4 Pages < 1 2 3 4 >
> How fast did you drive your Logan?, and what rpm you reached...
novauto
post 8 Feb 2006, 16:29
Does anubody know what is signal from VSS? Impulses or voltage?
It is relative easy to make speed alarm using VSS signal.
Dacia Logan - ......
dydycom
post 10 Feb 2006, 17:41
daca exista vointa, orice se poate
QUOTE(novauto @ 8 Feb 2006, 16:29)
it's impulses m8...625pulses/km
laguna 2.0 dci cva 2008 privilege
Imi vand Laguna 3, Detalii la bursa!
http://https://www.reno.ro/index.php?act=ST&f=5&t=313709
kodalo
post 11 Feb 2006, 18:37
QUOTE(dydycom @ 10 Feb 2006, 17:41)
Can you tell me what is the shape, square, duty cycle?
Dacia logan Ambiance 1.4 MPI - NN XXX BBBB
BogdanBMB
post 19 Feb 2006, 09:33
I have a logan 1.6 l and when I had 3500km on board the maximum speed I reached it was 165km/h. 5 months ago I've had almost 13500 km and with 4 peoples in it and the trunck loaded I've reached 185 km/h (on speedometer) ofcourse on highway and on stright line. The next day after that I was alone in the car, with no lugage and there was no way I could pass 180. Funny isn't it?
Dacia logan preference 1.6 - B- 82 -BMB
mitzaciobanu
post 19 Feb 2006, 13:55
We mustn't forget two physical aspects:
1. Aerodynamic friction force, also knwn as "drag" increases with the square of the speed. So, if wind conditions are not equivalent, it is normal to have differences in maximum speeds of 10-15 km/h
2. Generally, roads aren't 100% horizontal. You either climb, or descend, without actually noticing it. So gravity may help you reach higher speeds when going down, or lower of course, when climbing.
Finally, I believe that in order to have reasonable results of maximum speed or accelerations, tests should be performed in both directions of the same road. Thus the average value is closer to reality.
PS Speeds over 150 km/s should be avoided... I personally believe that the steering isn't accurate enough at these speeds, in order to drive safely.
Dacia Logan 1.6 MPI Ambition - 2005 - BV
mccoy
post 19 Feb 2006, 17:31
I`ll simlify: loaded car = lowered car for a few cm = better aerodynamics = higher top speed… wink.gif
Dacia Logan Laureate 1.6 - ...98-7.
Divide et impera ... and unite in EU !
mitzaciobanu
post 19 Feb 2006, 22:04
hmmm... by loading a car you don't change its shape, thus the drag should remain the same. Indeed, what you mean by "better aerodynamics" can be translated into better stability at high speeds.
But on the other hand heavier car means higher friction force between tyres and road = lower top speed wink.gif
mccoy
post 22 Feb 2006, 18:04
QUOTE(mitzaciobanu @ 19 Feb 2006, 21:04)
hmmm...
I must slightly disagree…
Attached File(s)
mccoy
post 22 Feb 2006, 18:35
hmmm...
chapter II
Lowering a car, even by loading, reduces total front area and the amount of air the car is pushing out of the way and
minimizes ground clearance and air flow under the car which causes a lot of drag.
"Better aerodynamics" means increased aerodynamic efficiency – a car cuts or splits through the air more smoothly,
of course with better stability.
Effects of higher weight and rolling friction are significantly overpowered by the benefit of reduced air resistance so,
on the straight, flat highway, normal weather conditions, decently loaded Logan achieves higher top speed than empty one …
You may prove it...
Attached File(s)
post 22 Feb 2006, 22:02
Maximum speed reached with 1.4 was 180km/h (on a highway). Speedometer lies not with 12-15 km/h, but with 20km/h.
Don't ask about rpm, at this speed I didn't care about rpm.
PS. I wasn't towed, I wasn't descending or in free fall, the wind wasn't blowing from behind. I don't have a GPS system to verify which is the real speed at 180km/h.
This post has been edited by IRONICK: 22 Feb 2006, 22:05
bness
post 7 Mar 2006, 12:41
Logan 1.5dci laureat pack 155km/h on speedometer. This is not the top speed because gas pedal was on 2/3 pushed. My gues is that max on speedometar is 160-165. I will try some other time. This time I did't have a chance for max speed.
This post has been edited by bness: 7 Mar 2006, 12:42
Dacia Logan Laureat Pack 1.5dci - 686 96
Smeagol
post 7 Mar 2006, 13:34
Membru ...
Ambition, 1.6 MPI. I had 140 km/h on the spedometer. Around <4000 rpms. I think that this is a good cruise speed. You are not so bother by the engine noise, the steering feels OK.
P.S. I didn't drive it on the motorway. We have achived this speed on the road from Timisoara to Arad.
This post has been edited by Smeagol: 7 Mar 2006, 13:34
Dacia Logan Ambition 2006, 1.6 MPI - TM 10 ???
"Ai grija ce-ti doresti. S-ar putea sa capeti."
vsebas
post 18 Mar 2006, 14:43
spawn
I have Ambition 1,6 MPI and my max speed on speed meter was 160Km/h (but the straight line was only 4Km); very hard from 145Km/h to 160Km/h and only if I change gear at 5000rpm otherwise I can't go faster that 140Km/h (on a 4Km road straight line)
Dacia Duster 1.5 dci, / ex Logan 1.6 MPI 2005 Ambition / 2012, Laureate - TM
People are simply not predictable
AMW
post 19 Mar 2006, 04:53
I`ve tested my top speed twice between Ploiesti-Baicoi and Baicoi-Ploiesti. Between Ploiesti and Baicoi my top speed was 155 kmh with 4 people in the car the rpm was 3800-3900, when i returned Baicoi-Ploiesti was 173-174 the rpm was 4000. At 170> i think theat my speedmeter was going crazy becouse my car is a 1.5 dci and the top speed for this model is 155kmh. At theat speed the nois of the engine in the car was very loud. By the time of this test the car had 2000km and the tank half full. If the moderator thinks theat this speed is unreal then i`m asking him to delete my post. I have 3 withneses for this speed... tongue.gif
Volkswagen Passat Highline 2.0 TDI 4MOTION B6
Renault Megane III 1.5 dCI - 90 cp - 2012
Renault Scenic II Dynamique 1.6 16v
sabor
post 23 Mar 2006, 09:22
170km/h - 1,4 laureate
DACIA LOGAN - 1
voicamic
post 23 Mar 2006, 18:19
With my Laureate 1.6 MPI I went once in april 2005 from Bucharest to Constanta in a big hurry. I runned up to 160 km/h on the highway and made the whole trip in 2h 30min, even if I had to stay some 15min somewhere on the highway because of a car stopped which cought fire, until the firefighters came.
Anyway, checking some time later the instant fuel consumption readings, I saw that over approx. 130 km/h it goes towards 10 l /100km and higher, so i've let it slower on the road since then (for economical reasons, and safety, of course).
Dacia Logan MCV Laureate 1.5 dCI 68 CP 2007 - B-**-***
Fugi D'acia!
xtraya
post 25 Mar 2006, 18:49
for 1.6 , 10 liters at full speed (4000 rpm) is a normal thing...
it would be 8,5 for 1.4
Dacia Logan 1.4 - 1.4
DigitalScribe
post 26 Mar 2006, 21:38
Scribul Digital
OK... I've done it again (that's second time). 175 - 180 Km/H on speedometer. Changed at 5500 RPM from IV to V. Started with 4000 RPM on V-th and went to ... I don't remember... somewhere arround 5000 RPM I guess. At that speed the car is more of a World War II airplane when it comes to sound. The engine screams and humms loud and the wind is making terrible noise. The pedal was to the floor.
With all this speed a Megane II Break went past me (I was accelerating from 140Km/H) and altho I stayed on 175 - 180 for a good while I couldn't reach it. It went much much faster.
Renault Espace V Renault Zoe D-Max 2022 - n/a
Cata_C
post 27 Mar 2006, 11:31
On Bucharest Constanta highway 175 Km/h Ambiance 1.4
Dacia Logan 2007 Laureate 1.6 - B57FXN
Jack Daniel's
post 28 Mar 2006, 01:13
MEMBRU DE LA INCEPUT!
Speed record of my Logan 1.4 is 175 !
Multi membri, putini oameni!
post 28 Mar 2006, 10:28
Logan 1,4 max speed is 162 km/h.
From 162 to 175 is a long way...you need 15 horse power more to do 175 km/h(real speed, not speedometer bullshit)
This post has been edited by argon: 28 Mar 2006, 10:30
Jack Daniel's
post 29 Mar 2006, 01:26
QUOTE(Cata_C @ 27 Mar 2006, 13:31)
ARGON ???
Octav
post 29 Mar 2006, 21:24
My speed record with Logan 1.6 is 180 km/h , 2 person
DACIA LOGAN Laureate 1.6 - Bucuresti
Keka
post 31 May 2007, 17:24
Logan driver :P
On several different occasions (full, half full, just driver) max speed on highway (Novi Sad-Subotica; Novi Sad-Beograd, Beograd-Nis) was 175 km/h @ unknown rpm, I had to look in front of me, not down icon_mrgreen.gif
As I've read here, some people have problems with accelerating over 130 km/h in 5th gear.......Mine "Dacha" goes like hell in 5th
As far as rpms, this is for sure: 90km/h@2500 rpm; 110 km/h@3000rpm; 60km/h@1500 rpm (all 5th gear)
Fuel consumption at max speed......just 17 L/100 km radmasa.gif
Dacia Logan 2004 1.6 MPI Laureat pack LPG by Dora - Kadett 1.6D 1983
martin245
post 31 May 2007, 19:19
EX PAT
QUOTE(argon @ 28 Mar 2006, 09:28)
EXACTLY
I like the one who can see he is doing 175kph but could not read the rev counter laugh.gif
Stu
Ps I have not driven mine over 155 kph .If I wanted to go fast I could have kept my Rover 825 and used lots of fuel doing so
Stu
31 May 2007, 18:31:
QUOTE(AMW @ 19 Mar 2006, 03:53)
KEEP ON DRIVING LIKE THAT AND YOU NOISY ENGINE WILL BECOME QUIETER
sTU
This post has been edited by martin245: 31 May 2007, 19:31
dacia logan 14 mpi Simply RED 2007 - GB 1
Bessy Regs
alokin
post 31 May 2007, 22:08
I think that speed alarm is board computer feature which can be setting-up by owner, is not? Board computer in VW Cady have this feature - you can adjust this alarm on speed you want, and sound is like a gong.
Skoda Favorit 1993 - C 9328 BK
this what you see, is not what you think !
martin245
post 31 May 2007, 22:31
EX PAT
OH MY GOD
My speed alarm is me biggrin.gif !!! Myself mad.gif ...My own common sense blink.gif
who need a fucking dong or beep to tell you that you are driving or pushing your car to the limits radmasa.gif
Stu
Bessy Regs
Uri
post 1 Jun 2007, 21:58
Just one question guys.
On which planet do you live?
Ain't there no cops at all?!
Almost all those "rockets" at 160+ kmph would be caught in Estonia, and you'd have not just fifteen minutes of fame promised by Andy Warhole but the whole evening of fame. Your story would be printed white on black in the evening news.
I'm what Australians call a Volvo driver: town 50/70, highway 90/110 (e.g. always within speed limits).
Ciao
This post has been edited by Uri: 1 Jun 2007, 22:03
Dacia Logan 2006
Keka
post 2 Jun 2007, 09:21
Logan driver :P
Do you maybe know how many lines are in speedometer? You look at it every day biggrin.gif
martin245
post 2 Jun 2007, 11:08
EX PAT
I just know that if I can see the Rev Counter I can see the Tachometer
Bessy Regs
4 Pages < 1 2 3 4 >
Lo-Fi Version  Harta site  Parteneri  Jocuri online  Curs Valutar  HRH Haine din lana merinos Time is now: 15th July 2025 - 02:57
