dacia asistenta-cel mai tare serviciu de asistenta
Alydor |
- Igo8 - C520
vijelie |
Am avut un coleg care a apelat la ei fiindca nu-i mai pornea masina (tot Logan). Au venit baietii intr-o ora (Bucuresti fiind locul faptei), i-au umblat la sigurante, era una arsa, au schimbat-o, i-au cerut carnetul de garantie in original, ala nu l-a avut, ooo! ce misto!, va costa 600.000 rol, a platit, sanatate, drum bun! Era prin iunie 2005.
Duster
2011 Laureate dCi
Liv05 |
![]() Membru Group: Members Posts: 149 Joined: 29 October 05 From: Arad ![]() |
Am apelat de mai multe ori la ei. O data nu o vrut sa-mi porneasca Solenza si eram inafara orasului ( masina iesise din garantie ), i-am chemat si or rezolvato, a costat 600.000 rol, din cate imi aduc aminte.
Astra Sedan 1,7 cdti
2008, Enjoy
dizzy |
![]() Work smart not hard! Group: Members Posts: 5.114 Joined: 11 February 04 ![]() |
Am apelat o data cand am fost bou si mi-am uitat farurile aprinse la SLZ, au venit, mi-au pornit-o, i-am dat 500 000 pe chitanta si sanatate.
In schimb in Constanta nu au avut serviciu, asta in 2003. |
Whirpool
ex Dacia Logan
stuiberv |
Membru autentic Group: Members Posts: 246 Joined: 8 April 05 From: Iasi ![]() |
Solenta in garantie, in Iasi, sunat, venit in 7 minute, rezolvat (mizerie intrata pe la un papuc la electromotor), semnat, la revedere.
Papuci
marimea 43
3 ani bocanci
- is xx undoitrei “All parts should go together without forcing. You must remember that the parts you
are reassembling were disassembled by you. Therefore, if you can’t get them together again, there must be a reason. By all means, do not use a hammer.” — IBM maintenance manual, 1925 |
aphophis |
![]() Membru autentic Group: Members Posts: 7.492 Joined: 14 January 06 ![]() |
lamuriti-ma: daca masina se strica si e in garantie (in speta garantie normala +garantie extinsa) vine cineva sa-ti tracteze masina pana in cel mai apropiat service dacia? Si e gratuit? Sau scoti banii la inaintare?
Later-edit: si de ce ar fi nevoie de carnetul de garantie (sau cum ii zice) sa il ai? NU se poate verifica in baza de date dacia? This post has been edited by aphophis: 7 Aug 2006, 14:06 |
Kia
Rio
2021
silviumc |
![]() Members Group: Members Posts: 315 Joined: 17 January 03 From: Bucuresti ![]() |
Eu sunt foarte multumit de Dacia Asistenta. Chiar daca e mai scump, macar stii ca nu ramai infundat in maro nicaieri.
Am avut nevoie de 2 ori, una dintre dati a fost asta iarna. Am ramas noaptea, duminica, la 25 de km de Bucuresti, pe un ger si un vant de groaza. Am iesit de 2 ori din masina, in camp, si am incercat sa fac ceva la motor, dar mi-au inghetat mainile in 30 de sec. asa de rau, ca nu mai puteam apasa butonul ca sa intru inapoi in masina, ii faceam semn sotiei sa-mi dea drumu' inauntru! Noroc ca mai mergea motorul cat de cat, ca sa bage niste caldura. A venit cel de la Dacia in 40 de minute, a pus masina pe platforma si ne-a dus pana acasa. Nu mi-a parut rau dupa bani. Deci vivat Dacia Asistenta. |
Megane 3 hatchback
2011 Sporty Dynamique TCe 130
adostar |
![]() Membru autentic Group: Members Posts: 419 Joined: 12 October 04 From: Galati ![]() |
1. Eu am ramas cu dacia 1310 din 1994 la 12 km de orasul Constanta, am sunat la dacia asiatenta le-am explicat care-i problema, presupun ca s-a dus bobina...etc. Dupa 30 min ma suna ei si imi spun ca nu au nici o masina in zona si ca le pare rau (era duminica pe la 12.30). Culmea vis-a-vis era o benzinarie dar nu aveau bobine, cei de la mag. spunand ca de cand au aparut daciile pe injectie nu mai tin bobine. Am luat frumos un maxi pana in CT, am oprit chiar la intrare unde erau doua magazine de piese auto si mi-am cumparat bobina dupa care m-am intors la masina si am schimbat-o.
2. Dacia 1307 pick-up 1,9 diesel - eram in Galati in cartierul tiglina1 cand acesta masina "superba" ![]() ![]() |
gaz
cazan
1980
- gaz/porc
pasarel |
![]() Membru incepator Group: Members Posts: 83 Joined: 9 April 06 ![]() |
Domnilor suntem in Romania!
Sunt treburi care nu mai mira pe nimeni. |
dacia 1310
mls
- b.27.zlt nu te baga in tarate ca te maninca porcii!
ghc |
..:::Cautatorul:::.. Group: Members Posts: 411 Joined: 9 December 03 From: Cluj-Napoca ![]() |
ZKR (Logan by Dacia)
BaLaureate 3.14
1907 toamna
- CJ-01-GHC
Octav |
![]() Membru Group: Members Posts: 168 Joined: 8 April 05 ![]() |
Ma intreb daca suna cineva cu un BMW sau alta masina "straina" la Dacia Asistenta , ce se intampla?? Halal serviciu de asistenta! Pai se compara cu cei de la ADAC? Aia meseriasi si , intradevar , serviciu de asistenta....
Laureate 1.6
- Bucuresti
AMW |
![]() Membru autentic Group: Members Posts: 779 Joined: 7 March 06 From: Bucuresti ![]() |
Mie de 1 Mai anul asta pe cand plecam de la mare spre buc am observat ca imi aruncase ulei prin compartimentul motor, am pus mana pe telefon, am sunat la ei am vorbit cu o domnisoara, i-am expus problema am intrebat-o daca sa mai continui drumul sau daca sa ma opresc pe dreapta sa astept depanarea, mi-a zis ca e duminica si mai e si 1 mai si ca in cam 3-4 ore poate sa vina o masina pentru ca trebuie sa il cheme pe sofer de acasa si mi-a facut legatura cu un domn inginer care era la un gratar (cred) si mi-a explicat ce am si ca nu e problema sa ajung pana in bucuresti probabil ca era un pic pilit ca imi zicea ca daca pateste ceva masina mea pana in bucuresti il gasesc la rent car service si ca mi-o repara el din banii lui si in timpul in care sta masina in service imi da masina lu nevastasa sa imi rezolv treburile
Volkswagen Passat
Highline 2.0 TDI 4MOTION
B6 Renault Megane III 1.5 dCI - 90 cp - 2012
Renault Scenic II Dynamique 1.6 16v |
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 16th July 2025 - 22:32 |
