[VAND] Piese Noi LOGAN si RENO, suntem un magazin nou, avem preturi mici
RadulescuRomulus |
![]() Sunt cu ochii pe voi! Group: Members Posts: 1.780 Joined: 7 December 10 From: naufragiat ![]() |
VW Passat berlina
2.0 Tdi CR + DSG
04.2009 - diesel, 140cp
- B 69 COI EX: megane 2.1, 1.5dci, 101 magari - B 314 ZDA
ionutz_87 |
![]() ionutz_87 Group: Members Posts: 1.029 Joined: 21 February 09 From: pantelimon(ilfov)-roman(neamt) ![]() |
pompa de apa clio 1.4 8v an 2003?
VF1LB0BC529696760 This post has been edited by ionutz_87: 30 Sep 2011, 21:29 |
CLIO
2003/LB0C5/CLIO
- IF 03 DAP Grand scenic 2004 1.6
RadulescuRomulus |
Salut,
Pompa Apa - AIRTEX - 120 lei Mastersport - 80 Lei Ambele variante sunt pe stoc. Multumesc, |
VW Passat berlina
2.0 Tdi CR + DSG
niku2 |
Membru Group: Members Posts: 113 Joined: 26 August 11 From: Iasi ![]() |
Pt Laguna II 1.9 dci 2001 valva EGR aduceti?
EX Renault
Laguna II Dynamique
2001 1.9dci 88kw 120CP -> Good car
RadulescuRomulus |
In principiu, da.
da-ne VIN-ul masinii sau macar ce tip/ model de motor e si iti dam pret. 1 Oct 2011, 20:09: Cati KW are Laguna? 1 Oct 2011, 20:12: E posibil sa fie ceva pe PIERBURG- 679 lei, insa am nevoie de datele exacte. This post has been edited by RadulescuRomulus: 1 Oct 2011, 19:12 |
VW Passat berlina
2.0 Tdi CR + DSG
RadulescuRomulus |
Pentru a nu exista conflicte de topic, adaug listei initiale de piese, cateva repere publicate in alt topic [ce va fi inchis]. Asadar:
LOGAN --------------------------marca piese: Starline Descriere ------------------------------------- Pret vanzare Elemente de directie---------------------------- 31.04 Cap Bara Dreapta-------------------------------- 41.96 Cap Bara Stanga---------------------------------- 41.98 Bieleta directie----------------------------------- 44.05 Bieleta directie----------------------------------- 44.65 Amortizoare spate------------------------------- 154.01 Amortizoare fata--------------------------------- 138.23 Pivot------------------------------------------------ 33.83 Kit-uri rulmenti roata fata fara ABS----------- 38.08 Kit-uri rulmenti roata spate--------------------- 32.25 Bascula dreapta---------------------------------- 106.18 Bascula stanga------------------------------------ 106.18 Bucsa bascula------------------------------------- 14.11 Bieleta antiruliu---------------------------------- 13.46 Discurii frana 260 ventilat--------------------- 147.63 / set 2 buc Discurii frana 238 plin-------------------------- 95.19 / set 2 buc Saboti frana fara ABS--------------------------- 66.64 Saboti frana cu ABS----------------------------- 108.46 Filtru ulei------------------------------------------- 15.74 Filtre aer DCI-------------------------------------- 16.39 Filtre habitaclu----------------------------------- 19.24 La care se mai adauga: 1. pompe spalat parbriz, FEBI [pt megane 2.1] = 70 ron [de asemeni, noi!] 2. bielete antiruliu noi Lemforder - 89 ron/buc [din cate mi s-a spus, cu din astea vin echipate BMW-urile] 3. saua dintre scaune = 55 ron sau un pack de Heineken pt mushteriul din Bucuresti / Botosani! [donatie] Intrebari? raspunsuri directe: Romulus Radulescu - 0746-218-120 |
VW Passat berlina
2.0 Tdi CR + DSG
dannieltudorache |
![]() Membru autentic Group: Members Posts: 251 Joined: 7 February 10 From: Bucuresti ![]() |
Salut ma intereseaza niste saboti frina 1.6 berlina fara ABS. Sunt Starline?
2006 Romanului ii place munca cum ii place mierlii sunca
RadulescuRomulus |
Salut,
Da, sabotii de frana sunt Starline. 66.64 ron, cei fara ABS. Daca te-ar interesa o alta marca, zi care anume si un VIN ar fi de ajutor... This post has been edited by RadulescuRomulus: 3 Oct 2011, 11:40 |
VW Passat berlina
2.0 Tdi CR + DSG
ionutz_87 |
duze injector pt megan 1.5?
CLIO
2003/LB0C5/CLIO
niku2 |
QUOTE(RadulescuRomulus @ 1 Oct 2011, 15:55) In principiu, da. da-ne VIN-ul masinii sau macar ce tip/ model de motor e si iti dam pret. <span class='edit'>1 Oct 2011, 20:09:</span> Cati KW are Laguna? <span class='edit'>1 Oct 2011, 20:12:</span> E posibil sa fie ceva pe PIERBURG- 679 lei, insa am nevoie de datele exacte. Masina din semnatura - VIN - VF1KG0G0624984238 |
EX Renault
Laguna II Dynamique
RadulescuRomulus |
@ionutz_87: Momenta nu avem, revin cu un pret in momentul cand am un pret.
VW Passat berlina
2.0 Tdi CR + DSG
bogdanmarian |
Membru incepator Group: Members Posts: 45 Joined: 20 September 11 From: piatra neamt ![]() |
amortizoare fata megane 2.1 an 2004 60 kw break,ms.
renault
megane
RadulescuRomulus |
Salut,
Pentru : amortizoare fata megane 2.1 an 2004 60 kw break Avem ca variante: ALKO - 189 lei cu TVA KAYABA - 208 lei cu TVA SACHS - 240 lei cu TVA Multumesc, Romulus Valabil astazi, 5 octombrie 2011: Curea transmisie Dacia Logan, Peugeot 206, 307, Renault Clio II, Clio III, Megane II - 46.50 RON Rola întinzatoare Dacia Logan, Renault Clio II, Clio III, Kangoo, Megane II, 1.5 dCi - 140 RON This post has been edited by RadulescuRomulus: 5 Oct 2011, 10:40 |
VW Passat berlina
2.0 Tdi CR + DSG
RadulescuRomulus |
UP
puteti urmari topicul doar si pt promotiile care se vor posta. |
VW Passat berlina
2.0 Tdi CR + DSG
sorin1983 |
![]() Membru autentic Group: Members Posts: 5.637 Joined: 3 July 06 From: Bucuresti-Rahova ![]() |
megane 1, 1.6 16v, 2002, iac(idle air control) ce preturi s-ar gasi?
Megane1-
Victorine |
Ai putea pune niste poze relevante (sa nu fie facute chiar cu telefonul mobil, ca sa imi dau seama de calitatea fabricatiei) cu capete de bara, bascule, pompa de apa, discuri de frana ventilate, placute STARLINE? Preturile sunt foarte tentante, insa din pacate nu prea sunt referinte pentru produsele starline ca sa stim daca sunt comparabile cu cele chinezesti sau cu celelate mai rasarite...
LE - vad ca unii ofera 3 ani garantie la piesele Starline, fara clauze... poate chiar sunt OK This post has been edited by Victorine: 6 Oct 2011, 07:58 |
Toyota
Auris Touring Sports HSD
2014
RadulescuRomulus |
@sorin1983: in cataloagele noastre, nu apar denumiri in engleza, ci doar echivalente in romana. Si alte struto-camile. Prin urmare, ca sa nu caut pe presupus, da-mi detalii despre ce anume cauti. si un VIN, ca sa iti prezint cele mai bune rezultate.
@victorine: lucram la acest aspect. suntem constienti ca piesele si consumabilele nu sunt [inca] cunoscute. insa toate lucrurile necesita timp. O sa incercam sa prezentam pe parcurs si poze. Promotia zilei de 6 octombrie 2011: INA Kit distributie Dacia Logan, Sandero, Duster, Nissan Micra, Renault Clio, Kangoo, Megane, 1.5 dCi - 241 RON This post has been edited by RadulescuRomulus: 6 Oct 2011, 09:05 |
VW Passat berlina
2.0 Tdi CR + DSG
Victorine |
Eu te astept cu pozele, ma intereseaza unele repere. Bafta!
Toyota
2014
RadulescuRomulus |
Salut,
Nu stiu cat de importante sunt pozele. La urma urmei, un cap de bara... e un cap de bara, care arata la fel pe masina solicitata, indiferent de producator. Calitatea cred ca e mai importanta. Iar 3 ani garantie, fara cerinte deosebite [gen montaj stand pe coate si privirea in jos, cu parul dat pe spate in prealabil] spune ceva. Starline e pe piata din martie 2011, deci... nu sunt referinte suficiente. Am atasat 2 poze primite acum, de dimineata. Attached thumbnail(s) bieleta_directie_Starline.jpg ( Size: 9.08k ) Number of downloads: 5202 cap_bara_Starline.jpg ( Size: 23.16k ) Number of downloads: 5240 |
VW Passat berlina
2.0 Tdi CR + DSG
sorin1983 |
Megane1-
Victorine |
Multumesc pentru poze, daca ai si cu restul, pune. Iti spun eu cat de importante sunt imaginile REALE pentru mine, si probabil nu numai. FOARTE. Cumpar multe produse de pe net, inclusiv piese auto (aproape exclusiv) si principalul dezavantaj fata de magazinele traditionale este ca nu poti vedea sau atinge produsul, astfel ca o imagine reala compenseaza lucrul asta. Pe alte forumuri nici nu sunt permise anunturile la bursa daca nu sunt insotite de imagini. Ideea este ca daca ai produsul pe stoc si o camera foto la indemana sa-i faci o poza, nu sa pui niste thumbnails de pe site-ul producatorului. Ai putea sa iei cererea mea ca un feedback din partea unui potential client relativ la asteptarile acestuia, daca crezi ca ti-e util si te ajuta sa vinzi mai mult, dai curs cererii, daca nu - fiecare isi vinde cum stie mai bine marfa.
LE - vezi mai sus postata de sorin1983 o imagine expresiva a unui reper. Pe mine ma interesa sa vad produsele Starline, pentru Delphi se gasesc o gramada de imagini la magazinele online si referinte pe net. This post has been edited by Victorine: 6 Oct 2011, 10:30 |
Toyota
2014
emilian69 |
![]() Membru autentic Group: Members Posts: 279 Joined: 19 February 11 ![]() |
Salut cat costa un kit distributie pentru o laguna II Dynamique din 2001 motor 1.9 Dci,88 kw ,120 c.p.?
Laguna II
2001 Dynamique
- TR-04- Cine nu este cu noi este impotriva noastra
RadulescuRomulus |
@emilian69: Kit-uri distribuþie CONTI: 327,15 RON
@sorin1983: mai caut, pana gasesc ceva bun sub raport pret/calitate. @Victorine: tot ce ai spus tu e adevarat. Tot ce putem oferi noi, in acest moment, sunt poze ... nu prea expresive. Pentru livrarile in Bucuresti, handicapul vizualizarii pozelor e anulat de faptul ca forumistul reno nu plateste pana nu pipaie/ vede/aproba, etc. Prin urmare, acum, vindem cum putem, nu neaparat cum stim. Oricum, ceea ce ai spus tu e de apreciat. Mai rau [si frustrant] este ca nu te putem ajuta, si implicit, vinde. |
VW Passat berlina
2.0 Tdi CR + DSG
Victorine |
Oricum, preturile la Starline sunt bune, fara discutie. Din cate vad foloseste lumea la multe marci, asa ca probabil vor aparea in curand si referintele, daca e cazul.
This post has been edited by Victorine: 6 Oct 2011, 18:28 |
Toyota
2014
beberazvan_n |
![]() Membru autentic Group: Members Posts: 587 Joined: 30 June 09 From: Bucuresti ; Branesti Ilfov ![]() |
Salut sunt interesat de urmatoarele:
pivoti, bielete antiruliu, bucsa bascula ( cele 2 ) . La ce preturi sunt. Mersi. Nr. identificare : VF1SM0F0528554217 This post has been edited by beberazvan_n: 6 Oct 2011, 19:23 |
Megane 2, 1.5 dci...
- IF-03-VZL
RadulescuRomulus |
@sorin1983: imi pare rau, insa doar pe origine am gasit: 860 RON, cu tva.
6 Oct 2011, 20:42: @beberazvan_n: Salut, pivoti: Mastersport -18,47 lei RTS - 36,14 lei SWAG - 67,66 lei LEMFÖRDER - 84,25 lei bielete antiruliu: SWAG - 78,37 lei LEMFÖRDER - 98,25 lei bucsa bascula: SWAG - fata - 38,58 lei SWAG - spate - 38,62 lei LEMFÖRDER - fata - 61,39 lei LEMFÖRDER - spate- 61,15 lei Multumesc, This post has been edited by RadulescuRomulus: 6 Oct 2011, 19:42 |
VW Passat berlina
2.0 Tdi CR + DSG
beberazvan_n |
Salut, mersi pentru informatii, dar inainte de a comanda as dori sa stiu ce dimensiune are pivotul ( 16 sau 18 mm) mersi mult.
Am vazut ca sunt de 2 feluri si de aceea te intreb. This post has been edited by beberazvan_n: 6 Oct 2011, 20:03 |
- IF-03-VZL
br0klyn |
![]() Membru autentic Group: Members Posts: 411 Joined: 16 June 10 ![]() |
Piese de solenza nu ai ?
RadulescuRomulus |
@beberazvan_n
Salut, Dimensiunea de 16.00 mm este pentru auto pâna în an fabricatie: 01.01.2003; Dimensiunea de 18.00 mm este pentru auto incepand cu an fabricatie: 01.01.2003; Eu am ofertat 18.00mm, ce ai tu, sper sa nu gresesc ![]() 6 Oct 2011, 21:27: @br0klyn: ce anume te interesaza ? This post has been edited by RadulescuRomulus: 6 Oct 2011, 20:27 |
VW Passat berlina
2.0 Tdi CR + DSG
beberazvan_n |
Am inteles. Si cum facem pentru comanda, te pot contacta maine dimineata , pana seara se pot aduce? Din ce zona esti?
- IF-03-VZL
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 23rd July 2025 - 07:31 |
