Cold Start Problems, Starting the car in the morning.
Russini55 |
Membru incepator Group: Members Posts: 4 Joined: 1 October 12 ![]() |
Duster
1.6 4WD
D-Ice |
Membru autentic Group: Members Posts: 826 Joined: 27 June 10 ![]() |
Check the flywheel sensor, it may be clogged or damaged, though it is hard to believe it may be happening on a new engine.
Check also the spark plug wires or the ignition coil. If the moisture condensates on the high voltage electrical parts on a cold start, it is possible to cause trouble until the engine gets hot and the water evaporates. This is easy to check: put one hand on the wires, and the other one on the chassis, where it stings, there is the problem. Be sure first that you don`t have any heart related health problems, or you may have the oportunity to meet your ancestors. This post has been edited by D-Ice: 9 Oct 2012, 20:54 |
. „Omul a ajuns un semizeu tehnic înainte ca, din punct de vedere moral, să fi coborât de tot din copac.” — Jean Rostand
Russini55 |
Ok guys, seems like that anybody else had the same problem. I went to a shop to make a diagnostic check up. When they plugged the car into the computer the problem that poped up was related to a bad conduction of the gases from the engine to the exhaust system, the gases are clogged up. Either the catalyst or the lambda probe are having problems...i already got my Duster on the elevator but, to be able to work on the catalyst i need to remove the whole part so it will takle longuer than what i expected.
![]() I'll keep you posted...it may happen the same to you and that way you will have some ideas where to start looking. Best regards |
Duster
1.6 4WD
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 4th August 2025 - 07:09 |
