12 Pages « < 7 8 9 10 11 > »
> [VAND] Dezmembrez solenza scala., Dezmembrez solenza scala 2003.
ionutz8772
post 30 Jan 2013, 11:15
Post #241
QUOTE(just_horia @ 29 Jan 2013, 19:48)
Asa este, nu e de uzina. Punem  punct IMI CER SCUZE DACA TE-M DERANJAT
Ok multumesc de intelegere.
S-au mai dat:
-gmv
-o conducta de la ac
-corpul clapeta
-un furtun de la radiatorul de apa
-stap stanga spate
Mai sunt urmatoarele:
Compresor AC – 200 ron
Rampa injectoare – 100 ron
Senzor turatie – 50ron
Electromotor –150 ron(are o ureche rupta)
Calculator motor – 200ron
Claxon – 50ron
Catalizator – 150ron
Radiator apa – 100ron-REZERVAT VELCEANI
Radiator AC – 100ron
Canistra carbon – 100ron
Etrier stanga –40 ron
Servofrana – 50ron
Vas stropgel – 30ron
Motoras stropgel – 15ron
Aeroterma – 80ron-doar motorasul fara elice-REZERVATA
Pedale (frana si ambreaj) – 50ron
Brate (stanga, dreapta) – 40 ron buc
Portfuzeta stanga– 40 ron
Bara antiruliu(stabilizatoare) – 50ron
Lampa stop haion cu leduri – 35ron
Instalatie electrica – 300ron
Calorifer caldura – 80ron
Cablu acceleratie – 10ron
Buton avarii – 10ron
Buton dezaburire luneta – 10ron
Motorase inchidere centralizata(acuator) – 10 ron buc
UCE + chei – 100ron
Cadru motor – 250ron
Usa dreapta spate (coaje) – 170ron
Rezervor – 100ron
Stop spate – 50 ron buc
Centuri siguranta – 50 ron buc
Lampa semnalizare aripa fata – 5 ron
Motor (ulei,filtru ulei schimbate)1000 ron
Cutie de viteze(bonus kit ambreiaj schimbat de 800km)-700 ron
Frana de mana-50 ron
Bloc lumini-100 ron
Volan fara airbag-50 ron
Vas expansiune-30 ron
Instalatie AC-800 on
Scaune fata+banchete si huse negre frumoase 350 ron
Punte spate+tamburi-350 ron
Armature bara fata/spate-50 ron/buc
Mocheta interior-70 ron
Masca fata fara emblema-70 ron-REZERVATA
Plansa bord-120 ron
Aeratoare caldura de logan-15 ron buc
Plasticele de pe stalpi-60 ron
Butoane geamuri electrice-30 ron buc
Haion cu tot cu luneta-200 ron
motoras geam electric sofer-100 ron
panouri-50 ron buc
mocheta porbagaj-30 ron
eztractor aer-30 ron-REZERVAT
suport roata de rezerva-40 ron
aparatoare noroi roata stanga fata-40 ron
geam usa fata-spate-40 ron
maciulie schimbator logan-25 ron
plasticul de la aeroterma cu tot cu cheder-50 ron
carcasa filtru de aer-100 ron
alarma viper 350hv cu 2 telecomenzi,buton pentru deschidere portbagaj-150 ron
oglinzi electrice logan-un geam are o fisura pe jumate-80 ron
oglinzi normale solenza(vopsite albastru dar neprofesional)-50 ron
radiator solenza fara aer-50 ron
orice cheder 10 ron(nu garantez cu nimic pentru ele decat poze pot sa va dau)
PANA PE DATA DE 15 FEB PRETURILE VOR FI MAI ACCESIBILE,NU EZITATI SA INTREBATI.
STIMA TUTUROR!!!!!!
dacia solenza 2003/scala
aliosha
post 30 Jan 2013, 13:35
Post #242
furtunele mele, le-ai "dovedit" ??
Renault Megane 2.2 CC 2008
ionutz8772
post 30 Jan 2013, 21:04
Post #243
QUOTE(aliosha @ 30 Jan 2013, 13:35)
M-am lasat pagubas ca riscam sa rup teava de la calorifer.
Imi pare rau.....
Stima!
suchea
post 30 Jan 2013, 21:25
Post #244
mocheta interior podea mai este? si plasticele stalpi spate cele care se imbina cu suportii de la polita? clapeta deshidere usa sofer/spate exterior?
Dacia SuperNova 2001/confort - GL 61 TES
http://www.daciaclub.ro/index.php?showtopic=259258&hl=
ionutz8772
post 30 Jan 2013, 23:52
Post #245
QUOTE(suchea @ 30 Jan 2013, 21:25)
Este mocheta dar nu in stare prea buna-50 ron.
Plasticele le daau toate-60 ron.
Manerele nu mai sunt.
Stima!
anecula_08
post 31 Jan 2013, 21:51
Post #246
Salut, calculatorul de injectie(cel de langa baterie (doar daca este de pe masina ta, cu AC)) mai este? La ce pret?
P.S. Daca se razgandeste colegul pentru radiatorul de apa (pt varianta cu AC) sa ma anunti.
This post has been edited by anecula_08: 1 Feb 2013, 09:34
Dacia Solenza Europa cu AC - 1.4 MPI / Renault Laguna 2 Facelift - 1.6 16v / Dacia Logan Stepway - 1.0 TCE
ionutz8772
post 31 Jan 2013, 22:36
Post #247
QUOTE(anecula_08 @ 31 Jan 2013, 21:51)
Salut, calclatorul de injectie(cel de langa baterie (doar daca este de pe masina ta, cu AC)) mai este? La ce pret?
Calculatorul este original de pe masina mea.
pret 250 ron cu totu-chei-uce sau uch nu ma pricep-calculatorul.
Daca se razgandeste te anunt,respectivu a luat caseta de directie si odata ce ma rugat sal opresc nu am ce face.
Stima!!
anecula_08
post 1 Feb 2013, 09:33
Post #248
Am inteles. Din pacate mie imi trebuia doar calculatorul(cu restul nu am ce sa fac, cheile si uch/uce habitaclu nu sunt "legate" de calc de injectie). Merci si bafta la vanzare in continuare.
This post has been edited by anecula_08: 1 Feb 2013, 09:35
ionutz8772
post 2 Feb 2013, 17:43
Post #249
QUOTE(anecula_08 @ 1 Feb 2013, 09:33)
Eu am inteles ca sunt legate de calculator de asta am si zis ca le dau la set,nu era vorba ca nu vreau sa le separ.Daca imi confirmi ca e asa ca tine eu pot sati dau si calculatorul.
Stima!
anecula_08
post 2 Feb 2013, 18:20
Post #250
Eu stiu ca impreuna sunt doar cheile cu uch/uce habitaclu. Asa se vand si pe forum si tot asa se schimba cand nu le mai merg cheile.
Florin27
post 2 Feb 2013, 19:47
Post #251
Da, dar trebuie rescris si uce injectie...Plus bucsa de contact...
Dacia Solenza 2004/Scala
anecula_08
post 2 Feb 2013, 20:01
Post #252
ok atunci, nici eu nu stiu exact.
ionutz8772
post 3 Feb 2013, 22:18
Post #253
QUOTE(Florin27 @ 2 Feb 2013, 19:47)
Multumesc de completare.....asa am auzit si eu.
Stima!
QUOTE(anecula_08 @ 2 Feb 2013, 20:01)
Daca ai posibilitate sa le scrii sau nu stiu....ma contactezi.
Stima si imi pare rau ca nu am putut sa te ajut.
Florin27
post 4 Feb 2013, 02:15
Post #254
Mie la doctorasul mi-au trebuit uce injectia si bucsa de contact plus uce si cheia veche (astea nu stiu daca au trebuit) si ma gandesc ca uch-ul a fost blank si s-a copiat codul de pe uce injectie in el. Aici presupun ca trebuie operatie inversa.
ionutz8772
post 4 Feb 2013, 22:10
Post #255
Up!!!!!!!!
Preturi negociabile!!!!!!!!!!!
suchea
post 4 Feb 2013, 22:59
Post #256
poze cu mocheta interior si cele 2 chedere usi spate, se poate?
ionutz8772
post 4 Feb 2013, 23:06
Post #257
QUOTE(suchea @ 4 Feb 2013, 22:59)
Sper sa fac maine dar nu promit nimic.
Stima!!
Bengalezu
post 6 Feb 2013, 00:53
Post #258
Buna ziua!
Butonul de dezaburire luneta ma intereseaza, daca il mai aveti. Sunt din Bucuresti.
Dacia Solenza 2003
ionutz8772
post 6 Feb 2013, 01:50
Post #259
QUOTE(Bengalezu @ 6 Feb 2013, 00:53)
Buna ziua!
Este butonul dar trebuie sa mai iei ceva daca vrei sal trimit nu ma complic pentru 10 ron(sper ca intelegi).
Stima!
Bengalezu
post 7 Feb 2013, 01:12
Post #260
QUOTE(ionutz8772 @ 6 Feb 2013, 01:50)
Stima!
Inteleg. Speram ca poate aveti drum prin Bucuresti zilele astea, sau poate vreo cunostinta de-ale dumneavoastra. Atat, doar acel buton ma interesa; raspundeti-mi la post doar daca se nimereste cumva sa treceti prin capitala. Altfel, e okay. Spor la vandut piese, preturile sunt mai mult decat de bun simt! 0771742582 e numarul meu, in caz ca ne putem intalni eventual.
Dacia Solenza 2003
kondl
post 7 Feb 2013, 11:26
Post #261
KOndL
poza cu grila fata se poate? mai e rezervata? as fi interesat de ea
dacia solenza 2004 scala
ionutz8772
post 7 Feb 2013, 20:02
Post #262
QUOTE(Bengalezu @ 7 Feb 2013, 01:12)
Drum nu am dar poate te mai gandesti la ceva.
QUOTE(kondl @ 7 Feb 2013, 11:26)
Nu mai este rezervata respectivu nu a mai zis nimic.Poze gasesti in pag 2 sau 3.
kondl
post 8 Feb 2013, 17:46
Post #263
KOndL
QUOTE(ionutz8772 @ 7 Feb 2013, 20:02)
ti am lasat mesaj
ionutz8772
post 9 Feb 2013, 21:49
Post #264
QUOTE(kondl @ 8 Feb 2013, 17:46)
ti am lasat mesaj
60 ron ultimul pret,transportul cu ce vrei doar ca la posta e mai complicat de ambalat....
Stima!
ionutz8772
post 12 Feb 2013, 16:05
Post #265
Am primit mesajul de la tine.
Transportul dupa cum am mai zis pot sa il fac prin posta romana sau fan curier.
-fan curier costa pentru 100 de ron de exemplu si 2 kg greutate undeva la 35-40 de ron.
-posta undeva la 10-12 ron.
Acum e alegerea ta.
Stima!
PENTRU CINE MAI E INTERESAT SE MAI DEZMEMBREAZA MERCEDES E 270 AN 2003 MODELUL AVANGARDE:
-DUBLU CLIMATRONIC
-INTERIOR PIELE
-130000 KM
ETC
PENTRU INFORMATII DESPRE PIESE SAU ORICE ALCEVA UTILIZATI FORUMUL SAU:
0763633118
ionutz8772@yahoo.com
This post has been edited by ionutz8772: 12 Feb 2013, 21:18
ionutz8772
post 14 Feb 2013, 09:54
Post #266
Up cu piesele de mercedes si solenza!!!!!!!!!!
Preturi bune!!!!!!!
Valy90
post 14 Feb 2013, 10:48
Post #267
Roata de rezerva o mai ai? poti pune poze cu ea?
Dacia/Opel Solenza/Astra H 2004/ 1.4 mpi / 2005-1.7 cdti - GR-xx-WAL
ionutz8772
post 14 Feb 2013, 11:23
Post #268
QUOTE(Valy90 @ 14 Feb 2013, 10:48)
Nu mai este roata de rezerva.
Stima!
kondl
post 15 Feb 2013, 10:49
Post #269
KOndL
ai reusit sa trimiti?
ionutz8772
post 15 Feb 2013, 11:46
Post #270
QUOTE(kondl @ 15 Feb 2013, 10:49)
Nu am primit de la tine confirmarea si cu ce sa trimit-posta sau curier.
Stima!
Lo-Fi Version  Harta site  Parteneri  Jocuri online  Curs Valutar  HRH Haine din lana merinos Time is now: 18th June 2025 - 21:12
