Bula daciotului
Bula daciotului
l@u |
#9571
Land Rover
Freelander
Td4, HSE
ady77 |
#9572
Eu in depasiri sting farurile.
________________
________________
ecnedifnocfollufsisoM |
Markos |
#9573
Megan
#9574
![]() - Group: Members Posts: 22.737 Joined: 19 April 05 From: Romania ![]() |
l@u |
#9575
Nu stiu exact principiul dar cele ce le-am vazut eu aveau in interior o parghie pe care o actionai .
Land Rover
Freelander
Td4, HSE
#9576
l@u |
#9577
Asa tata !!!Ala dsg, fiecare roata cu frana si acceleratia ei ! Nici nu mai ai nevoie de volan !
This post has been edited by l@u: 18 Jan 2012, 22:53 |
Land Rover
Freelander
Td4, HSE
Shush |
#9578
![]() ٩(Ś̯Ś)۶ Group: Members Posts: 2.117 Joined: 30 January 07 From: Brasov ![]() |
Seat
Leon
2008 Reference 1.6
- Bv-29-Trei Litere Yamaha YZF-R125 2009 - Bv-88-Aceleasi Trei Litere
ex Dacia Logan 2005 Laureate 1.4 If a vegetarian eats vegetables, what does a humanitarian eat ? |
bmwh548 |
#9579
alexys |
#9580
Membru autentic Group: Members Posts: 350 Joined: 28 February 06 From: Topoloveni ![]() |
Intentia initiala a fost sa raspund la postarea respectiva, da' mi-a iesit prea off topic, cred ca se potriveste mai bine aici:
. QUOTE(PH-06-BOA @ 21 Jan 2012, 23:01) Alexis, mi-ai speriat geologul! Culmea e, ca si dracu' s-a inegrit la fata, de spusele tale! Cum e posibil sa scoti din mintea aia a ta, o asa perla, ca din scoica, ca turatia se regleaza din clapeta? DA, LA CARBURATOR TURATIA SE REGLEAZA DIN CLAPETA DE ACCELERATIE, ASTA DACA NU CUMVA BMW-UL CU INALTIMEA DE RIDICARE VARIABILA A SUPAPELOR DE ADMISIE EXISTA SI IN VARIANTA CU CARBURATOR! GPL-ul trece prin canalul ASTUPAT cu dopul de aluminiu. Ce intelege onul asta? DA, CANALUL ALA, CARE ESTE PRELUCRAT FARA TELEPORTAREA MATERIALULUI IN EXCES, ARE GAURA TEHNOLOGICA ASTUPATA CU UN DOP DE ALUMINIU, PROBABIL CA SA NU IASA GAZUL IN ATMOSFERA - STII TU ALTA METODA - UN SCUT DE ENERGIE, CEVA??? IN ALTA ORDINE DE IDEI OMUL INTELEGE CE TREBUIE, ONUL CRED CA SE OCUPA CU DREPTURILE ASTUIA DIN URMA SI IL PREOCUPA MAI PUTIN CE AM SCRIS EU ACOLO Ce face contrapiulita si surubul? AL DOILEA SE PLIMBA SI PRIMA IL BLOCHEAZA Modifica planul? NU, CRED CA DE FAPT E VORBA DE DEFORMAREA RELATIEI SPATIU TIMP, AM VOIE SA SUN UN PRIETEN? Sau cursa? AICI RECUNOSC CA M-AI BLOCAT - ESTI DE LA FBI? Care-i rolul unei supape de cauciuc? AICI OPTEZ PENTRU 50%-50%, SUNT DEJA DOBORAT (DE RAS) Sa se adapteze la neuniformitati si diferente intre planuri , nu? AHAA! ABIA ACU' INCEP SA INTELEG, ERA (PE-APROAPE) O INTREBARE RETORICA DECI! De ce era nevoie de un surub stramb? VARIANTA SCURTA DE RASPUNS: CA SA SE MIRE PROSTII, VARIANTA 2, IDEM NUMAI CA LE PERMITE (UNOR FRAIERI) CARE PUN O PASTILA DE CAUCIUC MAI GROASA SAU MAI SUBTIRE SA ADUCA SUPRAFATA DE ETANSARE IN ACELASI PLAN, UN PLAN PARALEL CU ACESTA NEFIIND LA FEL DE BUN CAND MISCAREA SUPAPEI RESPECTIVE ESTE DE ROTATIE IMPREUNA CU PARGHIA SI NU DE TRANSLATIE, DEASEMENI NU ESTE O GAURICA CAT VARFUL DE AC SA NU CONTEZE INCLINAREA SI NICI NU ESTE ARTICULATA IN SPATE CA SA SE CENTREZE SINGURA CA LA LOVATO SPRE EXEMPLU, E RIGIDA SI NU VREA SA SE MISTE DECAT IMPREUNA CU PARGHIA Furtunul, daca e la diametrul interior, asemanator cu cel original si nu se descompune la agentii petrolieri, nu afecteaza reglajul, mai ales ca lui i-a consumat 12%. DA, TREI ZILE TREI SAPTAMANI SAU TREI LUNI NU AFECTEAZA, DE FAPT EXTERIORUL RAMANE LA FEL, DOAR INTERIORUL MAI PLEACA LA PLIMBARE SI SE STRANGE IN DIVERSE LOCURI, DE OBICEI UNDE E TRASEUL INGUSTAT, ACOLO CREDE EL CA E LA MODA SA SE OPREASCA. PROSTI RAU AIA, CARE CER OMOLOGARE PE FURTUNELE DE GPL SI NESIMTITI PE DEASUPRA, CAND IL VAND, PE UNUL AU OBICEIUL SA SCRIE CA-I PENTRU APA SI PE ALTUL, CA-I PENTRU GPL, AM VAZUT UNELE SI PENTRU BENZINA - AICI CHIAR CA AU EXAGERAT!!!! AM MAI VAZUT SI UNELE DE GPL PUSE LA POMPA DE BENZINA CARE S-AU INGRASAT DE BUCURIE SI PANA LA URMA AU PLESNIT (MAXIM 5 MINUTE) - OARE AU PUS ASTIA STEROIZI IN BENZINA??? Motorul trebuie sa mearga LA FEL, cu si fara filtru. Iar o prostie pe care o transmiti BA NU IO! -TU VAD CA ZICI - NU MA MAI AMETI!!! , asa, ca sa te simti tu bine. Cate filtre ai separat de carburator, si ai vazut ca se modifica mersul? NU A TREBUIT SA LE SEPAR EU, AU VENIT UNII CARE SUSTINEAU CA DEGEABA AU APELAT LA MESERIASI CA TINE CA SA LE REGLEZE CARBURATORUL CA AIA DE LA RAR SUNT SUPERBULANGII NU VOR SA TINA CONT DECAT DE ANALIZOR SI DE LEGE IN PLUS DACA LE DAU EU O FOAIE LA MANA SI IN EA SCRIE CA N-A POLUAT, AIA NU AU TUPEU SA CEARA SPAGA SPUNAND CA NU-I BINE REGLATA, TU POTI SA FACI MINUNI DINTR-ASTEA? Ai statie PECO? DOAR O BUTELIE DE GAZ, DA NU-I A MEA, ASA CA NU-I RELEVANT Atunci cand mersul e influientat de legarea filtrului la carburator, filtrul e colmatat, traseu strangulat. SI TU TE LASI "INFLUIENTAT" DE EL NU-I ASA? PROBABIL FILTRUL ALA FACE ASA CA SA CONVINGA PROSTII, ALA NOU NU SE BAGA IN SEAMA CU ORICINE, DOAR CU ANALIZORUL SI CU CONSUMUL, ARE SI EL MANDRIA LUI SI PENTRU ASTA MERITA FELICITAT De ce crezi ca s-a apelat la bartai sulacul, si cu hartia in zigzag? DIN CAUZA CA NU TOTI AU BANI DE FILTRE SPORT - CARE DUPA LOGICA TA SUNT CU TURBOCOMPRESOR INCLUS CA SA LE POATA DEPASI PE ALEA STANDARD Pentru a se mari suprafata si a fi neglijabil , in calea absorbtiei de catre carburator. IO PUTEAM SA JUR CA NICI O SUPRAFATA MARE NU POATE FI NEGLIJATA, POATE DOAR UNA MICA SI NICI DE CARBURATORUL ABSORBANT N-AM AUZIT E CUMVA TURBINCA LUI IVAN Mixer din Polonia? DA, DACA NU-SI PERMITE UNUL FABRICAT DE UN DESTEPT CA TINE IN ROMANIA (DE FAPT UITASEM IN ROMANIA SE FABRICA NAVETE SPATIALE NU NE INCURCAM NOI CU ORICE) Adica noi, Romanii astia, asa cum suntem, avem nevoie de Incasi, sa facem niste calcule de a cladi si parasuta ditamai mixerul, pe un carburator, care tu nu l-ai vazut niciodata, decat in pozele colegului, si alea incomplete inteleg. CONSIDER CA AI JIGNIT INCASII, TU PERSONAL NU AI AJUNS NICI LA NIVELUL UNEI MAIMUTE, CREDE-MA PE CUVANT, CU INCA DOI CA TINE AJUNGEM CA MEDIA PE TARA LA IQ SA FIE NEGATIVA. CA SA INTELEGI MAI BINE, SUNTEM MAXIM 23 DE MILIOANE MAJORITATEA CU IQ PESTE 100, CIFRE NEINSEMNATE ATATA TIMP CAT PROSTIA POATE FI INFINITA, SI NU MAI FOLOSI CUVANTUL "INTELEG", LA TINE NU SE APLICA Te rog, vino doar putin cu picioarele pe pamant, sa vezi ca nu suntem chiar asa prosti! Chiar meritam asta , si de la tine? IAR INCEPI SA VORBESTI IN NUMELE TUTUROR, NU STIAM CA DAN DIACONESCU S-A NASCUT LA PLOIESTI, DA AM VENIT SI TE-AM VAZUT, NU ESTI CHIAR ATAT, POTI DEMONSTRA MEREU CA E LOC DE MAI MULT. IN REALITATE NU MERITAI NICI O VIRGULA DA' SUNT LA MITING SI AM ASA UN CHEF DE BASCALIE....! P.S.: Daca nu cumva inainte de a te naste, cineva a fost in Italia sa-i lustruiasca balustradele de inox lui Mr. Landi, nu ai de ce sa imi spui mie ce face o supapa de cauciuc! Cand ai dobandit atatea cunostinte incat poti sa spui cuiva ce face si ce nu face o piulita sau orice altceva de la Landi Renzo? Nu-mi amintesc sa se fi facut instruiri de personal la stanele de pe Valea Prahovei pe Landi Renzo, din punct de vedere oficial esti nul in privinta asta, doar unul care-si da cu parerea si atat. Ca sa intelegi mai bine, degeaba visezi tu la operatii pe creier, daca nu ai si tu macar o hartie care sa ateste acest lucru,oficial te numesti neica-nimeni. Insa, daca mostenesti aceste cunostinte despre Landi Renzo genetic, ar fi pacat sa nu-ti ceri drepturile! Da-mi datele pe care sa-ti scriu un certificat oficial (promit ca va fi parafat si de Landi Renzo, pentru tine fac un efort si cer sa fie semnat personal si de Mr. Landi) ca sa ateste ca esti prea Napolact si nu ai voie sa discuti despre Landi Renzo. Daca nu o sa crezi ca-i original cu numar de inregistrare cu tot si vrei sa-l ridici singur, uite ce trebuie sa faci: - fugi in Italia, in Reggio Emilia - Cavriago, te cazezi, vezi ca e un hotel dragut langa statuia lui Lenin, nasol ca e cam scumpa masa daca nu-ti plateste nimeni deplasarea, dar aia de la L.R. sunt draguti o achita ei, vizitezi sediul Landi Renzo, atentie sa nu te holobezi prea tare la tablourile imense de pe pereti, sunt poleite unele cu aur, altele cu argint, le spui ca asa ceva ai si tu la buda si te duci pe linia de asamblare (include si CTC) a reductoarelor, este a doua hala pe stanga si le spui despre surubul stramb si legea cauciucului care astupa gauri. Ca tot esti in zona, nu uita sa vizitezi Ferrari si Maserati, nu incerca la Lamborghini ca aia sunt bulangii, refuza pe diverse motive, ba ca testeaza un prototip secret, ba ca trebuie aprobare speciala, daca te vad pe tine asa plin de idei, sigur le va fi frica de spionaj industrial. Ar mai trebui sa stii ca albanezii sunt pusi pe ciordeala, desi am impresia ca or s-o ia la fuga cand te-or vedea sa nu fie incadrati la complicitate pentru idiotenie. Dupa ce obtii atestatul respectiv, incerca si sa vizitezi Pietra di Bismantova, urca pe scari si coboara pe alta cale, vei face un serviciu omenirii... P.S.2: Daca nu-mi trimiti datele suficient de repede o sa pierzi ocazia, mi-e ca-mi scapa mouse-ul pe ignore sau imi iau primul ban din viata mea! P.S.3: Evident, tot un meserias ca tine i-a pus instalatia, nu te recunosti in rezultate? |
KIA
Sephia
1996
- AG-11-LPG
vet |
#9581
![]() Membrul Group: Members Posts: 464 Joined: 9 December 07 ![]() |
QUOTE(alexys @ 24 Jan 2012, 02:47) Intentia initiala a fost sa raspund la postarea respectiva, da' mi-a iesit prea off topic, cred ca se potriveste mai bine aici: Eu cred ca se potrivea cel mai bine pe PM, dar daca tot l-ai pus aici, poate imi explici si mie care din voi este de bula. |
2007 / KissFM 1.5 dCi .
#9582
Nu sta nici dracu sa citeasca romanul asta.
![]() Nu exista varianta pe scurt? |
alexys |
#9583
Eu c-aveam prea mult timp, ca de el n-am ce zice, e policalificat sa-si dea cu parerea oriunde.
KIA
Sephia
1996
- AG-11-LPG
#9584
Andy_ACS |
#9585
Nu s-a referit la nr de G3 care sunt inmatriculate in RO, ci la alea inmatriculate pe care le-ai vazut tu
bucatzel |
#9586
QUOTE(alexys @ 24 Jan 2012, 02:47) P.S.2: Daca nu-mi trimiti datele suficient de repede o sa pierzi ocazia, mi-e ca-mi scapa mouse-ul pe ignore sau imi iau primul ban din viata mea! Nu toti verifica intregul forum, sa vada daca le-o raspuns cineva. Asta nu inseamna ca te rog sa-i raspunzi asa pe topic, ca am prea mult de lucru zilele astea, si n-am chef sa stau sa fac curat pe topicul de |
1981
dacia_amg |
#9587
![]() Un neanderthal ejaculat din beci. Group: Members Posts: 237 Joined: 24 November 10 ![]() |
Stiu ca nu e locul potrivit, dar mi-a fost lene sa caut un topic mai in tema:
![]() ![]() ![]() ![]() ![]() Muscle car Dacia 1310 V8 This post has been edited by dacia_amg: 24 Jan 2012, 12:13 |
24 valves black e34
bimmer
touring Ai furat bara de striptease?!
Du-o inapoi urgent, La martorii lu' Ebola (no comment). |
Shush |
#9588
Si-au gasit si aia de ce sa rada desi pe forumul ala sunt laudate sute de cazane "tunate" care arata mult mai rau decat aia.
Seat
Leon
2008 Reference 1.6
bion |
#9589
QUOTE(IRONICK @ 18 Jan 2012, 22:50) S-o fi inspirat dupa anumite vehicule de tot kkt-ul poreclite Merceds care au o pedala acolo in stg. pentru frana de" mana" ![]() |
SLZ Scala
bmwh548 |
#9590
Curat rampandule.
Marty |
#9591
Un argon de pe alt forum...
QUOTE Anvelopele sunt ca noi, nu s-a facut nici o pana cu ele, sunt rulate max.25k |
Gillette
De unica folosinta
2011
#9592
CAPTUR E-Tech full hybrid 145
2024
l@u |
#9593
unde-i bula ?
Land Rover
Freelander
Td4, HSE
#9594
eram curios de nr de pedale
2024
l@u |
#9595
aha, deci ai postat unde trebuie !
Land Rover
Freelander
Td4, HSE
#9596
Marty |
#9597
Gillette
De unica folosinta
2011
#9598
Ia marfa neamule, abiea trecute de semnul de uzura.
Markos |
#9599
Megan
bucatzel |
#9600
@argon. De cand ai avatarul asta, mi-e si frica sa mai trec prin deva.
1981
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 19th July 2025 - 19:35 |
