Motor de R5 Alpine pe Dacia 1300, o mica problema cu pompa de apa :D
BH 59 FIF |
#691
![]() Membru cu Break Group: Members Posts: 1.456 Joined: 13 July 06 From: Tara Crisului ![]() |
Attached thumbnail(s) 2013_03_16_16.42.30.jpg ( Size: 1.31mb ) Number of downloads: 1002 2013_03_16_17.19.59.jpg ( Size: 1.14mb ) Number of downloads: 1051 2013_03_16_17.20.12.jpg ( Size: 1.16mb ) Number of downloads: 1013 |
1310 Break Alpineliebe
1986
- BH 59 FIF http://www.youtube.com/watch?feature...&v=-qRd8N3XU5Y
Cumpar priza aer capota R19 16v ph2. |
djalex_bolidu |
#692
![]() Membru autentic Group: Members Posts: 760 Joined: 16 February 06 ![]() |
Ai turometru de injectata sau de carburatie? daca e de carburatie astea sunt simptomele, asa facea si la mine pana sa pun de injectie
'84
- AG 88 PVA
BH 59 FIF |
#693
E de carburatie asta de-l am montat. Si zici ca dau iau unul de pe o injectata se rezolva?
1986
djalex_bolidu |
#694
da, trebuie unul de injectie, dar vezi sa il iei cu tot cu montajul electronic aferent.
'84
- AG 88 PVA
b44dvl |
#695
![]() Membru cu 1300 Group: Members Posts: 447 Joined: 9 March 09 From: Bucuresti ![]() |
Asa e si la mine... Dar pe dor
1300 din
1976
- B 44 DvL Bad Mojo Mother Fucker
JWF |
#696
![]() Membru Group: Members Posts: 174 Joined: 19 May 09 ![]() |
niste poze cu niste ceasuri din ceva stocuri mai vechi! lamuriti-ma si pe mine daca sunt ce ne trebe noua sau nu si daca merge bagate direct in mufe sau face popcorn
![]() ![]() pe langa astea mai pun ceva poze cu noua grila de dacie turbo de fabrica! app scuzati degustatoru din poza ![]() ![]() ![]() ![]() This post has been edited by JWF: 18 Mar 2013, 22:56 Attached thumbnail(s) 180320131578.jpg ( Size: 1.02mb ) Number of downloads: 853 180320131577.jpg ( Size: 744.32k ) Number of downloads: 858 180320131576.jpg ( Size: 980.52k ) Number of downloads: 171 180320131575.jpg ( Size: 1.07mb ) Number of downloads: 205 180320131574.jpg ( Size: 970.14k ) Number of downloads: 192 180320131573.jpg ( Size: 584.43k ) Number of downloads: 157 180320131572.jpg ( Size: 845.07k ) Number of downloads: 172 180320131571.jpg ( Size: 793.68k ) Number of downloads: 169 |
1320
- 1988
- BH 01 JWF
ghitza |
#697
poza 4 stanga sus este de injectie ,poti lua turometru cu tot cu montaju electronic care este prin in cele 3 piulite mici se vad in poza
Dacia/BMW 316i an 99
1310 li
2003 Berlina
- Ar-07-GIB/BG
BH 59 FIF |
#698
Senchiu.
1986
djalex_bolidu |
#699
prima poza si in a4a cele doua de sus sunt de injectie, se vede dupa cele 3 surubele ale montajului electronic al turometrului. Poti lua turometrul si sa il arunci inceasurile tale si te legi la cablajul ceasurilor tale, sau pui si cablajul de injectie. Eu am pus si cablajul de injectie la mine, deoarece cel al ceasurilor nu era intr-o stare prea buna.
'84
- AG 88 PVA
JWF |
#700
Ceasuri...
![]() 19 Mar 2013, 23:29: Ceasuri... ![]() scuzati claritatea pozelor,in realitate arata mult mai bine This post has been edited by JWF: 19 Mar 2013, 23:29 Attached thumbnail(s) 190320131583.jpg ( Size: 853.04k ) Number of downloads: 136 190320131589.jpg ( Size: 910.78k ) Number of downloads: 149 190320131591.jpg ( Size: 792.02k ) Number of downloads: 138 190320131592.jpg ( Size: 789.9k ) Number of downloads: 134 190320131596.jpg ( Size: 859.02k ) Number of downloads: 171 |
1320
- 1988
- BH 01 JWF
Leo0608 |
#701
BH 59 FIF, pana la urma ramai pe cutia de dacia ? sau alegi sa pui alta CV de Renault?
This post has been edited by total: 20 Mar 2013, 00:02 |
pentru?
200x
- X XX XXX
BH 59 FIF |
#702
Deci maine avem (sper) si indicator de turatie
![]() ![]() Cu filtrul de aer montat, sistem de esapament complet si actuatorul reglat la 0,5 bar nu mai e chiar asa "racheta" cum era la 1 bar cu ocazia primului test dar totusi in continuare e ceva asemanator unui vis umed ![]() This post has been edited by BH 59 FIF: 20 Mar 2013, 00:13 |
1986
b44dvl |
#703
1300 din
1976
Leo0608 |
#704
cauta un radiator de Aluminiu de pe alta masina, eventual cu 2 furtune pe aceeasi parte
disipa mult mai bine caldura ![]() |
pentru?
200x
- X XX XXX
BH 59 FIF |
#705
In continuare mici/mari probleme cu turometrul. De data asta la treapta a 2-a de contact urca pana in capat (dincolo de 8000 rot/min) dar nu se mai misca de acolo nici dupa pornirea motorului
![]() This post has been edited by BH 59 FIF: 20 Mar 2013, 21:41 |
1986
JWF |
#706
spuneti-mi si mie va rog ca nu mai inteleg! deci turometru are 3 fire.
1.alimentare cu plus de la contact 2.alimentare cu minus de la contact sau de pe caroserie. 3.nu stiu ce este,plus sau minus firu ce vine de la aprindere! la urma urmei o sa trag 3 fire,alimentez turometru si ii dau semnal separat de la aprindere! problema e ca nu stiu daca turometrele astea de carb sau de injectie stiu sa interpreteze semnalul dat de aprinderea asta de alpine si inca o chestie,turometru vechi de dacia pe carb, ia semnal de la bobina prin firul acela subtire maro ce vine pus pe minus la borna de pe bobina de inductie? |
1320
- 1988
- BH 01 JWF
djalex_bolidu |
#707
QUOTE(JWF @ 20 Mar 2013, 23:28) ... si inca o chestie,turometru vechi de dacia pe carb, ia semnal de la bobina prin firul acela subtire maro ce vine pus pe minus la borna de pe bobina de inductie? da. desfa acel fir si pune contactul si vezi daca mai salta acul al 8000. nu stiu cum e la aprinderea de alpin dar la mine sunt 3 fire: galben, negru si verde. verde este firul de semnal pt turometru. This post has been edited by djalex_bolidu: 20 Mar 2013, 23:55 |
'84
- AG 88 PVA
Leo0608 |
#708
jwf&fif, Desfa din circuit turometrul si leaga-l separat pt proba de functionare: legi firul de [-] la masa masinii, firul de [+] la [+] bobina inductie si firul de semnal, la [-] bobia de inductie. Montajul il poti face direct in compartimentul motor.
Daca totul merge OK dupa acest montaj, inseamna ca ai facut tu o legatura aiurea prin bord. ![]() |
pentru?
200x
- X XX XXX
JWF |
#709
Ok! Voi încerca mai multe tipuri de turometre ,injectie,carb,extern universal si original de gtt! O sa-l leg direct in compartimentul motor
1320
- 1988
- BH 01 JWF
BH 59 FIF |
#710
S-a rezolvat. De obicei problemele complexe au solutii simple. In cazul de fata turometrul era dus. Am pus altul (tot de injectata) si indica ce trebuie
1986
Leo0608 |
#711
BH 59 FIF toata stima, ti-am zs aseara pe mess sa pui altul
pentru?
200x
- X XX XXX
JWF |
#712
turometru a fost legat corect de la inceput
1320
- 1988
- BH 01 JWF
Leo0608 |
#713
@jwf, bine ca s-a rezolvat
pentru?
200x
- X XX XXX
arazvan2002 |
#714
![]() Membru autentic Group: Members Posts: 312 Joined: 14 June 06 From: Bucuresti ![]() |
Ai cumva o poza cu intercoolerul de Frontera nemontat? De pe ce tip de Frontera e si ce dimensiuni are.
Merci |
MEGANE
2000 RXE 1.9dTI 1.9dTI 120CP 245Nm Upsolute cip tuning
Audi A4 B5 1.9 TDI quattro |
BH 59 FIF |
#715
Poze cu el nemontat nu am din pacate. Intercoolerul e de Frontera A (motor 2,3l). Mai este un model de intercooler montat pe Frontera A (motor 2,8 din cate tin minte), asta avand 3 sau 4 randuri suplimentare. Atasez niste poze luate de pe net pentru a se observa diferentele. Cand ajung pe la garaj in masor ca am uitat exact ce dimensiuni are.
L.E: Am gasit pe net si dimensiunile intercoolerului de 2,3, 598x198x38 mm This post has been edited by BH 59 FIF: 22 Mar 2013, 13:09 Attached thumbnail(s) vendo_intercooler_para_adaptar__1_.jpg ( Size: 181.45k ) Number of downloads: 150 FMICrear.jpg ( Size: 31.7k ) Number of downloads: 159 |
1986
arazvan2002 |
#716
Merci
Ce dimensiuni au intrarile? Gasisem si eu ceva pe net dar la tine parea mai gros putin. Cred ca mai e neva negru sub el. ![]() |
MEGANE
BH 59 FIF |
#717
Intrarile au diametrul de 50 mm.
1986
BH 59 FIF |
#718
Am scos azi masina din nou. Merge relativ ok dar ceva o gatuie, nu mai are forta pe care o exprima acum 2 sapt. O fi din tobe, o fi din filtru, o fi din ambele, nu stiu. In rest mai trebuie schimbata garnitura de la distributie (lacrimeaza putin), reglati din nou tachetii si aia e.
This post has been edited by BH 59 FIF: 24 Mar 2013, 13:17 Attached thumbnail(s) 2013_03_24_11.09.56.jpg ( Size: 1.74mb ) Number of downloads: 166 2013_03_24_11.09.49.jpg ( Size: 2.06mb ) Number of downloads: 213 2013_03_24_11.09.35.jpg ( Size: 1.46mb ) Number of downloads: 207 2013_03_24_11.09.20.jpg ( Size: 1.99mb ) Number of downloads: 187 |
1986
JWF |
#719
Aproape ca bag mana in foc pt filru ala,nu aveam licra la noi ca incercam si fara el
1320
- 1988
- BH 01 JWF
b44dvl |
#720
Cate tobe sunt pe traseu? Si ce diametru are teava de la turbo pana la tips? Teoretic la turbo se poate merge fara tobe pentru ca turbina preia marea majoritate a zgomotelor... si un traseu mai maricel ca evacuarea sa se faca mai repede si sa nu existe back presiure ca sa ingreuneze turbina
Arata bine bine de tot masina ![]() |
1300 din
1976
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 27th July 2025 - 05:21 |
