2 Pages < 1 2
> Curatare motor loganel
paul_p
post 27 Sep 2012, 00:38
BMW recomanda ca motorul sa fie cald, la temperatura normala de functionare.
Se spala doar zonele care necesita a fi spalate.
Dupa spalare se sufla cu aer comprimat si se porneste imediat motorul.
Procedura de spalare a motorului recomandata in documentatia BMW (TIS) este urmatoarea:
Bring the engine to operating temperature, and switch the engine Off.
Cover or shield any component - such as the ignition distributor, multi-connectors, etc. - in the area to be cleaned with plastic sheeting.
Apply engine degreaser or general engine cleaning solvent to the dirty area, allowing it to soak for at least five minutes.
Spray warm water on the area to be cleaned, flushing the solvent and the contaminants.
Do not aim the water spray directly at components. Do not use the water spray any longer than necessary. Do not wash the entire engine compartment when only one area requires degreasing, such as the front crankshaft radial seal, M20 oil filter replacement, etc.
Blow the cleaned area dry immediately with moderate-pressure compressed air.
Start the engine immediately and road test the vehicle to confirm satisfactory operation.
2 Pages < 1 2
Lo-Fi Version  Harta site  Parteneri  Jocuri online  Curs Valutar  HRH Haine din lana merinos Time is now: 17th June 2025 - 08:45
