3 Pages  1 2 3 >
> [VAND]Piese noi si SH Dacia 13XX
tynn
post 4 Mar 2015, 13:54
Intrucat pe Dacioara mea o paste Remat-ul in curand, scot la vanzare mai multe piese noi si SH din "rezerva de stat" facuta in decursul anilor:
Piese NOI:
-Set 4 buc. rulmenti fata URB Alexandria - 100 ron
-Set 4 buc ( +1 buc. bonus) rulmenti spate URB Alexandria - 70 ron
La un set de rulmenti primiti bonus, la alegere, o cutie de 1 kg vaselina Lubrifin sau un tub de 400g vaselina Mobil ( ambele sunt noi, neincepute)
-Pivot superior (2 buc.) + inferior (1 buc.) Topoloveni - 20 ron/buc
-Macara geam usa sofer - 30 ron
-Set ornamente crom pasaje roti - 40 ron
-Pivot inferior SuperNova ( de origine) - 30 ron
-Set 4 buc. bucse tirant ( de origine ) - 20 ron
-Kit spalator parbriz ( vas + suport fixare + pompa + furtunase + duze) - 40 ron
-Suport radio tip vechi - 15 ron
-Bendix electromotor tip nou ( scurt) ASAM - 25 ron
-Set 2 buc. cilindrii receptori frana spate ( pt. tamburi mici) - 30 ron
-Sonda temp. E/P 108 gr.C pt. bec bord - 15 ron
-Garnitura chiulasa motor 1300 - 10 ron
-Curea pompa apa 1218 mm - 10 ron
-Fulie arbore cotit tip vechi - 15 ron
-Kit oglinda retrovizoare - 25 ron
-Bricheta + soclu - 10 ron
-Disc ambreiaj 170 mm - 20 ron
-Tampoane bieleta c/v tip vechi ( 2 buc) - 10 ron amandoua
-Ax delco motor 1300 - 15 ron
-Bucsa teflon caseta directie - 5 ron/ buc
Piese SH:
-Prese rulmenti fata si spate - 30 ron/ buc.
-Prese bucse bascule fata - 20 ron
-Kit inaltatoare spate - 35 ron
-Cric tip nou - 25 ron
-Antifurt volan cu cheie - 20 ron
-Ceasuri suplimentare apa (E/P) + incarcare baterie ( Jaeager) + suport + sonda apa pt. ceas - 50 ron
-Maneta semnalizare - 10 ron
-Nuca schimbator 4 tr. - 10 ron
-Buson rezervor ventilat - 10ron
-Capac delco (M/P) + lulea + condensator (Intermotor) - 15 ron
-Fulie mare pompa apa + curea Fartec - 20 ron
-Rotor electromotor mare + bendix E/P - 35 ron
-Rotor electromotor mare fara bendix - 20 ron
-Solenoid electromotor - 15 ron
-Set oglinzi ext plastic ( stg+ dr) - 25 ron
-Oglinda ext plastic stg - 15 ron
-Set semnalizari CN3 + 2 socluri bec de rezerva - 15 ron
-Lampa stop frana suplimentara - 15 ron
-Centura siguranta ( provine de pe un BMW, dar a fost montata pe Dacia) - 15 ron
-Scut motor tabla - 25 ron
Se ofera livrare personala in Constanta. Trimit in tara prin posta sau curier rapid. Din motive de ordin economic, nu trimit colete cu valoare mai mica de 50 ron. La valori mai mari de 80 ron ( cu exceptia seturilor de rulmenti, care au deja bonus vaselina), ofer gratuit, la alegere, un spray degripant Loctite sau Wurth, sau un spray Liqui Moly pt. sistemul de franare. Sau va puteti alege bonus cate ceva din piesele de valori mai mici.rul___vaselina.jpg ( Size: 805.45k ) Number of downloads: 844
This post has been edited by tynn: 4 Mar 2015, 13:58
Dacia Logan 1.4 MPI 2008
Dacia Duster Prestige 4x4 Dci 2015
florin iulian
post 4 Mar 2015, 19:00
cilindrii receptori frana spate ( pt. tamburi mici) de catre ce producator sunt fabricati ?
Dacia, Nissan 1300,1310,1310,Note 1980,1984,2002,2006
razvan32
post 4 Mar 2015, 20:42
superdaciuta
le dai separat? ce pret au?
DACIA 1310 1990 TX BERLINA - 6-PH-7008
tynn
post 4 Mar 2015, 22:47
@florin iulian - sincer nu stiu... este inscriptionat AS pe ei, dupa cum se vede in poza
@razvan32- imi pare rau, dar nu dau separat, decat la pachet cu flansele de cauciuc
tynn
post 6 Mar 2015, 11:11
UP!
tynn
post 7 Mar 2015, 12:06
up!
fullhouse
post 7 Mar 2015, 15:02
Ti-am trimis un PM cu o oferta.
dacia 1310 Li 2000
denisbossu
post 8 Mar 2015, 09:08
Am trimis un pm, ca as dorii ceasurile suplimentare de apa si incarcare baterie
Dacia Logan 2020 - DB-89-DNX
tynn
post 8 Mar 2015, 10:40
Aveti PM baieti!
tynn
post 9 Mar 2015, 12:41
Prea + rulmentii fata + vaselina Mobil + ceasurile suplimentare au plecat.
Restul valabile in continuare!
tynn
post 10 Mar 2015, 19:47
up!
denisbossu
post 11 Mar 2015, 13:36
Vânzător serios, am cumparat ceasurile de apa si baterie sunt ok
Si inca ceva un up pentru posta romana, au ajuns intr o zii, puse luni din Constanta si ajunse marti la ora doua in Dâmbovița
fullhouse
post 11 Mar 2015, 18:55
Am primit coletul, frumos impachetat, totul este intreg si ok. O mica nemultumire am, doar 2 rulmenti sunt seria 6207 RSANB, adica cu etansare doar pe o parte, acea etansare cu buza specifica rulmentilor auto, ceilalti 2 sunt 6207 RSR, adica cu dubla etansare, uzuali. Sper sa pot recupera de la rulmentii uzati 2 etansari cu acea buza. Multumesc si o seara placuta.
dacia 1310 Li 2000
tynn
post 11 Mar 2015, 23:16
Cu placere! Ti-am scris PM.
tynn
post 13 Mar 2015, 11:25
UP!
tynn
post 14 Mar 2015, 20:16
up!
tynn
post 16 Mar 2015, 10:42
up!
tynn
post 17 Mar 2015, 20:52
up!
tynn
post 19 Mar 2015, 15:38
up!
tynn
post 21 Mar 2015, 20:49
up!
tynn
post 23 Mar 2015, 12:58
up!
tynn
post 25 Mar 2015, 12:32
anunt valabil!
tynn
post 27 Mar 2015, 10:36
up!
tynn
post 28 Mar 2015, 20:40
up!
tynn
post 30 Mar 2015, 10:59
up!
tynn
post 31 Mar 2015, 19:07
up!
tynn
post 2 Apr 2015, 22:56
up!
tynn
post 4 Apr 2015, 19:50
up!
tynn
post 7 Apr 2015, 17:56
up!
tynn
post 9 Apr 2015, 11:46
up!
3 Pages  1 2 3 >
Lo-Fi Version  Harta site  Parteneri  Jocuri online  Curs Valutar  HRH Haine din lana merinos Time is now: 16th July 2025 - 20:02
