[VAND] Piese Noi LOGAN si RENO, suntem un magazin nou, avem preturi mici
RadulescuRomulus |
#151
![]() Sunt cu ochii pe voi! Group: Members Posts: 1.780 Joined: 7 December 10 From: naufragiat ![]() |
VW Passat berlina
2.0 Tdi CR + DSG
04.2009 - diesel, 140cp
- B 69 COI EX: megane 2.1, 1.5dci, 101 magari - B 314 ZDA
RadulescuRomulus |
#152
CASTROL EDGE 5W30 1L 45 RON
CASTROL EDGE 5W30 5L 200 RON CASTROL EDGE 5W40 TURBO DIESEL 1L 35 RON CASTROL EDGE 5W40 TURBO DIESEL 5L 140 RON CASTROL EDGE TURBO DIESEL 5W40 4L 125 RON CASTROL MAGNATEC DIESEL 5W40 B4 1L 30 RON CASTROL MAGNATEC DIESEL 5W40 B4 5L 130 RON CASTROL MAGNATEC DIESEL B4 - 10W40 - 1L 30 RON CASTROL MAGNATEC DIESEL B4 - 10W40 - 5L 105 RON Ulei VAT, facut in Polonia: Vat SynGold 5W-40 1L 25 RON Vat SynGold 5W-40 4L 92 RON LOGAN ------------------piese marca Starline, garantie 3 ani! Descriere ------------------------------------- Pret vanzare Elemente de directie---------------------------- 31.04 Cap Bara Dreapta-------------------------------- 41.96 Cap Bara Stanga---------------------------------- 41.98 Bieleta directie----------------------------------- 44.05 Bieleta directie----------------------------------- 44.65 Amortizoare spate------------------------------- 154.01 Amortizoare fata--------------------------------- 138.23 Pivot------------------------------------------------ 33.83 Kit-uri rulmenti roata fata fara ABS----------- 38.08 Kit-uri rulmenti roata spate--------------------- 32.25 Bascula dreapta---------------------------------- 106.18 Bascula stanga------------------------------------ 106.18 Bucsa bascula------------------------------------- 14.11 Bieleta antiruliu---------------------------------- 13.46 Discurii frana 260 ventilat--------------------- 147.63 / set 2 buc Discurii frana 238 plin-------------------------- 95.19 / set 2 buc Saboti frana fara ABS--------------------------- 66.64 Saboti frana cu ABS----------------------------- 108.46 Filtru ulei------------------------------------------- 15.74 Filtre aer DCI-------------------------------------- 16.39 Filtre habitaclu----------------------------------- 19.24 SAU orice alta marca doriti. Toate reperele de mai sus sunt marca Starline. Avem la vanzare si alte marci, mai cunoscute pe piata, pt care oferim pret la solicitare expresa. Mai mult, garantia este de 3 ani la reperele Starline! REPERE UNIVERSALE: antigel G12 13,19 RON antigel G12 38,93 RON lichid spalat parbriz -20 grade 5,40 RON lichid spalat parbriz -20 grade 15,35 RON acumulator 44 amperi 196,83 RON acumulator 54 amperi 232,82 RON acumulator 66 amperi 275,16 RON acumulator 74 amperi 305,03 RON acumulator 97 amperi 393,86 RON Bec Megalight Ultra H7 - 55w 38,03 RON Bec incandescent H7 GE 13,57 RON PROMOTIE PANA LA 22 NOIEMBRIE: LICHID FRANA TEXTAR 1L, dot 4, made in Germany = 37.50 RON This post has been edited by RadulescuRomulus: 15 Nov 2011, 20:03 |
VW Passat berlina
2.0 Tdi CR + DSG
RadulescuRomulus |
#153
LICHID FRANA TEXTAR 1L, dot 4, made in Germany = 37.50 RON |
VW Passat berlina
2.0 Tdi CR + DSG
danyos |
#154
![]() Membru autentic Group: Members Posts: 275 Joined: 30 June 09 From: focsani /vrancea ![]() |
buna ziua , pt un scenic 2 - palacute de frana pentru puntea spate , marca TEXAR ? Mentionez ca sistemul de franare la al meu scenic este bosch . merci astept oferta D-voastra
scenic 2
renault
2005 dynamique 1.5 dci
- VN 10 XTX danios
RadulescuRomulus |
#155
cati kw/cp?
74/101 60/82 76/103 78/106 63/86 Avem Textar. Preturile variaza in fct de cati kw/cp aveti... L.E. Sigur pe spate ai sistem de franare Bosch? intreb deoarece pana acum am intalnit pe spate sistem de franare Lucas sau Teves. Bosch doar pe fata. . . Pt siguranta, da-mi kw/cp si VIN-ul, ca sa ofertez corect. Mersi, Romulus This post has been edited by RadulescuRomulus: 17 Nov 2011, 17:37 |
VW Passat berlina
2.0 Tdi CR + DSG
danyos |
#156
da ...... aveti dreptate , sistemul de franare pe puntea spate nu este bosch ci Lucas .
scenic 2
renault
- VN 10 XTX danios
gavy |
#157
![]() Membru incepator Group: Members Posts: 28 Joined: 18 October 10 ![]() |
buna seara ma intereseaza si pe mine telescoape fata pentru twingo 2001 1149 16v 75cp
Twingo
2001 1.2 16v 55kw D4F
RadulescuRomulus |
#158
@danyos:
TEXTAR: 92 ron Grosime [mm]: 15.20 | Latime [mm]: 87.00 | Înaltime [mm]: 53.00 | Sistem frânare: Lucas | Partea de montare: spate @gavy mno, cred ca ai auzit de SACHS - sunt [printre] cei mai tari in domeniu. tari = Calitate. stanga: 307 ron dreapta: 307 ron Sunt si variante mai ieftine, insa pt acelea nu ma incumet sa acord garantie. [oricum, garantia nu ti-o dau eu personal, ci e data de producator prin distribuitor, insa variantele mai ieftine sunt ... dubioase]. ![]() Pe de alta parte, dupa cum se vede, Sachs are preturi la fel, tari ![]() ![]() This post has been edited by RadulescuRomulus: 17 Nov 2011, 21:31 |
VW Passat berlina
2.0 Tdi CR + DSG
dbx |
#159
![]() Membru incepator Group: Members Posts: 99 Joined: 2 June 08 From: Bucuresti ![]() |
Salut, antigel pentru Renault megane 1,9 dCi / 75kW / 2003 (GlaceElf sau Glaceol - marci/preturi) ?
si filtru motorina (mann) Multumesc. |
Megane I
- B-60
RadulescuRomulus |
#160
@dbx:
Salut, Nu am glaceol / glaceElf, insa astea sunt recomandate de producator. Si ar fi bine sa pui din aceastea. am descoperit pret bun la Glaceol / litru in AUCHAN! Cat priveste mann - nu mai aduc, ca nu ies bine. importatorii [sau poate chiar mann?!] au sarit preturile nesimtit de mult, fara nici o justificare din pct meu de vedere. Nu au crescut nici calitatea, nici rapiditatea livrarii, etc... de aia, eu personal m-am reorientat pe Starline, Ufi si chiar Bosch, ca filtre. Calitatea e aceeasi ... |
VW Passat berlina
2.0 Tdi CR + DSG
stanionjan |
#161
Membru autentic Group: Members Posts: 226 Joined: 13 February 11 ![]() |
salut!pt. megane 1,an 2000, 1,6 l,VF1KA0F0523292994,motorasul de relanti,o zi buna!
renault megane
brek
2000,1,6l-benzina
- IL-03-BYL
RadulescuRomulus |
#162
cati cp/kw ai?
cumva 64/87? This post has been edited by RadulescuRomulus: 18 Nov 2011, 19:23 |
VW Passat berlina
2.0 Tdi CR + DSG
dbx |
#163
QUOTE Cat priveste mann - nu mai aduc, ca nu ies bine. importatorii [sau poate chiar mann?!] au sarit preturile nesimtit de mult, fara nici o justificare din pct meu de vedere. Nu au crescut nici calitatea, nici rapiditatea livrarii, etc... de aia, eu personal m-am reorientat pe Starline, Ufi si chiar Bosch, ca filtre. Calitatea e aceeasi ... OK, ascult recomandari si ...preturi pentru filtru motorina (si multam pentru informatii). |
Megane I
- B-60
RadulescuRomulus |
#164
@dbx:
Bosch: 135 ron, pt cele fabricate pana in 01.09.2003 Knecht: 114 ron [acestea sunt facute in mod sigur de Mahle, in germania daca retin bine. = aceasta este si recomandarea mea.] |
VW Passat berlina
2.0 Tdi CR + DSG
hexagon |
#165
Membru incepator Group: Members Posts: 6 Joined: 2 April 07 ![]() |
o sa ramana pana la urma la mine:
filtru ulei UFI: 18 ron filtru aer UFI: 28 ron ulei Catrol MAGNATEC A3/B4 - 10W40 - 4L = 106 ron placute de frana SWAG: 55 ron rulment Starline: 40 ron nu pot sa iti dau pm cu adresa asa ca o sa te sun la un moment dat sa stabilim. mersi mult. |
2006 1.6MPI Preferance
- MS 13 GLO
RadulescuRomulus |
#166
mno bine,
ne auzim cand ai posibilitate. in principiu, sapt ce vine pot pune la curier [posta romana] doar de marti dimineata incolo. |
VW Passat berlina
2.0 Tdi CR + DSG
RadulescuRomulus |
#167
CASTROL MAGNATEC DIESEL 5W40 4L- 120 RON
CASTROL MAGNATEC DIESEL 10W40 4L - 100 RON CASTROL EDGE 5W30 1L 45 RON CASTROL EDGE 5W30 5L 200 RON CASTROL EDGE 5W40 TURBO DIESEL 1L 35 RON CASTROL EDGE 5W40 TURBO DIESEL 5L 140 RON CASTROL EDGE TURBO DIESEL 5W40 4L 125 RON CASTROL MAGNATEC DIESEL 5W40 B4 1L 30 RON CASTROL MAGNATEC DIESEL 5W40 B4 5L 130 RON CASTROL MAGNATEC DIESEL B4 - 10W40 - 1L 30 RON CASTROL MAGNATEC DIESEL B4 - 10W40 - 5L 105 RON Ulei VAT, facut in Polonia: Vat SynGold 5W-40 1L 25 RON Vat SynGold 5W-40 4L 92 RON LOGAN ------------------piese marca Starline, garantie 3 ani! Descriere ------------------------------------- Pret vanzare Elemente de directie---------------------------- 31.04 Cap Bara Dreapta-------------------------------- 41.96 Cap Bara Stanga---------------------------------- 41.98 Bieleta directie----------------------------------- 44.05 Bieleta directie----------------------------------- 44.65 Amortizoare spate------------------------------- 154.01 Amortizoare fata--------------------------------- 138.23 Pivot------------------------------------------------ 33.83 Kit-uri rulmenti roata fata fara ABS----------- 38.08 Kit-uri rulmenti roata spate--------------------- 32.25 Bascula dreapta---------------------------------- 106.18 Bascula stanga------------------------------------ 106.18 Bucsa bascula------------------------------------- 14.11 Bieleta antiruliu---------------------------------- 13.46 Discurii frana 260 ventilat--------------------- 147.63 / set 2 buc Discurii frana 238 plin-------------------------- 95.19 / set 2 buc Saboti frana fara ABS--------------------------- 66.64 Saboti frana cu ABS----------------------------- 108.46 Filtru ulei------------------------------------------- 15.74 Filtre aer DCI-------------------------------------- 16.39 Filtre habitaclu----------------------------------- 19.24 SAU orice alta marca doriti. Toate reperele de mai sus sunt marca Starline. Avem la vanzare si alte marci, mai cunoscute pe piata, pt care oferim pret la solicitare expresa. Mai mult, garantia este de 3 ani la reperele Starline! REPERE UNIVERSALE: antigel G12 13,19 RON antigel G12 38,93 RON lichid spalat parbriz -20 grade 5,40 RON lichid spalat parbriz -20 grade 15,35 RON acumulator 44 amperi 196,83 RON acumulator 54 amperi 232,82 RON acumulator 66 amperi 275,16 RON acumulator 74 amperi 305,03 RON acumulator 97 amperi 393,86 RON Bec Megalight Ultra H7 - 55w 38,03 RON Bec incandescent H7 GE 13,57 RON PROMOTIE PANA LA 22 NOIEMBRIE: LICHID FRANA TEXTAR 1L, dot 4, made in Germany = 37.50 RON 21 Nov 2011, 16:48: Am primit o promotie. V-o atasez in aceeasi ordine si format care mi-a fost data. This post has been edited by RadulescuRomulus: 21 Nov 2011, 16:48 Attached File(s) ![]() |
VW Passat berlina
2.0 Tdi CR + DSG
RadulescuRomulus |
#168
Promotie la PROMOTIE:
~ cine a mai cumparat articole de la mine, pretul de achizitie pt lichid frana TEXTAR ramane 37.50 RON. Pretul intreg este de 41 ron / 1L. |
VW Passat berlina
2.0 Tdi CR + DSG
RadulescuRomulus |
#169
VW Passat berlina
2.0 Tdi CR + DSG
lungubogdan |
#170
Membru incepator Group: Members Posts: 98 Joined: 22 July 08 ![]() |
buna ziua,
m-ar interesa si pe mine un ventilator de habitaclu (climatronic) pentru masina: Marca: RENAULT Anul: 2003 Model: LAGUNA II Grandtour (KG0/1_) Submodel: 1.9 dCi (KG0G) Serie sasiu: VF1KG0G0628926185 Email: lungubogdan@yahoo.com ati spus ca aveti piese si pentru alte masini nu? un kit de distributie pentru vw new beetle 2001 motor 1.6 SR tip AYD 75 kw wvwzzz9cz1m626854 si niste anvelope de iarna 225/45/r17. piese vin cu factura nu? le cumpar pe firma. o zi buna, This post has been edited by lungubogdan: 24 Nov 2011, 10:01 |
seat
leon 5F ST 1.2TSI DSG7
2014
- B59GAE
RadulescuRomulus |
#171
@lungubogdan: ai PM
VW Passat berlina
2.0 Tdi CR + DSG
RadulescuRomulus |
#172
Lista de preturi [mai ales cea din .pdf], din postul 167, este VALABILA!
VW Passat berlina
2.0 Tdi CR + DSG
vik_nini01 |
#173
![]() Membru Group: Members Posts: 121 Joined: 14 December 10 ![]() |
sal,vreau sa-mi bag lumina in torpedou
![]() cod :contactor - 7700816818 lampa alba - 8200418356 (are bec tip w5w) lampa neagra - 7700771935 sau 7701042832 -ANTENA RADIO DE CITROEN C2,COD :6561.N3 DOAR UNA DIN LAMPA (CEA MAI IEFTINA) ASTEPT UN RASP.MS FA-MI UN PRET SI LA AMORTIZOARE FATA CLIO 1.5 DCI,48 KW,BICORP DIN 2003 This post has been edited by vik_nini01: 26 Nov 2011, 01:51 |
renault
clio II
2003 hatchback 1.5dci
- bv 87 nin
RadulescuRomulus |
#174
Salut vik_nini01,
Din tot ce ai solicitat, eu pot sa iti dau doar amortizoare pt Clio: STARLINE: 170 ron ALKO: 175 ron KAYABA: 227 ron SACHS: 256 ron In fct de cine si cum conduce masina, recomandarea mea este Starline sau Alko [un mod economic, 100% fiabil si siguranta], iar Sachs [daca vrei performante deosebite]. Cele bune, Romulus |
VW Passat berlina
2.0 Tdi CR + DSG
vik_nini01 |
#175
astea vin la bucata sau la set ca nu am mai cumparat si nu am idee,mrs mult!
renault
clio II
- bv 87 nin
RadulescuRomulus |
#176
Preturile sunt exprimate pe bucata!
Se poate achizitiona si o singura bucata, insa nu este recomandat. Multumesc, |
VW Passat berlina
2.0 Tdi CR + DSG
RadulescuRomulus |
#177
In curand, preturi f bune la acumulatori XT BAT.
VW Passat berlina
2.0 Tdi CR + DSG
RadulescuRomulus |
#178
VW Passat berlina
2.0 Tdi CR + DSG
stefanbadboy |
#179
Membru incepator Group: Members Posts: 9 Joined: 11 October 10 ![]() |
salut.sunt interesat de urmatoarele piese,pt renault megane 2/2006,
cap planetara/stanga/dreapta discuri frana spate rulmenti spate amortizor fata flanse amortizor/rulment sonda landa termostat multumesc si astept un raspuns cu preturile URGENT |
renault
megane
- B 969 RTK
Davidoff |
#180
![]() Membru incepator Group: Members Posts: 19 Joined: 27 July 06 From: Bucuresti ![]() |
Buna ziua!
Sunt interesat de un senzor de presiune rampa pentru Renault Symbol 1.5 dci 60kw Euro 3, an 2006. Eventual rampa de inalta presiune daca nu exista doar senzorul singur. This post has been edited by Davidoff: 30 Nov 2011, 08:21 |
Symbol 2006
Expression, 1.5dci, 60kW/82CP
- B 270 Getting older, so carpe diem ;)
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 23rd July 2025 - 02:41 |
