33 Pages « < 9 10 11 12 13 > »
> [VAND] Piese Noi LOGAN si RENO, suntem un magazin nou, avem preturi mici
RadulescuRomulus
post 16 Feb 2012, 11:49
Post #301
Sunt cu ochii pe voi!
Preturi f bune la ulei si acumulatori in posturile #272 si #289 !
VW Passat berlina 2.0 Tdi CR + DSG 04.2009 - diesel, 140cp - B 69 COI
EX: megane 2.1, 1.5dci, 101 magari - B 314 ZDA
RadulescuRomulus
post 17 Feb 2012, 14:48
Post #302
NOI SORTIMENTE DE ULEI MOTOR, in oferta noastra.
gama de ulei XT:
XToil Hypersynt 5W-40 1L = 16.90 ron
Ulei sintetic, Sae 5w-40 A3/B3/C3, WV 502.00/505.00, MB 229.1/229.3
XToil Hypersynt 5W-40 5L = 77.50 ron
XToil Synplus 10w-40 1L = 15.50 ron - 5L = 80 ron
Ulei semisintetic, Sae 10w-40 A3/B4-04, VW 500.00/505.00, MB 229.1
LA CASTROL, avem preturi MINIME:
CAS EDGE 0W-40/1 = 55 ron
CAS EDGE 0W-40/4 = 210 ron
EDGE 5W30 -1L = 44.50 ron
EDGE 5W30 -5L = 199 ron
EDGE TURBO DIESEL 5W40 -1L = 35 ron
EDGE TURBO DIESEL 5W40 - 5L = 141.50 ron
MAGNATEC C3 - 5W40 - 1L = 30.50 ron
MAGNATEC C3 - 5W40 - 5L = 120 ron
MAGNATEC DIESEL B4 - 5W40 - 1L = 29.50 ron
MAGNATEC DIESEL B4 - 5W40 - 4L = 114.50 ron
MAGNATEC A3/B4 - 10W40 - 1L = 27.50 ron
MAGNATEC A3/B4 - 10W40 - 5L = 110 ron
PROMO: filtru benzina, BOSCH = 30 ron, compatibilitati in postul nr. 214.
PIESE OE si AFTERMARKET pt reno cu precadere, dar si alte marci. Oferim producatori competitivi prin calitate: SWAG, LEMFORDER, BREMBO, RTS, BOSCH, KAYABA, SACHS dar si alternative a unor jucatori de calitate, intrati pe piata mai recent: STARLINE [ http://www.starline-parts.com/home-page ] si XT [uleiuri, antigel, baterii, etc]
LICHID FRANA TEXTAR, dot 4, 1L : 22 ron
Indiferent de valoarea comenzii, transport gratuit pentru Bucuresti. In tara trimitem cu Posta Romana, intre 16 ron si 25 ron, transport cu plata ramburs in fct de greutatea coletului.
Va invitam sa cereti macar o cotatie de pret pt a va face idee de oferta noastra.
ACUMULATORI:
XT BAT PREMIUM 56 = 220 RON
Voltaj: 12
Cold-test Current, EN [A] = 480
Battery Capacity [Ah] = 56
Length [mm] = 242
Width [mm] = 175
Height [mm] = 190
XT BAT PREMIUM 72 = 374 RON
Voltaj: 12 V
Cold-test Current, EN [A] = 680
Battery Capacity [Ah] = 72
Length [mm] = 278
Width [mm] = 175
Height [mm] = 175
XT BAT PREMIUM 74 = 384.50 RON
Voltaj: 12 V
Battery Capacity [Ah] = 74
Length [mm] = 278
Width [mm] = 175
Height [mm] = 190
BOSCH: = 220 RON
Voltaj: 12 V
Length [mm] = 242
Width [mm] = 175
Height [mm] = 190
BOSCH: = 280
Voltaj: 12 V
Cold-test Current, EN [A] = 640
Battery Capacity [Ah] = 70
Length [mm] = 278
Width [mm] = 175
Height [mm] = 175
RadulescuRomulus
post 20 Feb 2012, 11:20
Post #303
UP!
ARAMIS
post 20 Feb 2012, 12:20
Post #304
neste incandescente pentru masina din semnatura?
Renault Megane 2.1 2003 hatch 1.5dCi 82>100 HP (Ph1) Authentique - BR - - NKD
RadulescuRomulus
post 20 Feb 2012, 13:00
Post #305
ai PM.
RadulescuRomulus
post 21 Feb 2012, 14:11
Post #306
cucu-bau!
RadulescuRomulus
post 23 Feb 2012, 09:40
Post #307
gabinicu77
post 23 Feb 2012, 16:16
Post #308
Buna ziua,
pentru un logan 1.4 din 2005 fara ABS, varianta Ambiance, UU1LSDAAH33430438, as dori o oferta pentru :
- set discuri frana
- set placute frana
- brat inferior stanga cu bucse (daca exista si varianta cu bucse separat rog oferta si in aceasta varianta)
- bucse bara stabilizatoare (2 int + 2 ext)
Multumesc!
Renault Megane II 1.6 16v 2009 Luxury edition
RadulescuRomulus
post 24 Feb 2012, 11:08
Post #309
ai PM!
RadulescuRomulus
post 25 Feb 2012, 13:06
Post #310
Valabil!
preturi in postul #302, pe aceasta pagina.
gabinicu77
post 25 Feb 2012, 18:49
Post #311
Merci de oferta.
Deoarece nu pot sa dau PM, intreb aici : ce diametru au discurile de frana (citisem pe undeva ca sunt doua variante, iar eu inca nu le-am masurat)?
paulbdn
post 25 Feb 2012, 22:20
Post #312
preturi pt geam oglinzi stanga/dreapta scenic 1 din 2001 cu incalzire daca sunt?
Renault Scenic 2002 Expression
RadulescuRomulus
post 26 Feb 2012, 15:19
Post #313
@paulbdn: salve, nu avem sad.gif
@gabinicu77: revin cu PM luni...
dj_ionutz
post 27 Feb 2012, 13:38
Post #314
pret 4 bujii clio 1.4 8v si inel etansare esapament?
C li o
Cautati siguranta? Circulati cu sandero.
razvan_Bv47
post 27 Feb 2012, 14:43
Post #315
spirala air-bag pentru laguna 2 , 2002,1.9 dci ?
cheder usa sofer?
Un pret daca se poate
Renault Laguna II 2002 privilege
RadulescuRomulus
post 27 Feb 2012, 20:34
Post #316
@razvan_Bv47: imi pare rau, nu te pot ajuta...
paulbdn
post 27 Feb 2012, 20:59
Post #317
Salut, pret pentru semnale laterale logan (albe)?
Multumesc!
desmo
post 28 Feb 2012, 00:56
Post #318
trimite-mi si mie oferta pe care ti-am dat-o pe PM. ms.
Renault Laguna III 2008/ 2.0 Dci-150 cp
constant si iute...
RadulescuRomulus
post 28 Feb 2012, 11:16
Post #319
@desmo: ai PM.
28 Feb 2012, 11:56:
@paulbdn: ai PM cu info despre oglinzi. despre semnale logan - nu te pot ajuta.
This post has been edited by RadulescuRomulus: 28 Feb 2012, 11:56
beboiu
post 28 Feb 2012, 14:06
Post #320
tampon hidroelastic pentru un megane 2.1 1.5 dCI 74kw din 2004 hatchback, pe original/ producator ?
This post has been edited by beboiu: 28 Feb 2012, 14:10
renault megane 2.1 2004 1.5 dCi 74kw
RadulescuRomulus
post 28 Feb 2012, 14:33
Post #321
@beboiu: ai PM. ne auzim la telefon daca te hotarasti, ca nu poti da PM [inca]
gabinicu77
post 28 Feb 2012, 17:46
Post #322
QUOTE(gabinicu77 @ 25 Feb 2012, 19:49)
... ce diametru au discurile de frana (citisem pe undeva ca sunt doua variante, iar eu inca nu le-am masurat)?
QUOTE(RadulescuRomulus @ 26 Feb 2012, 16:19)
... ai aflat ceva, legat de diametrul discurilor de frana? (logan 1.4MPI 2005 fara ABS, varianta Ambiance, UU1LSDAAH33430438) respekt.gif
This post has been edited by gabinicu77: 28 Feb 2012, 17:48
RadulescuRomulus
post 28 Feb 2012, 20:23
Post #323
@gabinicu77:
salut,
azi am revenit la lucru si 1001 restante ma asteptau.
Maine ma ocup si de discurile care te intereseaza. Cauti un anume diametru? Fugi de o anumite dimensiune? Am mai vandut discuri si toate s-au potrivit 1:1... de aceea sunt curios / surprins de solicitarea ta.
gabinicu77
post 28 Feb 2012, 20:31
Post #324
Sunt doua dimensiuni de discuri pe logan...si nu as vrea sa fac comanda in necunostiinta de cauza. Vezi atasamentul.
Attached File(s)
RadulescuRomulus
post 29 Feb 2012, 10:40
Post #325
@gabinicu77: discurile sunt pe 259 diametru wink.gif
RadulescuRomulus
post 1 Mar 2012, 10:44
Post #326
oferta valabila!
gabinicu77
post 1 Mar 2012, 19:16
Post #327
Salut,
merci frumos de oferta trimisa. Eu inca nu m-am decis (nici nu ma grabesc foarte tare) dar, cel mai probabil saptamana viitoare te voi contacta telefonic pentru o comanda.
PS : Brat inferior complet marca TRW poti aduce si la ce pret ?
RadulescuRomulus
post 2 Mar 2012, 09:55
Post #328
salut gabi,
imi pare rau, nu am gasit pe TRW la preturi bune.
desmo
post 2 Mar 2012, 15:36
Post #329
recomand cu mare incredere.
constant si iute...
corne04
post 2 Mar 2012, 17:42
Post #330
capace protectie janta Drenalic (pt Renault Laguna II) poti aduce? ma refer la capacelele cu sigla reno de pe janta...atasez poza
Renault Laguna II 2002 - AR-19-CNN
Lo-Fi Version  Harta site  Parteneri  Jocuri online  Curs Valutar  HRH Haine din lana merinos Time is now: 25th July 2025 - 03:24
