cod radio- casetofon / radio-cd
Mytusin |
#331
![]() Membru incepator Group: Members Posts: 3 Joined: 16 August 14 ![]() |
DACIA LOGAN
suchea |
#332
![]() Membru autentic Group: Members Posts: 584 Joined: 7 March 09 From: Galați ![]() |
MA AJUTATI SI PE MINE.......
Model no. 22DC229/62 TOK289 RN229F20109428 Prod no. FD0402460109428 8200057676TK289 8200 057 676 --D This post has been edited by suchea: 23 Aug 2014, 18:16 |
SuperNova
2001/confort
- GL 61 TES http://www.daciaclub.ro/index.php?showtopic=259258&hl=
Maskatu |
#333
5573
0.9 TCE - 2019
suchea |
#334
Merci Maskatu
SuperNova
2001/confort
C O S T I |
#335
![]() Membru incepator Group: Members Posts: 76 Joined: 7 February 08 ![]() |
Noroc. Se poate un ajutor si pentru mine ?
este radio cd pentru Duster si are urmatoarele serii: 7 648 051 592 FD108 905 BP8051 B 2540193 281115428RT F865 SECURITY |
2006-laureat dci [B]dacia[/B][U]
Maskatu |
#336
2716.
0.9 TCE - 2019
C O S T I |
#337
Multumesc. Asa este. Am gasit azi si eu locul unde lipise-m eticheta cu codul
OPELTUNING |
#338
Membru incepator Group: Members Posts: 4 Joined: 29 March 09 ![]() |
Salutare am nevoie de cod la cd ul din masina personala Sandero, an 2012.
Atasez seria de caroserie si eticheta de pe cd. Multumesc Attached thumbnail(s) DSC_1158.JPG ( Size: 1.58mb ) Number of downloads: 299 DSC_1160.JPG ( Size: 1.69mb ) Number of downloads: 290 |
renault
clio
OPELTUNING |
#339
Salutare, ma poate ajuta cineva sau nu? Multumesc
renault
clio
Maskatu |
#340
Ar trebui ceva cu security... nu prea imi dau seama din toate codurile care ar fi.
0.9 TCE - 2019
kingviper |
#341
![]() - Group: Members Posts: 301 Joined: 4 May 08 From: Bucuresti, Berceni ![]() |
Codul e 5592
This post has been edited by kingviper: 9 Oct 2014, 10:55 |
2005, Confort
- B 4* ***
Gorilla |
#342
Membru incepator Group: Members Posts: 4 Joined: 3 February 15 ![]() |
Ajutati-ma si pe mine, am uitat codul de la casetofon dupa ce am ramas fara baterie.
Si daca puteti sa ma ajutati sa conectez inca doua boxe, adica sa mai pun doua boxe pe spate cum fac ? Attached thumbnail(s) 10961837_806341169437062_560440274_n.jpg ( Size: 64.25k ) Number of downloads: 213 10967993_806341172770395_223564187_n.jpg ( Size: 85.78k ) Number of downloads: 208 |
- B 27 SYM
sorinnx2 |
#343
Membru incepator Group: Members Posts: 55 Joined: 22 March 14 ![]() |
Poti conecta 4 boxe la casetofon doar daca mufa este prevazuta cu 4 intrari de boxe .
Nu cunosc exact daca la solenza au fost 4 iesiri din fabrica sau 2 (dar cu posibilitate sa pui 4 , schimband mufa ) dar poti sa verifici astfel : mufa are 2 parti , o parte de alimentare , de obicei cu fire de culorile astea : rosu - 12v dupa contact , galben-12v permanent si negru-masa si inca o parte in care sunt 8 fire sau 4 ( depinde de treaba de mai sus ) . Daca sunt 8 fire te uiti unde pleaca cele 4 care nu sunt de la boxele fata si e usor de acolo . Daca sunt 4 fire si nu e loc in mufa de alte 4 (locuri libere ) trebuie schimbata mufa . |
kingviper |
#344
2005, Confort
- B 4* ***
Gorilla |
#345
BAnuiesc ca asta trebuie sa adaug..
4 Feb 2015, 10:01: Vreau sa fac o improvizatie.. Sa scot mufa jack, si sa lipesc la firele existente alte fire care duc la cele doua boxe din spate This post has been edited by Gorilla: 4 Feb 2015, 10:01 Attached thumbnail(s) 10969416_806819132722599_1921229848_o.jpg ( Size: 90.26k ) Number of downloads: 180 |
- B 27 SYM
Maskatu |
#346
Incearca 6734.
0.9 TCE - 2019
Gorilla |
#347
Revin in 10 minute cu un raspuns.
4 Feb 2015, 10:21: Da a mers codul, multumesc mult. Astea sunt mufele din casetofon.. This post has been edited by Gorilla: 4 Feb 2015, 10:21 Attached thumbnail(s) 10955968_806825599388619_1156374880_n.jpg ( Size: 87.05k ) Number of downloads: 41 10961848_806825596055286_1800378769_n.jpg ( Size: 73.96k ) Number of downloads: 34 |
- B 27 SYM
kingviper |
#348
QUOTE(Gorilla @ 4 Feb 2015, 09:53) BAnuiesc ca asta trebuie sa adaug.. <span class='edit'>4 Feb 2015, 10:01:</span> Vreau sa fac o improvizatie.. Sa scot mufa jack, si sa lipesc la firele existente alte fire care duc la cele doua boxe din spate Abia acum am ajuns iar pe forum. Asa da domne, se vede dovada ![]() ![]() Referitor la boxe: el parca scoate doar 2 boxe, nu? Daca tot vrei sa mai pui inca 2 boxe (cu riscul de a forta player-ul), vezi ca din mufa de sub bord din stanga (aia mare cu enspe mii de fire), pleaca boxele fata (de acolo m-am legat eu la boxele spate, cand am pus pe spate dar cu player care suporta 4 boxe). Pana acolo aveam fire din instalatia masinii. De acolo nu mai iesea nimic. Afla care-s firele care pleaca spre boxe si mai te lipesti la pinii respectivi cu fire si pentru boxele spate. Grija mare sa nu fortezi player-ul. Nu de altceva, dar dupa ce muncesti sa tragi fire, sa lipesti etc, sa pornesti muzica, ca la disco si sa iasa fum din player. Nu cred ca vrei asta ![]() This post has been edited by kingviper: 4 Feb 2015, 11:53 |
2005, Confort
- B 4* ***
Gorilla |
#349
Salut, am reusit sa fac boxele pe spate, numai ca am gost tras in piept cu metrii de la cablu si acum e prea scurt da se rezolva
![]() Cum fac cu mufa jack.. ? la ce pini trebuie sa ma uit ? Alternative daca nu se poate ? Caseta..sau altceva ? |
- B 27 SYM
kingviper |
#350
Vezi ca exista caseta adaptoare cu jack
![]() 61d49a888cfbd6bb55bc9ad76b39fc51_large.jpg Bagi caseta in casetofon si bagi muzica din telefon. Cea mai simpla optiune si relativ ieftina, chiar si pe la 20 lei gasesti. Vezi o*x, to*mai. This post has been edited by kingviper: 6 Feb 2015, 19:21 |
2005, Confort
- B 4* ***
danygaro |
#351
![]() Membru autentic Group: Members Posts: 529 Joined: 19 October 04 ![]() |
Pentru un Logan MCV al carui radio s-a resetat (bateria busita), se poate afla codul ?
Ce date sunt necesare ??? |
2003 - Confort - Lot refuzat la export
- CT-96-PIX Ce cate ori mergi cu Dacia, este ca si cand te-ai da intr-un Roller Coaster sau Mountagne Rousse. Niciodata nu stii ce te asteapta, este mereu imprevizibila, de fiecare data traiesti senzatii noi si necunoscute, iar la final poti avea fel de fel de surprize.
Cu prostul nescolarizat, te lupti un pic si ai scapat, Dar duci o munca colosala, cu prostul care are scoala. |
Maskatu |
#352
Seriile.
0.9 TCE - 2019
mihailaurentiu |
#353
Membru incepator Group: Members Posts: 2 Joined: 25 February 15 ![]() |
salut cine ma poate ajuta si pe mine cu un cod la cesetofon de logan.RNRC2550030227. RENRCD200-00. FD0305500030227. 820354517T. R044.Din ce retin codul ar fi trebuit sa fie 8989 dar nu merge
This post has been edited by mihailaurentiu: 26 Feb 2015, 14:27 |
- db 16 trf
george_scala_2004 |
#354
da, asa e: 8989...
![]() This post has been edited by george_scala_2004: 25 Feb 2015, 19:22 |
- Antonio Gramsci. |
mihailaurentiu |
#355
pai si atunci care sa fie problema?dupa ce bag codul si imi da error dupa 90 sec ma pune sa bag codul din nou
This post has been edited by mihailaurentiu: 26 Feb 2015, 12:55 |
- db 16 trf
george_scala_2004 |
#356
daca a fost introdus gresit trebuie asteptat o perioada...nu mai stiu cit...scrie in manual...daca nu vrea nu stiu de la ce ar putea fi...niste electronisti mai priceputi ar putea sa rezolve problema...
gedac2000 |
#357
Membru incepator Group: Members Posts: 3 Joined: 24 March 15 ![]() |
Buna ziua!
Am si eu probleme cu gasirea codului pentru radiocasetofonul de pe Solenza (am revenit dupa lung timp la casetofonul original...) MODEL NO: 22DC229/62 L259 Security RN229F50273858 PROD NO: FD0805100273858 8200057676TL259 Attached thumbnail(s) asigurare_RCA.png ( Size: 1.69mb ) Number of downloads: 52 |
2000
espacern |
#358
![]() ART-ist Group: Moderatori Posts: 17.610 Joined: 14 August 09 From: Mihalaya ![]() |
@gedac=3579
- . RENAULT are mistere pe care OMUL nu va reusi niciodata sa le afle!
dodowajda |
#359
Membru incepator Group: Members Posts: 1 Joined: 12 March 15 ![]() |
Buna! Ma ajuta si pe mine cineva cu un cod pentru un cd player? Este pentru o Solenza din 2003. Atasat gasiti o poza cu codurile de pe cd player respectiv talonul masini. Multumesc mult!
25 May 2015, 11:05: Buna! Ma ajuta si pe mine cineva cu un cod pentru un cd player? Este pentru o Solenza din 2003. Atasat gasiti o poza cu codurile de pe cd player respectiv talonul masini. Multumesc mult! This post has been edited by dodowajda: 25 May 2015, 11:05 Attached thumbnail(s) IMAG0881.jpg ( Size: 1.63mb ) Number of downloads: 43 IMAG0880.jpg ( Size: 1.9mb ) Number of downloads: 46 |
Solnza
#360
eu as incerca 8206
DaciaClub - Reno Bot |
![]() Mesaj automat ![]() |
Dragi concetateni. Pentru a putea primi codul de deblocare al casetofonului, trebuie sa faceti dovada ca sunteti propietarul masinii. Cum de cele mai multe ori masina pe care urmeaza sa fie pus este fie solenza fie super nova, fie logan, este suficienta o poza cu talonul sau cartea masinii. Puteti blura datele personale. Daca masina este alta marca este suficienta o poza cu interiorul masinii in care sa apara casetofonul in cauza.
Aceasta masura vine pentru a preveni furtul de casetofoane si a descuraja aceasta infractiune. Dacia club nu isi asuma responsabilitatea pentru eventuala defectiune a casetofonului ori a altor echipamente, survenite in urma manevrarii necorespunzatoare a casetofonului sau a introducerii codului gresit, rezultand in blocarea acestuia. |
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 12th July 2025 - 21:31 |
