[VAND]Vand piese SuperNova
AndreiSN |
![]() Membru autentic Group: Members Posts: 799 Joined: 20 December 10 From: Bucuresti ![]() |
Supernova
2001 Confort
AndreiSN |
!! UP !!
Supernova
2001 Confort
B_i_t_z_a |
![]() Membru autentic Group: Members Posts: 745 Joined: 8 May 09 From: The Land Of Opportunities ![]() |
Proietor fata stanga?
SuperNova
2003 Clima
- BH-85-BIT
AndreiSN |
Nup , sorry
Supernova
2001 Confort
t3r0r1s7u |
Membru t3r0r1s7 Group: Members Posts: 238 Joined: 21 March 10 ![]() |
pompa de benzina ai dat-o?
SuperNova
2001 1.4 Clima
- B 173 ROR
AndreiSN |
Salut , Pompa de benzina nu este.
Supernova
2001 Confort
AndreiSN |
up !!
Supernova
2001 Confort
aurelyan |
![]() Membru cu familie Group: Members Posts: 1.280 Joined: 20 June 09 From: Iasi ![]() |
Salut, ma intereseaza capacul de plastic de la distributie, sa nu aiba urechile de prindere crapate sau rupte. Ms.
Focus Mk3
2012 - 1.6 16v Ti-VCT Imbatranesc si tot invat - Eschil
AndreiSN |
Nu exista , am doar ce este in lista.
17 May 2011, 17:51: UP !! Injectoare 50 RON BUCATA ( am 4 BUCATI ) RAMPA 50 ron Regulator presiune 100 ron Compresor AC ( doar compresorul ) ( 100 ron ) Placa presiune - 100 ron Disc ambreiaj - 100 ron Canistra carbon - 50 ron Senzor temperatura apa - 30 ron Planetara stanga - scurta - 100 ron Planetara dreapta - lunga - 100 ron Grila dintre faruri culoare verde ( 20 ron ) Instalatie electrica ( 50 ron ) Fulie - 100 ron UCE - 50 ron Sonda Lambda - 30 ron Vas expansiune - 30 ron Nou ! - Conducte frana pentru rotile din fata ( Conductele sunt din Cupru ) Conducta Roata stanga 20 Ron Conducta Roata dreapta 30 Ron 12 May 2011, 10:38: UP !!! Se mai adauga un sistem de inchidere capota - Clanta de care tragi sa deschizi capota ( cea prinsa pe capota carigul ala ) - Cuiul - Si partea de jos in care intra cuiul 50 Ron toate 18 May 2011, 16:26: UPPP This post has been edited by AndreiSN: 18 May 2011, 16:26 |
Supernova
2001 Confort
Mikey26 |
Membru incepator Group: Members Posts: 1 Joined: 18 May 11 ![]() |
Salut.
Ma intereseaza si pe mine compresorul AC si planetara dreapta ( lunga ). Preturile si piesele mai sunt valabile? 0722829673 Bogdan Daca mai sunt valabile, da-mi un bip si te sun eu . Vin eu dupa piese. Mersi. Salut |
SuperNova Clima
AndreiSN |
Da , am vorbit la telefon.
<span class='edit'>19 May 2011, 21:21:</span> UP !! Injectoare 50 RON BUCATA ( mai sunt 2 bucati ) RAMPA 50 ron Regulator presiune 100 ron Compresor AC ( doar compresorul ) ( 100 ron ) - rezervat mikey Placa presiune - 100 ron Disc ambreiaj - 100 ron Canistra carbon - 50 ron Senzor temperatura apa - 30 ron Planetara stanga - scurta - 100 ron Planetara dreapta - lunga - 100 ron - rezervat mikey Grila dintre faruri culoare verde ( 20 ron ) Instalatie electrica ( 50 ron ) Fulie - 100 ron UCE - 50 ron Sonda Lambda - 30 ron Vas expansiune - 30 ron Nou ! - Conducte frana pentru rotile din fata ( Conductele sunt din Cupru ) Conducta Roata stanga 20 Ron Conducta Roata dreapta 30 Ron Sistem inchidere capota - Cuiul - Si partea de jos in care intra cuiul 30 Ron toate Ma intereseaza o plafoniera de logan cu 3 becuri , dau la schimb cu piesele de aici , de ex: o sonda lambda , un vas expansiune ceva ... This post has been edited by AndreiSN: 19 May 2011, 21:41 |
Supernova
2001 Confort
AndreiSN |
UP !!!
Compresorul de aer nu mai este. |
Supernova
2001 Confort
AndreiSN |
UP !!!
Ma mai intereseaza si o pereche de oglinzi de SLZ , sa le pun pe supernova. Reglaj manual din interior de preferat. Injectoare 50 RON BUCATA ( mai sunt 2 bucati ) RAMPA 50 ron Regulator presiune 100 ron Compresor AC ( doar compresorul ) ( 100 ron ) - rezervat mikey Placa presiune - 100 ron Disc ambreiaj - 100 ron Canistra carbon - 50 ron Senzor temperatura apa - 30 ron Planetara stanga - scurta - 100 ron Planetara dreapta - lunga - 100 ron - rezervat mikey Grila dintre faruri culoare verde ( 20 ron ) Instalatie electrica ( 50 ron ) Fulie - 100 ron UCE - 50 ron Sonda Lambda - 30 ron Vas expansiune - 30 ron Nou ! - Conducte frana pentru rotile din fata ( Conductele sunt din Cupru ) Conducta Roata stanga 20 Ron Conducta Roata dreapta 30 Ron Sistem inchidere capota - Cuiul - Si partea de jos in care intra cuiul 30 Ron toate Ma intereseaza o plafoniera de logan cu 3 becuri , dau la schimb cu piesele de aici , de ex: o sonda lambda , un vas expansiune ceva ... This post has been edited by AndreiSN: 23 May 2011, 10:44 |
Supernova
2001 Confort
AndreiSN |
SUSSSSSSS
Supernova
2001 Confort
AndreiSN |
UP UP UP
Supernova
2001 Confort
AndreiSN |
UP !!!
Supernova
2001 Confort
AndreiSN |
Uppppppp
Supernova
2001 Confort
AndreiSN |
Injectoare 50 RON BUCATA ( mai sunt 2 bucati ) RAMPA 50 ron Regulator presiune 100 ron Compresor AC ( doar compresorul ) ( 100 ron ) - rezervat mikey Placa presiune - 100 ron Disc ambreiaj - 100 ron Canistra carbon - 50 ron Senzor temperatura apa - 30 ron Planetara stanga - scurta - 100 ron Planetara dreapta - lunga - 100 ron - rezervat mikey Grila dintre faruri culoare verde ( 20 ron ) Instalatie electrica ( 50 ron ) Fulie - 100 ron UCE - 50 ron Sonda Lambda - 30 ron Vas expansiune - 30 ron Nou ! - Conducte frana pentru rotile din fata ( Conductele sunt din Cupru ) Conducta Roata stanga 20 Ron Conducta Roata dreapta 30 Ron Sistem inchidere capota - Cuiul - Si partea de jos in care intra cuiul 30 Ron toate Ma intereseaza o plafoniera de logan cu 3 becuri , dau la schimb cu piesele de aici , de ex: o sonda lambda , un vas expansiune ceva ... Sus Sus Sus , nu vrea nimeni grila ? ca ma apuc sa o tai sa o vopsesc alb si ii pun plasa ![]() ![]() |
Supernova
2001 Confort
valystfl |
Membru incepator Group: Members Posts: 10 Joined: 19 August 10 ![]() |
sal,planetara stg e ok?,adica nu bate sau troncane ceva pe la ea,la asta ma refer
supernova
2001,model confort
- DB07UJK
AndreiSN |
Salut , planetara stanga nu a fost pe masina sa stiu daca bate , dar la mana pare ok nu are joc.
Supernova
2001 Confort
AndreiSN |
upp
Supernova
2001 Confort
george_scala_2004 |
QUOTE(AndreiSN @ 2 Jun 2011, 09:29) Ma mai intereseaza si o pereche de oglinzi de SLZ , sa le pun pe supernova. Reglaj manual din interior de preferat. oglinzi ![]() |
- Antonio Gramsci. |
AndreiSN |
#53
Sunt de logan nu de slz , au capacul exterior rotund nu triunghi , nu pica pe caroserie cum trebuie
Supernova
2001 Confort
george_scala_2004 |
#54
si nu se pot adapta ?
AndreiSN |
#55
Nu stiu , si oricum 150 ron mi se pare cam mult
![]() 5 Jun 2011, 21:57: UP 6 Jun 2011, 21:36: upp This post has been edited by AndreiSN: 6 Jun 2011, 21:36 |
Supernova
2001 Confort
AndreiSN |
#56
uppppppp
Supernova
2001 Confort
AndreiSN |
#57
!! UP !!
Supernova
2001 Confort
AndreiSN |
#58
UPPP
Supernova
2001 Confort
AndreiSN |
#59
Injectoare 50 RON BUCATA ( mai sunt 2 bucati ) RAMPA 50 ron Regulator presiune 100 ron Compresor AC ( doar compresorul ) ( 100 ron ) - rezervat mikey Placa presiune - 100 ron Disc ambreiaj - 100 ron Canistra carbon - 50 ron Senzor temperatura apa - 30 ron Planetara stanga - scurta - 100 ron Planetara dreapta - lunga - 100 ron - rezervat mikey Grila dintre faruri culoare verde ( 20 ron ) Instalatie electrica ( 50 ron ) Fulie - 100 ron UCE - 50 ron Sonda Lambda - 30 ron Vas expansiune - 30 ron Nou ! - Conducte frana pentru rotile din fata ( Conductele sunt din Cupru ) Conducta Roata stanga 20 Ron Conducta Roata dreapta 30 Ron Sistem inchidere capota - Cuiul - Si partea de jos in care intra cuiul 30 Ron toate Ma intereseaza o plafoniera de logan cu 3 becuri , dau la schimb cu piesele de aici , de ex: o sonda lambda , un vas expansiune ceva ... Sus Sus Sus , nu vrea nimeni grila ? ca ma apuc sa o tai sa o vopsesc alb si ii pun plasa tongue.gif , si apoi am sa vand una neagra biggrin.gif originala bineinteles cea care va ramane This post has been edited by AndreiSN: 13 Jun 2011, 19:03 |
Supernova
2001 Confort
AndreiSN |
#60
uppp
Supernova
2001 Confort
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 14th July 2025 - 05:57 |
