Fitted my tow-bar.....nearly!
fusil56300 |
31 Aug 2011, 15:34
Membru incepator Group: Members Posts: 1 Joined: 31 August 11 |
Logan Van
1.5DCI
martin245 |
31 Aug 2011, 19:09
EX PAT Group: Members Posts: 913 Joined: 1 April 06 From: Karlsbad Germany (again) |
QUOTE(fusil56300 @ 31 Aug 2011, 14:34) Hello all, first message for me and I'm after some help. I'm stuck on the wiring of the rear lights on my dacia van. Can anyone tell what colour does what, I found a wiring diagram which was of no bloody use. Cheers in advance of any info, fusil56300 The only geordie in the village. Hi Geordie I could email you a complete set of Pdfs Just PM me your email address Stu The only Grimsby Guy here |
logan 14 mpi Simply RED
- GB 1 Bessy Regs
31 Aug 2011, 19:11
He can't PM because he hasn't 25 post.
martin245 |
31 Aug 2011, 19:16
Ok write to me on stuartmartin@web.de and I will get a bit of info sent to you mate
Thats a bit silly about the 25 posts before a PM ! Stu |
- GB 1 Bessy Regs
31 Aug 2011, 19:20
There were some spammers on PM, with no post.
It's a pretection against them. |
martin245 |
31 Aug 2011, 19:20
I HAVE GOOGLE TRANSLATED THIS FOR YOU
Cable assignment is: green = turn signal, = pink rebel, blue = light, black = ground orange = Brake I'm on the right side then (5mm drill holes) with the wires through the stopper went on the towing (with sikomastik then you tten or similar), but it must also get out on the side of the grid (Fig. 4 / 7 of Sparket) to to get the cable nzur tail light. Occupancy as follows: gray = blinkers, beige = Rückfahrli, blue + orange (who would have thought) = + brake light. Its a bit crappy but you can see the wiring colours OK Stu |
- GB 1 Bessy Regs
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 8th May 2024 - 20:05 |
