[VAND] pise din dezmembrare megane 2 2005, preturile le facem impreuna
dorin_p |
#121
![]() Membru incepator Group: Members Posts: 75 Joined: 31 October 13 From: CONSTANTA ![]() |
renault
megane
dorin_p |
#122
o parte din piesele disponibile . preturile nu sunt batute in cuie
aerator lateral bord 25 air-bag cortina 150 alternator 250 amortizor 75 aparatoare noroi aripa 30 arc fata 50 aripa spate 250 armatura bara spate 150 ax came 250 baie ulei 200 bandouri bara spate 100 bara spate 400 bare portbagaj 200 bascula fata 60 broasca usa 80 buton reglare oglinzi electrice 60 buton reglare faruri 40 cablu frana mana 60 cadru motor 400 calculator air-bag 200 calculator UCH 200 calculator motor 150 capac bord dr + st intrerup air bag 25 capota spate/haion complet 600 caseta directie 300 casetofon 110 ceasuri bord 150 chiulasa motor 800 colt plastic ext parbriz 15 coloana directie +servo 600 compresor ac 350 senzor presiune ac presostat 60 conducte AC 50 consola comanda clima 150 cutie viteze 6+1 trepte 1500 display radio 80 EGR 130 electromotor 350 etrier 130 evaporator AC 100 fata usa interioara 50 fulie arbore motor 100 furtune/racoarde apa, aer, motorina, frana fuzeta + disc +rulment 170 galerie admisie 80 galerie evacuare 80 geam lateral portbagaj break 100 geam usa fata 130 geam usa spate break 130 geam usa spate mic break 130 geam luneta break 150 grila laterala aerator parbriz 30 injectoare 1,9 dci bosch 250 intrerupator marsarier 30 intinzator (rola) curea transmisie 50 lampa stop break 150 maner exterior usa (negru) 40 maner interior usa (negru) 25 manete lumini + stergator cu CB 75 parbriz + senzor ( o ciobitura de 2 mm) 100 pedala acceleratie 100 Plafon interior 100 plafoniera 3 becuri (lampa) 25 planetara st 300 planetara dr (lunga) 300 pompa /sonda combustibil 170 pompa abs 200 pompa amorsare motorina(para) 50 pompa ambreaj 70 pompa apa 30 pompa frana 130 pompa injectie 1,9 dci 120 cp BOSCH 1000 pompa vacuum 150 pompa ulei 150 pompa lichid parbriz + rezervor 120 prag lateral 300 radiator habitaclu 130 rampa comuna + senzor pres motorina 250 releu bujii incandescente 50 rezistenta trepte aeroterma 60 rezervor motorina 250 rulou acoperire portbagaj 200 satelit comanda cas 80 scaun fata cu air-bag 250 senzor ploaie+lumini 100 senzor temperatura apa 30 sonda nivel ulei 50 stalp fata, mijloc spate 150 toba esapament + galerie 250 vas expansiune 80 |
renault
megane
dorin_p |
#123
valabil
24 Feb 2014, 10:20: 30% reducere pt. Prima comanda. This post has been edited by dorin_p: 24 Feb 2014, 10:20 |
renault
megane
dorin_p |
#124
valabil
renault
megane
dorin_p |
#125
valabil
renault
megane
dorin_p |
#126
30 % reducere la prima comanda
renault
megane
costi13 |
#127
![]() junior Group: Members Posts: 257 Joined: 1 December 09 From: prahova ![]() |
fetele de usi interioare, doar partea cu textil si perdelute ce pret ?
renault
megane 2.2
1.4 16v 2008/NOIR NACRE/
- PH 01
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 13th July 2025 - 00:12 |
