[VAND] piese Renault 21 turbo, 129kw, 175cp, Si diverse accesorii auto
vyp75 |
![]() Membru autentic Group: Members Posts: 557 Joined: 29 April 08 From: Sibiu ![]() |
Dacia Logan Mcv
1.6/16v, 105cp.
- SB-75-VYP
vyp75 |
- traseu intermediar original turbo - 130ron
- fata originala turbo(far stg/dr, masca) - 280ron - fata originala ph2(masca, grila) -150ron - aripa stanga 2.0l - 50ron - aripa dreapta 2.0l - 50ron - jante wolfrace cu amvelope 5x108/j7/et37 - 400ron - geamuri laterale/usa spate/usa fata - 50ron buc - pompa servo cu furtune 2.0l - 110ron - pompa frana - 120ron - pompa ABS - 600ron - calculator ABS - 170ron - oglinda electrica stg - 50ron - capota motor - 80ron - usa fata stg/dr - 120 ron buc - instalatie electrica usa stg/dr, fata/spate - 50ron buc - macarale geam electrice fata - 60ron buc - boasca usa fata stg/dr - 50ron buc - set 4 yale cu chei - 60ron - semnale aripi - 50ron set - valiza militara lemn rat style - 100ron - volan crem megane 2 fara airbag - 50ron - capac frana mana crem simplu megane 2 - 50ron Vand pentru programul Rabla renault 21 nevada din '90, cu acte in regula si ITP pana in 2016 sau dezmembrez, motor 1721 injectie. Poze am sa atasez la CERERE. Preturile sunt negociabile. |
Dacia Logan Mcv
1.6/16v, 105cp.
- SB-75-VYP
vyp75 |
upppppppppppppppppppp
Dacia Logan Mcv
1.6/16v, 105cp.
- SB-75-VYP
vyp75 |
upppppppppppppppppp
Dacia Logan Mcv
1.6/16v, 105cp.
- SB-75-VYP
vyp75 |
uppppppppppppppppppppppp
Dacia Logan Mcv
1.6/16v, 105cp.
- SB-75-VYP
vyp75 |
- fata originala turbo(far stg/dr, masca) - 280ron - fata originala ph2(masca, grila) -150ron - aripa stanga 2.0l - 50ron - aripa dreapta 2.0l - 50ron - jante wolfrace cu amvelope 5x108/j7/et37 - 400ron - geamuri laterale/usa spate/usa fata - 50ron buc - pompa servo cu furtune 2.0l - 110ron - pompa frana - 120ron - pompa ABS - 600ron - calculator ABS - 170ron - oglinda electrica stg - 50ron - capota motor - 80ron - usa fata stg/dr - 120 ron buc - instalatie electrica usa stg/dr, fata/spate - 50ron buc - macarale geam electrice fata - 60ron buc - boasca usa fata stg/dr - 50ron buc - set 4 yale cu chei - 60ron - semnale aripi - 50ron set - valiza militara lemn rat style - 100ron - volan crem megane 2 fara airbag - 50ron - capac frana mana crem simplu megane 2 - 50ron Poze am sa atasez la CERERE. Preturile sunt negociabile. |
Dacia Logan Mcv
1.6/16v, 105cp.
- SB-75-VYP
vyp75 |
Dacia Logan Mcv
1.6/16v, 105cp.
- SB-75-VYP
dil |
![]() Membru verde Group: Moderatori Posts: 1.372 Joined: 7 December 04 From: Corbeanca, Ilfov ![]() |
Redeschis la cerere.
- - Renault Captur 0.9 TCe XMOD (2015)
ex Daewoo Matiz 2004 (2012-2015) ex Renault Clio Symbol 1.5dci 80CP 2006 Fidji (2006-2011) |
vyp75 |
Dacia Logan Mcv
1.6/16v, 105cp.
- SB-75-VYP
vyp75 |
uppppppppppppp
Dacia Logan Mcv
1.6/16v, 105cp.
- SB-75-VYP
vyp75 |
Dacia Logan Mcv
1.6/16v, 105cp.
- SB-75-VYP
vyp75 |
SE POATE INCHIDE, S-AU VANDUT PIESELE
This post has been edited by vyp75: 16 Jun 2015, 16:27 |
Dacia Logan Mcv
1.6/16v, 105cp.
- SB-75-VYP
DaciaClub - Reno Bot |
![]() Mesaj automat ![]() |
Acest mesaj apare automat, chiar daca postul tau este sau nu OK
Extras din regulamentul ariei "Bursa" 1. Topicurile deschise vor avea un titlu cat mai concis ce va contine obligatoriu ca prim cuvant "[VAND]", "[CUMPAR]" sau "[SCHIMB]" in functie de situatie. Topicul trebuie sa contina in primul mesaj informatii despre produs (starea lui, defecte) si PRETUL DE PORNIRE, acesta fiind obligatoriu. 2. Nu se permit topicuri la sectiunea bursa in care mesajele sunt scrise cu alt font decat cel standard, cu alta marime decat cea standard si cu alta culoare decat cea neagra. 3. In cazul in care un vanzator are mai multe produse de vanzare, apartinand aceleiasi categorii, el trebuie sa le adune pe toate intr-un singur topic, acesta nedeschizand un topic pentru fiecare produs. 4. Initiatorul topicului are dreptul sa foloseasca UP-uri O DATA in decursul a 24 de ore. 5. Nu se admit posturi offtopic, de exemplu posturi de genul: "Da scump mai este", "Am eu mai ieftin" etc. 6. Cei care VAND ceva intr-un post de CUMPARARE, vor fi avertizati prin sistemul de warn al forumului daca nu pun pretul de vinzare, ci scriu doar ceva de genul "am eu, cauta-ma", "cit oferi". 11. Ofertele permanente ale persoanelor fizice sau juridice vor fi plasate la sectiunea "Anunturi" si se vor supune regulamentului general plus regulamentului de la sectiunea indicata. |
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 10th July 2025 - 09:52 |
