PROBLEME - Vopsea, Vopsea
Spirt-UA |
![]() Membru incepator Group: Members Posts: 35 Joined: 31 March 11 From: Kiev - Ukraine ![]() |
Attached thumbnail(s) IMG_0363.jpg ( Size: 112.2k ) Number of downloads: 3184 __1058___1088___1077___1097___1080___1085___1072__3.JPG ( Size: 51.4k ) Number of downloads: 3652 __1060___1086___1090___1086_1243_1.jpg ( Size: 14.05k ) Number of downloads: 3789 |
Renault DUSTER 4-4 Laureate
Бензин
- AA6569CB Spirt in Ukraine forum Renault Duster
What about guarantee?
If you don't have guarnatee, the problem is because of: 1. Not enough elasticizant additive was added in paint 2. Thickness of the paint is too high 3. Elastic sealants was still wet (not cured enough) when painted. The real solution for the problem is repainting. Practical solution: filling the crack with something (paint, clear coat etc) |
Spirt-UA |
Guarantee on all machines is +
Whether you have such problems??? They were resolved??? We have all the cars still under warranty is another question - what caused this problem? The question is - whether you have such cases. |
Бензин
vic24 |
![]() Membru autentic Group: Members Posts: 509 Joined: 14 April 08 ![]() |
din moment ce afecteaza aproape toate symbolurile, ce te face sa crezi ca s-ar remedia ceva la dacia ? una peste alta, eu cand am avut problema (cam la 1,5 ani de la cumparare) am dat cu vopsea si lac peste fisuri si noul strat nu a mai crapat. posibil, se pare, sa fie masticul de imbinare vopsit inca crud in fabrica...?!
Sandero
1.4
bobo77 |
Sau caroseria se onduleaza fiind insuficient ranforsata...
Laureate 1,6 mpi
2008 ph 2
vic24 |
saaaaaaau !
Sandero
1.4
PaulT |
Ceva asemanator aici:
http://www.daciaclub.ro/index.php?showtopi...dpost&p=3171352 Este putin mai vechi, din octombrie. |
Dacia/Mitsubishi
2006 Laureate/1973/2008
- B-00-xxx
blubbor |
Membru incepator Group: Members Posts: 1 Joined: 26 December 11 ![]() |
sad
asdasd
virgiliu |
![]() Membru incepator Group: Members Posts: 84 Joined: 13 April 09 From: Bucuresti ![]() |
Aceeasi problema cu apa in portbagaj am avut-o si eu. S-a rezolvat la service prin etansarea suplimentara cu mastic la balamalele hayonului. A aparut alta problema, mecanicii lui peste au stricat alineamentul haionului si imi atinge bara de protectie.
Duster 4x4 cu 4x4 valve
2010
Iszy |
![]() Membru autentic Group: Members Posts: 509 Joined: 17 April 10 From: Cluj ![]() |
Salut! 4 x 4 dci
![]() Are cineva solutie tehnica si/sau materiale pentru vopsirea, nichelarea etc. tobei spate si tevii esapament partea din spate care rugineste si arata urit? |
DUSTER 1,5 DCi 110 HP 4 x 4
2012/Laureate ' Intilnirea - un inceput; a ramine impreuna - un avans; a conlucra - un succes ' (Henry Ford)
jocherjocher |
![]() Membru incepator Group: Members Posts: 55 Joined: 17 July 09 From: prin lume ![]() |
raspuns tarziu dar sa zicem...exista vopsea rezistenta la temperaturi inalte...de ex in industria navala...cauta pe net contactele firmelor axate pe vopsea navala : International Paints, Hempel, Jotun, Chugoku Marine Paints, Sigma Coatings...astea sunt cele mai relevante si toate au astfel de produse...tot ce am intalnit/folosit era pe baza de particule de aluminiu si culoare gri...intreaba-i daca au si alte culori...recipientele au cam 4-5 litri minimum (de verificat cu ei) deci ar trebui sa te mai cuplezi cu alti doritori ca sunt destul de scumpe.
This post has been edited by jocherjocher: 25 Nov 2012, 21:00 |
Peugeot 207
Ford Transit
tavi_ro |
Membru autentic Group: Members Posts: 868 Joined: 11 September 05 ![]() |
Pai toba e considerata "consumabila" ? Daca a ruginit in garantie nu se schimba ? La ce e buna garantia aia anticoroziune?
Duster
Laureate 2012-1.6 16V, 4x4, GPL Tomasetto Stag4
Q-Box plus Logan Laureate 2005-1.4 MPI
Squirrel |
![]() Captain of Black Pearl™… Group: Members Posts: 4.466 Joined: 13 March 08 From: partea mea: Drum bun! ![]() |
La părțile vopsite. Și doar dacă "se vede dincolo".
Duster
2010 1,6 16v 4Ś4 Laureaté Noir Nacré
- RO 44 AWD Fire, walk with me...in 4 strokes, water cooled.
tavi_ro |
Asa, bun si toba la ce categorie intra? Ca a mea a luat o culoare foarte frumoasa zici ca i-a dat careva foc. Si banuiesc ca o sa rugineasca in curand, sau poate ma insel.
Duster
Squirrel |
Poți încerca cu garanția…dar am îndoieli referitoare la succesul înlocuirii acesteia pe garanție în lipsa unui defect de fabricație dovedit.
Duster
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 13th July 2025 - 20:01 |
