13 Pages « < 4 5 6 7 8 > »
> [VAND] Renault Laguna 1, Dezmembrez Renault Laguna 1 1.6, 16v; 1.8, 16v;2.0
katalyn03
post 10 Feb 2013, 10:25
Post #151
valabil
Renault laguna 1998 1.6 16v - DJ 84 HRB
Schimb distributii (100 RON) si repar orice RENAULT.Dezmembrez Laguna 1 si 2, Megane 2, Safrane.....
TEL: 0766 34 18 99
Monaco
post 10 Feb 2013, 10:53
Post #152
Ma intereseaza si pe mine un volan si un capac de-ala de cauciuc anticondens pentru far.
Renault Laguna 1999 Ph2 Concorde
katalyn03
post 10 Feb 2013, 19:34
Post #153
QUOTE(Monaco @ 10 Feb 2013, 10:53)
volan nu am nici unul bun
un capac far 10 ron
TEL: 0766 34 18 99
mishucc
post 14 Feb 2013, 12:04
Post #154
salut mai ai canistra de recirculare gaze ptr 1,6 16v?cand poti sa mio trimiti si mie
renault laguna 1 phase 2 2000
Monaco
post 15 Feb 2013, 12:55
Post #155
Ai si o diuza stropitoare pentru luneta ca sa nu iau numai capacul de far?
katalyn03
post 15 Feb 2013, 18:04
Post #156
QUOTE(mishucc @ 14 Feb 2013, 12:04)
da 40 ron
15 Feb 2013, 18:05:
QUOTE(Monaco @ 15 Feb 2013, 12:55)
inca 10 ron
This post has been edited by katalyn03: 15 Feb 2013, 18:05
TEL: 0766 34 18 99
mishucc
post 18 Feb 2013, 15:06
Post #157
imi poti trimite canistra prin posta?
katalyn03
post 18 Feb 2013, 21:35
Post #158
da pot dar dureaza mai mult
TEL: 0766 34 18 99
katalyn03
post 25 Feb 2013, 08:21
Post #159
discuri spate laguna 2 150 ron/buc
This post has been edited by katalyn03: 25 Feb 2013, 08:22
TEL: 0766 34 18 99
katalyn03
post 4 Mar 2013, 19:26
Post #160
caseta directie renault laguna 2 500 ron
TEL: 0766 34 18 99
dorin85
post 5 Mar 2013, 13:31
Post #161
Salut Katalyn, proiectoare pt phase2 ai?
renault laguna 1 1998 1.6i 16V - SB-02-DOR
katalyn03
post 5 Mar 2013, 21:18
Post #162
QUOTE(dorin85 @ 5 Mar 2013, 13:31)
momentan nu
TEL: 0766 34 18 99
Vallybz
post 6 Mar 2013, 20:28
Post #163
galerie evacuare de 1.6 16v? raspuns pe pm
Renault Megane 1 Facelift, 1.6, 16v Coupe 1999 K4M-A7-00 - BZ 87 BVM
katalyn03
post 7 Mar 2013, 19:51
Post #164
QUOTE(Vallybz @ 6 Mar 2013, 20:28)
am 150 ron, ai si pm
cutie viteze 1.6 16v 800 ron
TEL: 0766 34 18 99
katalyn03
post 14 Mar 2013, 08:13
Post #165
7 jante laguna pe 15, 4X100, 6,5J, ET 50 75 ron buc
This post has been edited by katalyn03: 14 Mar 2013, 22:40
TEL: 0766 34 18 99
mishucc
post 19 Mar 2013, 11:48
Post #166
vreau si eu canistra aia de carbon de 1.6 16v cum iti dau adresa sa mio trimiti?
katalyn03
post 19 Mar 2013, 21:35
Post #167
QUOTE(mishucc @ 19 Mar 2013, 11:48)
0766 34 18 99
TEL: 0766 34 18 99
cri8sti
post 20 Mar 2013, 15:43
Post #168
Salut! Clapeta acceleratie de 1.6 16v ai cumva? (cu tot cu senzor pozitie si sa fie in mintile ei) Un pret?
Renault Laguna 1.6 16v + GPL (tomasetto q-box) 2006 Expression - BR-11-PBC
Un om destept rezolva problema, un om si mai destept o evita
katalyn03
post 20 Mar 2013, 19:26
Post #169
QUOTE(cri8sti @ 20 Mar 2013, 15:43)
200 ron
TEL: 0766 34 18 99
katalyn03
post 26 Mar 2013, 08:32
Post #170
TEL: 0766 34 18 99
mishucc
post 26 Mar 2013, 14:57
Post #171
catalin te rog frumos dami si mie un sfat o ideie cu privire la motorul meu.am pus canistra de la tine ptr ca a mea era sparta si credeam ca asta e cauza.cand pornesc imi moare motorul numi tine relantiu.imi sta la relanti numai daca scot conducta care vine din canista de carbon si intra in corpul unde este motorasul pas cu pas.cei drept imi sta mai turat...spunemi si mie o parere te rog
katalyn03
post 26 Mar 2013, 19:50
Post #172
QUOTE(mishucc @ 26 Mar 2013, 14:57)
ai PM
TEL: 0766 34 18 99
mishucc
post 26 Mar 2013, 19:58
Post #173
e schimbat motorasul pas cu pas.sal las desfacut adica tija lui so desfac?sau sal las desfacut din suruburi?asa se regleaza nenorocirea asta nu se reseteaza in niciun fel?
27 Mar 2013, 12:44:
Am curatat motorasul cu wd când lam pus la loc mia pornit perfect cu turatie pana la 1500 si a scăzut singur la 750 am mers 2km am oprito după care din nou nu mai porneste...sare Putin peste 1000 când da sa porneasca si moare instantaneu nu tine relantiu sad.gif
This post has been edited by mishucc: 27 Mar 2013, 12:44
cozo
post 27 Mar 2013, 13:09
Post #174
salut.
galerie de evacuare pentru laguna 1.6 16v?
renault laguna 1998 1.6 16v - TM
katalyn03
post 27 Mar 2013, 18:20
Post #175
QUOTE(cozo @ 27 Mar 2013, 13:09)
salut.
da am 150 ron, dar este sudata
0766 34 18 99
27 Mar 2013, 18:24:
QUOTE(mishucc @ 26 Mar 2013, 19:58)
<span class='edit'>27 Mar 2013, 12:44:</span>
daca nu vad nu stie ce sa zic, eu tot pe IAC sau aer fals merg, clapeta in ce stare este?
nu trebuie sa treaca prin ea nici spay de rugina pe inchis, trebuie sa inchida perfect
bafta!
This post has been edited by katalyn03: 27 Mar 2013, 18:24
TEL: 0766 34 18 99
mishucc
post 27 Mar 2013, 19:33
Post #176
pai aer fals daca tragea nu imi statea prea turata?mie numi tine deloc moare instantaneu...trebuie sa o tin din acceleratie.o sa dau jos si clapeta sa o curat...pe tester daca o pun imi arata daca numi merge IAC-u?
This post has been edited by mishucc: 27 Mar 2013, 19:37
katalyn03
post 28 Mar 2013, 08:24
Post #177
QUOTE(mishucc @ 27 Mar 2013, 19:33)
da ar trebui sa dea eroare, ia un iac de pe alta si incearca-l, dar iacul dupa ce oreste motorul trebuie sa se auda un carait si cand pui contactul la fel
This post has been edited by katalyn03: 28 Mar 2013, 08:26
TEL: 0766 34 18 99
qazwer
post 28 Mar 2013, 17:37
Post #178
qazwer
planetarele de pe 1.8 16v?
Ford / Renault Focus / Laguna 1 ph2 2001 / 02-11-1999 - IS - 30 - ARF
In viata nu primesti ceea ce meriti ci ceea ce NEGOCIEZI
katalyn03
post 28 Mar 2013, 18:31
Post #179
QUOTE(qazwer @ 28 Mar 2013, 17:37)
salut
150 ron buc, pe ce parte iti trebuie
TEL: 0766 34 18 99
mishucc
post 29 Mar 2013, 01:17
Post #180
Iacul se aude ca lucreaza mai ales dupa ce opresc motorul si scot cheia la cateca secunde se aude caraitul care zici tu....in fine....mare bataie de cap imi da problema asta...
This post has been edited by mishucc: 29 Mar 2013, 01:18
Lo-Fi Version  Harta site  Parteneri  Jocuri online  Curs Valutar  HRH Haine din lana merinos Time is now: 23rd July 2025 - 07:53
