> [VAND] Piese si accesorii
chroma
post 29 Oct 2013, 12:12
Lichidare de stoc. Piese noi, de origine, Tva Inclus. Preturi de dezmembrari
Cateva exemple de preturi:
7701206227 POMPA SERVOFRANA 350ron MEGANE 1/SCENIC 1
7701203071 PLACUTE FRANA 85 ron MASTER 1
7701474446 KIT DISTRIBUTIE 180 ron CLIO 1 /MEGANE 1/
7701477424 PUNTE SPATE 2400ron MEGANE 2 SEDAN
8200365627 DISC AMBREIAJ 160 ron LAGUNA 2/KANGOO 2/DUSTER / LOGAN VAN
7701208218 Placute frana 160 ron MEGANE 2 bicorp /CLIO3 RS
7701476327 AMBREIAJ 200ron LAGUNA 2/KANGOO 2/DUSTER / LOGAN VAN / SUPERNOVA
7701208718 SERVO FRANA 400 ron MEGANE 2/SCENIC 2
8200311553 UCE INJECTIE 1200 ron MASTER 2
7711368748 TURBOCOMPRESOR 1200ron LAGUNA 2 /MEGANE 2/SCENIC 2
8200427859 CATALIZATOR 1150ron CLIO 1 /CLIO 2/CLIO3 /MEGANE 1/MEGANE 2/SCENIC 2/KANGOO 1/
6001546640CONVERTOR CATALITIC DIESEL SLZ 190 ron SOLENZA
7700435589 CASETA DIRECTIE 950 ron SCENIC 1
6001548359 TUB COBORARE SLZ 330 ron SOLENZA
6001543371 CHIULOASA AS SN 800ron SUPERNOVA
7701473569 KIT DISTRIBUTIE 480ron LAGUNA 1 /LAGUNA 2
7701477017 COLECTIE AMBREIAJ D 260 ron CLIO 1 /CLIO2 /MEGANE 1 / SCENIC 1 /KANGOO 1
8200000378 PARBRIZ LAGUNA II 220ron LAGUNA 2
8200232509 MACARA GEAM ELECTRIC 360ron CLIO 2
8200021822 COMPRESOR 800ron LAGUNA 2 /SCENIC 2/MASTER 2
7701057656 PROIECTOR 240 ron CLIO 2
8200418629 CALCULATOR FRANA MANA 700 ron VEL SATIS
8200025153 AVERTIZOR SONOR 250 ron LAGUNA 2
6001547154 MACARA ELECTRICA USA SPATE DREAPTA 150ron LOGAN
8200003330 PARBRIZ 380 ron LAGUNA 2
8200663651 AMORTIZOR SUSPENSIE 90 ron MEGANE 2
8200641468 GALET INTINZATOR 150 ron LOGAN/DUSTER
8200708128 CONDENSOR 650ron KANGOO 1
7701043964 MOTORAS VENTILATOR 350 ron KANGOO 1
8200675689 AMOTIZOR FATA 80 ron KANGOO 1
8200231663 PLANETARA 320 ron KANGOO 1
8200238762 CATALIZATOR SCENIC 650 ron SCENIC 1
7751471641 CAPOTA FATA 640 ron LAGUNA 2
7700822974 ARC ELICOIDAL FATA LAG 300ron LAGUNA 1
7700434383 RADIATOR AC 600 ron KANGOO 1
8200667618 ALTERNATOR 650ron LAGUNA 2 / MEGANE 2 /SCENIC 2
8200061950 AMORTIZOARE FATA 80ron SCENIC 1
8200117767 COMPRESOR CA-DA 550 ron CLIO 2
7700748643 AMORTIZOR 85 ron MASTER 1
7700860823 FILTRU ULEI 13 ron MASTER 1/MASTER 2/TRAFIC 1/TRAFIC 2
7751475900 LONJERON 550 ron MEGANE 2
7701477577 KIT DISTRIBUTIE 500 ron LAGUNA 2
7701471885 BIELETE DIRECTIE 80 ron MEGANE 1
8200416947 FILTRU MOTORINA 150 ron MEGANE 1 / SCENIC 1
7701477184 KIT DISTRIBUTIE 230 ron MEGANE 1 / SCENIC 1
6001546976 LOG STALP MIJLOC STANGA AS 70 ron LOGAN
8200287736 AMORTIZOR SPATE 80 ron CLIO 2
7701062106 DEFLECTOR CENTRAL 110 ron KANG00 1
7701206119 FILTRU MOTORINA 10 ron CLIO 2/MEGANE 1/SCENIC1/LAGUNA1
5001874365 ETRIER FRANA 450 ron MASCOTT
6001548659 PLANETARA DR.L0GAN DIESEL 220 ron LOGAN
7782198542 LONJERON SPATE 450 on MEGANE 2
7700437526 AIRBAG 450 ron CLIO 2
7701066109 RADIATOR 450 ron MASTER 2
6001546676 LOG DUBLURA CUSTODA 440 ron LOGAN
272108241R MOTOR GMV 480 ron MEGANE 3
7700864218 POMPA ULEI 220 ron CLIO 1 / MEGANE 1 /SCENIC 1/ KANG00 1 /LAGUNA 1
8200711396 CASETA DIRECTIE 440 ron CLIO 2
7701476941 PROIECTOR DREAPTA 400 ron LAGUNA 2
6001551030 COLECTIE POMPA FR 140 ron LOGAN / DUSTER
6001551031 COLECTIE POMPA FRANA 150 ron LOGAN
7701471464 KIT DISTRIBUTIE 210 ron LAGUNA 1/ LAGUNA 2 / MASTER 2 /TRAFIC 2
7701473523 BUCLIER FATA 400 ron SCENIC 1
8200427780 LUNETA 220ron CLIO 3
7701208945 CALCULATOR FAR 400 ron MEGANE 2 / SCENIC 3 /LAGUNA 3
7701062300 CORP CLAPETA 400 ron LAGUNA 1 /LAGUNA 2 /MEGANE 2 /SCENIC 2
6001546955 LOG TRAVERSA CENTRALA AS. 200 ron LOGAN
7700435721 GEAM LUNETA LAG 400 ron LAGUNA 2
7701469821 KIT DISTRIBUTIE 190 ron LAGUNA 1 /LAGUNA 2/MASTER 2/TRAFIC 2
7701206433 BUCLIER SPATE 380 ronLAGUNA 2
8200323863 CALCULATOR INJ 380 ron SUPERNOVA
8200432638 AIRBAG 380 ron MEGANE 2
7700845811 FILTRU PARTICULE 18 ron MEGANE 1
7701471098 COLECTIE INCUIETORI CUT E 380 ron CLIO 2
8200122947 AMORTIZOARE 90 ron MEGANE 2
8200040089 ARC SUSPENSIE180 ron MEGANE 2
7700431718 POMPA BENZINA 350 ron MEGANE 1 / SCENIC 1
7701207537 FLANSA AMORTIZOR180 ron LAGUNA 2
8200652289 CALCULATOR 370 ron CLIO 3
8200747214 RADIATOR APA 350 ron KANGOO 1
8200478622 MACARA USA 350 ron MEGANE 2
8200682388 CALCULATOR AIRBAG 350 ron MEGANE 2
8200350772 AIRBAG 350 ron KANG00 1
7700314057 DEBITMETRU AER 350 ron LAGUNA 2 / MASTER 2
8200188391 GARNITURA CHIULASA 120 ron CLIO 1 /CLIO 2 /CLIO 3/ KANG00 1/LAGUNA 1 /LAGUNA 2/ MEGANE 1/MEGANE 2 /SCENIC 1/ SCENIC 2 /LOGAN / SOLENZA
8200298164 CALCULATOR INJECTIE 380 ron CLIO 2 /MEGANE 1 / SCENIC 1
7751475985 PRAG DREAPTA 300 ron LAGUNA 2
8200436366 TRANSMISIE 350 ron MEGANE 2 / SCENIC 2
8200352230 SCUT MOTOR 340 ron MASTER 2
7782113083 DUBLURA PRAG 300 ron MEGANE 2
7700415822 AMORTIZOR SPATE 80 ron MEGANE 1
8200312454 AMORTIZOARE 90 ron MEGANE 2
8200804164 CABLAJ 340 ron TWINGO 2
7701472113 BIELETA DIRECTIE 90 ron CLIO 2 / KANGOO 1
7700314021 AMORTIZOR FATA 110 ron KANGOO 1
7701205894 CAPTOR PRESIUNE 300 ron CLIO 2 /KANG00 1 / MEGANE 1 / SCENIC 1
8200657100 AMORTIZOR SUSPENSIE 120 ron LAGUNA 2
8200001913 INST SP FARURI 150 ron LAGUNA 2
6001548546 UCE INJECTIE LOG DIESEL 270 ron LOGAN
8200378211 TAMPON ELASTIC 130 ron TRAFIC 2
8200646838 MACARA270 ron SCENIC 2
8200748633 VALVA RECICLAJ 270 ron CLIO 1 /CLIO 2/CLIO3 /MEGANE 1/MEGANE 2/SCENIC 2/KANGOO 1/KANG00 2 / LAGUNA 1/LAGUNA 2 /LAGUNA 3 /LOGAN/ SCENIC 1 / SCENIC 2
8200216446 BLOC LUMINI 130 ron MEGANE 2
8200042514 POMPA APA 90 ron LAGUNA 1 /LAGUNA 2 / MASTER 2
7701044518 FAR STG 250 ron MASTER 2
7701470812 BUCLIER SPATE 250 ron CLIO 2
8200185731 BARE PLAFON 250 ron LAGUNA 2
lista este foarte lunga. cereti si vi se va da!
29 Oct 2013, 13:06:
8200479789 COTIERA 90 ron MEGANE 2
8200196970 COTIERA 85 ron MEGANE 2
This post has been edited by chroma: 29 Oct 2013, 13:06
dacia sandero 2008 under construction
mad toz
post 29 Oct 2013, 22:59
fan dacia-reno
Parbriz atermic Megane II?
Codul cred ca este 8200200551.
Dacia 1310 1998-Berlina Motor 1,6 8v ,72 HP , 125 Nm
2004 Renault 1.9 8v , 120 HP , 300 Nm
chroma
post 30 Oct 2013, 09:12
nu am atermic. am colorat (fara senzor lumina si ploaie) 8200200547 545 ron, pret dealer 1108 ron
<span class='edit'>30 Oct 2013, 10:05:</span>
macara electrica dreapta fata fara impuls 8200478622 350 ron Megane 2
<span class='edit'>30 Oct 2013, 13:33:</span>
ADAUG
8200452715 BRAT INF 140 ron LAGUNA 2
7700838591 MACARA GEAM 280 ron SCENIC 1
6001546749 PASAJ ROATA FATA DREAPTA 45 ron LOGAN
7701475687 INCUIETOARE 220 ron MASTER 2
7700311821 MECANISM ELECTRIC GE 220 ron TRAFIC 2
7700312848 COND AC CONDENS/EVAP 220 ron CLIO 2
6001998005 ALARMA AUTO 130 ron SOLENZA
7701061075 FAR 250 ron CLIO 3
8200111671 CALCULATOR AIR-BAG 250 ron MEGANE 1
7700430611 GALERIE ESAPAMENT 270 ron MEGANE 1 / SCENIC 1
7700113209 ELECTROMOTOR 280 ron CLIO 1 /CLIO 2/CLIO3 /MEGANE 1/MEGANE 2/SCENIC 2/KANGOO 1/KANG00 2 / LAGUNA 1/LAGUNA 2 /LAGUNA 3 /LOGAN/ SCENIC 1 / SCENIC 2
7701468520 PARBRIZ MEGANE 230 ron MEGANE 1
8200893713 CABLAJ MOTOR 230 ron LOGAN
7701068385 RETROVIZOR 220 ron SCENIC 2
8200299241 MOTORAS REGLAJ RELANTI CUT F 220 ron CLIO 1 /CLIO 2/CLIO3 /MEGANE 1/MEGANE 2/SCENIC 2/KANGOO 1/KANG00 2 / LAGUNA 1/LAGUNA 2 /LAGUNA 3 /LOGAN/ SCENIC 1 / SCENIC 2
7700308546 TOBA 210 ron KANGOO 1
8200182358 TUB COMPRESOR 215 ron MEGANE 1 / SCENIC 1
8200455669 VOLAN 210 ron MASTER 2
7701709884 COND SERVODIRECTIE 215 ron MEGANE 1 / SCENIC 1
6001547546 BENDIX 105 ron LOGAN
8200239887 GRILA CALANDRU 200 ron MASCOTT
7700427101 POMPA BENZINA 220 ron LAGUNA 1
8200241713 TOBA INTERMEDIARA 200 ron SCENIC 1
8200272485 AOMRTIZOR SPT 100 ron CLIO 2
6001548993 CABLAJ MOTOR 200 ron LOGAN
8200016036 AMORTIZOR SPATE 100 ron LAGUNA 1
7701207350 RULMENT AMORTIZ 200 ron LAGUNA 2
8200620376 AMORTIZOR SPATE 100 ron VEL SATIS
7711425255 ECHIPAMENT SPORTIV (ornamente pr. ceata) 200 ron SYMBOL
7700434304 MACARA MEC USA SPATE DR 200 ron CLIO 2
7701044038 FAR DREAPTA 100 ron KANGOO 1
8200033595 AMORTIZOR 70 ron MEGANE 1
7700426204 TOBA FINALA 200 ron LAGUNA 1
8200270927 AMORTIZOR 100 ron TRAFIC 2
8200327551 PARBRIZ 200 ron CLIO 2
8200733832 MACARA GEAM SP DR 160 ron LOGAN / DUSTER
8200125050 TOBA DETENTA 180 ron CLIO 2
8200283391 AMORTIZOR 90 ron LAGUNA 2
7751473230 PASAJ ROATA 160 ron CLIO 2 / KANGOO 1
6001546044 X USA FATA DR AS DSLZ 80 ron SOLENZA
7701208333 ETRIER FRANA 160 ron CLIO 3 / MODUS / LOGAN /DUSTER
7701202788 PLACUTE FRINA 50 ron LAGUNA 1
8200692605 REGULATOR ELECTRIC CUT J 160 ron CLIO 1 /CLIO 2/CLIO3 /MEGANE 1/MEGANE 2/SCENIC 2/KANGOO 1/KANG00 2 / LAGUNA 1/LAGUNA 2 /LOGAN/ SCENIC 1 / SCENIC 2 / DUSTER
6001540547 DUBLURA ARIPA F STG M99 50 ron DACIA BREACK
8200249112 CAPTOR INALTIME SPATE CUT E BUC 160 ron MEGANE 2
6001546941 TRAVERSA INFERIOARA CADRU PARTE INFERIOARA 160 ron LOGAN
7700830498 AMORTIZOARE 80 ron LAGUNA 1
7700840264 AMORTIZOR 80 ron MEGANE 1
8200183704 DISC AMBREIAJ 150 ron CLIO 1 /CLIO 2/CLIO3 /MEGANE 1/MEGANE 2/SCENIC 2/KANGOO 1/KANG00 2 / LAGUNA 1/LAGUNA 2 /LOGAN/ SCENIC 1 / SCENIC 2 / DUSTER
6000022736 CAP BARA 70 ron LAGUNA 1
7701474022 KIT DISTRIBUTIE 150 ron CLIO 1 /CLIO 2/CLIO3 /MEGANE 1/MEGANE 2/SCENIC 2/KANGOO 1/KANG00 2 / LAGUNA 1/LAGUNA 2 /LOGAN/ SCENIC 1 / SCENIC 2 / DUSTER
8200009737 BIELETA ANTIRULIU VEL SATIS CUT A 150 ron VEL SATIS
8200009738 BIELETA ANTIRULIU VEL SATIS CUT A 150 ron VEL SATIS
7700105290 BUJIE APRINDERE 25 ron CLIO 1 /CLIO 2/CLIO3 /MEGANE 1/MEGANE 2/SCENIC 2/KANGOO 1/KANG00 2 / LAGUNA 1/LAGUNA 2 /LOGAN/ SCENIC 1 / SCENIC 2 / DUSTER
7701477112 COL. AMBREIAJ FI 512 130 ron CLIO 1 /CLIO 2/CLIO3 /MEGANE 1/MEGANE 2/SCENIC 2/KANGOO 1/KANG00 2 / LAGUNA 1/LAGUNA 2 /LOGAN/ SCENIC 1 / SCENIC 2 / DUSTER
6001537412 SET MOTOR DACIA 1400 INELE CAUCIUC 140ron DACIA BERLINA
7701057376 CABLU ACCELERATIE CUT I 140 ron MASTER 2
7701478115 SET AMBREIAJ 140 ron CLIO 1 /CLIO 2/CLIO3 /MEGANE 1/MEGANE 2/SCENIC 2/KANGOO 1/KANG00 2 / LAGUNA 1/LAGUNA 2 /LOGAN/ SCENIC 1 / SCENIC 2 / DUSTER
6000022753 CAP BARA CUT F 45 ron MEGANE 1 / SCENIC 1 / KANGOO 1
7700854622 INJECTOR CUT A 35 ron SAFRANE
6001548808 LOG TRAVERSA PAVILION BK 140 ron LOGAN MCV
7701471864 KIT DISTRIBUTIE 130 ron MEGANE 1 / SCENIC 1 / KANGOO 1 / LOGAN
6001547875 LOG BRAT STERGATOR DR 30 ron LOGAN
8200611295 PINION VITEZA A 5 A CUT E 130 ron CLIO 1 /CLIO 2/CLIO3 /MEGANE 1/MEGANE 2/SCENIC 2/KANGOO 1/KANG00 2 / LAGUNA 1/LAGUNA 2 /LOGAN/ SCENIC 1 / SCENIC 2 / DUSTER
622540002R GRILA CALANDRU 130 ron MEGANE 3
8200741758 SUPORT GMP 130 ron MEGANE 2 / SCENIC 2 / LAGUNA 2
7701469776 KIT DISTRIBUTIE 130 ron MEGANE 1 / SCENIC 1
7701466676 BUCLIER SPATE 130 ron CLIO 1
6001538405 HAYON NOVA AS 120 ron NOVA
7701205538 CALORIFER 120 ron KANGOO 1
6001546159 X PANOU USA SPATE STG 30 ron SOLENZA
8200794023 ELEMEN CENTRAL 120 ron CLIO 3
7703090362 RULMENT CV CUT.E BUC 120 ron CLIO 1 /CLIO 2/CLIO3 /MEGANE 1/MEGANE 2/SCENIC 2/KANGOO 1/KANG00 2 / LAGUNA 1/LAGUNA 2 /LOGAN/ SCENIC 1 / SCENIC 2 / DUSTER
8200620382 AMORTIZOR FATA 120 ron LAGUNA 2
8200165373 GARNITURA PD-M IN 120 ron MEGANE 2
7701208105 GRILA AERISIRE 120 ron CLIO 2
7751469983 TABLIE PODEA 120 ron MEGANE 1
6001546381 REPARTITOR AER 60 ron SOLENZA
7701209220 POMPA FRANA 120 ron MEGANE 2 / SCENIC 2
7700834098 GRILA PARBRIZ 120 ron MEGANE 1
7700777093 PALIER SPATE STG. 120 ron RENAULT 19
7700777094 PALIER SPATE DR. 120 ron RENAULT 19
7700354637 OGLINDA DR 120 ron KANGOO 1
6001543999 HAYON ANS SN120 ron SUPERNOVA
6001998037 ALARMA ANTIEFRACTIE VEH.CU INCH. CENTRALIZATA 120 ron SOLENZA
7701473354 SUPAPE EVACUARE 120 ron CLIO 1 /CLIO 2/CLIO3 /MEGANE 1/MEGANE 2/SCENIC 2/KANGOO 1/KANG00 2 / LAGUNA 1/LAGUNA 2 /LOGAN/ SCENIC 1 / SCENIC 2 / DUSTER
8200000515 TIRANT FATA CUT B 120 ron LAGUNA 2 / VEL SATIS
7701477280 ORNAMENT 120 ron TRAFIC 2
7751698514 TRAVERSA FATA PAVILION 120 ron CLIO 2
7700428438 AMORTIZOR 60 ron CLIO 2
8200140565 CONDUCTA ALIMENTARE 120 ron MEGANE 1 / SCENIC 1
7701205664 PROIECTOR 60 ron CLIO 2 / KANGOO 1 / MEGANE 1 / MASTER 2
7701069118 SUPORT COMUTATOR 120 ron TRAFIC 2
6001548684 USITA CUTIE ACTE 120ron LOGAN
7701471522 BURDUF PARTE DR CV 30 ron CLIO 1 /CLIO 2/CLIO3 /MEGANE 1/MEGANE 2/SCENIC 2/KANGOO 1/KANG00 2 / LAGUNA 1/LAGUNA 2 /LOGAN/ SCENIC 1 / SCENIC 2 / DUSTER
8200676228 TUB ALIMENTARE 120 ron LAGUNA 2
6001543070 SUPORT FAR STINGA NOVA1 10 ron SUPERNOVA
8200113957 CAPAC BATERIE 60 ron MEGANE 1
6001548129 CONDENSOR 120 ron SOLENZA
6001546028 X HAYON AS DSLZ 120 ron SOLENZA
8200007832 FILTRU ULEI 7 ron LAGUNA 1 / MASTER 1 / MASTER 2 / TRAFIC 2
8200218942 COND CARB REZERVOR 120 ron CLIO 2 / KANGOO 1
7701694295 GEAM CULISANT 120 ron MASTER 2
6001546461 ANS POMPA CARBURANT 120 ron SOLENZA
6001543342 PORTFUZETA STG SN 120 ron SOLENZA / SUPERNOVA
7700425952 CILINDRU EMITATOR AM CUT D 120 ron LAGUNA 1
7701470763 BIELETA DIRECTIE 120 ron KANGOO 1
7701474373 SET GARNITURI 120 ron LAGUNA 1 / LAGUNA 2 /MASTER 2 /TRAFIC 2
7701209714 CONDUCTE ASAMBLATE CUT E 70 ron CLIO 1 /CLIO 2/CLIO3 /MEGANE 1/MEGANE 2/SCENIC 2/KANGOO 1/KANG00 2 / LAGUNA 1/LAGUNA 2 /LOGAN/ SCENIC 1 / SCENIC 2 / DUSTER
8200739980 CENTURA DE SUGURANTA 120 ron KANGOO 1
8200675683 AMORTIZOR SPATE 50 ron KANGOO 1
7700804163 SUPORT ELASTIC120 ron MEGANE 1 / SCENIC 1
8200117291 CARENAJ 80 ron MEGANE 2
8200475182 SUPORT GMP 160 ron LAGUNA 2 / VEL SATIS
7711221280 ORNAMENTE PAVILION 100 ron MEGANE 2
7750836335 INTARITURA LONJERON 50 ron CLIO 2 / KANGOO 1
7700420122 STOP-SEMNALIZATOR 120 ron LAGUNA 1
6001540539 USA SPATE DREAPTA BK AS 40 ron DACIA BREACK
6001546642 X CAMERA DETENTA 50 ron SOLENZA
8200274709 CONDUCTA FLEXIBILA MASTER, TRAFIC, LAG 120 ron MASTER 2 / TRAFIC 2 / LAGUNA 2
6001548426 ROTULA AXIALA 12 ron SOLENZA / SUPERNOVA
6001543994 PARTE CENTRALA CUTIE CLIMATIZARE AC. ASAMBL 20 ron SUPERNOVA
6001998333 GRILAJ PROTECTIE SUPLIMENTARA LUNETA 70 ron LOGAN PICK-UP
6001545860 X PAVILION ASAMBL. DSLZ 120 ron SOLENZA
8200237374 AMORTIZOARE 120 ron LAGUNA 2
6001546021 X STILP FATA DRT AS DSLZ 12 ron SOLENZA
8200737135 BRAT INF 120 ron MEGANE 1
6001543093 ANS TRAVERSA INF PARBRIZ PICK-UP 12 ron PICK-UP
6001544277 HAION AS DSN - FARA ELERON 120 ron SUPERNOVA
8200694080 CABLU FRANA 35 ron KANGOO 1
7751714320 ARMATURA BUCLIER BUC 110 ron CLIO 2
7750350142 DUBLURA STALP 120 ron MASTER 2
8200069701 CONDUCTA APA 110 ron MEGANE 1 / SCENIC 1
7701473793 ORNAMENT 100 ron MEGANE 1
8200283036 TUB CIRCUIT 110 ron MASTER 2
7700420164 ACTUATOR CUT A 110 ron LAGUNA 1 / SCENIC 1
7700867177 SUPORT INTERMEDIAR PE CHIULASA35 ron SOLENZA / SUPERNOVA
6001545848 TABLA LATERALA PLANSEU DREAPTA ASAMBLAT 15 ron PICK-UP
6001543062 X LONJERON FATA STINGA DSLZ 35 ron SOLENZA
6001545590 TABLOU BORD 1310 INJ F T 100 ron PICK-UP
7700828300 GEAM CULISANT 100 ron MEGANE 1
7700424481 RULMENT AMORTIZOR 25 ron LAGUNA 2
31 Oct 2013, 10:29:
Alta lista. In total sunt peste 250000 de repere. Cereti!
6001549674 RETROVIZOR EXTERIOR 100 ron LOGAN
6001549675 RETROVIZOR EXTERIOR 100 ron LOGAN
7701042633 TRIPLA DREAPTA 50 ron MEGANE 1
7700429962 PARASOLAR 100 ron MEGANE 1
7700302428 SENZOR ABS 100 ron MASTER 2
8200336830 TRIPLA 100 ron TRAFIC 2
7701040208 BUJII 15 ron MASTER 2 / TRAFIC 2
7711130031 DISC AMBREIAJ 100 ron CLIO 1 / MEGANE 1 / SCENIC 1
8200142683 STOP/SEMNALIZ 100 ron MEGANE 2
7701469095 COMANDA VITEZE 100 ron MEGANE 1
7782208499 RAMFORSARE 100 ron MEGANE 2
7750424426 DUBLURA SUP.TRIPLA 100 ron LAGUNA 2
8200230791 RETROVIZOR 90 ron CLIO 2
8200262667 SEMNALIZATOR SPATE 90 ron LAGUNA 2
7701040682 FAR STG BUC 90 ron MEGANE 1 / SCENIC 1
8200131665 CONDUCTA AC COMP/DET 90 ron SCENIC 1
7782208500 RAMFORSARE 90 ron MEGANE 2
8200038866 SUPORT MOTOR 90 ron LAGUNA 2
7700828345 GEAM USA FATA 90 ron MEGANE 1
7700115309 FULIE VILBROCHEN 90 ron CLIO 1 /CLIO 2/CLIO3 /MEGANE 1/MEGANE 2/SCENIC 2/KANGOO 1/KANG00 2 / LAGUNA 1/LAGUNA 2 /LOGAN/ SCENIC 1 / SCENIC 2 / DUSTER
7701470363 CAP BARA CUT B 90 ron MASTER 2
7700830490 AMORTIZOR 90 ron LAGUNA 2
6001541547 BUCLIER FATA D1310 CN4 90 ron PICK-UP
7701057557 REZISTENTA CUT I 45 ron MASTER 2
924900030R TUB CIRCUIT 90 ron LAGUNA 3 / LATITUDE
963015334R RETROVIZOR EXTERIOR 90 ron LOGAN
7701476823 CABLAJ 90 ron MEGANE
8200060918 MANER COMANDA 90 ron CLIO 2
8200018949 PALIER CUT I 40 ron CLIO 1 /CLIO 2/CLIO3 /MEGANE 1/MEGANE 2/SCENIC 2/KANGOO 1/KANG00 2 / LAGUNA 1/LAGUNA 2 /LOGAN/ SCENIC 1 / SCENIC 2 / DUSTER
8200329944 AMORTIZOR FATA 90 ron VEL SATIS
7701207178 SABOTI FRANA 90 ron CLIO 2
7701205339 SEGMENTI FRANA 90 ron LAGUNA 1 / MEGANE 1 / SCENIC 1
7700430760 AMORTIZOR FATA 90 ron MEGANE 1 / SCENIC 1
7700737571 SENZOR CUT I 40 ron CLIO 1 /CLIO 2/CLIO3 /MEGANE 1/MEGANE 2/SCENIC 2/KANGOO 1/KANG00 2 / LAGUNA 1/LAGUNA 2 /LOGAN/ SCENIC 1 / SCENIC 2 / DUSTER
7701209059 OBTURATOR 90 ron CLIO 3
8200741228 CONDUCTA FLEXIBILA I 45 ron MEGANE 2
8200486264 ELECTROVANA 90 ron CLIO 1 /CLIO 2/CLIO3 /MEGANE 1/MEGANE 2/SCENIC 2/KANGOO 1/KANG00 2 / LAGUNA 1/LAGUNA 2 /LOGAN/ SCENIC 1 / SCENIC 2 / DUSTER
6001541139 BUTUC ROATA FATA CUT C 80 ron SUPERNOVA
7701207491 KIT SUSPENSIE 90 ron TRAFIC 2
7701205780 RULMENT FATA 90 ron LAGUNA 1 / MEGANE 1 / SCENIC 1
6001546992 LOG OGLINDA 80 ron LOGAN
8200299822 AMORTIZOARE 80 ron CLIO 2
8200136885 OBTURATOR CUT I 20 ron CLIO 2
7701207945 ORNAMENT CUT D 40 ron LAGUNA 2
7701205078 COMANDA SCAUN CUT E 40 ron KANGOO 1
8200837564 SURUB M10X150-50 CUT E 14 ron MEGANE 2 / SCENIC 2
8200299419 AMORTIZOR FATA 80 ron SCENIC 1
8200445919 CONDUCTA ALIMENTARE 40 ron CLIO 1 /CLIO 2/CLIO3 /MEGANE 1/MEGANE 2/SCENIC 2/KANGOO 1/KANG00 2 / LAGUNA 1/LAGUNA 2 /LOGAN/ SCENIC 1 / SCENIC 2 / DUSTER
7701470741 BUTUC HAYON CUT E 80 ron KANGOO 1
8200029320 CONDUCTA COMPRESOR 80 ron MASTER 2
7701469160 RETROVIZOR CUT B BUC 40 ron LAGUNA 1
7700428860 TUB COMPRESOR 80 ron CLIO 2 / KANGOO 1
7701040681 PROIECTOR 80 ron CLIO 1 / MEGANE 1 / SCENIC 1
6001546632 X TABLOU DE BORD 80 ron SOLENZA
6001548543 LOG INTARITURA STALP MIJLOC 80 ron LOGAN
6001543657 CONDUCTĂ CONDENSATOR REZVOR FILTRU 20 ron SUPERNOVA
7701206537 MOTORAS RACIRE CUT B 40 ron LAGUNA 2 / VEL SATIS
8200694053 CABLU FRANA 40 ron KANGOO 1
7700427573 ORNAMENT 20 ron MEGANE 1
7701472766 BIELETE DIRECTIE 80 ron LAGUNA 2
8200069652 MANER USA STG. CUT F 80 ron SCENIC 1
7700830492 AMORTIZOR 80 ron LAGUNA 1
6001540094 LAMPA SPATE DR M99 BK 10 ron DACIA BREACK
7701207481 SET REPARATIE ETRIER 80 ron KANGOO 1
7701207482 SET REPARATIE ETRIER 80 ron KANGOO 1
7700434880 OGLINDA STG 80 ron CLIO 2
6001540537 TABLA EXT USA SPATE DR D1,9D DC 20 ron PICK-UP
6001538284 USA F STG CN3 M96 1310 80 ron PICK-UP
7700834101 ORNAMENT 40 ron MEGANE 1
6001549861 LOG INTARITURA DUBLURA STG BUC 80 ron LOGAN
8200150623 TRIPLA STG 80 ron KANGOO 1
8200276019 TOBA INTERMEDIARA 80 ron MEGANE 2 / SCENIC 2
8200864613 BALAMA USA 80 ron CLIO 3
6001540010 ANS.PLATOU FRANA DREAPTA PAPUC 40 ron PICK-UP
7701474984 BANDOU 80 ron SCENIC 2
6001543478 CONDUCTA INTRARE RAD SN 5 ron SUPERNOVA
6001998202 PROTECTIE PANOURI LATERALE STANGA 80 ron LOGAN VAN
6001998214 PROTECTIE PANOURI LATERALE DREAPTA 80 ron LOGAN VAN
8200024935 AMORTIZOR SPATE 80 ron MASTER 2
6001540892 SERVOFRANA DACIA 40 ron PICK-UP
6001541551 BARA FATA NOV 40 ron SUPERNOVA
8200141544 CARENAJ BUC 80 ron MEGANE 2
8200664346 FULIE 80 ron LAGUNA 1 / LAGUNA 2 /MASTER 2 /TRAFIC 2
7700855900 TUB FLEXIBIL INJ 80 ron TRAFIC 1
7700834181 OGLINDA 80 ron MEGANE 1
7700427571 SUPORT BUCLIER 15 ron MEGANE 1
8200739495 BASCULA SUSPENSIE FATA 80 ron KANGOO 1
6001546023 X PANOU LATERAL STINGA DSLZ 80 ron SOLENZA
7700431999 PIPA UMPLERE CUT F 80 ron MEGANE 1
7700311973 DIVERSE GRUP 60 60 ronTRAFIC 2
8200120607 GEAM CULISANT 70 ron MEGANE 2
8200419949 SEMNALIZATOR SPATE 70 ron KANGOO 2
8200201090 DIVERSE BUC 70 ron TRAFIC 2
8200589655 ANSAMBLU FILTRU AER 70 ron CLIO 2 / KANGOO 1 / LOGAN
7701209291 CABLAJ 70 ron MEGANE 2
7700411189 BIELETA GMP CUT B 70 ron LAGUNA 1
8200354172 CUTIE VAPORI CUT D 70 ron LAGUNA 1 / LAGUNA 2 /MASTER 2 /TRAFIC 2
6001538536 TABLA LATERALA STG DROP-SIDE 20 ron PICK-UP
7701207185 SET REPARATIE ETRIER CUT E 35 ron KANGOO 1
7701062603 BAGHETA USA FATA BUC 70 ron KANGOO 1
7701416370 CUTIE RELEE 70 ron MEGANE 1
7700111822 GALET CUTA 70 ron CLIO 1 /CLIO 2/CLIO3 /MEGANE 1/MEGANE 2/SCENIC 2/KANGOO 1/KANG00 2 / LAGUNA 1/LAGUNA 2 /LOGAN/ SCENIC 1 / SCENIC 2 / DUSTER
7700308589 AMORTIZOR 70 ron KANGOO 1
7700430000 INTRERUPATOR CUT A 35 ron CLIO 2 / MEGANE 1
6001545269 COLECTIE GARNITURI Q 35 ron SOLENZA / PICK-UP
6001539799 PLANSEU INTERMEDIAR AS.D1,9DC 35 ron PICK-UP
6001550620 LOG LELEMENT INCHIDERE BAV 70 ron LOGAN
6001548544 L0G INTARITURA STALP MIJ 80 ron LOGAN
6001538513 PLANSEU PLATFORMA AS.D1,9D PICK-UP 70 ron PICK-UP
8200485667 ELEMENT FIXARE PARASOLAR CUT A 20 ron LAGUNA 2 / VEL SATIS
8200002443 COMANDA REGLAJ OGLINDA CUT. E 70 ron LAGUNA 2 / VEL SATIS
7701206776 ORNAMENT CUT G 70 ron LAGUNA 2
6001538639 ARMATURA SCAUN FATA STINGA DSN 70 ron SUPERNOVA
7700832031 GARNITURA HAYON 70 ron MEGANE 1
6001538524 CUTIE CLIMATIZARE 35 ron SOLENZA
6001546152 X PANOU USA FATA STG 35 ron SOLENZA
7701209808 PLACUTE FRANA 70 ron LAGUNA 2
6001545987 LONJERON FATA STG AS DSN 35 ron SUPERNOVA
8200237413 SUPORT CABLURI CUT F 30 ron MEGANE 2 / SCENIC 2
6001539726 PANOU LAT. DR. SIMPLU BL 70 ron DACIA BERLINA
7700836740 GARNISAJ HAYON 60 ron CLIO 2
6001540520 CAPOTA FATA ASAMBL M99 70 ron PICK-UP
6001545989 X TRAVERSA CENTRALA AS DSLZ 10 ron SOLENZA
7700842891 GEAM CULISANT 70 ron CLIO 2
7701473312 KIT DISTRIBUTIE 70 ron LAGUNA 2 / TRAFIC 2
8200331313 CONDUCTA APA 70 ron CLIO 2 / KANGOO 1
8200150619 STOP SMNALIZATOR 60 ron KANGOO 1
6001542782 PARTE CENTRALA BUCL SPT BL 20 ron DACIA BERLINA
7700433061 CRIC 70 ron CLIO 2
7700416066 SENZOR ACCELERATIE 70 ron LAGUNA 1
7701473979 COLECTIE GRILA 70 ron KANGOO 1
6001546957 TRAVERSA LATERALA STANGA SPATE AS 40 ron LOGAN
6001546958 TRAVERSA LATERALA DREAPTA SPATE AS. 40 ron LOGAN
7701043966 SUPORT GMV 70 ron KANGOO 1
6001539409 LONJ INTERMED DR AS D1,9D DC 20 ron PICK-UP
7700115710 CONDUCTA CARBURANT 70 ron SCENIC 1
6001545847 TABLA LATERALA PLANSEU STANGA ASAMBLAT 15 ron PICK-UP
7700308544 TOBA ESAPAMENT 70 ron KANGOO 1
8200859992 SEMICUZINETI CUT J 10 ron CLIO 1 /CLIO 2/CLIO3 /MEGANE 1/MEGANE 2/SCENIC 2/KANGOO 1/KANG00 2 / LAGUNA 1/LAGUNA 2 /LOGAN/ SCENIC 1 / SCENIC 2 / DUSTER
7701475290 GEAM 70 ron KANGOO 1
7701204497 FILTRU MOTORINA 7 ron CLIO 1 / MEGANE 1 / SCENIC 1
8200401106 TAPITERIE 70 ron MEGANE 2
7701040770 BRAT STERGATOR 70 ron MEGANE 1
8200455453 BURDUF CUT. E 70 ron CLIO 2
8200670524 SONDA NIVEL ULEI CUT A 70 ron CLIO 1 /CLIO 2/CLIO3 /MEGANE 1/MEGANE 2/SCENIC 2/KANGOO 1/KANG00 2 / LAGUNA 1/LAGUNA 2 /LOGAN/ SCENIC 1 / SCENIC 2 / DUSTER
7700310740 AMORTIZOR SPATE 70 ron MASTER 2
6001545715 AMORTIZOR ZGOMOT Q 1304 70 ron PICK-UP
7700437709 70 ron SCENIC 1
6001547578 VIZIERA BUC 60 ron LOGAN 1
7700419523 CONDUCTA COMPRESOR MEGANE 1 / SCENIC 1
6001998063 PLASA ELASTICA VERTICALA PORTBAGAJ 15 ron SOLENZA
8200116465 ELEMENT FIXARE 70 ron MEGANE 2
7701476899 CUZINET CUT G 70 ron ESPACE 4 / VEL SATIS
8200065344 ECRAN TERMIC CUT E 70 ron CLIO 1 /CLIO 2/CLIO3 /MEGANE 1/MEGANE 2/SCENIC 2/KANGOO 1/KANG00 2 / LAGUNA 1/LAGUNA 2 /LOGAN/ SCENIC 1 / SCENIC 2 / DUSTER
485204680R BIELETA 70 ron FLUENCE / MEGANE 3 / SCENIC 3
410600756R PLACUTE FR 70 ron SCENIC 2
6001538189 TRAVERSA EXTREMA SPATE DSN 10 ron SUPERNOVA
7700796972 AMORTIZOR 70 ron RENAULT 21
8200059855 TAMPON SOC SPATE CUT B 35 ron MASTER 2
6001542893 ELEMENT INCHIDERE LONJERON BUC 60 ron PICK-UP
7701469678 ORNAMENT USA DR F 60 ron LAGUNA 1
6001546022 X STALP FATA STANGA AS DSLZ BUC 10 ron SOLENZA
8200143048 CHEDER 60 ron SCENIC 1
6001541004 PANOU LATERAL STG 60 ron DACIA BREACK
6001538215 CENTURA PAVILION STG DSN 10ron SUPERNOVA
7700834858 INSONORIZANT COMP MOTOR 70 ron LAGUNA 1
7701472842 PORTFUZETA 70 ron LAGUNA 2
6001539887 PARTE SUP PANOU LAT DR AS D1,9D DC 10 ron PICK-UP
7701206536 MOTORAS CLIMA 60 ron LAGUNA 2 / VEL SATIS
8200491146 CONSOLA FRANA CUT.E 60 ron MEGANE 2
6001547666 TABLOU COMANDA INCALZIRE 60 ron LOGAN
7701052475 ORNAMENT 30 ron CLIO 2
7700786022 FURTUN RADIATOR 60 ron RENAULT 25
7750350524 PASAJ ROATA 60 ron MASTER 2
6001538504 LONJERON SPATE STANGA 60 ron PICK-UP
9649592880 CUREA 35 ron CLIO 2 / LAGUNA 1 / LAGUNA 2
7782254222 STALP 60 ron CLIO 3
7782118423 TRAVERSA INFERIOARA 70 ron KANGOO 1
7701473542 ORNAMENT USA 35 ron SCENIC 1
6001543010 CUZINETI PALIER R1 SET 35 ron SOLENZA / SUPERNOVA
7700273245 CUREA STRIATA 8 ron MEGANE 1 / SCENIC 1
8200221695 CUREA DISTRIBUTIE CLIO, LAG, MASTER 60 ron CLIO 1 /CLIO 2/CLIO3 /MEGANE 1/MEGANE 2/SCENIC 2/KANGOO 1/KANG00 2 / LAGUNA 1/LAGUNA 2 /LOGAN/ SCENIC 1 / SCENIC 2 / DUSTER
8200303794 INSONORIZANT CAPOTA 60 ron MEGANE 2
6001538715 CAPAC DISTRIBUITOR 10 ron SOLENZA / SUPERNOVA
7701035372 AGRAFE MENTINERE 5 ron CLIO 1 /CLIO 2/CLIO3 /MEGANE 1/MEGANE 2/SCENIC 2/KANGOO 1/KANG00 2 / LAGUNA 1/LAGUNA 2 /LOGAN/ SCENIC 1 / SCENIC 2 / DUSTER
8200577917 ORNAMENT 60 ron LOGAN
6001539773 LONJERON SPATE STANGA AS 30 ron DACIA BERLINA
7700825484 AMORTIZOR 30 ron RENAULT 19
6001546026 X ANS TABLIE SPATE DSLZ 30 ron SOLENZA
7701207742 CONDUCTA CARBURANT 60 ron MEGANE 2 / SCENIC 2
7700309154 CUZINET BARA ANTIRUL CUT C 15 ron MASTER 2
7701467235 BIELETA DIRECTIE STINGA CUT D 50 ron RENAULT 19
8200005500 GAEN USA FATA 60 ron TRAFIC 2
8200763573 ORNAMENT SUPERIOR GR 60 ron LOGAN
6001546943 SUPRAINALTARE CUPELA 30 ron LOGAN
7700437408 BUCSA BARA CUT E BUC 15 ron KANGOO 1 / SCENIC 1
6001545994 TRAVERSA EXTREMA SPATE AS. 15 ron SOLENZA
8200299816 AMORTIZOR FATA 60 ron CLIO 2
8200096570 CAPOTAJ MOTOR 60 ron MEGANE 1 / SCENIC 1
8200183864 CONDUCTA CLIMA 60 ron MEGANE 1
7701470764 BIELETA DIRECTIE CUT F 60 ron KANGOO 1
7700413206 CABLU AMBREIAJ 60 ron LAGUNA 1
7701046190 GEAM OGLINDA MASTER CUT B 60 ron MASTER 2
7701041740 FILTRU AER 5 ron LAGUNA 1
6001545252 X STILP MIJLOC STG DSLZ 20 ron SOLENZA
5001847284 RETROVIZOR INT EXT 60 ron MASCOTT
8200023140 ORNAMENT 60 ron MEGANE 1 / SCENIC 1
6001544134 TRAVERSA SUPERIOARA RADIATOR 10 ron PICK-UP
7701207332 ORNAMENT BARA PLAFON 50 ron LAGUNA 2
6001542721 CONTRALAMA DRT 10 ron DACIA BREACK
8200103845 SENZOR PLOAIE CUT A 60 ron MODUS
6001546120 X PARASOLAR DR AS 15 ron SOLENZA
6001541563 DUBLURA ARIPA FATA 60 ron PICK-UP
7701205733 GHIDAJ TETIERA 30 ron CLIO 2 / KANGOO 1 / LAGUNA 1 / MEGANE 1
6001538961 CAPOTA FATA CN3 MODEL 60 ron PICK-UP
6001543923 TABLA LAT INTERIOR DR D1,9D 7 ron PICK-UP
7701057371 OGLINDA STG RETROVIZ 60 ron MASTER 2
7700100558 BUJII INCANDESCENTE CUT A 15 ron CLIO 2 / SCENIC 1 / KANGOO 1
7701205524 ARC FIX SABOTI CUT A 15 ron KANGOO 1
8200126245 CABLU ALIMENTARE CUT D 60 ron MEGANE 1
6001546004 X TRAVERSA POST CONDUCERE DSLZ 30 ron SOLENZA
6001539804 ARIPA SPATE DREAPTA DACIA 1304 60 ron PICK-UP
This post has been edited by chroma: 31 Oct 2013, 10:29
chroma
post 4 Nov 2013, 12:25
up
djthem
post 4 Nov 2013, 12:41
Salut!
Senzori presiune pneuri Megane 2.2 ai cumva?
Multumesc!
RENAULT MEGANE 4 RSLine 2022
chroma
post 4 Nov 2013, 12:49
nu, se pot aduce 407005578r captor presiune roata 150 ron pret raft 203 ron
Alex_Nanu
post 4 Nov 2013, 13:26
-pivoti, bielete de directie+cap de bara, distributie+pompa de apa-originale pentru dacia solenza ai?Daca da la ce pret?
-far dreapta pentru dacia solenza original ai?Daca da la ce pret?
Multumesc!
Dacia Solenza 2003/Scala
Bogdan90
post 4 Nov 2013, 19:11
Disc de ambreiaj solenza 1.4 ma intereseaza (doar discul) pe original valeo daca se poate, daca nu, zi-mi ce ai.
Dacia Solenza 2004 - BT-90-PAN
Dacia 1310, Dacia Solenza, Skoda Fabia 6Y2.
chroma
post 5 Nov 2013, 09:05
QUOTE(Alex_Nanu @ 4 Nov 2013, 13:26)
Multumesc!
in stoc distributie 7701477024 238 ron pret raft 309 ron
se pot aduce pompa apa 8200146301 280 ron pret raft 366 ron
pivot 6001547918 45 ron 60 ron
rotula axiala 6001546524 36 ron 49 ron
pipa bieleta 6001546523 45 ron 58 ron
far dr 6001546538 140 ron 211 ron
QUOTE(Bogdan90 @ 4 Nov 2013, 19:11)
disc 8200507366 se poate aduce la 488 ron 585 ron
in stoc set ambreiaj 302055852r 480 ron 782 ron
chroma
post 7 Nov 2013, 09:06
antifurturi jante aliaj si tabla, de origine, noi, 60 ron/ set sau 50 ron/set pentru mai mult de 3 seturi inclusiv
7 Nov 2013, 09:11:
3xset bare de pavilion (aluminiu) CLIO3, 7711221419330 ron pret dealer 690 ron.
- 2xsuport ski (pt 2 perechi) 7711224161 220 ron, pret dealer 365 ron
This post has been edited by chroma: 7 Nov 2013, 09:11
bogdan_dsn
post 7 Nov 2013, 10:26
Un set de brate de stergator de duster sau sandero? Ma intereseaza bratele cu talpa aceea mai lunga, ca sa nu loveasca in capota. Pentru Sandero imi trebuie.
Kia Ceed SW 1.4 TGDI 2020
chroma
post 11 Nov 2013, 16:26
din pacate nu
Vallybz
post 11 Nov 2013, 16:50
Salut. Ma intereseaza si pe mine o oferta petru capete de bara si bielete pt urmatoarea masina:
Datele masinii
Clio Symbol
SERIE SASIU VF1LB8K0539574687
DATA FABRICATIE 07.2008
CILINDREE:1390
PUTERE MOTOR: 55KW
MOTOR: K7J-A7
COMBUSTIBIL: BENZINA
Astept raspuns pe pm. Mersi
Renault Megane 1 Facelift, 1.6, 16v Coupe 1999 K4M-A7-00 - BZ 87 BVM
chroma
post 15 Nov 2013, 08:37
pt casete TRW
ax bieleta 7701472734 290 ron 480 ron
cap dr 7701047813 255 ron 405 ron
cap stg 7701047812 255 ron 405 ron
set stg (ax+cap) 7701476762 310 ron 560 ron
set dr (ax+cap) 7701476763 330 ron 590 ron
exista si casete Koyo, SMI, Ktech (trebuie sa-mi spui ce caseta ai)
mad toz
post 15 Nov 2013, 12:49
fan dacia-reno
Nuca schimbator 8200596163?
chroma
post 15 Nov 2013, 14:22
8200596163 se poate aduce la 345 ron, pret raft 380 ron
djthem
post 15 Nov 2013, 15:54
Salut!
As vrea si eu un set antifurturi jante aliaj pt renault megane.
Cum procedam?
Multumesc!
chroma
post 15 Nov 2013, 22:45
imi pui in cont 73 ron (60 ron prezoanele si 13 ron taxele postale) si ti le trimit. daca era valoare mai mare mergea si plata ramburs, dar asa ma costa mai mult benzina pana la oficiu (trimitere colet si apoi preluare bani) decat taxele postale. Sper sa nu fiu inteles gresit! Cat despre tepe, la mine nu exista, sunt useri aici care au cumparat piese de peste 2000 ron, au platit in avans in cont si au primit exact ce trebuia (piese originale, noi noute). Si un nr de telfon sa ne auzim daca vrea cineva alte informatii : 0720700592
This post has been edited by chroma: 15 Nov 2013, 22:46
chroma
post 19 Nov 2013, 11:59
up
chroma
post 25 Nov 2013, 10:34
up
Bogdan90
post 25 Nov 2013, 19:59
Brat bascula inferior solenza?
chroma
post 26 Nov 2013, 11:24
6001538336 stg se poate aduce la 159 ron pret dealer 166
6001538335 dr se poate aduce la 159 ron pret dealer 166
chroma
post 2 Dec 2013, 11:22
up
polpuk
post 9 Dec 2013, 23:01
salut,
Ai cumva obturatorul (capac plastic) din fata alternatorului pentru renault clio symbol, model 2007. din pacate nu stiu codul.
multumesc
This post has been edited by polpuk: 9 Dec 2013, 23:01
Renault Clio Symbol 2006 - if89cam
chroma
post 10 Dec 2013, 14:36
fa-mi o poza, nu-mi dau seama despre ce obturator este vorba
chroma
post 16 Dec 2013, 09:36
up
chroma
post 27 Dec 2013, 14:21
up
MyKe89
post 27 Dec 2013, 14:34
Membru RFG
Salut!
Ai PM.
Prezoanele antifurt se potrivesc la Supernova?
Multumesc!
'23 Honda CR-V e:HEV
'02 BMW Z3 1.9i
'91 MB W124 230E
chroma
post 30 Dec 2013, 12:11
nu am probat (sunt de parere ca s-ar potrivi), nu are nimeni pe la noi supernova, solenza. Daca au aceeasi lungime ca cele de logan, merg
uite tabelul ala de care ti-am zis
6001543043 ARBORE COTIT SN 1.151,84
6001543371 CHIULOASA AS SN 1.882,12
8200211784 SN ROLA ANTRENARE 121,51
6001538223 CADRU LAT DR AS DSN 411,90
8200323863 CALCULATOR INJ 765,09
6001538862 RADIATOR 612,55
6001546457 REZERVOR AS 248,70
6001543627 CABLAJ MOTOR SN 456,40
6001544295 UNITATE DE CONTROL SN 439,01
6001539075 MEC DESC EXT F DR TN NOVA 30,36
6001543573 PIULITA 14,73
6001545988 LONJERON FATA DR AS DSN 67,63
6001543064 LONJERON F. SUP. DR. AS. DSN 29,91
6001543999 HAYON ANS SN 248,75
6001543070 SUPORT FAR STINGA NOVA1 18,53
6001543342 PORTFUZETA STG SN 237,53
6001548426 ROTULA AXIALA 23,01
6001543994 PARTE CENTRALA CUTIE CLIMATIZARE AC. ASAMBL 45,97
6001544277 HAION AS DSN - FARA ELERON 227,19
7700867177 SUPORT INTERMEDIAR PE CHIULASA 74,25
6001538221 STALP MIJLOC STG AS DSN 41,60
6001539080 MEC DESCH EXT SPT DR TN NOVA 34,22
6001538193 TABLA LATERALA PLANSEU STG AS DSN 49,09
6001538192 TABLA LATERAL PLANSEU DR AS DSN 36,63
6001541139 BUTUC ROATA FATA CUT C 177,26
6001543657 CONDUCTĂ CONDENSATOR REZVOR FILTRU 42,35
6001543478 CONDUCTA INTRARE RAD SN 11,64
6001541551 BARA FATA NOV 80,98
6001538639 ARMATURA SCAUN FATA STINGA DSN 150,00
6001545987 LONJERON FATA STG AS DSN 74,69
6001538189 TRAVERSA EXTREMA SPATE DSN 28,20
6001538215 CENTURA PAVILION STG DSN 19,78
6001543010 CUZINETI PALIER R1 67,09
6001538715 CAPAC DISTRIBUITOR 22,17
6001543076 DUBL. ARIPA PARTE FATA STG AS DSN 115,75
6001545887 LONJERON FATA INF 114,74
6001543075 DUBL. ARIPA PARTE FATA DR. AS. DSN 57,34
6001538267 CADRU GEAM PARBRIZ AS DSN 107,27
6001538214 CENTURA PAVILION DR DSN 20,49
6001543061 LONJERON F SUP STG AS DSN 34,13
6001539318 GMV CLIMATIZARE CUT D 102,08
6001544500 GARNITURA GEAM COL 16,75
6001538458 FATA USA SPATE STINGA DSN 14,01
6001544318 PANOU USA FATA DR SN 48,29
6001543658 CONDUCTA REZERVOR FILTRU EVAP 93,01
6001539486 MECANISM LIMITARE USA FATA DSN CUT C 92,11
6001541552 BARA SPATE NOVA 91,48
6001538218 STILP FATA DR AS DSN 22,69
6001543463 FURTUN APĂ 38,72
6001543069 SUPORT FAR DREAPTA NOVA1 6,07
6001543182 RULMENT CU BILE 40 X 68 X 15 SN 17,39
6001544844 TRIPODA CUT B 68,85
6001539675 CONTACT MERS INAPOI NOVA 16,13
6001539220 AX SI FURCA 3-4 AS. 31,98
6001539243 PINION VITEZA A 3 A CUT D 31,97
6001543074 DUBLURA ARIPA FATA DREAPTA AS DSN 62,60
6001538191 TRAVERSA SPATE REZERV.AS 28,40
6001543077 TABLA EXTERIOARA USA FATA DR SN 53,63
6001543030 FULIE ALTERNATOR SN 51,96
6001538219 STALP FATA STG AS DSN 50,30
6001542959 RONDELA GROWER 12 1,19
6001544644 RETROVIZOR EXTERIOR DREAPTA 47,25
6001543060 TRAVERSA FATA AS DSN 36,64
6001544328 RETROVIZOR INTERIOR AS. 35,39
6001543526 FURTUN INTRARE REPARTITOR SN 15,65
6001539485 OPRITOR USA FATA 29,53
6001538159 TABLA INCH.LONJ. SUP DR AS DSN 7,23
6001544667 BALAMA HAYON STG DSN 3,34
6001543071 SN TRAVERSA SUP. RADIATOR 24,37
6001543494 CARENAJ INFERIOR RADIATOR DSN 21,63
6001541873 GARNISAJ LATERAL PORTB STG DSN 17,99
6001544499 COLECTIE GARNITURI GEAM USA FATA STANGA 17,86
6001538171S TRAVERSA PLANSEU STANGA 8,80
6001538238 FATA USA SPATE STG DSN 14,01
6001538234 FATA USA FATA STINGA DSN 14,01
6001543009 GARNITURA ETANSARE CAMASI SN 11,43
6001544498 GLISIERA AS 10,31
chroma
post 3 Jan 2014, 00:28
up
Lo-Fi Version  Harta site  Parteneri  Jocuri online  Curs Valutar  HRH Haine din lana merinos Time is now: 8th June 2025 - 19:53
