12 Pages « < 8 9 10 11 12 >
> [VAND] Piese si accesorii de origine, peste 100.000 de repere
stef_x
post 20 Sep 2012, 15:01
Post #271
catalizator de dacie pe injectie euro 2 ai si la ce pret???
Dacia Break 2001 - MM02TFR
chroma
post 20 Sep 2012, 18:39
Post #272
pt gama dacia nu am piese decat pt dacia 2004-> (logan....)
nu mai am nimic mai jos de logan
dacia sandero 2008 under construction
dean35
post 21 Sep 2012, 20:52
Post #273
cheder intre faruri sub capota motor-renault symbol 2008...1,4 8v?si pasla capota motor interior?{vine iarna..} rolleyes.gif
renault symbol 2008 - bucuresti-ora exacta
boaingboaing
post 22 Sep 2012, 01:58
Post #274
kit distributie + pompa apa - clio2 2005 1.5 dci k9k700
fulie arbore cotit?
renault clio 2 2005
chroma
post 23 Sep 2012, 17:32
Post #275
QUOTE(dean35 @ 21 Sep 2012, 20:52)
cautam
QUOTE(boaingboaing @ 22 Sep 2012, 01:58)
fulie arbore cotit?
un cod vin? VF1......
chroma
post 26 Sep 2012, 17:06
Post #276
up
reducere pt protectii prag megane 2. 70 ron/set 2 buc
chroma
post 29 Sep 2012, 21:57
Post #277
hai sus
gabelu
post 29 Sep 2012, 23:43
Post #278
un pret pentru bavete megane2 fata cod 77 11 221 305 ?
Renault Megane sedan Luxe privilege 2007
chroma
post 2 Oct 2012, 17:05
Post #279
bavete 7711221305 in stoc la 108 ron/set pret raft 124 ron
gabelu
post 5 Oct 2012, 22:35
Post #280
Am gasit la dealer cu 115 ron. Multumesc oricum. Poate alta data.
TM80MAT
post 5 Oct 2012, 22:40
Post #281
Salut . fata de usa stanga logan ph2 sau sandero / duster . pret pt o fata de usa , sau eventual 2 , sa fie perechi , deoarece difera unele in functie de motorizari sau optiuni . Astept un PM . Mersi .
Sper sa nu fac infarct .
This post has been edited by TM80MAT: 5 Oct 2012, 22:41
diverse diverse 2007-2010
chroma
post 7 Oct 2012, 21:41
Post #282
cum adica fata de usa? si exact pt ce masina pt ca difera de la berlina la sandero si duster.
garnitura portiere (panoul interior), oglinzi electrice sau nu, completa (manere, capace difuzoare, ornamente etc) sau doar panoul chel? mai multe detalii te rog
This post has been edited by chroma: 7 Oct 2012, 21:42
Alin_harlley
post 7 Oct 2012, 22:18
Post #283
A-si dori si eu o aferta de preturi pt renault clio symbol 2006 1.5dci 60kw serie VF1LBTE0F35194121
cuzineti biela=121504680R
cuzineti vibro sus=8200859992
cuzineti vibro jos=8200859996
segmenti=120A10282R
7 Oct 2012, 22:23:
biela=7701475074
This post has been edited by Alin_harlley: 7 Oct 2012, 22:23
renault clio symbol 1.5 dci 2006
chroma
post 13 Oct 2012, 15:15
Post #284
QUOTE(Alin_harlley @ 7 Oct 2012, 22:18)
segmenti=120A10282R
<span class='edit'>7 Oct 2012, 22:23:</span>
biela=7701475074
se pot aduce la urmatoarele preturi:
121504680r 400 ron pret raft 422 ron
8200859992 47 ron pret raft 49 ron
8200859996 47 ron pret raft 49 ron
120a10282r 518 ron pret raft 553 ron
7701475074 369 ron pret raft 393 ron
diferenta de pret fiind foarte mica, poti comanda la tine la dealer intrucat nu se justifica factura de transport+taxe din craiova pana la tine
chroma
post 22 Oct 2012, 19:02
Post #285
up
vladadrian
post 22 Oct 2012, 19:13
Post #286
Pt un megane cu seria VF1LMSFC539223109 ma intereseaza kit macara geam fata dreapta. Multumesc anticipat.
Renault Megane Sedan Lux Privillege 2008 1,5 dci, 85 cp
Mariusca-82
post 1 Nov 2012, 09:37
Post #287
Salut. Pentru un Megane 2.2. 2006 1,6 16V VF1LM0C0H36305489 as dori un pret pentru un eleron portbagaj, cod 77 11 223 744.
Renault Mégane 2.2 1.6 16V 2006 - BxxxMFB
chroma
post 8 Nov 2012, 21:47
Post #288
350 ron + taxe livrare, pret dealer 740 ron. o singura bucata in stoc.
Mariusca-82
post 9 Nov 2012, 14:47
Post #289
Eleronul este original sau aftermarket? Din ce material este? Rezista prins doar cu adeziv daca ar trage cineva de el?
This post has been edited by Mariusca-82: 9 Nov 2012, 14:53
chroma
post 12 Nov 2012, 23:08
Post #290
original, din plastic ABS, rezista fara probleme (sunt mult mai mari sansele sa ramai fara el cu prinderea in suruburi deoarece se smulg din plastic. gandeste-te ca in accident parbrizul ramane pe pozitie chiar daca zboara cineva prin el). in plus, folosind kitul de lipire parbriz (baza +adeziv), eleronul nu va mai fi tensionat la variatiile de temperatura (asta insemnand un comportament mai bun al vopselei) si in plus este eliminat riscul coroziunii asupra capotei spate (cu conditia montajului corect, adica lasarea libera a zonelor de scurgere a apei cu care este prevazut eleronul precum si crearea unei suprafete optime de contact a adezivului pe eleron)
biciclist81
post 15 Nov 2012, 19:50
Post #291
cel ce pedaleaza
Eleron pentru Supernova?
dacia supernova clima 2003 - tm 08 kug
chroma
post 16 Nov 2012, 20:14
Post #292
din pacate nimic pt supernova
chroma
post 22 Nov 2012, 18:44
Post #293
up
b14bye
post 22 Nov 2012, 20:58
Post #294
salut caut si eu faruri megane 2.2 cu lupa facelift. ochelarii de far din spatele farurilor.. si suportu de bara care vine prins sub far.
renault megane 2 2007 - b13bye
miezu85
post 23 Nov 2012, 18:18
Post #295
scut motor metalic laguna 2 1.8 16v?
ms
renault laguna 2001 privilege 1.8 16v - VS-04-TGN
CataT
post 23 Nov 2012, 19:47
Post #296
Buna seara!
Rola Intinzator, curea Transmisie (alternator) pentru meganele din semnatura.
VF1LM1R0H37353575
Renault Megane 2 2007 / 1.6 16V
tudorelghiorghiasa
post 2 Dec 2012, 07:40
Post #297
Ai carenaj dreapta renault symbol 2007?
scenic 2000 1.6 16 v peugeot 207 diesel 2007 - IS 09 >>>
RENAULT SCENIC 2000 1.6 16 V
cosmonwo
post 3 Dec 2012, 02:44
Post #298
Salut,
Senzor planeitate fata 82 00 413 466?
Multumesc.
Renault 19 RT '93 F3N740
Megane II.2 Grandtour Dynamique 1.9 dCi FAP 2006
chroma
post 4 Dec 2012, 17:42
Post #299
QUOTE(b14bye @ 22 Nov 2012, 20:58)
nimic
QUOTE(miezu85 @ 23 Nov 2012, 18:18)
ms
din pacate nu
QUOTE(CataT @ 23 Nov 2012, 19:47)
Buna seara!
VF1LM1R0H37353575
in principiu da, astept sa se introduca facturile si fac oferta
QUOTE(tudorelghiorghiasa @ 2 Dec 2012, 07:40)
cautam
QUOTE(cosmonwo @ 3 Dec 2012, 02:44)
Salut,
Multumesc.
nu
prezoane jante tabla noi (set 16 buc) 60 ron/set
prezoane jante aliaj noi (set 16 buc) 75 ron/set
livrare cu posta romana (in jur de 10 ron)
cristianrobert
post 4 Dec 2012, 18:34
Post #300
Salut ai contact rotativ cu spirala airbag de solenza?,
dacia solenza scala 2004 - b
Lo-Fi Version  Harta site  Parteneri  Jocuri online  Curs Valutar  HRH Haine din lana merinos Time is now: 10th May 2025 - 12:48
