[VAND] piese DACIA 1300 noi & sh, vanzare piese
BLUE R 19 |
#721
![]() Membru autentic Group: Members Posts: 5.244 Joined: 12 August 10 From: Pitesti ![]() |
/1900
sobolan |
#722
turometrul a ajuns la mine..... recomand100% !!!
Logan-1.5dci-2017--
Golf mk5 - syncro - 2007--
BLUE R 19 |
#723
Multumesc !
/1900
BLUE R 19 |
#724
valabil
-- Fise Autolite - 80 lei setul -- garnitura pluta capac distributie - 6 lei -- surubelnita ventil roata - 7 lei -- oglinzi Dacia, R 12 si alte modele de Renault. Model care s-a montat pe mai multe Renault-uri - 60 lei perechea. This post has been edited by BLUE R 19: 26 Aug 2016, 17:43 Attached thumbnail(s) DSC01749.jpg ( Size: 128.51k ) Number of downloads: 288 DSC01750.jpg ( Size: 93.98k ) Number of downloads: 286 DSC01752.jpg ( Size: 153.7k ) Number of downloads: 282 DSC01744.jpg ( Size: 142.54k ) Number of downloads: 283 DSC01745.jpg ( Size: 118.73k ) Number of downloads: 283 DSC01760.jpg ( Size: 78.79k ) Number of downloads: 32 DSC01754.jpg ( Size: 138.47k ) Number of downloads: 28 DSC01763.jpg ( Size: 122.9k ) Number of downloads: 23 DSC01757.jpg ( Size: 131.36k ) Number of downloads: 18 DSC01756.jpg ( Size: 117.06k ) Number of downloads: 16 455b6c5cde9c12b0444fd4270f3b1e34.jpg ( Size: 88.42k ) Number of downloads: 38 Renault_5_GTL_5_door_1979_wallpaper.jpg ( Size: 341.05k ) Number of downloads: 37 renault_18_10.jpg ( Size: 270.63k ) Number of downloads: 25 |
/1900
BLUE R 19 |
#725
valabil
/1900
BLUE R 19 |
#726
valabil
--Disc ambreiaj Dacia 1310, 180 mm, de Uzina - 70 lei bucata This post has been edited by BLUE R 19: 29 Aug 2016, 00:08 Attached thumbnail(s) DSC01764.jpg ( Size: 157.97k ) Number of downloads: 30 DSC01765.jpg ( Size: 162.43k ) Number of downloads: 19 |
/1900
BLUE R 19 |
#727
valabil
-- Fise Autolite - 80 lei setul -- garnitura pluta capac distributie - 6 lei -- surubelnita ventil roata - 7 lei -- oglinzi Dacia, R 12 si alte modele de Renault. Model care s-a montat pe mai multe Renault-uri - 60 lei perechea. - Tampoane motor 1300 / 1310 tip vechi - 25 lei bucata. --Disc ambreiaj Dacia 1310, 180 mm, de Uzina - 70 lei bucata This post has been edited by BLUE R 19: 30 Aug 2016, 22:26 Attached thumbnail(s) DSC01766.jpg ( Size: 157.98k ) Number of downloads: 12 DSC01768.jpg ( Size: 102.81k ) Number of downloads: 16 |
/1900
BLUE R 19 |
#728
valabil
/1900
BLUE R 19 |
#729
valabil
Marius 0773 923 420 Electrice - Releu semnalizare mecanic, metalic cu 3 contacte - 5 lei - Contact pornire S.E.P. (chei cu dantura pe ambele parti) pentru Dacia 1300 / 1310 / Nova, este nefolosit si are ambele chei, fara probleme, functionare lina - 10 lei - stopuri frana suplimentare de interior, sovietice, NOS, model deosebit potrivit pt. clasice. Dimensiune 90 / 135 / 55, - 45 lei perechea. - lampa suplimentara stop frana spate, de interior, cu leduri, geam decolorat - 5 lei - baterie ceasuri suplimentare presiune ulei si temperatura apa 1310, cu suportul lor (august - septembrie '83) - 60 lei - Capac delco diferite modele, 10 -15 lei - pompe strop-gel RDG-iste si Sogemi Italy - 25 lei bucata - bloc sigurante 1300/ 1310, pentru capac transparent (doar blocul fara capac) - 20 lei - Martor BRAKE 1310 - 10 lei - martor centura de siguranta Dacia 1310 de export - 25 lei. - buton stergator, romanesc cu rama aluminiu - 25 lei - martori stergator romanesti - 10 lei - buton dezaburire nou - 10 lei - butoane lampi ceata, noi - 10 lei bucata Motor -- patine intinzator mecanic lant - ROLAST - 15 lei bucata - Tampoane motor 1300 / 1310 tip vechi - 25 lei bucata. - Garnituri semiinele etansare capete baie ulei (tip vechi) - 7 lei palier marit (2 buc.), 3 lei palier mic (1 bucata, am doar dinspre volant) - pinioane delco noi - 15 lei - tampon superior radiator 1310, simplu (cauciucul) - 5 lei bucata - capac plastic vas expansiune, nou - 5 lei - coliere noi cot radiator / termostat - 10 lei - cot inferior radiator mare si mic, originale ROLAST si ARTEGO - 20 lei - furtun\cot inferior calorifer-robinet 1310(sub grila) - ARTEGO - 15 lei - furtunuri mici (inferior, superior) calorifer-robinet 1300 - 6 lei bucata - furtunuri mici, T- eu aerisire / pompa apa / chiulasa ARTEGO si Rolast, 5 - 7 lei - inele cauciuc prindere toba finala - 3 lei bucata - Set echipare bloc motor (2 prezoane M 8 pompa benzina, dop mare astupare alezaj ax came inspre volant, racord filetat fixare filtru ulei, tub joja ulei, 2 stifturi mici filetate M 6 aluminiu, 2 dopuri mari distributie aluminiu) - 20 lei Cutie viteze -- Burdufuri planetare lungi, inspre roata - ROLAST - 30 lei bucata -- Burdufuri planetare lungi, inspre cutie - ROLAST - 30 lei bucata - Tampoane cutie 5 trepte ROLAST - 25 lei - rondela cutie viteza - 6 lei - Burdufuri protectie maneta schimbator viteze, sub podea -- 20 lei bucata. Sunt originale, fabricate mai demult. -- ace pt. galetii de la tripode - 15 lei punga cu 100 ace - Siemeringuri priza - 10 lei bucata - Tampoane bieleta timonerie 4 trepte, tip vechi - 5 lei bucata - simeringuri planetare spate camioneta - FARTEC - 20 lei 2 bucati Accesorii interior/exterior - 2 lamele stergator Uamt crom metal negru, partea metalica in stare buna, cauciucul uzat - 25 lei ambele. - 2 brate stergator UAMT cromate, cotorul este gaurit, si la unul cromul are fisuri - 30 lei ambele - 1 brat stergator IPAS, cromul de pe cotor are exfolieri - 20 lei - Set nou yale portiere si buton portbagaj 1310 tip vechi, berlina pana in '94 si break orice an, cu doua chei - UAMT Oradea - 30 lei. - buton nou portbagaj 1300/1310 tip vechi, berlina si break - UAMT, cu o cheie - 15 lei. - Set nou yale portiere si buton portbagaj 1310 tip vechi, berlina pana in '94 si break orice an - turcesti, cu doua chei - 10 lei. - Set nou yale portiere si portbagaj 1310 tip nou, dupa '94,cu doua chei - turcesti - 10 lei. - buton nefolosit portbagaj 1300/1310 tip vechi, cu o cheie, berlina si break, turcesc- 8 lei. - grile noi ventilatie montanti spate 1310, ( plastice spate stanga/dreapta) - 40 lei perechea - capac ornamental dintre parasolare si oglinda, negru - 10 lei - broasca portiera cu buton, spate stanga 1310, noua de UAMT - 20 lei - Cremaliere noi inchidere portiere - 5 lei bucata (pentru dreapta) - maner gri (bila) schimbator viteze 1300 - 10 lei - maner Renault schimbator viteze (tuning anii '90) - 15 lei - Manivele deschidere geam metalice cromate - 10 lei bucata - Manivela deschidere geam folosita, crom negru, mai stearsa - 7 lei. - Distantiere plastic de sub manivele (set 4 buc. fata si spate) 15 lei setul. - cleme prindere ornament maner interior portiera fata (in partea de sus, tine gatul ornamental din plastic care acopera surubul) - 5 lei bucata - ornamente noi deschidere portiere interior, din plastic - 15 lei. - 3 ornamente noi deschidere portiere interior, cromate - 15 lei toate - Set 4 nuci deschidere portiere - 20 lei - pereche scrumiere spate 1300/1310 (rame inox si scrumiere inox) - 40 lei - pereche scrumiere spate 1300/1310 (rame inox si scrumiere negre) - 15 lei - Set de 3 manere viraj albe din plastic Dacia 1300/1310/ Renault 12 - 15 lei - Set 3 manere viraj cu carlig pentru haine, metalice/cromate 1300/1310 - 40 lei - Set antifurt inox butoane portiere 1300/1310 (4 bucati), trei sunt fixe iar cel de la usa soferului are capac detasabil cu locas pt. introducerea cheii (nu am cheia, se executa usor, este model cu bolt excentric) - 30 lei - Set antifurt inox butoane portiere "DACIA 1310 TURBO" 1310 / 1300 (4 bucati si cheia), trei sunt fixe iar cel de la usa soferului are capac detasabil cu locas pt. apasare sau introducerea cheii (1300) la - 50 lei, unul dintre capace este putin 'traumatizat"pe doua dintre laturi. - Emblema aluminiu portbagaj "Dacia 1310" - 10 si 20 lei - Emblema TLX - 10/15 lei - Emblema MLS - 10 lei - Emblema "L" - 10 lei - Emblema cromata bord - 30 lei - Emblema aluminiu grila fata Dacia 1310 - 10 lei - 2 capace "romb" amarate - 10 lei bucata - capace plastic negru (dopuri) acoperire piulite roti, noi - 30 lei setul de 12 bucati - Incuietoare noua portbagaj, de tip nou, dupa '94 - 10 lei - Axuri/parghii\lagare actionare stergatoare, model cu caneluri fara surub; sunt noi fabricate demult - 15 lei perechea. Directie / Punti - bucse plastic caseta directie - 6 lei bucata - bucse cap cremaliera - FARTEC - 5 lei bucata - bucse ax volan - 5 lei bucata - bucse bara stabilizatoare (antiruliu) pentru bara de 19 mm ROLAST - 10 lei bucata - bucse bara stabilizatoare (antiruliu) pentru bara de 17 mm ROLAST - 10 lei bucata - bucse bieleta anti-ruliu (la prinderea pe bratul superior) - 15 lei 2 bucati. - bucse Tirant - ROLAST - 20 lei 4 bucati - Burdufuri rotule Rolast, Uzina si Artego, fiecare vine cu cele doua inele de fixare, mic si mare - 10 lei burduful cu 2 inele. - Bucse brat superior fata - 10 lei bucata - Bucse brat inferior fata si central spate - 10 lei bucata - simering butuc tambur - 10 lei bucata - ROLAST - simering butuc tambur - 7 lei bucata - Bucse complete brat lateral spate (tendoane / ciolane) - 30 lei setul (4 bucati). Sunt din plastic, foarte tari, pentru cine doreste rigiditate crescuta. Alimentare - Buson rezervor UAMT nou (non ventile, pentru injectie), cu o singura cheie - 20 lei - Buson rezervor UAMT crom negru, folosit , cu o singura cheie - 20 lei - Inel nou (cu garnitura) fixare sonda benzina in rezervor; pentru masina cu carburator - 9 lei, fara garnitura 5 lei. Frane - Set garnituri pompa simplu circuit 1300, ROLAST - 15 lei setul - Garnituri mari pompa simplu circuit "DBA" - 5 lei buc. - burdufuri protectie cilindri receptori spate mici, Dacia berlina (pt. cilindri de 22 mm)- Rolast - 3 lei bucata. - garnituri pistoane cilindri receptori spate 22 mm, Rolast - 3 lei bucata. - garnituri pistoane cilindri receptori spate 22 mm, DBA-Bendix - 5 lei bucata. - garnituri pistoane cilindri receptori spate camioneta 25,4 mm - Renak CZ - 4 lei bucata. - set garnituri cilindru frana spate Break (2 mansoane si 2 garnituri pistoane) ROLAST - 12 lei - garnitura/simering ax servofrana - ROLAST - 10 lei bucata - simering mare servofrana, original - 8 lei bucata. Transportul prin posta, 11 lei minim. - Presuri "ILBO 1300" fata stare foarte buna - 100 lei - presuri cauciuc spate stare foarte buna, model cu triunghiuri mici grupate in hexagoane - 50 lei - presuri fata "CATC Pitesti Dacia 1300", stare foarte buna - 80 lei - mocheta spate model "sare si piper", stare foarte buna - 70 lei -- Manometru roti - 15 lei (cadran aluminiu). - intinzatoare bord, accesoriu clasic putin intalnit (se monteaza sub bord la colturi pentru a-l tensiona in raport cu caroseria, astfel reducand vibratiile, scartaielile si aducand un plus de rigiditate ansamblului), are cromul exfoliat la zona centrala, acolo unde se antreneaza cu cheia - 100 lei. Este poza mai inainte. - maner gri (bila) schimbator viteze 1300 - 10 lei - maner Renault schimbator viteze (tuning anii '90) - 15 lei - 2 capace "romb" amarate - 10 lei bucata. - pompe strop-gel RDG-iste si Sogemi Italy - 25 lei bucata -- Fise Autolite - 80 lei setul -- garnitura pluta capac distributie - 6 lei -- surubelnita ventil roata - 7 lei -- oglinzi Dacia, R 12 si alte modele de Renault. Model care s-a montat pe mai multe Renault-uri - 60 lei perechea. - Tampoane motor 1300 / 1310 tip vechi - 25 lei bucata. --Disc ambreiaj Dacia 1310, 180 mm, de Uzina - 70 lei bucata -- brate stergator noi, UAMT, negre, de tip vechi - 30 lei bucata. This post has been edited by BLUE R 19: 4 Sep 2016, 22:03 Attached thumbnail(s) DSC01771.jpg ( Size: 155.91k ) Number of downloads: 27 DSC01772.jpg ( Size: 155.17k ) Number of downloads: 26 |
/1900
BLUE R 19 |
#730
valabil
/1900
BLUE R 19 |
#731
valabil
/1900
BLUE R 19 |
#732
valabil
-- Fise bujii Autolite - 55 lei setul. This post has been edited by BLUE R 19: 11 Sep 2016, 22:46 |
/1900
emildebreti |
#733
Membru incepator Group: Members Posts: 52 Joined: 6 December 15 From: Azuga ![]() |
Un rotor de alternator exista?
Dacia 1300
Dacia 1300
- Ph32zty
1978
BLUE R 19 |
#734
Nu am.
/1900
BLUE R 19 |
#735
valabil
This post has been edited by BLUE R 19: 14 Sep 2016, 22:09 Attached thumbnail(s) DSC01776.jpg ( Size: 141.82k ) Number of downloads: 34 |
/1900
BLUE R 19 |
#736
valabil
Marius 0773 923 420 Electrice - Releu semnalizare mecanic, metalic cu 3 contacte - 5 lei - Contact pornire S.E.P. (chei cu dantura pe ambele parti) pentru Dacia 1300 / 1310 / Nova, este nefolosit si are ambele chei, fara probleme, functionare lina - 10 lei - stopuri frana suplimentare de interior, sovietice, NOS, model deosebit potrivit pt. clasice. Dimensiune 90 / 135 / 55, - 45 lei perechea. - lampa suplimentara stop frana spate, de interior, cu leduri, geam decolorat - 5 lei - baterie ceasuri suplimentare presiune ulei si temperatura apa 1310, cu suportul lor (august - septembrie '83) - 60 lei - Capac delco diferite modele, 10 -15 lei - pompe strop-gel RDG-iste si Sogemi Italy - 25 lei bucata - bloc sigurante 1300/ 1310, pentru capac transparent (doar blocul fara capac) - 20 lei - Martor BRAKE 1310 - 10 lei - martor centura de siguranta Dacia 1310 de export - 25 lei. - buton stergator, romanesc cu rama aluminiu - 25 lei - martori stergator romanesti - 10 lei - buton dezaburire nou - 10 lei - butoane lampi ceata, noi - 10 lei bucata Motor -- patine intinzator mecanic lant - ROLAST - 15 lei bucata - Tampoane motor 1300 / 1310 tip vechi - 25 lei bucata. - Garnituri semiinele etansare capete baie ulei (tip vechi) - 7 lei palier marit (2 buc.), 3 lei palier mic (1 bucata, am doar dinspre volant) - pinioane delco noi - 15 lei - tampon superior radiator 1310, simplu (cauciucul) - 5 lei bucata - capac plastic vas expansiune, nou - 5 lei - coliere noi cot radiator / termostat - 10 lei - cot inferior radiator mare si mic, originale ROLAST si ARTEGO - 20 lei - furtun\cot inferior calorifer-robinet 1310(sub grila) - ARTEGO - 15 lei - furtunuri mici (inferior, superior) calorifer-robinet 1300 - 6 lei bucata - furtunuri mici, T- eu aerisire / pompa apa / chiulasa ARTEGO si Rolast, 5 - 7 lei - inele cauciuc prindere toba finala - 3 lei bucata - Set echipare bloc motor (2 prezoane M 8 pompa benzina, dop mare astupare alezaj ax came inspre volant, racord filetat fixare filtru ulei, tub joja ulei, 2 stifturi mici filetate M 6 aluminiu, 2 dopuri mari distributie aluminiu) - 20 lei Cutie viteze -- Burdufuri planetare lungi, inspre roata - ROLAST - 30 lei bucata -- Burdufuri planetare lungi, inspre cutie - ROLAST - 30 lei bucata - Tampoane cutie 5 trepte ROLAST - 25 lei - rondela cutie viteza - 6 lei - Burdufuri protectie maneta schimbator viteze, sub podea -- 20 lei bucata. Sunt originale, fabricate mai demult. -- ace pt. galetii de la tripode - 15 lei punga cu 100 ace - Siemeringuri priza - 10 lei bucata - Tampoane bieleta timonerie 4 trepte, tip vechi - 5 lei bucata - simeringuri planetare spate camioneta - FARTEC - 20 lei 2 bucati Accesorii interior/exterior - 2 lamele stergator Uamt crom metal negru, partea metalica in stare buna, cauciucul uzat - 25 lei ambele. - 2 brate stergator UAMT cromate, cotorul este gaurit, si la unul cromul are fisuri - 30 lei ambele - 1 brat stergator IPAS, cromul de pe cotor are exfolieri - 20 lei - Set nou yale portiere si buton portbagaj 1310 tip vechi, berlina pana in '94 si break orice an, cu doua chei - UAMT Oradea - 30 lei. - buton nou portbagaj 1300/1310 tip vechi, berlina si break - UAMT, cu o cheie - 15 lei. - Set nou yale portiere si buton portbagaj 1310 tip vechi, berlina pana in '94 si break orice an - turcesti, cu doua chei - 10 lei. - Set nou yale portiere si portbagaj 1310 tip nou, dupa '94,cu doua chei - turcesti - 10 lei. - buton nefolosit portbagaj 1300/1310 tip vechi, cu o cheie, berlina si break, turcesc- 8 lei. - grile noi ventilatie montanti spate 1310, ( plastice spate stanga/dreapta) - 40 lei perechea - capac ornamental dintre parasolare si oglinda, negru - 10 lei - broasca portiera cu buton, spate stanga 1310, noua de UAMT - 20 lei - Cremaliere noi inchidere portiere - 5 lei bucata (pentru dreapta) - maner gri (bila) schimbator viteze 1300 - 10 lei - maner Renault schimbator viteze (tuning anii '90) - 15 lei - Manivele deschidere geam metalice cromate - 10 lei bucata - Manivela deschidere geam folosita, crom negru, mai stearsa - 7 lei. - Distantiere plastic de sub manivele (set 4 buc. fata si spate) 15 lei setul. - cleme prindere ornament maner interior portiera fata (in partea de sus, tine gatul ornamental din plastic care acopera surubul) - 5 lei bucata - ornamente noi deschidere portiere interior, din plastic - 15 lei. - 3 ornamente noi deschidere portiere interior, cromate - 15 lei toate - Set 4 nuci deschidere portiere - 20 lei - pereche scrumiere spate 1300/1310 (rame inox si scrumiere inox) - 40 lei - pereche scrumiere spate 1300/1310 (rame inox si scrumiere negre) - 15 lei - Set de 3 manere viraj albe din plastic Dacia 1300/1310/ Renault 12 - 15 lei - Set 3 manere viraj cu carlig pentru haine, metalice/cromate 1300/1310 - 40 lei - Set antifurt inox butoane portiere 1300/1310 (4 bucati), trei sunt fixe iar cel de la usa soferului are capac detasabil cu locas pt. introducerea cheii (nu am cheia, se executa usor, este model cu bolt excentric) - 30 lei - Set antifurt inox butoane portiere "DACIA 1310 TURBO" 1310 / 1300 (4 bucati si cheia), trei sunt fixe iar cel de la usa soferului are capac detasabil cu locas pt. apasare sau introducerea cheii (1300) la - 50 lei, unul dintre capace este putin 'traumatizat"pe doua dintre laturi. - Emblema aluminiu portbagaj "Dacia 1310" - 10 si 20 lei - Emblema TLX - 10/15 lei - Emblema MLS - 10 lei - Emblema "L" - 10 lei - Emblema cromata bord - 30 lei - Emblema aluminiu grila fata Dacia 1310 - 10 lei - 2 capace "romb" amarate - 10 lei bucata - capace plastic negru (dopuri) acoperire piulite roti, noi - 30 lei setul de 12 bucati - Incuietoare noua portbagaj, de tip nou, dupa '94 - 10 lei - Axuri/parghii\lagare actionare stergatoare, model cu caneluri fara surub; sunt noi fabricate demult - 15 lei perechea. Directie / Punti - bucse plastic caseta directie - 6 lei bucata - bucse cap cremaliera - FARTEC - 5 lei bucata - bucse ax volan - 5 lei bucata - bucse bara stabilizatoare (antiruliu) pentru bara de 19 mm ROLAST - 10 lei bucata - bucse bara stabilizatoare (antiruliu) pentru bara de 17 mm ROLAST - 10 lei bucata - bucse bieleta anti-ruliu (la prinderea pe bratul superior) - 15 lei 2 bucati. - bucse Tirant - ROLAST - 20 lei 4 bucati - Burdufuri rotule Rolast, Uzina si Artego, fiecare vine cu cele doua inele de fixare, mic si mare - 10 lei burduful cu 2 inele. - Bucse brat superior fata - 10 lei bucata - Bucse brat inferior fata si central spate - 10 lei bucata - simering butuc tambur - 10 lei bucata - ROLAST - simering butuc tambur - 7 lei bucata - Bucse complete brat lateral spate (tendoane / ciolane) - 30 lei setul (4 bucati). Sunt din plastic, foarte tari, pentru cine doreste rigiditate crescuta. Alimentare - Buson rezervor UAMT nou (non ventile, pentru injectie), cu o singura cheie - 20 lei - Buson rezervor UAMT crom negru, folosit , cu o singura cheie - 20 lei - Inel nou (cu garnitura) fixare sonda benzina in rezervor; pentru masina cu carburator - 9 lei, fara garnitura 5 lei. Frane - Set garnituri pompa simplu circuit 1300, ROLAST - 15 lei setul - Garnituri mari pompa simplu circuit "DBA" - 5 lei buc. - burdufuri protectie cilindri receptori spate mici, Dacia berlina (pt. cilindri de 22 mm)- Rolast - 3 lei bucata. - garnituri pistoane cilindri receptori spate 22 mm, Rolast - 3 lei bucata. - garnituri pistoane cilindri receptori spate 22 mm, DBA-Bendix - 5 lei bucata. - garnituri pistoane cilindri receptori spate camioneta 25,4 mm - Renak CZ - 4 lei bucata. - set garnituri cilindru frana spate Break (2 mansoane si 2 garnituri pistoane) ROLAST - 12 lei - garnitura/simering ax servofrana - ROLAST - 10 lei bucata - simering mare servofrana, original - 8 lei bucata. Transportul prin posta, 11 lei minim. - Presuri "ILBO 1300" fata stare foarte buna - 100 lei - presuri cauciuc spate stare foarte buna, model cu triunghiuri mici grupate in hexagoane - 50 lei - presuri fata "CATC Pitesti Dacia 1300", stare foarte buna - 80 lei - mocheta spate model "sare si piper", stare foarte buna - 70 lei -- Manometru roti - 15 lei (cadran aluminiu). - intinzatoare bord, accesoriu clasic putin intalnit (se monteaza sub bord la colturi pentru a-l tensiona in raport cu caroseria, astfel reducand vibratiile, scartaielile si aducand un plus de rigiditate ansamblului), are cromul exfoliat la zona centrala, acolo unde se antreneaza cu cheia - 100 lei. Este poza mai inainte. - maner gri (bila) schimbator viteze 1300 - 10 lei - maner Renault schimbator viteze (tuning anii '90) - 15 lei - 2 capace "romb" amarate - 10 lei bucata. - pompe strop-gel RDG-iste si Sogemi Italy - 25 lei bucata -- Fise bujii Autolite, Renault 12 si Dacia - 55 lei setul -- garnitura pluta capac distributie - 6 lei -- surubelnita ventil roata - 7 lei -- oglinzi Dacia, R 12 si alte modele de Renault. Model care s-a montat pe mai multe Renault-uri - 50 lei perechea. - Tampoane motor 1300 / 1310 tip vechi - 25 lei bucata. --Disc ambreiaj Dacia 1310, 180 mm, de Uzina - 60 lei bucata -- brate stergator noi, UAMT, negre, de tip vechi - 30 lei bucata. This post has been edited by BLUE R 19: 18 Sep 2016, 12:54 |
/1900
BLUE R 19 |
#737
valabil
/1900
BLUE R 19 |
#738
valabil
/1900
BLUE R 19 |
#739
valabil
/1900
BLUE R 19 |
#740
valabil
Flansa elastica cuplaj caseta/coloana directie, originala ROLAST - 30 lei. This post has been edited by BLUE R 19: 25 Sep 2016, 22:16 Attached thumbnail(s) DSC01436.jpg ( Size: 97.36k ) Number of downloads: 31 |
/1900
BLUE R 19 |
#741
valabil
/1900
BLUE R 19 |
#742
valabil
/1900
BLUE R 19 |
#743
valabil
-- Embleme "TX" noi - 20 lei bucata -- Cuzineti axiali palier mic, R1 - 30 lei perechea. -- Pinioane distributie originale romanesti - 60 lei perechea, mic si mare. This post has been edited by BLUE R 19: 1 Oct 2016, 01:01 Attached thumbnail(s) DSC01779.jpg ( Size: 130.91k ) Number of downloads: 16 DSC01777.jpg ( Size: 153.48k ) Number of downloads: 14 DSC01778.jpg ( Size: 129.91k ) Number of downloads: 19 |
/1900
BLUE R 19 |
#744
valabil
/1900
BLUE R 19 |
#745
valabil
/1900
BLUE R 19 |
#746
valabil
- tava noua protectie carburator Dacia 1300 / 1310 - 35 lei This post has been edited by BLUE R 19: 11 Oct 2016, 22:13 Attached thumbnail(s) DSC01106.jpg ( Size: 144.67k ) Number of downloads: 16 DSC01107.jpg ( Size: 161.23k ) Number of downloads: 13 |
/1900
BLUE R 19 |
#747
valabil
-- Embleme "TX" noi - 20 lei bucata -- Flansa elastica cuplaj caseta/coloana directie, originala ROLAST - 30 lei. -- Cuzineti axiali palier mic, R1 - 30 lei perechea. -- Pinioane distributie originale romanesti - 60 lei perechea, mic si mare. - tava noua protectie carburator Dacia 1300 / 1310 - 35 lei. This post has been edited by BLUE R 19: 13 Oct 2016, 00:03 Attached thumbnail(s) DSC01781.jpg ( Size: 145.61k ) Number of downloads: 18 DSC01780.jpg ( Size: 141.73k ) Number of downloads: 13 |
/1900
BLUE R 19 |
#748
valabil
/1900
BLUE R 19 |
#749
valabil
/1900
BLUE R 19 |
#750
valabil
/1900
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 4th August 2025 - 06:23 |
