Dacia 1310/1984 - 5° gearbox?
Jiri89 |
Membru incepator Group: Members Posts: 1 Joined: 8 April 12 ![]() |
Transit
- 30100
bucatzel |
![]() Membru plictisit Group: Moderatori Posts: 6.507 Joined: 19 May 08 From: Timisoara ![]() |
Hey George.
Yes, you can easily exchange a 4 gear gearbox with a 5 gear gearbox. The only thing is that 5 gear ones use only short driveshafts (65 cm length) while 4 gear one use both short ones or long ones (66 cm length, mainly on older models). Your car, being a '84, should be using short ones, but there have been cases where a car had the other type mounted long after being retired from production. Anyway, even if you have the long driveshaft model, you can change the gearbox, just that you have to change the driveshafts as well. Also, the connecting underpinnings need to be changed, as they differ on these gearboxes, and you need to hammer the floor upwards a bit in one spot, because there's a place where the 5 gear gearbox touches the floor, if it's mounted instead of a 4 gear gearbox. |
- 3-SB-2608
1981 Si cu dansa-ntransa, si cu sufletu' in rai... cam greu...
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 4th August 2025 - 10:58 |
