> Dashboard illumination/backlight
kharak
post 5 Jan 2015, 18:57
Hello,
i have an issue with dashboard illumination. It should turn on, when i switch headlights on. But it does not. Also the backlight of the A/C controls doesn't work, same as window controls illumination.
What i have found strange, is that sound alarm if i forgot turn off headlights and shut down engine - does not work either. Open door control light does not work either.
I have checked fuse that should be responsible for dashboard, but that one is just fine.
Should i be looking for some another fuse that can be broken? If yes which?
Or is it another issue? Personally, i dont think that all this things could break at the same time smile.gif
Thanks a lot for answer.
This post has been edited by kharak: 5 Jan 2015, 18:59
Dacia Duster 2010
torquemada
post 8 Jan 2015, 22:48
torquemada
For dashboard illumination and sound alarm if i forgot turn off headlights check fuses 18 and 19 (see picture).
For Open door control light check the rest of the fuses highlighted with yellow
DACIA Logan II 2012 / 0.9 TCe Laureate - B-xxx-xxx
Există două feluri de oameni:
1 - Cei care pot extrapola din date incomplete
Lo-Fi Version  Harta site  Parteneri  Jocuri online  Curs Valutar  HRH Haine din lana merinos Time is now: 19th July 2025 - 06:04
