O Dacie si atat..., D 1300 L din `81
aditza579 |
#91
![]() Membru autentic Group: Members Posts: 1.195 Joined: 30 January 11 From: Bucuresti ![]() |
1610
RS '99
Florinel 86` |
#92
![]() Membru autentic Group: Members Posts: 270 Joined: 13 April 09 From: m17 customs(galati) ![]() |
Cu cat discul e mai mare in diametru cu atat eficienta creste la franare,asta era ideea.Si cauza pentru care am trecut la 4 prezoane.
D 1300 L
Berlina
An 1981 powered by F7P
aditza579 |
#93
Atunci succes si la cat mai mare.
1610
RS '99
nalodaniel |
#94
![]() a3a oara scriu corect Group: Members Posts: 361 Joined: 24 March 08 From: suceava ![]() |
presupun ca este un motiv foarte bun pentru care nu se trece la 5 prezone cu fuzete de papuc diesel
1986
aditza579 |
#95
1610
RS '99
nalodaniel |
#96
chiar e asa de greu de facut la strung partea de butuc+flansa de prindere?
This post has been edited by nalodaniel: 25 May 2011, 23:13 |
1986
sobolan |
#97
la papuc-ul D tre' sa se mai "joace" si cu cotele rulmentilor "fusului" puntii diferita fata de cea de berlina,da' diferita mult...si asta nu implica doar strung ! si ce daca e pe 4 si nu e pe 5 ?
ce-a facut el acolo se numeste smecherie curata.... This post has been edited by sobolan: 25 May 2011, 23:18 |
Logan-1.5dci-2017--
Golf mk5 - syncro - 2007--
nalodaniel |
#98
nunu, nu contest nimic, intrebam doar sa-mi satisfac o curiozitate. ms de raspuns
![]() This post has been edited by nalodaniel: 26 May 2011, 03:32 |
1986
Florinel 86` |
#99
Nimic nu este imposibil de realizat numai ca asta este varianta adoptata de mine.
![]() This post has been edited by Florinel 86`: 26 May 2011, 21:47 Attached thumbnail(s) DSC00651.JPG ( Size: 783.9k ) Number of downloads: 815 DSC00845.JPG ( Size: 811.64k ) Number of downloads: 850 DSC00847.JPG ( Size: 691.79k ) Number of downloads: 834 DSC00849.JPG ( Size: 827.17k ) Number of downloads: 830 DSC00850.JPG ( Size: 843.54k ) Number of downloads: 829 DSC00853.JPG ( Size: 802.59k ) Number of downloads: 342 DSC00856.JPG ( Size: 628.88k ) Number of downloads: 357 DSC00862.JPG ( Size: 675.19k ) Number of downloads: 301 DSC00891.JPG ( Size: 803.66k ) Number of downloads: 302 DSC00892.JPG ( Size: 703.3k ) Number of downloads: 338 |
D 1300 L
Berlina
sobolan |
#100
volanta de care-i ? smecherie mare cu rulment la priza.....
Logan-1.5dci-2017--
Florinel 86` |
#101
Volanta este a motorului care o sa-l urc pe masina,F7P.Iar la cutie i-am pus carter de ambreiaj de papuc diesel pentru a cupla cutia de motor.Si acel rulment este tot de papuc.
Attached thumbnail(s) DSC00877.JPG ( Size: 828.73k ) Number of downloads: 451 |
D 1300 L
Berlina
aditza579 |
#102
Ooooo, frumos. Cand il urci pe masina?
1610
RS '99
sobolan |
#103
se contureaza un mic monstru in pielea unui batran r12
Logan-1.5dci-2017--
aditza579 |
#104
Asta e combinatia perfecta, lup in piele de oaie. Este super
1610
RS '99
sobolan |
#105
cica ar fi o diferenta intre f7P si f7R..plm...
This post has been edited by sobolan: 28 May 2011, 13:15 |
Logan-1.5dci-2017--
aditza579 |
#106
Wikipedia:The F7x was the first of the F-type engine family with a 16-valve DOHC configuration, the valves were directly actuated by Hydraulic tappets. both the 1.8l as the 2.0l were equipped with a multipoint-EFI system.
Applications: F7P 1.8 L (1,764 cc (108 cu in), B x S: 82.0 by 83.5 millimetres (3.23 in Ś 3.29 in). 19??–1991 Renault R5 Super 5 (No official Renault references known) 1988–1997 Renault R19 1991–1996 Renault Clio F7R 2.0 L (1,998 cc (122 cu in), B x S: 82.7 by 93.0 millimetres (3.26 in Ś 3.66 in). 1994–1998 Renault Clio Williams 1996–1999 Renault Megane 1995–1999 Renault SPORT SPIDER |
1610
RS '99
Florinel 86` |
#107
Merci pentru interventie Adita,oricum si asa motoru` l-am gasit destul de greu.
D 1300 L
Berlina
aditza579 |
#108
F7P mi-se pare o alegere foarte buna. Cu ce ai de gand sa il alimentezi? Injectia multipunct standard sau vrei 2 orizontale? Daca il sti pe domnul Miclausu care alearga cu sportul la CNVC, avea pe un F7P doua orizontale si tragea forte bine masina, deci agndeste-te.
L.E. Stii ca cutia de Dacia este proiectata pentru 150Nm cuplu, cum te gandesti ca va rezista la un cuplu si o putere mai mare pe care le dezvolta acest motor? Merci This post has been edited by aditza579: 28 May 2011, 17:13 |
1610
RS '99
Florinel 86` |
#109
Daca ai fi citit topicul ai fi vazut ca deja am ales sistemul de alimentare.Iar cat despre cutia de viteze `sa speram` ca va rezista cuplului,alta optiune momentan nu am din cauza finantelor.
D 1300 L
Berlina
sobolan |
#110
rezista,parerea mea.....a rezitat cu succes la 1900 D care are cuplu mare si el....rezista !
la 1900D e aceeasi cutie doar ca diferea ce ai schimbat tu(palnia aia aka carter ambreiaj) si grupul deci nu-i bai.... |
Logan-1.5dci-2017--
aditza579 |
#111
QUOTE(Florinel 86` @ 24 Mar 2011, 19:07) l F7P pe care am sa-l pun pe `baba`,o sa fie 4 Dellorto de 45 deci carburi orizontale cu filtre de aer conice,toate astea dupa ce am sa schimb la ea semiaripile si voi modifica sistemul de franare si suspensie. Am citit tot topicul, dar nu imi mai aminteam. Acum am gasit, dar din cate stiu eu, si cred ca pot sa ma sustina multi, Dellorto DHLA 45 este un carburator dublucorp, cu 2 camere sincron, o camera pe cilindru, eu cred ca tu ai scris gresit acolo, adica ar fi imposibil sa montezi 4 bucati, cred ca 2 carburi, in total 4 camere, fiecare pe un cilindru. Am dreptate? |
1610
RS '99
Florinel 86` |
#112
Cand am scris 4 bucati m-am grabit si am scris gresit,iar daca tot suntem la capitolul alimentare am sa pun cateva poze.
Attached thumbnail(s) DSC00899.JPG ( Size: 682.02k ) Number of downloads: 427 _BwjWjU__Wk___KGrHqF__iEEv1_0DqG3BMJheHi0Zw___12.jpg ( Size: 28.98k ) Number of downloads: 319 DSC00924.JPG ( Size: 680.87k ) Number of downloads: 345 DSC00982.JPG ( Size: 737.27k ) Number of downloads: 357 |
D 1300 L
Berlina
aditza579 |
#113
Cel mai important e sa le vedem sus.
1610
RS '99
Florinel 86` |
#114
O sa fie si sus,nu-ti mai bate atat capul cu asta.
D 1300 L
Berlina
#115
QUOTE(sobolan @ 29 May 2011, 09:28) rezista,parerea mea.....a rezitat cu succes la 1900 D care are cuplu mare si el....rezista ! la 1900D e aceeasi cutie doar ca diferea ce ai schimbat tu(palnia aia aka carter ambreiaj) si grupul deci nu-i bai.... Ce comparatie ti-ai gasit, cuplu mare o lae, 1.9 D are un cuplu de 128 Nm, cam cat benzinarul romanesc de 1.6. |
sobolan |
#116
nu stiu exact ce cuplu are monstrul ala mic
![]() This post has been edited by sobolan: 30 May 2011, 09:19 |
Logan-1.5dci-2017--
aditza579 |
#117
QUOTE(argon @ 29 May 2011, 21:27) Ce comparatie ti-ai gasit, cuplu mare o lae, 1.9 D are un cuplu de 128 Nm, cam cat benzinarul romanesc de 1.6. Cata derptate poti sa ai nea' Argoane, eu cred ca(nu stiu sigur)F7P-ul are undeva in jur de 170-180Nm, ori cutia de dacie in normele de siguranta are 150Nm. Eu cred ca va rezista daca te comporti frumos cu motorul, daca ii dai scart la fiecare semafor, ori se rupe din prima, pori se duce cat-un dinte. Oricum incearca, si daca nu merge gandeste-te la altceva |
1610
RS '99
nalodaniel |
#118
defapt papucii au 118NM dieselu si 125NM benzinaru' de 1.6 .
sursa: wikipedia |
1986
sobolan |
#119
daca-i asa cam mare diferenta de cuplu....totusi nu prea imi dau seama ce poate sa se rupa...priza "preia din motor spre pinioane"....aia de D e mai groasa,asa stiam eu
Logan-1.5dci-2017--
Florinel 86` |
#120
Nu va mai bateti capu` cu asa ceva,daca tot vreti sa discutati despre cupluri motor si cutii de viteze va rog nu la mine pe topic.Stiu cum am facut acea cutie de viteze si eu zic ca va rezista,asa ca,subiect inchis.Multumesc.
D 1300 L
Berlina
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 17th July 2025 - 00:03 |
