33 Pages « < 3 4 5 6 7 > »
> [VAND] Piese Noi LOGAN si RENO, suntem un magazin nou, avem preturi mici
RadulescuRomulus
post 8 Nov 2011, 16:29
Post #121
Sunt cu ochii pe voi!
CASTROL MAGNATEC DIESEL 5W40 4L- 120 RON
CASTROL MAGNATEC DIESEL 10W40 4L - 100 RON
CASTROL EDGE 5W30 1L 45 RON
CASTROL EDGE 5W30 5L 200 RON
CASTROL EDGE 5W40 TURBO DIESEL 1L 35 RON
CASTROL EDGE 5W40 TURBO DIESEL 5L 140 RON
CASTROL EDGE TURBO DIESEL 5W40 4L 125 RON
CASTROL MAGNATEC DIESEL 5W40 B4 1L 30 RON
CASTROL MAGNATEC DIESEL 5W40 B4 5L 130 RON
CASTROL MAGNATEC DIESEL B4 - 10W40 - 1L 30 RON
CASTROL MAGNATEC DIESEL B4 - 10W40 - 5L 105 RON
Ulei VAT, facut in Polonia:
Vat SynGold 5W-40 1L 25 RON
Vat SynGold 5W-40 4L 92 RON
LOGAN ------------------piese marca Starline, garantie 3 ani!
Descriere ------------------------------------- Pret vanzare
Elemente de directie---------------------------- 31.04
Cap Bara Dreapta-------------------------------- 41.96
Cap Bara Stanga---------------------------------- 41.98
Bieleta directie----------------------------------- 44.05
Bieleta directie----------------------------------- 44.65
Amortizoare spate------------------------------- 154.01
Amortizoare fata--------------------------------- 138.23
Pivot------------------------------------------------ 33.83
Kit-uri rulmenti roata fata fara ABS----------- 38.08
Kit-uri rulmenti roata spate--------------------- 32.25
Bascula dreapta---------------------------------- 106.18
Bascula stanga------------------------------------ 106.18
Bucsa bascula------------------------------------- 14.11
Bieleta antiruliu---------------------------------- 13.46
Discurii frana 260 ventilat--------------------- 147.63 / set 2 buc
Discurii frana 238 plin-------------------------- 95.19 / set 2 buc
Saboti frana fara ABS--------------------------- 66.64
Saboti frana cu ABS----------------------------- 108.46
Filtru ulei------------------------------------------- 15.74
Filtre aer DCI-------------------------------------- 16.39
Filtre habitaclu----------------------------------- 19.24
SAU orice alta marca doriti.
Toate reperele de mai sus sunt marca Starline. Avem la vanzare si alte marci, mai cunoscute pe piata, pt care oferim pret la solicitare expresa. Mai mult, garantia este de 3 ani la reperele Starline!
REPERE UNIVERSALE:
antigel G12 13,19 RON
antigel G12 38,93 RON
lichid spalat parbriz -20 grade 5,40 RON
lichid spalat parbriz -20 grade 15,35 RON
acumulator 44 amperi 196,83 RON
acumulator 54 amperi 232,82 RON
acumulator 66 amperi 275,16 RON
acumulator 74 amperi 305,03 RON
acumulator 97 amperi 393,86 RON
Bec Megalight Ultra H7 - 55w 38,03 RON
Bec incandescent H7 GE 13,57 RON
This post has been edited by RadulescuRomulus: 8 Nov 2011, 16:30
VW Passat berlina 2.0 Tdi CR + DSG 04.2009 - diesel, 140cp - B 69 COI
EX: megane 2.1, 1.5dci, 101 magari - B 314 ZDA
m_birleanu
post 9 Nov 2011, 14:12
Post #122
Salutare,
Vreau sa schimb uleiul si filtrele la masina si am nevoie de urmatoarele:
Ulei Castrol Magnatec Diesel bidon 5l 5w40
Filtru Ulei
Filtru motorina cu senzor de apa
Filtu aer
Filtru habitaclu
Vin:VF1BM0F0529265007
Pe langa aste mai am nevoie de discuri si placute fata spate.
trimite-mi un PM cu preturile la toate astea.
Multumesc
Renault Megane 2003/bicorp/1.5dci - B-56-GRP
RadulescuRomulus
post 9 Nov 2011, 14:21
Post #123
QUOTE(m_birleanu @ 9 Nov 2011, 14:12)
... Filtru motorina cu senzor de apa
sigur vrei cu senzor de apa? eu tare cred ca nu e cu senzor. Daca masina e din 2003, nu prea cred ca are senzorul de apa...
m_birleanu
post 9 Nov 2011, 14:58
Post #124
Este cu senzor ca nu este prima data cand le schimb ca am masina de noua.
RadulescuRomulus
post 9 Nov 2011, 15:08
Post #125
OK, te cred. nu am acces acum la programul pe origine, asa ca te rog sa-mi dai:
kw/cp, an fabricatie si ce motorizare este.
Mersi,
Romulus
0746-218-120
m_birleanu
post 9 Nov 2011, 15:27
Post #126
Motorizarea este1.5DCI
Tipul Motorului K9K-D7 Seria D078814
Cilindree 1461 Putere 60KW
RadulescuRomulus
post 9 Nov 2011, 16:36
Post #127
filtru motorina cu senzor:
UFI: 270 RON [1-2 zile ajunge, ca nu e pe stoc].
Daca iti convin restul reperelor, mai caut ceva mai accesibil pt filtru motorina cu senzor. mai sus este "prima strigare", cum s-ar spune.
Mai jos, este mesajul unui om doxa intr-ale renou:
"Din seria VIN nu reiese ca are senzor de prezenta apa pe filtrul de combustibil.
La controlul fizic pe masina se poate remarca asta.
Cod fara senzor:8200186217
Cod cu senzor:7701061577 sau 7701062104 in functie de inscrisurile de pe filtru..."
Mihai.D.G.
post 10 Nov 2011, 08:40
Post #128
Jupanu'
Pentru un Megane 2 Sedane, 2005, 1.4 16v, 98cp, ma intereseaza placute frana fata si spate.
Renault Fluence 2010 1.5dci
RadulescuRomulus
post 10 Nov 2011, 09:11
Post #129
Domnu' Jupanu' ,
megane 2, 1390 cu 16V, 72/98, cod motor K4J730 sau K4J740
placute FATA:
ROADHOUSE: 94 ron
BOSCH: 142 ron [nu sunt pe stoc; 1-2 zile de la comanda ferma]
TEXTAR: 145 ron [textar echipeaza si veyronul...]
placute SPATE:
STARLINE: 60 ron
ROADHOUSE: 63 ron
TEXTAR: 95 ron
BOSCH: 105 ron
Romulus
0746-218-120
This post has been edited by RadulescuRomulus: 10 Nov 2011, 10:27
beberazvan_n
post 10 Nov 2011, 10:21
Post #130
Salut Romulus vreau sa te intreb daca poti aduce cablu frana de mana ca am o problema la o roata spate.
Mersi. Ne auzim.
Renault Megane 2, 1.5 dci... 2003 - IF-03-VZL
RadulescuRomulus
post 10 Nov 2011, 10:55
Post #131
Salve,
STARLINE: 77 ron
PIMAX: 70 ron
BOSCH: 69 ron
Nici unul nu e pe stoc. Daca dau azi comanda, pe maine ar trebui sa ajunga...
m_birleanu
post 10 Nov 2011, 11:35
Post #132
Salut Romulus,
Am mai primit o oferta pe Man la toate filtrele. Dupa ce iau o decizie te anunt.
Apropo filtru de combustibil Man cu senzor de apa 160 Ron.
Ma gandsc si te anunt.
RadulescuRomulus
post 10 Nov 2011, 15:54
Post #133
@m_birleanu: tinem legatura! e f.bun pretul la filtrul cu senzor de apa MAN.
RadulescuRomulus
post 11 Nov 2011, 20:37
Post #134
tynn
post 12 Nov 2011, 12:15
Post #135
Un pret pt. brate stergatoare de logan? Multumesc!
Dacia Logan 1.4 MPI 2008
Dacia Duster Prestige 4x4 Dci 2015
Renawlt
post 13 Nov 2011, 12:24
Post #136
tampon hidroelastic
bieleta antibalans / anticuplu
pt megane sedan2 1.5 dci 82 cp
BMW 330xd 2007 - B-00-XXX
RadulescuRomulus
post 13 Nov 2011, 17:49
Post #137
QUOTE(Renawlt @ 13 Nov 2011, 12:24)
tampon hidroelastic
Salve,
Tampon motor, hidroelastic, SWAG, 365 ron.
bieleta antibalans / anticuplu, SWAG, 135 ron
@tynn: nu am.
Mersi,
Romulus
0740-012-360
ARAMIS
post 13 Nov 2011, 20:58
Post #138
salutare,
un pret pentru bucsi bara stabilizatoare? (fara swag si febi.... swag am acu si-mi rup creierii )
multam'
Renault Megane 2.1 2003 hatch 1.5dCi 82>100 HP (Ph1) Authentique - BR - - NKD
RadulescuRomulus
post 13 Nov 2011, 22:01
Post #139
Aramis,
Swag sunt cele mai ieftine care le am: 42 ron. Pot sa aduc si originale, insa sunt piperate: 172 ron.
Alte marci, daca imi spui tu ce preferinte ai avea, pot cauta pt tine. Si pot oferi, cred, cele mai bune preturi.
Insa, din cate am citit, originalele sunt cele mai fiabile / bune.
Cele bune,
Romulus
0746-218-120
hexagon
post 13 Nov 2011, 22:51
Post #140
Salut,
Logan 1.6 MPI, an fabricatie 2006
Am nevoie de urmatoarele:
4 Litri ulei 10w40
filtru de ulei
filtru aer
placute frana ( fara abs )
rulment fata dreapta ( fara abs )
Sa-mi zici ce marca sunt si sa imi dai un pret pentru ele ( plus transport, imi trebuie in Tg-Mures )
Mersi mult.
Dacia Logan 2006 1.6MPI Preferance - MS 13 GLO
RadulescuRomulus
post 14 Nov 2011, 10:06
Post #141
Salut,
filtre ulei
HENGST: 43.50 ron
KNECHT: 25 ron
UFI: 18 ron
filtru aer
HENGST: 38 ron
UFI: 28 ron
ulei Catrol MAGNATEC A3/B4 - 10W40 - 4L = 106 ron
placute si rulment => searches are ongoing! dau PM cand aflu preturi [mai] bune.
Mersi,
Romulus
0746-218-120
adicted69
post 14 Nov 2011, 10:11
Post #142
Salut
Daca se poate o oferta pentru bujii incandescente(ce marci) pentru un Symbol cu VIN-ul VF1LBR7CF36987766.
Mersi frumos
Renault Symbol 2007 - B-**-GPJ
RadulescuRomulus
post 14 Nov 2011, 10:13
Post #143
zi-mi mai repede ce motorizare si cp ai...
<span class='edit'>14 Nov 2011, 10:54:</span>
@hexagon:
placute frana:
ROADHOUSE: 71 ron [sunt facute de TRW]
SWAG: 55 ron
BOSCH: 73 ron
rulment roata:
Starline: 40 ron [recomandare]
FAG: 80 ron
TRANSPORT: este cu posta romana si e in fct de greutate...
This post has been edited by RadulescuRomulus: 14 Nov 2011, 14:09
Eu4yas
post 14 Nov 2011, 11:17
Post #144
Euforisticul
Buna ziua,
Se poate o oferta de pret pt bielete de directie + capete de bara LEMFORDER sau TRW?
Renault Megane 2.2 1.5 105 2007 K9K 732.
Multumesc
This post has been edited by Eu4yas: 14 Nov 2011, 11:19
RadulescuRomulus
post 14 Nov 2011, 12:46
Post #145
Buna ziua,
bieleta directie LEMFÖRDER: 131 ron
cap bara stanga LEMFÖRDER: 144 ron
cap bara dreapta LEMFÖRDER: 144 ron
Mersi,
Romulus
0746-218-120
adicted69
post 14 Nov 2011, 13:48
Post #146
QUOTE(adicted69 @ 14 Nov 2011, 11:11)
Salut
Mersi frumos
1,5 Dci, 48 kw
RadulescuRomulus
post 14 Nov 2011, 14:05
Post #147
Bujii incandescente BOSCH
Pâna în an fabricatie: 01.10.2007
pret: 42 ron
SAU
Bujii incandescente SWAG: 28 ron
Mersi,
Romulus
0746-218-120
mache2k
post 14 Nov 2011, 16:37
Post #148
- daca mai ai, m-ar interesa si pe mine 1 bidon... + un pret pentru un filtru de ulei 'compatibil' cu un 1.9dCi
M-ar mai interesa un pret pentru bielete directie (Renault Scenic 2 2005), tampon motor (cel de deasupra) si placute de frana Ferodo Premier.
Mersi
This post has been edited by mache2k: 14 Nov 2011, 16:47
Renault Scenic 2005
RadulescuRomulus
post 14 Nov 2011, 16:42
Post #149
@mache2k:
ulei = 130 ron
filtru ulei = zi-mi ce masina ai [an, motorizare cp sau kw].
orientativ, m-am uitat dupa niste filtre ulei, si preturile variaza de la 18 ron [UFI] pana la 44 ron [HENGST]
Da-mi datele masinii sa pot cauta focusat.
Mersi,
Romulus
0746-218-120
This post has been edited by RadulescuRomulus: 14 Nov 2011, 16:48
mache2k
post 14 Nov 2011, 16:54
Post #150
QUOTE(RadulescuRomulus @ 14 Nov 2011, 16:42)
@mache2k:
ulei = 130 ron
Mersi,
Romulus
0746-218-120
Pai am scris mai sus: Renault Scenic 2 2005, 1.9dCi 88kW/120cp... Alte detalii chiar nu stiu...
This post has been edited by mache2k: 14 Nov 2011, 16:54
Renault Scenic 2005
Lo-Fi Version  Harta site  Parteneri  Jocuri online  Curs Valutar  HRH Haine din lana merinos Time is now: 22nd July 2025 - 23:45
