Dacia 1310 CN1 `91, TZZu` la restaurat
sobolan |
#361
Logan-1.5dci-2017--
Golf mk5 - syncro - 2007--
Barbalex |
#362
![]() Membru cu un cazan de break Group: Members Posts: 209 Joined: 4 July 14 ![]() |
Dada, fac ce trebuie
![]() Intr-un final am reușit sa pun masina pe roti. Acum urmează sa ajustez aripile fata, sa le curat, terosonez si vopsesc pe interior. This post has been edited by Barbalex: 29 Jan 2017, 20:13 Attached thumbnail(s) received_1250484285020034.jpeg ( Size: 273.42k ) Number of downloads: 1046 received_1250484248353371.jpeg ( Size: 302.09k ) Number of downloads: 1049 received_1250484521686677.jpeg ( Size: 189.86k ) Number of downloads: 1041 received_1250484328353363.jpeg ( Size: 237.68k ) Number of downloads: 1030 received_1250484371686692.jpeg ( Size: 258.94k ) Number of downloads: 1034 |
- B-xx-TZZ
Cn1 1991
Alex1300BV |
#363
![]() Membru autentic Group: Members Posts: 679 Joined: 20 November 08 ![]() |
Spor la munca in continuare!
1410
- xxxxxxxx
1991 1397 cmc TLX Break
sobolan |
#364
vezi sa nu-ti faca necazuri grundul ala rosu,o sa-l atace vopseaua cu care dai masina de la diluantii auto,chiar si sprit-kit-ul,il infolreste,iti blestemi zilele,ai facut munca de pomana....fii atent ca-s patit,dai o mana de sprit-kit 2k pe toata masina dar fara diluant,mixezi doar sprit-kit si intaritorul lui....cand se usuca(normal dupa 24h) vii cu vopseaua ei in mod normal(fie ea 1k sau 2k cu diluant si intaritor)....recomand vopsea 2k....varianta asta o poti folosi si cand ai vopsea veche "intrerupta" si vii cu aia noua...tot ce ti-am zis e valabil cu grunduri/vopseluri auto pistolabile(nu spray)...normal sprit-kitul asta folosit fara diluant creeaza un strat "neutru" intre straturi si se lipeste al naibii de bine....nu recomand deloc sprit-kit la spray....
This post has been edited by sobolan: 30 Jan 2017, 00:52 |
Logan-1.5dci-2017--
DACIOTUL_97 |
#365
![]() Ne plac femeile,dar iubim masinile ! Group: Members Posts: 1.649 Joined: 8 July 13 From: Bd-ul Dacia ![]() |
Pai filler-ul in compozitia lui e foarte gros,asa se aplica ? Eu am încercat aplicarea cu un pistol obisnuit de vopsit si nu prea a mers treaba,decat dupa ce l-am diluat putin.
This post has been edited by DACIOTUL_97: 30 Jan 2017, 03:01 |
1310/Logan/
MLS 1986/MLS 1985/1.6 16v Prestige 2008 "Voi lupta pana la ultima mea picatura de sange,ca sa ai dreptul,sa nu fi de acord cu mine"
#Pasionat de fiare vechi# Ex.Dacia 1310-CN3 & 1310-ph1 |
sobolan |
#366
merge brici,testat de mine ...poate e prea mic compresorul sau n-ai stiut sa reglezi presiunea din el sau din pistol.....deci,repet,merge brici !
Maine vopsesc o janta si o s-o dau cu sprit-kit amestecat doar cu intaritor....daca gasesc pe cineva sa filmeze ai sa vezi ce frumos merge .... This post has been edited by sobolan: 30 Jan 2017, 14:06 |
Logan-1.5dci-2017--
DACIOTUL_97 |
#367
1310/Logan/
Ov |
#368
![]() Academician doctor inginer, savant de renume mondial Group: Moderatori Posts: 7.533 Joined: 11 November 03 From: Bucuresti ![]() |
@sobolan: ce compresor ai?
Victor3001 |
#369
![]() Membru autentic Group: Members Posts: 326 Joined: 4 February 15 From: Medias, Sibiu ![]() |
Si mai important, ce presiune i-ai dat?
1975/ 1976
sobolan |
#370
eu imi reglez la ochi pistolul si compresorul,incerc pe un carton pana imi iese jetul cum trebuie...in linii mari pe la 5,5 il tin pe linia de iesire,din pistol ma joc cu cele doua reglaje pana e ok...aici e vorba de la pistol la pistol ca fiecare pistol are o anumita duza si daca duza e mare si mergi pe presiune joasa nu e ok....la sprit-kit folosesc un pistol cu duza de 1,5mm,la vopsit am unul cu duza de 1 parca,ambele-s no-name dar is obisnuit cu ele....
Am doua compresoare,unul mic FIAC de 25 si unul mare de 50 Black&Decker....cu ala mic de 25 am vopsit masina toata,iti trebuie si rabdare cu el dar ala mare era prea greu de mutat pentru ca am furtunele scurte..... |
Logan-1.5dci-2017--
Victor3001 |
#371
Eu la grund ii dau cu 3-3,5 atm...peste nu vrea sa iasa bine, in rest reglajele le fac si eu la fel, pe carton, oar ca si compresor am unul facut de tata cu 2 butelii, mai miltumit ca de compresorul asta n-am fost de niciunul. Tine 12-13 atm constant si vreau sa-i mai pun 2 butelii. Sa vezi atunci compresor
1975/ 1976
sobolan |
#372
eu pot sa jur ca sunt vopseluri metalizate care trebuie vopsite la presiuni joase si nu e gluma,daca maresti presiunea nu se mai vede ok pigmentul...da' sa dai grund la 3 atmosfere e cam putin,acum repet : E VORBA SI DE PISTOL/DUZA !!!
Logan-1.5dci-2017--
Victor3001 |
#373
Ma rog..asa m-a invatat un vopsitor batran...si am incercat si la 5 si a iesit naspa de tot...azi ma uit sa vad de cat am duza...
1975/ 1976
Barbalex |
#374
Am mai facut cate ceva,in limita timpului disponibil.Am curatat aproape toata evacuarea,exceptand toba finala,si am vopsit-o.
Sobolan,s-a dovedit ca ai avut dreptate cu acele `cratere`,insa nu sunt chiar atat de apropiate de cilindrii(vezi poza 7).In plus,inainte,masina pe care a fost chiulasa a mers mult si bine fara sa aiba vreo problema.Mai adaug ca acele cratere s-au mai redus in urma planarii 1mm. This post has been edited by Barbalex: 13 Feb 2017, 21:13 Attached thumbnail(s) received_1265992906802505.jpeg ( Size: 152.3k ) Number of downloads: 217 received_1265992810135848.jpeg ( Size: 232.13k ) Number of downloads: 165 received_1265992660135863.jpeg ( Size: 135.96k ) Number of downloads: 150 received_1265992780135851.jpeg ( Size: 242.25k ) Number of downloads: 139 received_1265992750135854.jpeg ( Size: 214.49k ) Number of downloads: 157 received_1265992830135846.jpeg ( Size: 298.44k ) Number of downloads: 162 received_1265992916802504.jpeg ( Size: 298.2k ) Number of downloads: 153 received_1265992936802502.jpeg ( Size: 529.36k ) Number of downloads: 146 received_1265992920135837.jpeg ( Size: 474.61k ) Number of downloads: 121 received_1265992933469169.jpeg ( Size: 532.8k ) Number of downloads: 101 received_1265992873469175.jpeg ( Size: 379.54k ) Number of downloads: 107 received_1265992640135865.jpeg ( Size: 195.03k ) Number of downloads: 132 received_1265992676802528.jpeg ( Size: 236.33k ) Number of downloads: 138 received_1265992683469194.jpeg ( Size: 196.32k ) Number of downloads: 136 received_1265993823469080.jpeg ( Size: 137.51k ) Number of downloads: 142 |
- B-xx-TZZ
Cn1 1991
sobolan |
#375
Pare ok acum....cu 1mm in minus mergi la sigur cu gaz de 98 la vara ca sa eviti detonatiile,pune-i sinterom 14np21,is mai reci o idee.....o sa traga bine
![]() ![]() LE: garnitura de chiuloasa se aseaza pe bloc si se urmaresc inelele ca sa cada perfect pe cilindri,la nevoie se mareste usor gaura din centru(spre delc) din garnitura pana cand o faci sa cada perfect cu inelele la cilindri....atentie la micile detalii,is decisive uneori,berbeci multi repara motoare dar nu multi le fac sa tina....stai linistit ca si eu am fost berbec de cateva ori,din greseli inveti dar de preferat din ale altora.... Eu te sfatuiesc sa dai cu vaselina/ulei pe garnitura inainte de montaj.....se "muleaza" mai ok pe suprafete si dac-o strangi in vreo 5 etape pana la 6,5 cred ca la 500km nu mai umbli,doar verifici pentru linistea personala...lasam parerile "cunoscatorilor" deoparte..... Fa-i valvele,pasuieste-le la mana cu un furtun.....nu cu bormasina,uzezi excesiv ghidurile si creezi santuri in suprafata de asezare pe scaun....la mana,inainte-inapoi,sus-jos.....cate 5 minute de valva e maxim....piseaza bine o bucatica de piatra de polizor mai fina,amesteca praful cu vaselina si ai obtinut pasta ideala.......ca sa fii sigur....la probezi fara arc cu benzina,daca 10 minute nu scapa nimic e deajuns.....am scris la mine pe topic cum se face,citeste p-acolo......arcul se pune cu artea de spire mai distantate spre culbutor,nu prea am inteles de ce,pune simeringuri noi ,ia de alea bune de la unix de renault trafic 2500 benzina,victor reinz...citeste pe la mine,ai cod ,ai tot.......tot ce e goetze de prin magazinele de dacia is rahaturi mizerabile,or sa sara din ghid......daca ai rabdare sa le faci "degetare" ca la oltcit e ok,merg si alea goetze.... Inca ceva : intoarce saibele de la prezoanele chiuloasei.....ca sa nu paraie prezonul la strangere si sa te induca in eroare cheia ![]() ![]() ![]() ![]() ![]() This post has been edited by sobolan: 14 Feb 2017, 01:06 |
Logan-1.5dci-2017--
DACIOTUL_97 |
#376
1310/Logan/
Barbalex |
#377
Sobolan, mulțumesc pentru sfaturi,mi-au fost de mare folos.
![]() Intr-un final am reușit sa asamblez motorul, mâine sper sa il pornesc. |
- B-xx-TZZ
Cn1 1991
Adrian Frigo |
#378
Puteai să cauți o chiulasă bună,să nu te mai complici cu asta....mai ales că e puțin mâncată și bucșată la cilindrul 3.Important e să meargă bine,poate ne încânți și cu un video!
Spor la lucru în continuare! ![]() |
Dacia 1300/
1310/1410 GTL/CL/Lj/Renault
- XX-00-UAP/ACR
/1972/1986/1997/2000 și ceva... Mașina este ca femeia,dacă nu o întreții....TE LASĂ!
Daciot convins! |
Barbalex |
#379
Pozele
This post has been edited by Barbalex: 24 Feb 2017, 23:16 Attached thumbnail(s) 16935983_1276658249069304_739982155_o.jpg ( Size: 186.4k ) Number of downloads: 165 16935638_1276658222402640_1797609961_o.jpg ( Size: 144.46k ) Number of downloads: 162 16990422_1276658272402635_995909955_o.jpg ( Size: 235.57k ) Number of downloads: 162 16930575_1276638619071267_1531092272_o.jpg ( Size: 195.02k ) Number of downloads: 170 16931084_1276638542404608_786918895_o.jpg ( Size: 167.88k ) Number of downloads: 190 16930611_1276638479071281_1034701788_o.jpg ( Size: 151.54k ) Number of downloads: 171 16930951_1276638409071288_1600155051_o.jpg ( Size: 159.14k ) Number of downloads: 151 |
- B-xx-TZZ
Cn1 1991
sobolan |
#380
Logan-1.5dci-2017--
Barbalex |
#381
Adrian Frigo, daca nu isi va face treaba corespunzător, o voi schimba, dar nu cred ca o sa fie cazul.
Încerc pe cât posibil sa fac si un video. Mulțumesc! ![]() |
- B-xx-TZZ
Cn1 1991
Barbalex |
#382
Gata,ma duc sa ma imbat!A pornit la prima incercare motorasu.Pic de fum n-a scos,merge superb,sunt foarte multumit de el.
![]() Si filmarea promisa https://www.youtube.com/watch?v=Mhp_KixKVOw This post has been edited by Barbalex: 27 Feb 2017, 22:56 |
- B-xx-TZZ
Cn1 1991
Adrian Frigo |
#383
QUOTE(Barbalex @ 27 Feb 2017, 23:54) Gata,ma duc sa ma imbat! Eu deja ți-am luat-o înainte! ![]() ![]() De văzut cum merge cu adevărat o să vezi la drum întins,bagă mare să termini! |
Dacia 1300/
- XX-00-UAP/ACR
Daciot convins! |
om_bland |
#384
Membru autentic Group: Members Posts: 671 Joined: 15 December 09 ![]() |
Felicitari tinere !
Berlina
1984 dacia berlina RESPECTA DREPTUL la opinie indiferent daca esti de acord sau nu , cu parerea celui de langa tine!
opre |
#385
Membru incepator Group: Members Posts: 87 Joined: 22 February 17 ![]() |
Salut si bravo! asa eram si eu....profita cat mai poti sa lucrezi cat mai ai timp! eu din pacate nu am:(
1975 berlina
johnybic |
#386
![]() dacia si atat Group: Members Posts: 617 Joined: 6 December 13 From: Buzau ![]() |
1985
Barbalex |
#387
Multumesc tuturor!
![]() Astazi i-am pus instalatia de racire,l-am lasat sa mearga cam 40minute,a consumat 1l de benzina. https://www.youtube.com/watch?v=ADxdvbXuclA |
- B-xx-TZZ
Cn1 1991
sobolan |
#388
frumosssss......esti mai nebun decat mine
![]() ![]() Ai putea sa-i faci un break-in pe masina,il lasi vreo ora in regim alternat cu turatii CONSTANTE si nu bruscari....adica 5 minute la ralanti,5 accelerat dar nu peste 2000,apoi iar ralanti si tot asa.....o ora....dupa ce s-a racit il scoti la un drum afara orasului de 50-100 de km si-l tii constant daca poti in aceeasi treapta de viteza pe la 2500 maxim,dupa ce s-a racit iar bine de tot ii strangi iar chiuloasa,refaci jocurile la culbutoare si gata.... ii dai jar.... This post has been edited by sobolan: 2 Mar 2017, 23:55 |
Logan-1.5dci-2017--
Victor3001 |
#389
1975/ 1976
Barbalex |
#390
Mașinuța a mai primit câte ceva
![]() This post has been edited by Barbalex: 24 Apr 2017, 00:00 Attached thumbnail(s) received_1338272986241163.jpeg ( Size: 162.76k ) Number of downloads: 122 received_1338272949574500.jpeg ( Size: 134.68k ) Number of downloads: 104 received_1338272989574496.jpeg ( Size: 215.44k ) Number of downloads: 101 received_1338272996241162.jpeg ( Size: 234.52k ) Number of downloads: 101 received_1338272972907831.jpeg ( Size: 139.36k ) Number of downloads: 107 received_1338273726241089.jpeg ( Size: 235.23k ) Number of downloads: 94 received_1338273729574422.jpeg ( Size: 198.54k ) Number of downloads: 73 received_1338273719574423.jpeg ( Size: 215.4k ) Number of downloads: 65 received_1336734046395057.jpeg ( Size: 184.81k ) Number of downloads: 75 received_1338273732907755.jpeg ( Size: 252.92k ) Number of downloads: 86 received_1338274596241002.jpeg ( Size: 210.4k ) Number of downloads: 79 received_1338274482907680.jpeg ( Size: 190.88k ) Number of downloads: 68 received_1338274489574346.jpeg ( Size: 182.17k ) Number of downloads: 80 received_1338274509574344.jpeg ( Size: 227.78k ) Number of downloads: 73 received_1338274516241010.jpeg ( Size: 210.14k ) Number of downloads: 71 received_1338276126240849.jpeg ( Size: 196.17k ) Number of downloads: 74 received_1338275999574195.jpeg ( Size: 156.81k ) Number of downloads: 67 received_1338276692907459.jpeg ( Size: 357.9k ) Number of downloads: 71 received_1338276582907470.jpeg ( Size: 284.74k ) Number of downloads: 81 received_1338274526241009.jpeg ( Size: 219.18k ) Number of downloads: 86 received_1338276136240848.jpeg ( Size: 212.29k ) Number of downloads: 89 received_1338276159574179.jpeg ( Size: 233.93k ) Number of downloads: 89 |
- B-xx-TZZ
Cn1 1991
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 9th September 2025 - 16:48 |
