3 Pages < 1 2 3 >
> [VAND] Dezmembrez Megane 2, 1.9 dCI, Megane 2.1, Break, argintiu
alintosu
post 7 Feb 2015, 12:56
Display Update List. Afisaj portocaliu. Inclusiv mufa neagra si galbena(conectata la display). Pret: 75lei. Livrare prin Posta-Romana: 12lei, Curier - 25lei.
*Preturi negociabile la toate piesele!
This post has been edited by alintosu: 7 Feb 2015, 15:26
Renault Megane II Grandtour, 1.5 dCI, 74kW 2004
126cp, 260Nm
alintosu
post 8 Feb 2015, 20:09
Valabil!
126cp, 260Nm
alintosu
post 8 Feb 2015, 20:17
Set oglinzi Megane 2, cu reglaj electric, incalzire, si rabatare manuala. Stare foarte buna de functionare. Fara sticle si fara carcase(capace)! Pret: 130lei/set.
This post has been edited by alintosu: 8 Feb 2015, 20:18
126cp, 260Nm
alintosu
post 9 Feb 2015, 21:24
Up!
126cp, 260Nm
Alexandru Costache
post 10 Feb 2015, 17:33
Salut,
Mi-ar trebui si mie niste piese, ai pm.
Renault Kadjar 2015
alintosu
post 10 Feb 2015, 17:54
@ Alexandru Costache - Ai PM.
126cp, 260Nm
alintosu
post 11 Feb 2015, 18:06
Valabil!
126cp, 260Nm
alintosu
post 11 Feb 2015, 18:10
Janta de tabla(1 buc.), 15", 4x100, 6.5J, ET 45, CB 60.1, originala Renault. Stare foarte buna, practic este noua. Fara rugina.
Fara anvelopa!
Pret: 100 lei.
This post has been edited by alintosu: 11 Feb 2015, 18:10
126cp, 260Nm
ex5
post 11 Feb 2015, 18:55
motoras spalator parbriz si luneta ... pret?
renault megan2 1,6 16V 2005
alintosu
post 11 Feb 2015, 19:01
@ex5 - Ai PM.
126cp, 260Nm
alintosu
post 12 Feb 2015, 20:39
Up!
Carligul, roata de rezerva pe 16"+kitul accesorii si displayul update s-au vandut.
*Set panouri usi fata(cu decupaje spatii depozitare)+panouri spate(cu perdelute originale), pe bej cu textil - 200lei
This post has been edited by alintosu: 12 Feb 2015, 20:41
126cp, 260Nm
Alexandru Costache
post 13 Feb 2015, 09:30
Salut,
Am primit astazi coletul (display + kit roata rezerva). Totul este in regula. User serior, recomand.
Mersi.
Renault Kadjar 2015
gimianti
post 13 Feb 2015, 18:44
Manerele de la usile din fata si parghia de la frana de mana pret daca ai.
Multumesc!
Renault Megane 1.5 dci 2009
alintosu
post 13 Feb 2015, 19:19
@gimianti - Ai PM.
Poze cu manerele:IMG_20150213_01087.jpg ( Size: 609.98k ) Number of downloads: 75
Luni pun poze si cu frana de mana.
This post has been edited by alintosu: 13 Feb 2015, 20:30
126cp, 260Nm
alintosu
post 14 Feb 2015, 19:50
Valabil!
126cp, 260Nm
alintosu
post 16 Feb 2015, 18:45
Valabil!
126cp, 260Nm
Flavian
post 17 Feb 2015, 09:47
Salut,
Cat vrei pe frana de mana.
Nu ai un volan cu piele, negru?
Mersi,
This post has been edited by Flavian: 17 Feb 2015, 10:13
Renault Megane 2.2 Sedan 1.5dci 2006
costi13
post 18 Feb 2015, 18:52
junior
Set covorase interioare cu inscriptia megane,ai ?
renault megane 2.2 1.4 16v 2008/NOIR NACRE/ - PH 01
alintosu
post 19 Feb 2015, 12:12
Salut! Nu am covorase.
126cp, 260Nm
alintosu
post 20 Feb 2015, 23:37
Up!
126cp, 260Nm
alintosu
post 22 Feb 2015, 13:26
*Comanda climatronic - 150lei
*Scaune fata fara incalzire, cu tetiere(carte) - 150lei/buc.
*Consola centrala argintie, pentru climatronic - 50lei
*UCH(nivel 3) Renault Megane 2.1 + cartela(disponibil un singur card) si cititor. - 350lei
*Manere cromate cu Keyless - 300lei (disponibile si celelalte componente ale sistemului Keyless)
*Ceasuri bord -250lei - afiseaza pe displayul central fiecare usa deschisa si rotile cu presiune scazuta (optional: senzori presiune roti)
*Set jante de aliaj originale, 16", 4x100, 6.5J, ET 49, cu anvelope de vara Michelin EnergySaver 205/55 R16 91H, DOT4808x4708x2309x2810, Made in Germany.(inclusiv senzorii de presiune) - 200euro
*Airbag - 250lei
*Manere usi interior - 20lei/buc.(60lei toate 4)
*Grile ventilatie -Grila centrala: 50lei
-Grilele laterale: 30lei/buc.
*Vas lichid parbriz(3l) cu motoras(doua cai). Fara capacul galben.
-Vasul - 70lei
-Motoras doua cai - 30lei
-Setul vas+motor - 100lei
*Janta de tabla(1 buc.), 15", 4x100, 6.5J, ET 45, CB 60.1, originala Renault. Stare foarte buna, practic este noua. Fara rugina. Pret: 100 lei.
*Carcasa(capac, scoica) oglinda dreapta. Culoare: argintiu cod TE069. Toate clemele de fixare sunt intacte. - 50lei
*Cozoroc ceasuri bord Megane 2.1 - 50lei
*Brate stergatoare parbriz Megane 2.1. Prindere tip carlig. - 80lei/set.
*Frana de mana - 100lei
*Consola display radio Megane 2.1 - 60lei IMG_20150203_01013.jpg ( Size: 434.48k ) Number of downloads: 41
*Set panouri usi fata(cu decupaje spatii depozitare)+panouri spate(cu perdelute originale), pe bej cu textil - 200leiIMG_20150221_01112.jpg ( Size: 328.94k ) Number of downloads: 43
This post has been edited by alintosu: 22 Feb 2015, 13:27
126cp, 260Nm
Catalinmodena
post 22 Feb 2015, 18:28
Partea neagra,cu textil de la fetele usi fata,se poate da jos?
Renault megane sedan manager 1.4 16v 2007
alintosu
post 22 Feb 2015, 19:09
Salut! E prinsa in partea de sus de restul panoului. Sunt niste nituri din plastic pe care le poti desface ca sa o detasezi, dar o sa fie ceva de munca, cand vrei sa o prinzi la loc.
126cp, 260Nm
mariannae2001
post 22 Feb 2015, 23:23
Salut
discuri frana spate de 270mm daca ai la ce pret si ce grosime mai au ?
Renault Megane Break 2011 1.5dci 90hp. 66kw - B 238 ABY
Marian[QUOTE]Marian[/QUOTE]
alintosu
post 23 Feb 2015, 10:41
@ mariannae2001 - Ai PM.
@ soryn94 - IMG_20150223_01139.jpg ( Size: 316.37k ) Number of downloads: 41
* Suruburi("prezoane") pentru jante de tabla, originale - 10lei/buc.
This post has been edited by alintosu: 23 Feb 2015, 15:24
126cp, 260Nm
alintosu
post 24 Feb 2015, 15:02
* Jante de aliaj, originale Renault, 15", 4x100, 6J, ET43, CB 60,1. Stare foarte buna. Anvelope de iarna Dunlop SP WinterSport 3D 195/65 R15 88T, M+S, DOT 4209. Profil ramas: 3.5-4mm. Pret fara anvelope: 730 lei, sau cu anvelope: 900 lei. IMG_20150224_01149.jpg ( Size: 721.73k ) Number of downloads: 56
* Set boxe spate originale Megane 2. Diametru 13cm. Mufele incluse. Pret - 50 lei setul. IMG_20150224_01172.jpg ( Size: 606.09k ) Number of downloads: 27
This post has been edited by alintosu: 24 Feb 2015, 18:11
126cp, 260Nm
Bitu
post 24 Feb 2015, 20:36
Radiator apa, furtun de la radiator apa la vas expansiune, aparatoare noroi pe partea pasagerului (cel cu capacul de vizitare pt. schimbare bec), aripa dreapta ?
Multumesc frumos!
Renault Megane 1 benzina 1.4 16V Break (2003); Megane 2.2 diesel 1,5 dci Sedan (2007)
alintosu
post 24 Feb 2015, 21:52
@ Bitu - Ai PM.
126cp, 260Nm
alintosu
post 25 Feb 2015, 22:04
Valabil!
126cp, 260Nm
alintosu
post 26 Feb 2015, 22:15
Up!
126cp, 260Nm
3 Pages < 1 2 3 >
Lo-Fi Version  Harta site  Parteneri  Jocuri online  Curs Valutar  HRH Haine din lana merinos Time is now: 12th July 2025 - 19:39
