8 Pages < 1 2 3 4 > »
> [VAND] piese noi Originale sau Producator, piese de schimb
evali22
post 13 Aug 2012, 11:15
ciumiki ai PM
dacia logan 2005 laureate
AMZ
post 13 Aug 2012, 11:26
Oldschool Member
pe PM sa-mi trimiti si mie o oferta pt.urmatoarele:
SS:VF1KMS70635870405-Renault Megane Estate 2006/1.9Dci-81kw.
Amortizoare spate+arcuri-dar vreau sa trec pe PDG,deci pt.PDG!!
Bucsi Punte spate
Caseta directie+capete de bara+bielete.
Renault Renault Grand Scenic 3.1.6 Dci 130 HP. 2011 - B.XXX.AMZ
evali22
post 13 Aug 2012, 12:15
AMZ, ai PM...
ciumiki
post 13 Aug 2012, 15:27
Curios. NU an primit PM-ul tau. Poti sa mai trimiti inca odata ?
Renault Megane 2007, 1.5 dci
megane 2.2, 1.5 dci, 63 kw, an 2007
evali22
post 14 Aug 2012, 13:42
ciumiki ai primit PM-ul?
evali22
post 16 Aug 2012, 16:37
Valabil in continuare....piese Logan si Renault....
alupsa74
post 18 Aug 2012, 17:02
Salut
set ornamente bara fata Laguna 2 GRI (bandouri) ????
77 01 206 435
Multumesc
Renault Laguna II 2001 Initiale 1.8 16v
evali22
post 20 Aug 2012, 08:17
alupsa74 ce imi ceri tu costa 550 ron setul
This post has been edited by evali22: 20 Aug 2012, 08:17
evali22
post 22 Aug 2012, 22:02
Anunt valabil in continuare, citeva repere noi:
- maneta stergatoare cu buton Cb la------------- 60 ron/buc
- bloc lumini cu proiector model Valeo------------ 120 ron
- bucsi bascule de origine ------------------------ 25 ron/buc
- bujii Equiem------------------------------------ 60 ron/set
- termostat (producator) LG diesel--------------- 115 ron
- cap bara Lemforder ----------------------------- 90 ron/buc
- bieleta directie Lemforder------------------------ 90 ron/buc
- cap bara de origine------------------------------ 90 ron/buc
- bielete directie de origine------------------------ 80 ron/buc
- cap bara RTS------------------------------------50 ron/buc
- bielete directie RTS-------------------------------50 ron/buc
- termostat benzina------------------------------- 35 ron
- pivoti (LEMFORDER)------------------------------ 35 ron
- bascula de origine------------------------------- 110 ron
- set saboti (ATE)-------------------------------- 135 ron
- nuca schimbator Prestige plastic------- ---------- 35 ron
- nuca schimbator Prestige piele--------------------65 ron
- bucsi bara stabilizatore mijloc -------------------- 20 ron/buc
- bielete antiruliu de origine ------------------------ 25 ron/buc
- rulmenti roata FAG fara ABS ---------------------- 80 ron/buc
- rulmenti de spate originali -- ---------------------- 95 ron/buc.
- rulmenti fata originali pentru model fara ABS la ----- 90 ron
- rulment roata cu ABS pana in model 2007 -------- ron
- rulment roata cu ABS dupa model 2007------------ ron
- filtru ulei original Purflux benzina ------------------- 15 ron
- filtru ulei original Motorina ------------------------- 20 ron
- filtru aer benzina si motorina ----------------------- 25 ron
- filtru aer 16 valve --------------------------------- 30 ron
- filtru motorina EURO 3 ---------------------------- 115 ron
- filtru motorina EURO 4 ---------------------------- 125 ron
- filtru polen Valeo ---------------------------------- 25 ron
- oglinzi Prestige electrice ---------------------------270 ron/set
- proiectoare ceata Logan Ph1 Valeo ----------------- 70 ron/buc
- buton reglaj oglinzi electrice ------------------------35 ron
- buton deschidere usa -------------------------------10 ron
- amortizoare Monroe fata ----------------------------120 ro/buc
- amortizoare Monroe spate --------------------------105 ron/buc
- amortizoare Bilstein B4 fata -------------------------145 ron/buc
- amortizoare Bilstein B4 spate ------------------------125 ron/buc
- flanse amortizor originale -----------------------------35 ron/buc
- rulmenti amortizor SNR -------------------------------25 ron/buc
- bieleta antirasturnare --------------------------------75 ron
- bieleta antirasturnare VAN----------------------------80 ron
- carcasa cheie cu telecomanda ----------------------- 50 ron
- discuri frana VAN Brembo --------------------------- 135 ron/buc
- placute frana VAN Ferodo SL ------------------------125 ron/set
- discuri frana 259 pline Ferodo ------------------------175 ron/set
- discuri frana 259 ventilate Ferodo --------------------190 ron/set
- discuri frana 259 ventilate Brembo--------------------210 ron/set
- discuri fraba 259 ventilate Brembo Striate-------------185 ron/buc
- placute frana TRW ----------------------------------- 60 ron/set
- placute frana Ferodo FQT ----------------------------125 ron/set
- placute frana Ferodo Premier--------------------------90 ron/set
- cablu ambreiaj MPI-DCI -------------------------------45 ron
- cablu acceleratie MPI -------------------------------- 35 ron
- sonda servodirectie -----------------------------------50 ron
- sonda mers inapoi -------------------------------------35 ron
- plafoniera 3 becuri ------------------------------------35 ron
- plafoniera 1 bec ---------------------------------------30 ron
- contactor lumina pedala frana ------------------------- 20 ron
- spirala airbag volan ------------------------------------ 60 ron
- kit distributie MPI -------------------------------------175 ron
- pompa apa de origine MPI -----------------------------215 ron
- pompa apa HEPU pt benzina ---------------------------175 ron
- kit distributie DCI ------------------------------------- 315 ron
- pompa apa DCI ----------------------------------------215 ron
- kit ambreiaj SACHS 1.6 MPI ---------------------------- 390 ron/set
- curele accesorii ---------------------------------------- 55 ron
- kit accesorii MPI model cu AC de origine -----------------240 ron
- kit accesorii DCI model cu AC de origine -----------------255 ron
- role ghidaj MPI/DCI------------------------------------- 35 ron
- spray luciu anvelope ------------------------------------25 ron
- autocolante stalpi Prestige ------------------------------35 ron/set
- aeratoare Prestige argintii -------------------------------65 ron/set
- aeratoare Duster cromate--------------------------------60 ron/set
- set tapiterie Black Line----------------------------------140 ron/set
- ulei motor, ELF, CASTROL, MOBIL, ARAL-------------------Intrebati
si multe altele...se pot aduce si piese pentru masini straine,
mentionez ca piesele sunt de origine, nu facaturi.
evali_daniel este id-ul meu
evali22
post 25 Aug 2012, 09:40
Up cu anuntul.....
DODO75
post 27 Aug 2012, 10:31
Buna ziua! Pentru un megane break 2001 , 1.9dci, 75kw, amortizoare fata si bara rigidizare punte spate ai? vf1ka050525250737
This post has been edited by DODO75: 27 Aug 2012, 13:48
RENAULT MEGANE BREAK 2001 / 1
evali22
post 27 Aug 2012, 14:43
DODO75, ai PM
evali22
post 29 Aug 2012, 16:10
Dominohunter
post 3 Sep 2012, 10:58
Salut,
M-ar interesa aceasta fulie:
http://www.piesenet.ro/Fulie-Motor-Renault-Megane2
Stima
renault megane 2003 1.9 dci
danvizi
post 3 Sep 2012, 12:43
Salutare.
Ma intereseaza preturile si codurile lor de origine pentru kit distributie si kit accesorii la un Megane 1,5 dCI 86 cp, euro 4 din 2008. VIN: VF1LMSFC539234102 MOTOR K9 724.
Te intreb si codurile lor echivalente Renault pentru ca am comandat cu seria VIN la un magazin de piese auto bielete antirului si mi-a adus din cele fara PDG, masina avand PDG din fabrica.
Multumesc anticipat.
P.S. Daca se poate o oferta cat mai completa si cu numele firmelor Gates, Ina etc.
Oferata o astept pe PM
Renault Megane Sedan 1.5 dci 86 cp 2008
evali22
post 4 Sep 2012, 09:21
aveti PM
evali22
post 6 Sep 2012, 07:30
evali22
post 10 Sep 2012, 09:21
Valabil in continuare.....
evali22
post 12 Sep 2012, 21:03
sus cu anuntul......
evali22
post 13 Sep 2012, 16:12
Vand diverse piese noi de Logan:
- opritor usi -----------------------------------------35 ron
evali22
post 15 Sep 2012, 17:50
valabil....
evali22
anunt valabil.....
evali22
post 17 Sep 2012, 06:49
sus cu anuntul.....
evali22
valabil in continuare...
evali22
post 19 Sep 2012, 06:38
sus cu anuntul...
evali22
post 19 Sep 2012, 06:39
valabil in continuare.....
evali22
post 23 Sep 2012, 15:31
sus cu anuntul...
evali22
post 23 Sep 2012, 15:32
anecula_08
post 25 Sep 2012, 19:18
Salut
"-maneta stergatoare cu buton Cb la------------- 60 ron/buc"
mai este valabil?
Dacia Solenza Europa cu AC - 1.4 MPI / Renault Laguna 2 Facelift - 1.6 16v / Dacia Logan Stepway - 1.0 TCE
evali22
post 27 Sep 2012, 06:37
sus cu anuntul....
Lo-Fi Version  Harta site  Parteneri  Jocuri online  Curs Valutar  HRH Haine din lana merinos Time is now: 13th July 2025 - 07:06
