TEMPORIZATOR STERGĂTOARE, ...asa cum avea până si bătrâna Berlină
campean_cristian |
#331
![]() Membru Group: Members Posts: 124 Joined: 15 June 06 ![]() |
Logan 1.4MPI
- AB-::-:::
2006 Ambiance
FRATELLO |
#332
![]() Membru autentic Group: Members Posts: 924 Joined: 7 November 06 From: PLOIESTI ![]() |
Incearca sa pui o dioda (1N400x) pe alimentarea catre PIC-ul "pentru stergatoare", la iesirea din 78L05 ; banuiesc un "spike" de tensiune ... La montajele mele de butoane cu impuls am montat pe alimentare un P6KE (transient voltage surge suppressor).
old 1.5 dCi-E4 ; now 1.2 @ 16V
campean_cristian |
#333
Ce fel de P6KE ? Unidirectional sau bidirectional?
Multumesc |
Logan 1.4MPI
- AB-::-:::
2006 Ambiance
FRATELLO |
#334
Bi-directional. Iar in loc de 78L05 poti incerca un LM2931-AZ5.
okke |
#335
Membru incepator Group: Members Posts: 1 Joined: 20 July 09 ![]() |
Laureate 1.4
marian_ariciuc |
#336
![]() User Group: Members Posts: 322 Joined: 6 May 10 From: de obicei, acasa ![]() |
QUOTE(FRATELLO @ 28 Jul 2013, 09:04) Iar in loc de 78L05 poti incerca un LM2931-AZ5 1. care ar fi avantajul? ![]() 2. cum ai conectat acea P6KE (transient voltage surge suppressor)? This post has been edited by marian_ariciuc: 21 Jul 2014, 11:38 |
1.6 16V E5 Vand modul inteligent de geam pentru logan 1 si 2 si alte...
FRATELLO |
#337
1. Proiectat pentru "auto environment".
2. Nu conteaza ; e bi-directional. |
aline |
#338
Membru incepator Group: Members Posts: 15 Joined: 13 February 15 ![]() |
am gasit si eu la vechea dacie un temporizator de stergatoare,care regla baleierea,dar nu stiu daca merge la logan.
este ceva ,,made in hungary,,dar va spun ca mergea foarte bine pe dacie. pun si niste poze poate ma ajuta cineva. am citit toate paginile dar nu stiu care se potriveste cu ce am eu. IMG_20150329_173813.jpg ( Size: 500.91k ) Number of downloads: 769 IMG_20150329_174002.jpg ( Size: 615.29k ) Number of downloads: 778 IMG_20150329_174100.jpg ( Size: 472.09k ) Number of downloads: 781 IMG_20150329_174108.jpg ( Size: 464.87k ) Number of downloads: 768 IMG_20150329_174131.jpg ( Size: 504.18k ) Number of downloads: 757 |
logan 1,6
GIC |
#339
![]() Doar membru Group: Members Posts: 930 Joined: 13 January 04 From: Oradea ![]() |
Vezi aici. Tai firul de la A1 (maneta stergartor) catre UCH si le legi la releul din temporizator adica A1 il legi cu pinul 53M si capatul catre UCH cu pinul 30/31. 53K ramane in aer, 15 e plus dupa contact si 31 e masa.
aline |
#340
Multumesc..incerc sa vad daca merge..se poate strica uch-ul?
logan 1,6
GIC |
#341
Nu vad ce se poate strica. Practic tu montezi un intrerupator comandat electronic pe fir.
aline |
#342
astazi am montat si eu temporizatorul,merge perfect,l-am pus langa bricheta jos la schimbator.
multumes pentru ajutor..raman dator |
logan 1,6
velceani |
#343
![]() Membru autentic Group: Members Posts: 953 Joined: 29 May 09 From: C de Arges ![]() |
salut,
ce face, mai precis, acest temporizator? This post has been edited by velceani: 1 Apr 2015, 07:46 |
Logan 2
Sl plus 1.2 16v 2016
campean_cristian |
#344
QUOTE(aline @ 29 Mar 2015, 17:56) am gasit si eu la vechea dacie un temporizator de stergatoare,care regla baleierea Cam asta face... |
Logan 1.4MPI
- AB-::-:::
2006 Ambiance
velceani |
#345
adica poti sa ii reglezi timpul de baleiere?
Daca ai deja trei trepte la ce iti mai trebuie asta? |
Logan 2
robbie_ro |
#346
![]() ----------------------- Group: Members Posts: 464 Joined: 25 June 07 ![]() |
Deoarece pe unii utilizatori de Logan nu ii multumeste temporizarea de 4 secunde de pe prima treapta si vor o plaja reglabila de 3-20 secunde.
2007, Laureate Plus
velceani |
#347
acum am inteles... e ceva util mai ales cand e burnita sau ploaie marunta...
Logan 2
#348
![]() Membru autentic Group: Members Posts: 8.184 Joined: 12 May 06 From: BUCURESTI ![]() |
ajutor , am facut schema de aici am montat , dar nu functioneaza bine , la temporizare mai mare de 4-5 sec intra temporizarea uch , care ma deranjaza si nu stiu cum o pot modifica , (de unde) , daca ma puteti ajuta , dispun de interfata si program , mai rmine sa ma indrumati unde sa umblu
CAPTUR E-Tech full hybrid 145
- B 07 BGY
torquemada |
#349
![]() torquemada Group: Members Posts: 1.904 Joined: 17 January 05 From: Bucuresti ![]() |
La X90 temporizarea pe intermitent e fixă și nereglabilă, dar e teoretic poți intra pe clio II x65 și poate poți intra pe uch(nu pe uch transv 7) și la ConfigUsine cauti temps cadencement essuie vitre av (s) și schimbi, poate te lasa poate ca nu.
Logan II
- B-xxx-xxx
2012 / 0.9 TCe Laureate Există două feluri de oameni:
#350
ms o sa incerc
- B 07 BGY
mcxc |
#351
Membru incepator Group: Members Posts: 1 Joined: 27 September 15 ![]() |
Daca ai facut schema postata de userul hash nu trebuie sa faci nici o modificare in UCH! Daca ai montat cum trebuie, firul care comanda baleierea intermitenta este intrerupt, deci nu va putea intra baleierea din UCH.
Incearca sa schimbi iesirea modulului pe contactul normal deschis de la releu! This post has been edited by mcxc: 20 Dec 2015, 20:06 |
1.5Dci
2006 Laureat
FRATELLO |
#352
Are dreptate mcxc.
Detalii de montare : http://www.daciaclub.ro/index.php?showtopi...dpost&p=2920415 |
#353
am rezolvat-o pe sursa , ramine de montat pe masina , s-a stricat quartul , si a trebuit sa il inlocuiesc, schema aia este prost desenata
- B 07 BGY
ctropett |
#354
Membru incepator Group: Members Posts: 3 Joined: 26 December 05 ![]() |
Salutare!
Din pacate in post-ul in care userul Hash explica cum a facut temporizatorul nu reusesc sa accesez imaginile si arhivele (post-ul cu pricina). Se pot reface legaturile sau poate are cineva salvate respectivele scheme si codul pentru programarea microcontrollerului? |
Hyundai / Dacia
Tucson / Logan 2
2007 / 2015
#355
eu am facut schema asta merge bine
- B 07 BGY
ctropett |
#356
Multumesc. O sa ma apuc de mesterit.
Hyundai / Dacia
Tucson / Logan 2
2007 / 2015
ctropett |
#357
Temporizare reglabila stergatoare Logan dupa 2013
Dupa ceva studiu pe diverse forumuri am reusit sa construiesc un modul care se conecteaza pe mufa de la maneta de comanda a stergatoarelor si modifica durata temporizarii pentru pozitia "baleiaj intermitent" dupa modelul de la VW Golf 3, Skoda etc. Functionalitatea este urmatoarea: se trece maneta de comanda a stergatoarelor pe pozitia "baleiaj intermitent"-prima pozitie, dupa care inapoi pe "oprit" (se da un impuls stergatoarelor). Din acest moment modulul incepe sa contorizeze timpul. Dupa impulsul initial, cand soferul considera ca este nevoie de urmatoarea baleiere a stergatoarelor trece maneta pe pozitia "baleiaj intermitent" si o lasa acolo, fara a o mai trece in pozitia oprit. Acum modulul care a memorat intervalul de timp trecut de la primul impuls si momentul in care s-a trecut maneta pe pozitia "baleiaj intermitent" va repeta intervalul de timp programat pana se modifica pozitia manetei de comanda in alta stare decat "baleiaj intermitent". Pentru inspiratie tin sa multumesc userilor adi_stezar, FRATELLO, hash, mariuscond, marian_ariciuc, bygy007 , DerBaum, unii de pe forumul concurent, unii de pe forumul asta, iar ultimul de pe forumul german dacianer.de. O particularitate a schemei este data de faptul ca la noul Logan (modelul dupa 2013) comanda electronica a "baleiajului intermitent" se face prin aplicarea unui semnal negativ (masa) pe intrarea de comanda a stergatoarelor din UCH - pinul A7 din conectorul negru, fata de Logan PH1 si PH2 la care activarea se face prin aplicarea unui semnal pozitiv (+12V). Modulul de monteaza prin conectarea in apropiere de mufa manetei de comanda a stergatoarelor. Accesul la mufa maro de conectare se face prin demontarea cochilei superioare a volanului. Din mufa maro se folosesc firele 1, 3 si 7 pentru conectare astfel: in paralel cu firul negru 7 se conecteaza firul de masa, in paralel cu firul galben 3 se conecteaza firul de alimentare +12V a modului, iar firul gri 1 se taie la o distanta convenabila de mufa, capatul dinspre mufa se leaga la intrarea modului iar capatul dinspre manunchiul de fire (spre A7-UCH) se leaga la iesirea modului. Pentru amplasarea modulului sunt necesare fire de conexiune de aproximativ 15... 20 cm, acesta avand loc in spatele mufei, in dreapta coloanei volanului. Intrucat curentii si tensiunile din modul sunt mici acesta nu se incalzaste in functionare, nu sunt necesare masuri speciale pentru disiparea caldurii. Pentru impiedicarea aparitiei "greierilor" recomand ambalarea modului cu un burete, folie, fonomin etc. Atentie la izolarea conexiunilor electrice! Fisierul hex folosit in programarea microcontrolerului l-am obtinut prin compilarea fisierului sursa asm pentru care multumesc userului hash. Modulul l-am montat si functioneaza fara probleme. Sper sa fie de ajutor si altora. schema_electrica.png ( Size: 28.28k ) Number of downloads: 191 Image1.jpg ( Size: 51.63k ) Number of downloads: 199 Image2.jpg ( Size: 51.93k ) Number of downloads: 150 Image3.jpg ( Size: 52.81k ) Number of downloads: 145 Image4.jpg ( Size: 40.48k ) Number of downloads: 139 Image5.jpg ( Size: 33.69k ) Number of downloads: 92 Image6.jpg ( Size: 27.15k ) Number of downloads: 97 Image7.jpg ( Size: 11.3k ) Number of downloads: 100 ![]() This post has been edited by ctropett: 23 Apr 2016, 20:12 |
Hyundai / Dacia
Tucson / Logan 2
2007 / 2015
FlorinMANEA |
#358
Membru incepator Group: Members Posts: 12 Joined: 23 June 08 ![]() |
Salut,
Vreau si eu sa montez temporizatorul pt parbriz dar nu depistez deloc pinul pentru comanda. Daca pt luneta l-am depistat babeste, cu 12v pe pinii mufei, luati la rand, pe cel de parbriz nu l-am gasit! Am depistat doi pini, corespunzatori pt vit1 si vit2, se misca stergatoarele dar nu se mentine cursa. Daca iau 12v, stergatoarele se opresc in pozitia curenta, nu revin la baza. La cel de pe luneta, la un impuls de 12v, acesta face o cursa completa. Cum sa fac?Unde gresesc? Multumesc PS: Probele le-am facut direct pe mufa de la maneta stergator. Si nu bag mana in foc, dar am vazut si -12V prin mufa aia. Masina e logan mcv dci/2008. This post has been edited by FlorinMANEA: 20 Feb 2018, 11:54 |
Logan MCV, DCi, 85CP
2008, Laureate 5 locuri
#359
aici ai un pdf cu explicatii destul de amanuntite eu dupa ala m-am luat , si in prezent montajul functioneaza ok
- B 07 BGY
FlorinMANEA |
#360
Multam mult.
O sa incerc diseara cand ajung. Dar stiu sigur ca am pus 12 v pe A1si nu s-a intamplat nimic.Se aude un tzac undeva si atata.Cred ca mai trebuie un contact ceva undeva. La mcv am conectorul de la stergator plin de fire! Dar nu ma las. !!!!!!!!!!!!!!!!!!!!!! Ce tare! Am reusit!! Multumesc mult pentru instructiunile atasate, fara ele nu ii dadeam de cap! Daca pentru stergatorul de la luneta era de ajuns un impuls de 12V pt o tura completa, pt cel de parbriz era nevoie ca maneta sa fie in poz 1 iar eu faceam probele cu mufa scoasa. O sa pun temporizator si pe fata si pe spate, daca tot sunt la capitolul acesta. O sa revin cu detalii. This post has been edited by FlorinMANEA: 21 Feb 2018, 22:16 |
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 9th September 2025 - 18:00 |
