4 Pages  1 2 3 > »
> [VAND] diverse piese noi de Logan, [VAND] piese noi de Logan
evali22
post 29 Mar 2013, 15:40
[vand] diverse piese noi de Logan, originale sau producator, mai jos este o lista cu ce comercializez:
- maneta stergatoare cu buton Cb la------------- 60 ron/buc
- bloc lumini cu proiector model Valeo------------ 120 ron
- bucsi bascule de origine ------------------------ 25 ron/buc
- bujii Equiem cu 2 craci-------------------------- 60 ron/set
- bujii Equiem cu 1 crac---------------------------50 ron/set
- termostat (producator) LG diesel--------------- 115 ron
- cap bara Lemforder ----------------------------- 90 ron/buc
- bieleta directie Lemforder------------------------ 90 ron/buc
- cap bara de origine------------------------------ 90 ron/buc
- bielete directie de origine------------------------ 80 ron/buc
- cap bara RTS------------------------------------50 ron/buc
- bielete directie RTS-------------------------------50 ron/buc
- termostat benzina------------------------------- 35 ron
- pivoti (LEMFORDER)------------------------------ 35 ron
- bascula de origine------------------------------- 110 ron
- set saboti (ATE)-------------------------------- 135 ron
- nuca schimbator Prestige plastic------- ---------- 35 ron
- nuca schimbator Prestige piele--------------------65 ron
- bucsi bara stabilizatore mijloc -------------------- 20 ron/buc
- bielete antiruliu de origine ------------------------ 25 ron/buc
- rulment roata fata FAG (fara ABS) ----------------105 ron/buc
- set rulmenti roata fata FAG (fara ABS)-------------160 ron/set (2 buc)
- rulment roata fata MAPCO (fara ABS)---------------70 ron/buc
- rulment roata spate MAPCO------------------------60 ron/buc
- burduf planetara stanga Logan-------80 ron
- burduf schimbator viteze-------------35 ron
- mufe instalatie incalzire scaune-------10 ron/buc
- filtru ulei original Purflux benzina ------------------- 20 ron
- filtru ulei original Motorina ------------------------- 20 ron
- filtru aer benzina si motorina ----------------------- 25 ron
- filtru aer 16 valve --------------------------------- 25 ron
- filtru motorina EURO 3 ---------------------------- 115 ron
- filtru motorina EURO 4 ---------------------------- 115 ron
- filtru polen Valeo ---------------------------------- 25 ron
- filtru uleu Duster-----------------------------------35 ron
- oglinzi Prestige electrice ---------------------------270 ron/set
- proiectoare ceata Logan Ph1 Valeo ----------------- 70 ron/buc
- buton reglaj oglinzi electrice ------------------------35 ron
- buton deschidere usa -------------------------------10 ron
- amortizoare Monroe fata ----------------------------120 ro/buc
- amortizoare Monroe spate --------------------------105 ron/buc
- amortizoare Bilstein B4 fata -------------------------145 ron/buc
- amortizoare Bilstein B4 spate ------------------------125 ron/buc
- flanse amortizor originale -----------------------------35 ron/buc
- rulmenti amortizor SNR -------------------------------20 ron/buc
- bieleta antirasturnare --------------------------------70 ron
- bieleta antirasturnare VAN----------------------------80 ron
- discuri frana VAN Brembo --------------------------- 135 ron/buc
- placute frana VAN Ferodo SL ------------------------125 ron/set
- discuri frana 259 pline Ferodo ------------------------190 ron/set
- discuri frana 259 ventilate Ferodo --------------------200 ron/set
- discuri frana 259 pline Brembo------------------------190 ron/set
- discuri frana 259 ventilate ATE ------------------------310 ron/set
- discuri frana 259 pline ATE -----------------------------230 ron/set
- discutri frana 260 ventilate ATE ------------------------300 ron/set
- discuri frana 259 ventilate Brembo---------------------240 ron/set
- discuri fraba 259 ventilate Brembo Striate-------------390 ron/set
- discuri frana ventilate RoadHouse---------------------140 ron/set
- placute frana TRW ----------------------------------- 60 ron/set
- placute frana ATE------------------------------------- 120 ron/set
- placute frana Ferodo FQT ----------------------------125 ron/set
- placute frana Ferodo Premier--------------------------95 ron/set
- cablu ambreiaj MPI-DCI -------------------------------45 ron
- cablu acceleratie MPI -------------------------------- 35 ron
- sonda servodirectie -----------------------------------50 ron
- sonda mers inapoi -------------------------------------35 ron
- plafoniera 3 becuri ------------------------------------35 ron
- plafoniera 1 bec ---------------------------------------30 ron
- contactor lumina pedala frana ------------------------- 20 ron
- spirala airbag volan ------------------------------------ 70 ron
- kit distributie MPI -------------------------------------170 ron
- pompa apa de origine MPI -----------------------------210 ron
- pompa apa HEPU pt benzina ---------------------------175 ron
- kit distributie DCI ------------------------------------- 300 ron
- pompa apa DCI ----------------------------------------210 ron
- kit ambreiaj SACHS 1.6 MPI ---------------------------- 380 ron/set
- kit ambreiaj Origine 1.4 MPI-----------------------------330 ron/set
- kit ambreiaj DCI producator LUK-------------------------350 ron
- rulment ambreiaj hidraulic Valeo-------------------------170 ron
- curele accesorii ---------------------------------------- 55 ron
- kit accesorii MPI model cu AC de origine -----------------240 ron
- kit accesorii DCI model cu AC de origine -----------------255 ron
- role ghidaj MPI/DCI------------------------------------- 35 ron
- spray luciu anvelope ------------------------------------25 ron
- autocolante stalpi Prestige ------------------------------35 ron/set
- aeratoare Prestige argintii -------------------------------65 ron/set
- aeratoare Duster cromate--------------------------------60 ron/set
- set tapiterie Black Line----------------------------------140 ron/set
- ulei motor, ELF, CASTROL, MOBIL, ARAL-------------------Intrebati
- set incalziri scaune complet cu carenaje-------------------210 ron
- tapiserie Black Line ( 4 tetiere)----------------------------140 ron
- duze stropitor tip perdea------------------------------------20 ron/set
- ARAL HIGH TRONIC 5W-40 4L-----------------110 ron
- ARAL HIGH TRONIC 5W-40 1L------------------30 ron
- CAS EDGE 5W-40/1 T.D. 5W40 -1L------------37 ron
- CAS EDGE 5W-40/4 T.D. 5W40 -4L------------135 ron
- CAS EDGE 5W-40/5 T.D. 5W40 -5L------------160 ron
- CAS EDGE 5W-40 B4 5W-40 B4/5-1L ----------44 ron
- CAS EDGE 5W-40 B4 5W-40 B4/5-4L ----------145 ron
- CAS EDGE 5W-40 B4 5W-40 B4/5-5L ----------165 ron
- CAS EDGE 5W-30 5W-30 -1L ----------------51 ron
- CAS EDGE 5W-30 5W-30 -4L ----------------190 ron
- CAS EDGE 5W-30 5W-30 -5L ----------------215 ron
- CAS MAGNATEC C3 5W-40 -1L ----------------35 ron
- CAS MAGNATEC C3 5W-40 -4L ----------------125 ron
- CAS MAGNATEC C3 - 5W-40 -5L ----------------140 ron
- CAS MAGNATEC DIESEL B4 5W-40 -1L-------------35 ron
- CAS MAGNATEC DIESEL B4 5W-40 -4L------------130 ron
- CAS MAGNATEC BENZINA 10W-40 -1L-------------30 ron
- CAS MAGNATEC BENZINA 10W-40 -4L-------------115 ron
- CAS MAGNATEC BENZINA 10W-40 -5L--------------130 ron
- CAS MAGNATEC DIESEL 10W-40 -1L---------------32 ron
- CAS MAGNATEC DIESEL 10W-40 -4L---------------120 ron
- CAS MAGNATEC DIESEL 10W-40 -5L---------------130 ron
- ELF EVOLUTION SXR 5W-40 -4L--------------------135 ron
- ELF EVOLUTION SXR 5W-40 -1L--------------------38 ron
- ELF COMPETITION ST 10W-40/4L------------------85 ron
- ELF COMPETITION ST 10W-40/1L------------------25 ron
- ELF TURBO DIESEL 10W-40/5L---------------------110 ron
- ELF TURBO DIESEL 10W-40/4L---------------------85 ron
- ELF TURBO DIESEL 10W-40/1L---------------------25 ron
- MOBIL SUPER 3000 5W-40/4L----------------------125 ron
- MOBIL SUPER 3000 5W-40/1L-----------------------35 ron
si multe altele...se pot aduce si piese pentru masini straine.
evali_daniel este id-ul meu
0766.403.938 Vali
dacia logan 2005 laureate
adigan92
post 29 Mar 2013, 18:22
Un pret pt.:5lulei-ELF 10-40 turbo,filtru aer,filtru motorina MANN pt un Megan 1,72 kw curier inclus Constanta
This post has been edited by adigan92: 29 Mar 2013, 18:25
renault megane classic 2000/1,9DTI - ct-92-gan
cookie
post 31 Mar 2013, 23:51
Oglinzile de Prestige au si capacul in culoarea masinii? Albastru egee ma intereseaza. Merci
This post has been edited by cookie: 31 Mar 2013, 23:51
dacia LOGAN 2005 AMBITION - B CC LLL
the fast and furious
post 1 Apr 2013, 21:22
Placute frana TRW sunt pt benzina / diesel ?
Imi trebuie pt 1.6 8v . Se ofera si factura ?
Dacia / Opel - Berlina / Astra Classic - 1999 / 2006 - B -- ---
evali22
post 3 Apr 2013, 09:59
fast ai PM
evali22
post 7 Apr 2013, 19:17
valabil in continuare
evali22
post 11 Apr 2013, 21:37
sus cu anuntul....
cookie
post 12 Apr 2013, 08:15
Oglinzi de pretige albastru egee ai ?
evali22
post 12 Apr 2013, 18:42
cookie, oglinzile vin in diverse culori daca iti gasec la culoare iti spun.
evali22
post 16 Apr 2013, 14:06
valabil...
evali22
post 22 Apr 2013, 10:09
Valabil in continuare.....
- duze stropitor tip perdea------20 ron/set
- kit distributie Logan DCI------250 ron/kit
evali22
post 25 Apr 2013, 17:26
Anunt valabil in continuare, precizez ca unele preturi se pot modifica ulterior ofertei afisate:
- cap bara Lemforder ----------------------------- 85 ron/buc
- bieleta directie Lemforder------------------------ 85 ron/buc
- cap bara de origine------------------------------ 85 ron/buc
- bielete directie de origine------------------------ 75 ron/buc
- filtru ulei MANN-FILTER----------------------------- 20 ron
- filtru aer MANN-FILTER (mpi) ----------------------- 33 ron
- filtru aer MANN-FILTER (dci)-------------------------43 ron
- filtru ulei Duster-----------------------------------35 ron
- placute frana VAN BOSCH ---------------------------150 ron/set
- placute frana VAN TRW ----------------------------- 170 ron/set
- discuri frana 259 ventilate Ferodo --------------------210 ron/set
- placute frana ORIGINE(FRANTA)------------------------125 ron/set
- kit distributie DCI ------------------------------------- 260 ron
- set incalziri scaune complet cu carenaje-------------------200 ron
si multe altele...se pot aduce si piese pentru masini straine,
mentionez ca piesele sunt de origine.
0766.403.938 Vali
evali22
post 30 Apr 2013, 12:15
evali22
post 8 May 2013, 12:37
Valabil in continuare....!
evali22
post 15 May 2013, 10:11
evali22
post 20 May 2013, 16:29
Valabil in continuare.....hai la piese....
evali22
post 24 May 2013, 13:09
Sus cu anuntul.....filtre si ulei la preturi decente....
evali22
post 29 May 2013, 10:42
evali22
post 4 Jun 2013, 15:47
Valabil in continuare......
evali22
post 11 Jun 2013, 12:25
valabil in continuare.....
evali22
post 22 Jun 2013, 07:40
evali22
post 28 Jun 2013, 12:53
Valabil....
evali22
post 3 Jul 2013, 07:08
- set tapiserie Black Line------------140 ron
evali22
post 12 Jul 2013, 12:43
evali22
post 18 Jul 2013, 13:17
evali22
post 24 Jul 2013, 16:17
evali22
post 31 Jul 2013, 14:11
0766.403.938 Vali
evali22
post 9 Aug 2013, 18:02
Valabil in continuare...........
evali22
post 21 Aug 2013, 14:17
- set duze tip perdea------------20 ron
evali22
post 28 Aug 2013, 09:05
4 Pages  1 2 3 > »
Lo-Fi Version  Harta site  Parteneri  Jocuri online  Curs Valutar  HRH Haine din lana merinos Time is now: 4th June 2025 - 12:08
