Bucuresti ![]() |
Salut,
Ma intereseaza pret pt urmatoarele repere : Far dreapta Bara fata Proiector Suport far Aparatoare noroi ( este de plastic, situata sub bara fata, si vizibila in dreptul rotilor, nu stiu daca m-am exprimat corect, dar sper sa se inteleaga ) Megane 3 , an 2011, Sport Edition, Serie sasiu : VF1BZA10545666484 Multumesc. |
Megane 1.6 16V SE
2011
- so sylk Plecat in depresie......
Vallybz |
#117
Salut. Ma intereseaza si pe mine o oferta de pret pe un kit de ambreiaj pe urmatoarea masina:
Marca: RENAULT Tip, varianta: MEGANE Caroserie: COUPE Numar de identificare: VF1DA040520540166 Luna, an fabricatie: 06/1999 Tip motor: K4MA7-00 Combustibil: BENZINA Capacitate: 1596 Putere KW: 79 Putere CP: 106 Detalii: PLACUTA OVALA da04 e009904 e2 san913 san513 nv676 drap06 harm01 0/ acgk mrtw Astept raspuns pe privat. Mersi mult de tot. |
- BZ 87 BVM
sorinache11 |
#118
![]() Membru autentic Group: Members Posts: 363 Joined: 25 August 12 From: Constanta ![]() |
Salut,
Te rog, o oferta pentru: -filtru combustibil (de origine si aftermarket, dar de calitate) -filtru ulei -filtru aer -filtru habitaclu -ulei 5w40 (elf evolution sxr, dar nu numai) -far dreapta Autoturism: Renault Scenic 2, 2004, 1,5 dCi, 74 kw (101 CP), VIN: VF1JM020532231250 Multumesc |
SCENIC 2; 1.5 dCi; 101 CP
oanavas |
#119
![]() Membru autentic Group: Members Posts: 591 Joined: 14 April 09 From: Bacau ![]() |
Cumpar kit distributie megane 2.2 16 16v fabricatie 2007.
Doresc neaparat si cele 2 capace de cauciuc care astupa gaura la cele 2 axuri. prefer role INA si cureaua sa nu fie plastifiata. |
skoda fabia
Renault megane
2007 1,6 16 valve GPL
SebyG |
#120
@oanavas: Aveti PM.
Megane II Estate
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 22nd July 2025 - 05:51 |
