12 Pages  1 2 3 > »
> [VAND] Dezmembrez solenza scala., Dezmembrez solenza scala 2003.
ionutz8772
post 7 Dec 2012, 17:36
SE DEZMEMBREAZA SOLENZA SCALA:
-AN 2003
-90000KM
Pompa servo – 200 ron
Compresor AC – 200 ron
Rampa injectoare – 100 ron
Senzor turatie – 50ron
Alternator – 200ron
Clapeta acceleratie – 70ron - motoras pas cu pas de srl nu de uzina
Fise – 50ron
Electromotor – 200ron
Calculator motor – 200ron
Claxon – 50ron
Planetara stanga – 150ron
Planetara dreapta-120
Catalizator – 150ron
Radiator apa – 100ron
Radiator AC – 100ron
Canistra carbon – 100ron
Etrieri (stanga, dreapta) –40 ron buc.
Servofrana – 50ron
Pompa frana – 80ron
GMV racire cu aer – 80ron
Vas stropgel – 30ron
Motoras stropgel – 15ron
Faruri –50 buc
Aeroterma – 80ron-doar motorasul fara elice
Ansamblu stergatoare – 80ron
Pedale (frana si ambreaj) – 50ron
Brate (stanga, dreapta) – 40 ron buc
Portfuzeta (stanga, dreapta) – 40 ron buc
Ceasuri bord logan cu ledurile schimbate albastru + maneta stergatoare cu buton C.B-200 ron
Bara antiruliu(stabilizatoare) – 50ron
Panou comanda(aer,caldura,recirculare) – 50ron
Lampa plafon – 25ron
Lampa stop haion cu leduri – 35ron
Instalatie electrica – 300ron
Calorifer caldura – 80ron
Cablu acceleratie – 15ron
Buton avarii – 10ron
Buton dezaburire luneta – 10ron
Motorase inchidere centralizata(acuator) – 10 ron buc
UCE + chei (contact defect) – 100ron
Cadru motor – 250ron
Scut motor – 50ron
Usa fata stanga,dreapta (coaje= fara panouri , geam , macara) – 170ron
Usa stanga,dreapta spate (coaje) – 170ron
Aripa fata – 80ron buc
Rezervor – 100ron
Furtune racire – 60 ron toate
Eleron scala – 100ron
Stop spate – 50 ron buc
Centuri siguranta – 50 ron buc
Lampa semnalizare aripa fata – 5 ron
Motor (ulei,filtru ulei schimbate)1000 ron
Cutie de viteze-700 ron
Frana de mana-50 ron
Bloc lumini-100 ron
Volan fara airbag-50 ron
Vas expansiune-30 ron
Instalatie AC-800 on
Bara spate-120 ron/buc
Scaune fata+banchete si huse negre frumoase 350 ron
Punte spate+tamburi-350 ron
Armature bara fata/spate-50 ron/buc
Masca radiator-25 ron
Mocheta interior-70 ron
jante stella modelul scala-400 ron
Capota -180 ron
Masca fata fara emblema-70 ron
Plansa bord-120 ron
Aeratoare caldura de logan-15 ron buc
Plasticele de pe stalpi-60 ron
Butoane geamuri electrice-30 ron buc
Haion cu tot cu luneta-300 ron
Si multe altele,de care va rog sa intrebati.
Preturile sunt foarte usor negociabile pentru ca déjà sunt destul de accesibile.
Daca suma de care cumparati este mai mare de 1000 ron mai e si o reducere de 5-7%.
ATENTIE MASINA SE DEZMEMBREAZA INCEPAND CU DATA DE 1 IANUARIE 2013!!!!!!!!!!!!!
Tel 0763633118
Email:ionutz8772@yahoo.com
PITESTI
dacia solenza 2003/scala
costivio0509
post 7 Dec 2012, 18:32
cat costa o singura roata?
Dacia Solenza 2003 Clima - TR 04 LRM
ursul_bipolar
post 7 Dec 2012, 18:50
Salut,
Spune-mi te rog in ce stare sunt jantele? M-ar interesa pe mine?
Au suferit vreo avarie in decursul timpului?
Capota originala rosie mai este? Daca da in ce stare este?
Toyota RAV4 HSD Elegance 2018
Toyota Highlander HSD Exclusive 2022
anecula_08
post 7 Dec 2012, 19:23
Salut, macaralele electrice de la geamurile de pe fata(stg+dr) la ce pret le dai?
This post has been edited by anecula_08: 7 Dec 2012, 19:24
Dacia Solenza Europa cu AC - 1.4 MPI / Renault Laguna 2 Facelift - 1.6 16v / Dacia Logan Stepway - 1.0 TCE
ionutz8772
post 7 Dec 2012, 20:39
QUOTE(costivio0509 @ 7 Dec 2012, 18:32)
se dau doar la set.
stima
7 Dec 2012, 20:41:
QUOTE(ursul_bipolar @ 7 Dec 2012, 18:50)
Salut,
capota este cea din poza,vopsita negru mat.
jantele nu au fost sudate sau mai stiu eu ce si strambe sper sa nu fie dar le probam.
stima!
7 Dec 2012, 20:44:
QUOTE(anecula_08 @ 7 Dec 2012, 19:23)
doar macaraua sofer merge si nu stiu cat sa zic,daca esti interesat doar de asta zimi cat oferi.
stima!
7 Dec 2012, 20:46:
QUOTE(ionutz8772 @ 7 Dec 2012, 20:39)
se dau doar la set.
stima
<span class='edit'>7 Dec 2012, 20:41:</span>
stima!
<span class='edit'>7 Dec 2012, 20:44:</span>
stima!
SI INCA ODATA DEZMEMBRAREA INCEPE IN LUNA IANUARIE.
MULTA STIMA TUTUROR SI VA ASTEPT CU INTREBARI.
This post has been edited by ionutz8772: 7 Dec 2012, 20:46
anecula_08
post 7 Dec 2012, 21:20
Multumesc, dar nu. Alternatorul este cel original de 80A? Probleme la rulmenti?
This post has been edited by anecula_08: 7 Dec 2012, 21:21
mecanicosu
post 7 Dec 2012, 21:24
Sall extractor aer cel din portbagaj mai este?
Atasez o poza
Dacia Solenza Clima cu apucături de bmw 2004
Prima Dacie care i-a readus pe Romani In randul Europenilor :)
ionutz8772
post 7 Dec 2012, 21:32
QUOTE(anecula_08 @ 7 Dec 2012, 21:20)
sincer sper sa fie cel original eu nu lam schimbat niciodata si nu am probleme cu el.
stima!
7 Dec 2012, 21:33:
QUOTE(mecanicosu @ 7 Dec 2012, 21:24)
Atasez o poza
masina este intreaga,asa ca este si acel extractor.
stima!
This post has been edited by ionutz8772: 7 Dec 2012, 21:33
mecanicosu
post 7 Dec 2012, 21:37
<span class='edit'>7 Dec 2012, 21:33:</span>
stima!
[/quote]
Poti sa-mi zici un pret corect pentru extractor si doua chedere de la usile din spate
This post has been edited by mecanicosu: 7 Dec 2012, 21:39
vladut88
post 7 Dec 2012, 21:45
as dorii motoreductorul pt clapeta recirculare aer ,ofer 30 lei
I hate BMW
anecula_08
post 7 Dec 2012, 21:59
ofer 150 pe el, ce zici?
ionutz8772
post 7 Dec 2012, 22:03
[quote=mecanicosu,7 Dec 2012, 21:37]
stima!
[/quote]
[/quote]
20 de ron extractorul si 30 de ron chederele.
7 Dec 2012, 22:06:
QUOTE(vladut88 @ 7 Dec 2012, 21:45)
nu stiu la ce te referi daca imi gasesti o poza si imi spui pe unde se afla iti dau un raspuns.
stima!
7 Dec 2012, 22:09:
QUOTE(anecula_08 @ 7 Dec 2012, 21:59)
anecula_08 dupa cum am spus si mai sus preturile in raport cu calitatea sunt destul de bune,cu toate astea mai pot face si mici reduceri dar in nici un caz de 25 %,cel putin nu pentru piesele de genul asta.
stima!
This post has been edited by ionutz8772: 7 Dec 2012, 22:09
anecula_08
post 7 Dec 2012, 22:11
atunci spune-mi un ultim pret pt el si rezerva-l pentru mine.
This post has been edited by anecula_08: 8 Dec 2012, 09:22
george_scala_2004
post 7 Dec 2012, 22:41
QUOTE(ionutz8772 @ 7 Dec 2012, 17:36)
-AN 2003
-90000KM
Faruri –50 buc
Tel 0763633118
PITESTI
salut,
sint originale? ceva probleme la ele - urechi rupte, geam fisurat? pozed etaliate se poate?
stima,
ursul_bipolar
post 7 Dec 2012, 23:30
stima!
Ok, le putem verifica impreuna inainte de livrare?
Daca da, le poti rezerva pt mine.
Multumesc,
ionutz8772
post 8 Dec 2012, 10:36
QUOTE(anecula_08 @ 7 Dec 2012, 22:11)
180 ron ultimul pret,daca e ok se rezerva pentru tine.
stima!
8 Dec 2012, 10:38:
QUOTE(ursul_bipolar @ 7 Dec 2012, 23:30)
stima!
Multumesc,
sincer nu stiu cum am putea sa le verificam impreuna daca gasesti o solutie e ok cum zici tu.
stima!
This post has been edited by ionutz8772: 8 Dec 2012, 10:38
AlexandruSB
post 8 Dec 2012, 12:17
Ma intereseaza urmatoarele: faruri cu semnalizari(daca nu au clemele rupte), eleron portbagaj, usa torpedou, grila dintre faruri si ceasurile de logan cu tot cu mufa de adaptare.Astept un pret pt pachet.Ms
This post has been edited by AlexandruSB: 8 Dec 2012, 12:21
Dacia 1310 1999
ionutz8772
post 8 Dec 2012, 12:26
QUOTE(AlexandruSB @ 8 Dec 2012, 12:17)
Ma intereseaza urmatoarele: faruri cu semnalizari(daca nu au clemele rupte), eleron portbagaj, usa torpedou, grila dintre faruri.Astept un pret pt fiecare.Ms
+farurile:
-dreapta e ok -60 ron cu tot cu semnalizare
-stanga are clemele rupte-40 ron cu totul
+eleron 90 ron
+usa torpedou-30 ron
+grila 60 ron(necesita vopsire)
stima!
dezmembrarea incepe in ianuarie.
AlexandruSB
post 8 Dec 2012, 12:31
QUOTE(ionutz8772 @ 8 Dec 2012, 12:26)
+farurile:
+eleron 90 ron
stima!
Ceasurile de logan mai sunt?Ma intereseaza si alea.Te rog rezerva-mi eleronul,usa torpedou, grila si ceasurile (daca mai sunt) pana incepi sa o dezmembrezi.Ms
Dacia 1310 1999
ionutz8772
post 8 Dec 2012, 13:17
QUOTE(AlexandruSB @ 8 Dec 2012, 12:31)
sunt si ceasurile-180 ron cu tot cu maneta stergatoare cu buton.
stima!
anecula_08
post 8 Dec 2012, 18:20
este ok, pastreaza alternatorul pt mine.
ionutz8772
post 8 Dec 2012, 19:17
QUOTE(anecula_08 @ 8 Dec 2012, 18:20)
Alternator -rezervat pt anecula_08
Fise – 50ron
Claxon – 50ron
Servofrana – 50ron
Pompa frana – 80ron
Faruri –50 buc
Scut motor – 50ron
Rezervor – 100ron
Bloc lumini-100 ron
Capota -180 ron
Plansa bord-120 ron
suchea
post 8 Dec 2012, 21:41
m-ar interesa planetara dreapta
a mai fost schimbata in decursul a 90000 km?
Dacia SuperNova 2001/confort - GL 61 TES
http://www.daciaclub.ro/index.php?showtopic=259258&hl=
ionutz8772
post 8 Dec 2012, 23:18
QUOTE(suchea @ 8 Dec 2012, 21:41)
sincer nu stiu ce sati spun masina o am de la 65000 de km,stiu doar ca e de uzina.
stima!
ionutz8772
post 11 Dec 2012, 00:15
<<<<<<<<<<<<mai astept intrebari pentru piese>>>>>>>>>>
MASINA NU ESTE LOVITA SAU MAI STIU EU CE.AM RAMAS FARA TALON SI NU O AM INSCRISA PE NUMELE MEU SI E MAI COMPLICAT, ASA CA AM DECIS SA O DEZMEMBREZ.
IN MOMENTUL CAND O SA INCEP SA DEZMEMBREZ LA EA FIECARE PIESA VA AVEA MAI MULTE POZE SI O SA VEDETI CA E MASINA BUNA.
STIMA TUTUROR!
piese de caroserie cum ar fi:
-praguri
-oalele spate foarte putina rugina
-aripile spate
-stalpi
-lonjeroane
-partea fata
-partea spate
etc
This post has been edited by ionutz8772: 11 Dec 2012, 00:18
jayhova
post 11 Dec 2012, 06:10
Salut,
M-ar interesa daca nu este rezervat farul dreapta fara semnalizare si proiecturul ceata dreapta , la fel si chederele fata daca nu sunt crapate.
dacia solenza 2004 - PH-34-RAZ
velceani
post 11 Dec 2012, 08:55
Salut,
bara fata, grila si radiator de apa cat ceri pe ele?
caseta de directie e ok? cat ceri pe ea?
de unde esti din Pitesti?
as avea nevoie de mai multe...
Auzi da mie mi se pare foarte cunoscuta masina... nu vii prin C de Arges des?
This post has been edited by velceani: 11 Dec 2012, 08:57
Dacia Logan 2 Sl plus 1.2 16v 2016
ursul_bipolar
post 12 Dec 2012, 15:32
QUOTE(ionutz8772 @ 8 Dec 2012, 11:36)
stima!
<span class='edit'>8 Dec 2012, 10:38:</span>
stima!
Le poti rezerva pt mine te rog.
Inca o rugaminte, imi poti trimite niste poze cat mai de aproape la fiecare janta pentru a vedea cum se prezinta? Din pozele pe care le-ai pus nu se observa f bine.
Multumesc,
alex_DNK
post 12 Dec 2012, 18:18
fetele de usi de pe fata la ce pret le dai?
skoda octavia 2009 - 87 dnk
sorin_pan
post 12 Dec 2012, 19:39
M-ar interesa chederul de la usa fata stanga (usa sofer), amortizoarele daca sunt in stare buna, polita de la haion, preturi si modalitatea de trimitere ! Cu stima !
Dacia Solenza Confort 2004 - B -xx-xxx
12 Pages  1 2 3 > »
Lo-Fi Version  Harta site  Parteneri  Jocuri online  Curs Valutar  HRH Haine din lana merinos Time is now: 18th June 2025 - 13:08
