[VAND]Vand amplificatoare
adytza1212 |
Membru Group: Members Posts: 130 Joined: 25 July 08 ![]() |
Attached thumbnail(s) HPIM6012.JPG ( Size: 1.5mb ) Number of downloads: 91 HPIM6013.JPG ( Size: 672.02k ) Number of downloads: 89 |
Seat
Cordoba
adytza1212 |
Amplificator auto COUGAR C500.4 - 150 ron
Putere maxima 4 x 400 Putere RMS 4 x 95W RMS Posibilitatea de a se conecta in 4 ,3 , 2 canale Bass Boost (6, 12 dB). PIONEER GM3400: - 130 ron 4x80W REXCEL KB 905 - 140 RON 4X100W XXL AMP 444 - 140 ron 4 CHANNEL : 4x175 WATT ( 4x80 WATT RMS ) 3- CHANNEL : 2x175 WATT + 1x350 WATT ( 2x 80 WATT + 1x160 WATT RMS ) 2- CHANNEL : 2x350 WATT (2x160 WATT RMS ) WECONIC VX 4200 - 160 ron 4 x 50Wrms @ 4 ohm 2 x 120Wrms @ 4 ohm Filtru canal 1/2 LPF Filtru canal 3/4 HPF High-Level-Input Greutate 4,5 kg IMPACT LK454 - 200 ron Power RMS (4 Ohms) 75W x 4 tri mode operation Bass Boost (Variable) 0~ +18dB High Pass Crossover 100Hz Low Pass Crossover (Variable) Continuously Variable 35Hz ~ 155Hz Bridged (4 Ohms) Power 250W x 2 Audison LR72 - 170 ron MAX DYNAMIC POWER (2 Ch x 4 Ohms) 75 W MAX DYNAMIC POWER (1 Ch x 4 Ohms) Bridge 225 W CONT. NOMINAL POWER (Tol. +10%; -5%) 2 Ch x 4 Ohms; 0.3% THD; 12 VDC 45 W (RMS) CONT. OUT POWER (2 Ch x 4 Ohms; 13.8 VDC) 50 W (RMS) CONT. OUT POWER (2 Ch x 2 Ohms; 13.8 VDC) 75 W (RMS) MONO OUT POWER (1 Ch x 4 Ohms; 13.8 VDC) Bridge 150 W (RMS) DISTORTION THD (1 KHz; 90% Nominal Pwr) 0.07 % BANDWIDTH (-3 dB; Nominal Pwr) 4 Hz ÷ 100 KHz DAMPING FACTOR (4 Ohms) 150 RISE TIME 4.5 μS SIGNAL / NOISE RATIO 98 dBA INPUT SENSITIVITY 0.3 V ÷ 4 VRMS INPUT IMPEDANCE 15 KOhms LOAD IMPEDANCE Stereo 8 - 4 - 2 Ohms LOAD IMPEDANCE Mono 8 - 4 Ohms Audison SR8055 - 170 ron CONT. OUT POWER (2 Ch x 4 Ohms; 13.8 VDC) 55 W (RMS) MONO OUT POWER (1 Ch x 4 Ohms; 13.8 VDC) Bridge 110 W (RMS) Attached thumbnail(s) Audison_SR8055__1_.JPG ( Size: 886.02k ) Number of downloads: 76 Audison_SR8055__2_.JPG ( Size: 678.46k ) Number of downloads: 77 Audison_LR72__1_.JPG ( Size: 1.3mb ) Number of downloads: 75 Audison_LR72__2_.JPG ( Size: 477.23k ) Number of downloads: 6 |
Seat
Cordoba
adytza1212 |
COUGAR C500.4 - Vandut
XXL AMP 444 - Vandut |
Seat
Cordoba
amadi |
![]() Membru autentic Group: Members Posts: 971 Joined: 17 January 08 From: Mehedinti ![]() |
cu reducerile alea, prima statie ajunge pe la vreo 42lei (10% de 12x). frumoasa pioneer-ul ala si super bune.
spor la vanzare! |
renault
laguna 2
2002 privilege :( 1.9 dci 120hp
adytza1212 |
Ar fi trebuit sa platesc eu pe cineva ca sa le cumpere la cate reduceri au fost.
![]() Ms de urari. |
Seat
Cordoba
adytza1212 |
Valabile in continuare
PIONEER GM3400: - 130 ron 4x80W REXCEL KB 905 - 130 RON 4X100W WECONIC VX 4200 - 140 ron 4 x 50Wrms @ 4 ohm 2 x 120Wrms @ 4 ohm Filtru canal 1/2 LPF Filtru canal 3/4 HPF High-Level-Input Greutate 4,5 kg IMPACT LK454 - 180 ron Power RMS (4 Ohms) 75W x 4 tri mode operation Bass Boost (Variable) 0~ +18dB High Pass Crossover 100Hz Low Pass Crossover (Variable) Continuously Variable 35Hz ~ 155Hz Bridged (4 Ohms) Power 250W x 2 Audison LR72 - 130 ron MAX DYNAMIC POWER (2 Ch x 4 Ohms) 75 W MAX DYNAMIC POWER (1 Ch x 4 Ohms) Bridge 225 W CONT. NOMINAL POWER (Tol. +10%; -5%) 2 Ch x 4 Ohms; 0.3% THD; 12 VDC 45 W (RMS) CONT. OUT POWER (2 Ch x 4 Ohms; 13.8 VDC) 50 W (RMS) CONT. OUT POWER (2 Ch x 2 Ohms; 13.8 VDC) 75 W (RMS) MONO OUT POWER (1 Ch x 4 Ohms; 13.8 VDC) Bridge 150 W (RMS) DISTORTION THD (1 KHz; 90% Nominal Pwr) 0.07 % BANDWIDTH (-3 dB; Nominal Pwr) 4 Hz ÷ 100 KHz DAMPING FACTOR (4 Ohms) 150 RISE TIME 4.5 μS SIGNAL / NOISE RATIO 98 dBA INPUT SENSITIVITY 0.3 V ÷ 4 VRMS INPUT IMPEDANCE 15 KOhms LOAD IMPEDANCE Stereo 8 - 4 - 2 Ohms LOAD IMPEDANCE Mono 8 - 4 Ohms Audison SR8055 - 130 ron CONT. OUT POWER (2 Ch x 4 Ohms; 13.8 VDC) 55 W (RMS) MONO OUT POWER (1 Ch x 4 Ohms; 13.8 VDC) Bridge 110 W (RMS) OSIO NRG4070X - 150 ron 4 x 70 Watt RMS @ 4 ohm 4 x 85 Watt RMS @ 2 ohm 2 x 140 Watt RMS @ 4 ohm - THD: 0.05% - S/N Ratio: >100 dB A - High level input - Low Pass Filter 40~250Hz @ 12dB/oct - High Pass Filter 40~250Hz @ 12dB/oct Tel 0769607934 This post has been edited by adytza1212: 5 May 2012, 12:33 Attached thumbnail(s) OSIO_NRG_4070X__1_.JPG ( Size: 891.4k ) Number of downloads: 7 OSIO_NRG_4070X__2_.JPG ( Size: 615.78k ) Number of downloads: 8 |
Seat
Cordoba
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 21st July 2025 - 02:09 |
