[VAND] statii cb si accesorii cb (second hand )
radu c |
30 Dec 2012, 14:39
Membru autentic Group: Members Posts: 260 Joined: 5 September 07 From: medias |
Attached thumbnail(s) mid__220_1.jpg ( Size: 69.91k ) Number of downloads: 1923 mid_220_2.jpg ( Size: 80.37k ) Number of downloads: 2030 XM_7082_BLUE_1.jpg ( Size: 67.45k ) Number of downloads: 1988 XM_7082_BLUE_2.jpg ( Size: 71.48k ) Number of downloads: 1996 XM_7082__1.jpg ( Size: 67.7k ) Number of downloads: 1978 XM_3500_1.jpg ( Size: 72.79k ) Number of downloads: 362 XM_3500_2.jpg ( Size: 70.56k ) Number of downloads: 337 caart_1.jpg ( Size: 86.88k ) Number of downloads: 300 carat_2.jpg ( Size: 86.25k ) Number of downloads: 329 strato_1.jpg ( Size: 109.32k ) Number of downloads: 304 strato_2.jpg ( Size: 93.4k ) Number of downloads: 290 start_1.jpg ( Size: 72.3k ) Number of downloads: 274 start_2.jpg ( Size: 76.88k ) Number of downloads: 274 ae_6080_1.jpg ( Size: 77.83k ) Number of downloads: 287 ae_6080__2.jpg ( Size: 67.85k ) Number of downloads: 364 xm_5000_1.JPG ( Size: 141.7k ) Number of downloads: 389 xm_5000_2.jpg ( Size: 93.28k ) Number of downloads: 307 ae_4400_1.JPG ( Size: 155.56k ) Number of downloads: 286 ae_4400_2.jpg ( Size: 90.68k ) Number of downloads: 299 pan_1.jpg ( Size: 69.72k ) Number of downloads: 318 pan_2.jpg ( Size: 41.82k ) Number of downloads: 323 Attached image(s) |
2006 ambiance 1.4 ; gpl ;ex 1300/1970;1300/1982
- sb 06 vry
radu c |
3 Jan 2013, 21:13
up ! inca valabil .
- sb 06 vry
radu c |
4 Jan 2013, 22:33
statie cb PAN MINI TOP AM FM in ambalaj original
statie cb ALBRECHT AE 4400 -- sigiliul intact , ambalaj original -- statie cb STABO XM 5000 -- ambalaj original -- statie cb ALBRECHT AE 6080 cu SQUELCH AUTOMAT s-au vandut ! restul statiilor sant inca disponibile . |
- sb 06 vry
radu c |
6 Jan 2013, 16:31
statie cb MIDLAND ALAN 42 ( ambalaj original ) + antena SIRIO de 60 cm cu talpa magnetica
STATIA ESTE IN STARE BUNA ; 100 % FUNCTIONALA ;SE LIVREAZA IN AMBALAJUL ORIGINAL Acesta statie se poate conecta si la antena masinii (de exterior) sau poate functiona foarte bine cu antena proprie. Generalitati Canale 40 AM/FM Gama de frecventa 26.965 - 27.405 MHz Controlul frecventei PLL Tensinue de alimentare13.2 Vdc ± 15% Dimensiuni 70(W) x 140(H) x 30(D)mm Greutate 220gr Receptor Sitem de receptie Superheterodyne cu dubla conversie Frecvente intermediare 10.695 MHz - 455 KHz Sensibilitate0.5µV la 10dB SINAD in FM si 0.25µV la 10dB SINAD in AM Putere audio de iesire cu 10% THD 0.5 W la 8 Ohm Distorsiuni audio 3% la 1KHz Sensibilitate 65dB Raport semnal zgomot 45 dB Consum in stand-by 100 mA - 45 mA Emitator Putere de emisie 4W AM/FM la 13.2 Vdc Modulatie AM:90% ± 5% si FM: 2 KHz Raspuns in frecventa 500 Hz ~ 3 KHz Impedanta de iesire RF 50 Ohm nebalansata Raport semnal zgomot 40 dB MIN Curent consumat 900 mA Coletul contine: - statie radio - antena SIRIO de 60 cm cu talpa magnetica - suport 8 acumulatori + suport 6 acumulatori - adaptor antena externa si 12V pret : 430 lei Attached thumbnail(s) ALAN_42.JPG ( Size: 128.75k ) Number of downloads: 231 ALAN_42_2.JPG ( Size: 149.37k ) Number of downloads: 117 |
- sb 06 vry
radu c |
18 Jan 2013, 20:59
statie cb STABO XM 7082 DMTF -- MICROFON PNI CU ECOU --DISPLAY PE ALBASTRU
IDENTICA CU PRESIDENT HARRISON SI MAYCOM EM-27 , 100% FUNCTIONALA ; DIMENSIUNI REDUSE ,80 CANALE FM/4 W ; 12 CANALE AM /1 W ,RF-GAIN ; DUAL WATCH ; SCAN ; BEEP ; MEMORY ; VOLTMETRU ... statiile STABO si PRESIDENT sant produse de aceeasi firma : UNIDEN pret : 399 lei statie cb STABO XM 7082 DMTF -- MICROFON PNI CU ECOU -- IDENTICA CU PRESIDENT HARRISON SI MAYCOM EM-27 , 100% FUNCTIONALA ; DIMENSIUNI REDUSE ,80 CANALE FM/4 W ; 12 CANALE AM /1 W ,RF-GAIN ; DUAL WATCH ; SCAN ; BEEP ; MEMORY ; VOLTMETRU ... statiile STABO si PRESIDENT sant produse de aceeasi firma : UNIDEN pret : 399 lei statie cb DNT CARAT STATIA PREZINTA URME DE UZURA INSA ESTE 100% FUNCTIONALA ;40 CANALE FM / 12 CANALE AM ;RF-GAIN ; SCAN ; MEMORY ; MICROFON CU TASTE UP SI DOWN pret :170 lei statie cb DNT STRATO I 40 CANALE FM / PUTEREA DE EMISIE 4 W;12 CANALE AM / PUTEREA DE EMISIE 1 W ;FILTRU DE ZGOMOT N.B. ; RF-GAIN atentie ! butonul de selectie pt. FM/AM este blocat pe pozitia FM pret :160 lei statie cb MIDLAND ALAN 42 ( ambalaj original ) + antena SIRIO de 60 cm cu talpa magnetica STATIA ESTE IN STARE BUNA ; 100 % FUNCTIONALA ;SE LIVREAZA IN AMBALAJUL ORIGINAL Acesta statie se poate conecta si la antena masinii (de exterior) sau poate functiona foarte bine cu antena proprie. Generalitati Canale 40 AM/FM Gama de frecventa 26.965 - 27.405 MHz Controlul frecventei PLL Tensinue de alimentare13.2 Vdc ± 15% Dimensiuni 70(W) x 140(H) x 30(D)mm Greutate 220gr Receptor Sitem de receptie Superheterodyne cu dubla conversie Frecvente intermediare 10.695 MHz - 455 KHz Sensibilitate0.5µV la 10dB SINAD in FM si 0.25µV la 10dB SINAD in AM Putere audio de iesire cu 10% THD 0.5 W la 8 Ohm Distorsiuni audio 3% la 1KHz Sensibilitate 65dB Raport semnal zgomot 45 dB Consum in stand-by 100 mA - 45 mA Emitator Putere de emisie 4W AM/FM la 13.2 Vdc Modulatie AM:90% ± 5% si FM: 2 KHz Raspuns in frecventa 500 Hz ~ 3 KHz Impedanta de iesire RF 50 Ohm nebalansata Raport semnal zgomot 40 dB MIN Curent consumat 900 mA Coletul contine: - statie radio - antena SIRIO de 60 cm cu talpa magnetica - suport 8 acumulatori + suport 6 acumulatori - adaptor antena externa si 12V pret : 430 lei contact : 0744258917 sau radu_capatina@yahoo.com |
- sb 06 vry
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 2nd May 2024 - 04:42 |
