[VAND] supape retur DELPHI 9308-621C,, pentru injectoare 1.5dci/logan/megane/ford 1.8
gabriel.cornel |
#211
Membru autentic Group: Members Posts: 847 Joined: 26 August 09 From: Bucuresti ![]() |
MEGANE SEDAN 2.1/
- B 17 GNF
1.5 DCI 2004 74KW
gabriel.cornel |
#212
UP!
MEGANE SEDAN 2.1/
- B 17 GNF
1.5 DCI 2004 74KW
gabriel.cornel |
#213
Supape de retur originale delphi 320 Ron/ buc. fara ambalaj si 340 cu ambalaj.
0722922613 |
MEGANE SEDAN 2.1/
- B 17 GNF
1.5 DCI 2004 74KW
gabriel.cornel |
#214
UP!
MEGANE SEDAN 2.1/
- B 17 GNF
1.5 DCI 2004 74KW
gabriel.cornel |
#215
Supape de retur noi originale Delphi, made in Franta, la cutiuta - 340 Ron / bucata, fara cutiuta- 320 Ron / bucata 0722922613 Nu conteaza ca aveti E3, E4, E5, sau diferite motorizari, 1.5dci, 1.8tdci, 2.0tdci, 2.4tdci, D27DT 2.9 HPDI, sau motoare de diferiti kw. Aceste supape se potrivesc la toate injectoarele Delphi, common rail. Sunt pentru urmatoarele autoturisme care folosesc injectie de tip DELPHI: -> DACIA - Logan 1,5 dCi -> FORD - Focus, Transit Connect, Tourneo Connect - 1,8 TDCi -> MONDEO, TRANSIT – 2,0 TDCi -> HYUNDAI ACCENT 1.5 CRDi -> TRANSIT 2,4 TDCi -> RENAULT - Clio, Kangoo, Megane 2, Scenic, Modus – 1,5 dCi -> KIA - Carnival, Pregio, Bongo, Frontier – 2,9 HPDi -> SSANGYONG - Rodius, Rexton – D27DT -> NISSAN - Almera, Kubistar, Micra – 1,5 dCi -> CITROEN - C3 1,4 HDI -> SUZUKI - Liana 1,4 Ddis ; Jimny 1,5 Ddis -> JAGUAR - X400 2,0 TDCi -> MERCEDES C200, C220,E Klasse -> PEUGEOT 407 Dupa schimbarea supapelor de retur, daca nu schimbati locul injectorului in chiuloasa, nu trebuie sa scrieti codul in calculatorul masinii, nu trebuie centicubat injectorul. Numai bine. |
MEGANE SEDAN 2.1/
- B 17 GNF
1.5 DCI 2004 74KW
gabriel.cornel |
#216
UP!
MEGANE SEDAN 2.1/
- B 17 GNF
1.5 DCI 2004 74KW
gabriel.cornel |
#217
0722922613 |
MEGANE SEDAN 2.1/
- B 17 GNF
1.5 DCI 2004 74KW
gabriel.cornel |
#218
Supape de retur originale Delphi, la cutiuta, cod 28239294 - 320 Ron/bucata + transport
Se vand numai la set - 0724551077 |
MEGANE SEDAN 2.1/
- B 17 GNF
1.5 DCI 2004 74KW
gabriel.cornel |
#219
Supape de retur originale la cutiuta, made in Franta - 320 Ron/bucata
Se vinde la set 0724551077 |
MEGANE SEDAN 2.1/
- B 17 GNF
1.5 DCI 2004 74KW
P-A-C-O |
#220
![]() What you see is what you get! Group: Members Posts: 2.350 Joined: 3 October 10 ![]() |
posteaza te rog poza cu partea sup si inf a valvei.
multumesc |
- Ziua de 16 nov 2014 a ramas in istoria Romaniei ca fiind ziua in care omul politic Victor Ponta a fost cel mai aproape sa devina Presedintele Romaniei
gabriel.cornel |
#221
Supape de retur originale Delphi, negre, la cutiuta, cod 28239294/made in Franta - 320 Ron /buc.
Grija mare!!! Cumparati de la persoane de incredere, cu recomandari, va spun asta ca sa fiti atenti de unde luati sa nu primiti supape de retur folosite, date jos de pe masina, cum au patit-o destui, pentru ca dupa cum vedeti nu sunt chiar asa ieftine. Nu conteaza ca aveti E3, E4, E5, sau diferite motorizari, 1.5dci, 1.8tdci, 2.0tdci, 2.4tdci, D27DT 2.9 HPDI, sau motoare de diferiti kw. Aceste supape se potrivesc la toate injectoarele Delphi, common rail. Sunt pentru urmatoarele autoturisme care folosesc injectie de tip DELPHI: -> DACIA - Logan 1,5 dCi -> FORD - Focus, Transit Connect, Tourneo Connect - 1,8 TDCi -> MONDEO, TRANSIT – 2,0 TDCi -> HYUNDAI ACCENT 1.5 CRDi -> TRANSIT 2,4 TDCi -> RENAULT - Clio, Kangoo, Megane 2, Scenic, Modus – 1,5 dCi -> KIA - Carnival, Pregio, Bongo, Frontier – 2,9 HPDi -> SSANGYONG - Rodius, Rexton – D27DT -> NISSAN - Almera, Kubistar, Micra – 1,5 dCi -> CITROEN - C3 1,4 HDI -> SUZUKI - Liana 1,4 Ddis ; Jimny 1,5 Ddis -> JAGUAR - X400 2,0 TDCi -> MERCEDES C200, C220,E Klasse -> PEUGEOT 407 Dupa schimbarea supapelor de retur, daca nu schimbati locul injectorului in chiuloasa, nu trebuie sa scrieti codul in calculator, nu trebuie centicubat injectorul. ATENTIE!!! Daca schimbati tot setul si le montati dvs., sa nu incercati sa le schimbati pe toate odata pentru ca daca se intimpla sa se blocheze vreuna din cauza mizeriei, nu stiti care este, asa ca va recomand sa schimbati una cate una dupa aceea porniti masina si vedeti daca functioneaza, pe urma treceti la urmatoarea si tot asa... Daca cumva se intimpla sa se blocheze, o stiti care este , o demontati o spalati si o puneti la loc. 0724551077 1zvd8hg.jpg |
MEGANE SEDAN 2.1/
- B 17 GNF
1.5 DCI 2004 74KW
gabriel.cornel |
#222
320 Ron/bucata - 0724551077
MEGANE SEDAN 2.1/
- B 17 GNF
1.5 DCI 2004 74KW
P-A-C-O |
#223
gabriel.cornel |
#224
320 Ron/bucata- supape de retur originale Delphi, la cutiuta- made in Franta
0722922613 |
MEGANE SEDAN 2.1/
- B 17 GNF
1.5 DCI 2004 74KW
gabriel.cornel |
#225
320 Ron/bucata, supape de retur originale
0722922613 |
MEGANE SEDAN 2.1/
- B 17 GNF
1.5 DCI 2004 74KW
gabriel.cornel |
#226
QUOTE(P-A-C-O @ 20 Dec 2012, 06:56) Ai pozele. 320 Ron/buc. 0724551077 1zvd8hg.jpg bj8pxl.jpg 31476sh.jpg sm7nkk.jpg |
MEGANE SEDAN 2.1/
- B 17 GNF
1.5 DCI 2004 74KW
P-A-C-O |
#227
ms
up de la mine |
P-A-C-O |
#228
revin cu o intrebare, poti sa faci rost de ansamblul supapa retur din dreapta (vezi foto)?
lico |
#229
![]() Membru autentic Group: Members Posts: 510 Joined: 25 November 07 From: Bucuresti ![]() |
Un up si de la mine, anuntul este valabil.
Megane
- B XX XXX
2003 2.1 dci + Lume multa oameni putini !
gabriel.cornel |
#230
QUOTE(P-A-C-O @ 12 Jan 2013, 09:02) revin cu o intrebare, poti sa faci rost de ansamblul supapa retur din dreapta (vezi foto)? xxx.jpg ( Size: 7.3k ) Number of downloads: 915 P-A-C-O, momentan nu. Va multumesc pentru up-uri. Supape de retur originale 320 Ron/buc - 0724551077 |
MEGANE SEDAN 2.1/
- B 17 GNF
1.5 DCI 2004 74KW
gabriel.cornel |
#231
Supape de retur originale -320 Ron/buc.
MEGANE SEDAN 2.1/
- B 17 GNF
1.5 DCI 2004 74KW
gabriel.cornel |
#232
Supape de retur originale Delphi, made in Franta - 320 Ron/bucata
0722922613 |
MEGANE SEDAN 2.1/
- B 17 GNF
1.5 DCI 2004 74KW
gabriel.cornel |
#233
320 Ron/ bucata
MEGANE SEDAN 2.1/
- B 17 GNF
1.5 DCI 2004 74KW
gabriel.cornel |
#234
Up!
MEGANE SEDAN 2.1/
- B 17 GNF
1.5 DCI 2004 74KW
gabriel.cornel |
#235
320 Ron/buc-supape originale Deplhi, made in Franta.
0722922613 |
MEGANE SEDAN 2.1/
- B 17 GNF
1.5 DCI 2004 74KW
gabriel.cornel |
#236
UP!
MEGANE SEDAN 2.1/
- B 17 GNF
1.5 DCI 2004 74KW
gabriel.cornel |
#237
320 Ron/bucata
MEGANE SEDAN 2.1/
- B 17 GNF
1.5 DCI 2004 74KW
mykep |
#238
Membru incepator Group: Members Posts: 4 Joined: 22 November 11 ![]() |
doar duze de pulverizare pentru euro3 80 cai ce pret/bucata?
multumesc. |
kia
ceed
gabriel.cornel |
#239
[quote=mykep,25 Feb 2013, 10:11]
doar duze de pulverizare pentru euro3 80 cai ce pret/bucata? multumesc. Nu am. Numai bine. |
MEGANE SEDAN 2.1/
- B 17 GNF
1.5 DCI 2004 74KW
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 29th July 2025 - 07:49 |
