cod radio- casetofon / radio-cd
Iulikk |
#241
Autoturism
visiniu
cu roti
beni1906 |
#242
Membru incepator Group: Members Posts: 6 Joined: 16 February 13 ![]() |
A mers 8388. Mersi mult maskatu. Tot respectul!
Laguna II
Maskatu |
#243
Cu placere.
![]() This post has been edited by Maskatu: 23 Feb 2013, 14:10 |
0.9 TCE - 2019
marianmrn |
#244
Membru incepator Group: Members Posts: 3 Joined: 17 March 13 ![]() |
MODEL NO:22DC239/62
TOU066 RN239F30027959 PROD NO:FD0203230027959 8200057672TU066 8200 057 672 --D |
2003 scala
Maskatu |
#245
incearca 5926
0.9 TCE - 2019
marianmrn |
#246
Multumesc mult Maskatu
2003 scala
marianmrn |
#247
Model no:22dc229/62
Prod no:fd0805220301920 RN229f50301920 8200057676 8200057676--E |
2003 scala
#248
ca samsarii, vorba aia, un casetofon pe saptamana...
Maskatu |
#249
Are doua solenze si a pierdut factura la ambele. Si eu am pierdut scurtatura de la program....
0.9 TCE - 2019
petre15 |
#250
Membru incepator Group: Members Posts: 1 Joined: 26 March 13 ![]() |
Salut Klaus ma poti ajuta si pe mine cu un cod la o solenza
MODEL NO:22DC229/62 TF619 RN229F30170529 PROD NO:FD0503400170520 820057676--E |
2003 clima
Maskatu |
#251
Pana nu pui o poza cu talonul sau cartea de identitate, sau dupa factura, nu te poate ajuta. Si nu mai scrie mai multe posturi despre aceeasi problema ca iei ban.
0.9 TCE - 2019
Coo |
#252
Membru incepator Group: Members Posts: 10 Joined: 6 April 13 ![]() |
Va rog si eu am un casetofon de Solenza codat. Pe cartea aia a lui scrie ca parola aceea este : "Sparta" dar mie mi'o cere in continuare...
Model No : 22DC229/62 Prod No : FD0402480111232 TOL559 RN229F20111232 8200 057 676--D Am rezolvat chestia asta... Acum am o noua problema. This post has been edited by Coo: 6 Apr 2013, 19:35 |
2004- Rapsodie
- Secret
leone_1901 |
#253
Membru incepator Group: Members Posts: 4 Joined: 21 March 13 ![]() |
6 Apr 2013, 19:11: va rog AJUTOR pt acest model...(RENAULT 8200 354 519) RNRD8260121445 RENRDD200-09 BS0006230121445 multumesc anticipat ![]() 6 Apr 2013, 19:22: rog ajutor cod pt acest model RENAULT 8200 354 519 RNRD8260121445 RENRDD200-09 BS0006230121445 MULTUMESC This post has been edited by leone_1901: 6 Apr 2013, 19:22 |
1995 berlina
Coo |
#254
QUOTE(eXistenZ_Tg @ 1 Feb 2011, 18:16) buna tuturor , am o ciudata problema si anume , am un radio casetofon tuner list pe supernova , si am fost azi sa rezolv o garantzie cu bateria auto , asa ca , cand am plecat mi-a cerut codul , il am dar nu era la mine si am bagat gresit si imi aparea "CODE" , am ajuns acasa l-am kuat sus , l-am alimentat si tot asa , am citi aici pe topic cum ca ar trebuii sa apas 2 si 5 inainte sa il pornesc , am facut si surpriza , merge , am coborat la masina si cand il alimentez a pornit radioul dar e o mica problema , la fiecare 2 secunde imi trece pe mute si se aude un beep in boxe apoi iara canta , tine asa cam vreo 3 minute apoi imi apare 0000 , ii bag codul din nou si imi zice "OTHERS" habar nu am ce inseamna si ce face , ori ce apas nu merge daca il opresc si il pornesc iara canta la radio si iara trece pe mute si face beep , si tine iara vreo 3 minute si iara imi cere codul , si pana la adanci batranetzi probabil ca face asa , are cineva idee ce sa fac sau ce idei avetzi? QUOTE(ZLATE58 @ 1 Feb 2011, 19:00) apasa de mai multe ori pe 6 pina porneste aparatul prima data apare others apoi altceva si iar altceva sa mai departe Am incercat si eu asa... Dar la mine daca las radio'ul inchis si apas de mai multe ori pe 6 nu se aprinde. Va rog ajutati'ma! |
2004- Rapsodie
- Secret
Iulikk |
#255
TINE APASAT PE 6 pana incepe sa cante.
Autoturism
visiniu
cu roti
Coo |
#256
2004- Rapsodie
- Secret
Iulikk |
#257
Eu am bagat codul, am tinut apasat pe 6 si dupa aia a inceput sa cante cd-playeru.
Autoturism
visiniu
cu roti
george_scala_2004 |
#258
ATENȚIE
După introducerea pentru prima dată a codului de securitate și validarea acestuia, pe afișaj va apărea mesajul OTHERS. În continuare va trebui să apăsați pentru 5 secunde tasta 6 pentru a valida acest mesaj. Apoi pe afișaj va apare mesajul CURVE pe care va trebui să-l validați apăsând tasta 6 pentru 5 secunde. Va apărea apoi mesajul REAR ON pe care îl validați apăsînd tasta 6 pentru 5 secunde. După ce ați efectuat aceste operațiuni, aparatul va funcționa normal. Dacă în urma întreruperii alimentării aparatului va trebui să introduceți din nou codul de securitate, nu va mai fi necesară efectuarea validării mesajelor OTHERS CURVE și REAR ON deoarece acestea nu vor mai apărea pe afișaj. IMPORTANT Dacă codul introdus nu este corect, veți auzi un semnal de avertizare, iar pe afișaj va apărea mesajul CODE. Pentru a efectua o nouă încercare de introducere a codului de securitate lăsați aparatul sub tensiune și efectuați din nou operațiunile de introducere a codului după 1 minut de la prima încercare. Dacă această nouă tentativă eșuează, puteți repeta operațiunile de introducere a codului lăsând aparatul sub tensiune, dar timpul de așteptare va crește la 4, 8, 16 și 32 minute. http://daciaclub.tehnoplus.net/DaciaClub/D...28romana%29.pdf This post has been edited by george_scala_2004: 6 Apr 2013, 21:26 |
- Antonio Gramsci. |
Coo |
#259
QUOTE(Iulikk @ 6 Apr 2013, 20:25) Am facut si eu asa... Si face precum colegului mentionat mai sus...Adica, canta 2-3 secunde, dupa care se da mute si se aude un bip, dupa care incepe iar sa cante 2-3 secunde, dupa care iar se aude bip si tot asa... Maine am sa mai incerc odata... Am sa revin sa va spun daca am reusit ceva... ![]() This post has been edited by Coo: 6 Apr 2013, 21:44 |
2004- Rapsodie
- Secret
Iulikk |
#260
Are la Carrefour, player cu slot USB si card de memorie cu 100 de lei. Pisa-te pe el de casetofon original.
Autoturism
visiniu
cu roti
george_scala_2004 |
#261
si cu alade pemasina ce sa faca? in afara de a se***a pe el? sau poate ca nu are nevoie de altul sau nu are bani de altul...
Coo |
#262
@george_scala_2004
@Iulikk Va multumesc enorm pentru ajutor. Am rezolvat. >:D< Dar acum am o mica intrebare... Totul merge ok, doar ca o parte de la casetofon se infierbanta foarte tare... Acea parte este din cupru (POZA) Este normal sa se infierbante asa sau e vre'o problema de la mine? Astept un raspuns. Attached thumbnail(s) 668126992482702449190750_4623201_700_700.jpg ( Size: 34.62k ) Number of downloads: 440 |
2004- Rapsodie
- Secret
nikuniku |
#263
e normal sa se incalzeasca,dar daca frige tare ai o problema la boxe,sunt de putere prea mare sau una este pe duca
opel zafira
f75
1.6-16valve
Coo |
#264
2004- Rapsodie
- Secret
leone_1901 |
#265
revin shi eu cu rugamintea unui cod...
S.O.S....... |
1995 berlina
Maskatu |
#266
3736
0.9 TCE - 2019
leone_1901 |
#267
chiar nu ma poate ajuta shi pe mine nimeni?
am luat un cd de la un prieten ,mi-a dat shi codul dar nu merge Attached thumbnail(s) IMG355.jpg ( Size: 611.03k ) Number of downloads: 355 |
1995 berlina
Maskatu |
#268
AM SCRIS MAI SUUUUUS!!!! NU VEZIIII?????
0.9 TCE - 2019
leone_1901 |
#269
scuzee
![]() MS MS MULT ESHTI UN DOMN ![]() |
1995 berlina
80T |
#270
Membru incepator Group: Members Posts: 2 Joined: 25 April 13 ![]() |
Salut. Am la munca o Dacia papuc (chinuita de vai mama ei...) cu un radiocasetofon stoc. Am luat datele de pe eticheta ieri cand am gasit topicul pe net.
Model: Philips 22DC229/62 TOK244 RN229F30139465 Prod No. FD0403170139465 8200057676TK244 8200 057 676 | --D Mersi anticipat daca ma puteti ajuta. This post has been edited by 80T: 25 Apr 2013, 17:11 |
nici una
N/A
N/A
- N/A
DaciaClub - Reno Bot |
![]() Mesaj automat ![]() |
Dragi concetateni. Pentru a putea primi codul de deblocare al casetofonului, trebuie sa faceti dovada ca sunteti propietarul masinii. Cum de cele mai multe ori masina pe care urmeaza sa fie pus este fie solenza fie super nova, fie logan, este suficienta o poza cu talonul sau cartea masinii. Puteti blura datele personale. Daca masina este alta marca este suficienta o poza cu interiorul masinii in care sa apara casetofonul in cauza.
Aceasta masura vine pentru a preveni furtul de casetofoane si a descuraja aceasta infractiune. Dacia club nu isi asuma responsabilitatea pentru eventuala defectiune a casetofonului ori a altor echipamente, survenite in urma manevrarii necorespunzatoare a casetofonului sau a introducerii codului gresit, rezultand in blocarea acestuia. |
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 12th July 2025 - 09:32 |
