Piese auto la preþuri mici pentru Daciºti/Renoiºti, Piese la cele mai mici preturi GARANTAT! :)
hardinc |
#181
![]() Membru autentic Group: Members Posts: 245 Joined: 28 October 10 From: Slobozia/Ialomita ![]() |
Laguna 1.1
1995, 1.8 RT
pimP |
#182
Membru Group: Members Posts: 158 Joined: 10 February 09 ![]() |
QUOTE(hardinc @ 2 Sep 2015, 09:24) Elemente de caroserie aftermarket pentru o Laguna 1 poti aduce? Ma interesau pragurile si elementele de reparatie pt aripi spate. Daca nu se pot aduce aftermarket, ce preturi au originalele? Salutare, Da-mi te rog o serie de sasiu si mai multe detalii despre masina (tip caroserie, motorina, an). Mersi, Florin |
- - Piese / Consumabile la preturi mici mici :) => http://www.reno.ro/Piese-auto-la-preturi-mici-pentru-Dacisti-Renoisti-t253454.htm
hepea |
#183
Membru autentic Group: Members Posts: 841 Joined: 8 June 10 From: Bucuresti ![]() |
Salut. Un pret kit distributie si accesorii pt. VF1JMGED640138822, te rog. Merci
ex Dacia
Spring
2021
pimP |
#184
hepea |
#185
Grand Scenic, 78kw/105CP, 1461 cmc, 2008
ex Dacia
Spring
2021
hardinc |
#186
Laguna 1 hatchback, benzina , an 1995, 1794cmc ,66kw . VIN : VF1B56AK513179747 . Am nevoie de prag stanga + dreapta si de elementul de reparatie la aripa din spate stanga + dreapta. Atasez poza cu ce imi trebuie in spate:
Laguna 1.1
1995, 1.8 RT
TomachE |
#187
![]() Membru autentic Group: Members Posts: 553 Joined: 20 August 15 From: Bucuresti ![]() |
Salut !M.ar interesa pt VF1KM1R0H34819500-1598cm3,83kw,benzina,2005:
-Sondele Lambda (cea din fata si cea din spate)=>pret -Kit distributie + rola defazoare (este primul schimb de distributie asa k nu ma pricep ce se schimba,dc ma poti ajuta tu !) +>pret Toate pe original,te rog !!! Iti multumesc ! This post has been edited by TomachE: 4 Sep 2015, 14:48 |
Megane II
1.6/16v 82kW 112 cp Break
- B 301 AAT
pimP |
#188
QUOTE(hepea @ 3 Sep 2015, 13:10) Salut, Ai PM ![]() O zi frumoasa, Florin QUOTE(hardinc @ 4 Sep 2015, 06:58) Laguna 1 hatchback, benzina , an 1995, 1794cmc ,66kw . VIN : VF1B56AK513179747 . Am nevoie de prag stanga + dreapta si de elementul de reparatie la aripa din spate stanga + dreapta. Atasez poza cu ce imi trebuie in spate: Screenshot_1.jpg ( Size: 22.81k ) Number of downloads: 405 Salutare, Din pacate in Romania nu mai este permis comercializarea pieselor aftermarket pentru gama Dacia-Renault. Pe original este foarte scump, iti recomand second hand ![]() O zi frumoasa, Florin QUOTE(TomachE @ 4 Sep 2015, 14:46) Salut !M.ar interesa pt VF1KM1R0H34819500-1598cm3,83kw,benzina,2005: -Sondele Lambda (cea din fata si cea din spate)=>pret -Kit distributie + rola defazoare (este primul schimb de distributie asa k nu ma pricep ce se schimba,dc ma poti ajuta tu !) +>pret Toate pe original,te rog !!! Iti multumesc ! Salutare, Ai PM! ![]() O zi frumoasa, Florin |
leo987 |
#189
Membru incepator Group: Members Posts: 5 Joined: 8 July 14 From: Mamaia ![]() |
Va salut!
Pt clio de la profil, VIN: VF1BB0WCF24803810 amortizoare fata la ce pret sunt? Maine merg la mecanic si revin si cu alte repere ( posibil rulment roate fata, elemente de suspensie etc ). Stima! |
Clio 2 Bicorp
2001 Dynamique
bg17aw |
#190
Membru Group: Members Posts: 154 Joined: 23 September 15 From: Bucuresti ![]() |
Nu prea am inteles de ce spui ca in romania nu se mai permite comercializarea de piese aftermarket pt Renault, e plin pe aici de asa ceva, poate explici un pic mai mult.
Ma intereseaza si pe mine un pret la niste piese de origine, dar si in varianta calitate medie aftermarket. Sinteti autorizat si tot ce trebuie pt a beneficia de garantie si a avea siguranta ca piesele de origine (in cutie Renault) chiar sint Renault? Ma intereseaza si pe mine o oferta la urmatoarele daca se poate: VF1LMRFC532563070 Megane II 1.5 dCI 82bhp 60kW 2004 Motor: K9F-D7 - kit distributie 7701477028 - pompa apa - kit accesorii 7701476476 - discuri frana spate 7701207823 - placute frana spate 440605839R - filtru motorina 7701067123 - filtru polen 7701064235 |
Megane II Berlina dCI 82bhp (60kW)
Tetelu1980 |
#191
![]() Membru Group: Members Posts: 162 Joined: 20 December 07 From: Bucuresti ![]() |
Buna seara!
Rog oferta de pret si termen de livrare pentru Bucuresti (inclusiv transport sau ridicare personala) pentru Dacia Logan 1.4 MPI tip LSDAA cu A/C model 2005 serie UU1LSDAAH34000684 pentru urmatoarele: ulei motor ELF Competition 10W40 (sau echivalentul de la ELF ca s-a schimbat denumirea) - 3 l filtru ulei origine - 1 buc. garnitura buson baie ulei motor - 1 buc. filtru aer origine - 1 buc. bujii origine (in cutie parca sunt EYQUEM) - 1 set / 4 buc. antigel origine Dacia Glaceol RX D - 3 litri apa dedurizata/distilata (sau care o fi denumirea tehnica) - 3 litri lichid frana SAE J 1703 DOT 4 - 0,5 l (sau cat este nevoie pentru schimb complet inclusiv pe conductele instalatiei) ulei cutie viteze ELF TRJ 75W80 API GL5 - 4 litri garnitura buson cutie viteze - 1 buc. kit distributie (curea distributie + rola (galet) intinzatoare + pompa de apa) origine - 1 kit kit curea transmisie (accesorii/servicii) (curea si role) versiunea pentru directie asistata si A/C de origine - 1 buc. lichid directie asistata - ELF RENAULTMATIC D2 - 1 litru garnitura capac culbutori (cea pentru asigurare etansare intre capac culbutori si chiulasa) origine - 1 buc. Multumesc, o seara buna! |
Logan Laureate 1.4 MPI
- B-XX-SLT Dacia Logan Laureate 1.4 MPI PH1 (2005) B-XX-SLT
andreis |
#192
![]() Membru autentic Group: Members Posts: 1.689 Joined: 30 June 06 From: B u c u r e s t i ![]() |
Salut,
Ma intereseaza pentru un Renault Megane 2, 1,5 dci, VIN: VF1LMSC537868782 - Amortizoare fata (pentru masina cu pachet de drumuri grele). - Set kit flansa plus rulment Multumesc. |
ex Renault
Megane
2.2 1,6 16v
diesel_power |
#193
![]() Membru autentic Group: Members Posts: 2.964 Joined: 18 February 05 From: diaspora ![]() |
Janta originala Dacia Logan, cod 8200789882, la ce pret ?
Symbol faza 3, 1.5dCi 60kW,
2005, Fidji
thisadi |
#194
Membru autentic Group: Members Posts: 243 Joined: 20 December 11 ![]() |
Salut.
Ma intereseazã pentru un Clio Symbol, an 2009, 1.4 16v, 72kw, SS: VF1LBND0541531325,o caseta de directie. Mersi |
Mr_X |
#195
![]() Membru autentic Group: Members Posts: 398 Joined: 17 October 15 From: Brașov ![]() |
Salut. Am nevoie de:
- Un simering (dreapta) cutie de vitezã - Protecția de cauciuc pentru cablurile electrice care intra în portbagaj (cablurile trec din caroserie în portbagaj printr-o protecție de cauciuc și aia s-a fãcut praf). Pot sã pun o poza dacã e nevoie. - Covorașe (preșuri) fațã, dar sã sã se potriveascã bine. Acum am unele care se agațã în pedale și este foarte enervant. REANULT MEGANE II: VF1LM1R0H37974997 |
Megane II 1.6 16V
vet |
#196
![]() Membrul Group: Members Posts: 464 Joined: 9 December 07 ![]() |
Ma intereseaza si pe mine plasticele de pe fata Logan 1.5 2007 . Toate dracovenile care vin ca aparatori pe langa roti...motor....bara si eventual bara fata.
2007 / KissFM 1.5 dCi .
dan22y |
#197
Membru autentic Group: Members Posts: 5.514 Joined: 7 June 06 From: B ![]() |
Sonda marche-arriere pt. Megane 2? E aceeasi de pe Duster... cu 3 fire...
R
M
8
- B
paunaxdr |
#198
Membru incepator Group: Members Posts: 24 Joined: 16 January 13 From: Bucuresti ![]() |
Salut, as avea si eu nevoie de urmatoarele piese:
pentru Dacia Logan VAN 1.5 dci 50 kW K9K-K7 An 2007 VIN: UU1FSD1K538114915 amortizoare fata flansa amortizor, rulment amortizor si tot ce mai trebuie, adica kitul complet iar pentru Renault Megane 2.2 2007 VIN: VF1LMSFC538194174 1.5 dci 63 kW K9K-G7 placute frana fata (din ce am citit pe forum sunt cu prindere ATE) filtru de motorina (neaparat original) filtru de aer filtru de polen As dori sa imi dai preturi de la mai multi producatori, inclusiv originale. Eliberezi factura fiscala? Multumesc |
Megane 2.2
- BTM
diesel_power |
#199
Salut,
Poti oferi pret pt urmatoarele repere de origine OE Dacia: 963023121R 963015207R ? Multumesc. |
2005, Fidji
Virusake |
#200
Membru Group: Members Posts: 162 Joined: 26 September 06 ![]() |
Buna seara, aveti cumva un set complet de yale (butuci) + contact + rezervor + 2 chei pentru un Logan din 2007, berlina, 1.4 MPI?
Nova
1997 1.6
diesel_power |
#201
Intrebarea mea nu mai e de actualitate. Multumesc.
2005, Fidji
klub89 |
#202
Membru incepator Group: Members Posts: 9 Joined: 14 October 10 ![]() |
Spune-mi si mie te rog pentru un Renault Megane 2 Sedan ... stop-uri spate.. si pt model 2005 cel cu cerc pentru mansalier sau cel facelift la ce pret sunt perechea. Mersi
MEGANE II
2005 1.6 16v
SteSoMan |
#203
Membru incepator Group: Members Posts: 6 Joined: 14 February 19 ![]() |
Buna seara,
o oferata pentru ansamblu timonerie, cabluri + maneta schimbator, pentru Megane 2005/6+1/131Hp. VF1KMS40634507960 Multumesc anticipat! This post has been edited by SteSoMan: 19 Feb 2019, 20:47 |
Megan
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 12th July 2025 - 21:31 |
