> Fuel level sensor for 1310
samson44
post 7 May 2012, 14:57
Hi Guys,
I'm looking for fuel level sensor for '91 Dacia 1310.
Here in Poland i have found only one brand new sensor... but
when i recived i found out it will not fit. My old one was for two cables and
new one must be for newer model - with only one connecting cable.
Can anyone help me finding right one fuel level sensor?
Dacia 1310 TX 1991
post 7 May 2012, 15:06
I guess this is the one you're looking for.
http://www.bestautovest.ro/sonda-benzina-cu-fir-1310.html
I'm not sure if they ship internationally, but it's worth trying.
Anyway, usually what goes wrong with these sensors is the floating element, which you can switch quite easily between the old sensor and the new one, and keep on using the old one.
This post has been edited by bucatzel: 7 May 2012, 15:06
Dacia 1300 - 3-SB-2608 1981
samson44
post 10 May 2012, 22:03
btw - this shop is great,everything in one place
Dacia 1310 TX 1991
samson44
post 15 May 2012, 19:57
Hi Guys,
Just got new fuel level sensor from Bestautovest.ro. I've put this in fuel tank, connected two wires and... nothing. Only low fuel level beam is lighting (fuel in tank about 3/4 full). Any ideas?
Dacia 1310 TX 1991
user123
post 18 May 2012, 23:47
QUOTE(samson44 @ 15 May 2012, 19:57)
.... Only low fuel level beam is lighting (fuel in tank about 3/4 full). Any ideas?
Well.....if the tank is 3/4 full than you can check the floater to see if it`s broken; if it is, when you`ll get it out of your fuel tank you`ll see that its heavy, maybe some gasoline will drip from it too....otherwise, i doubt it`s the floater lever but hell, who knows....
Down here its pretty usual to get broken parts ......hope yours isnt really broken ; best of luck and keep us informed on what you find out...
Dacia Renault 2004/2018
Lo-Fi Version  Harta site  Parteneri  Jocuri online  Curs Valutar  HRH Haine din lana merinos Time is now: 4th August 2025 - 07:18
