2005 Citroen C5 Sedan Exclusive
R19/16v |
DS
5H
Laurentziu83 |
Mai joaca-te putin cu virgulele, ca se poate intelege altceva.
R19/16v |
Na poftim
DS
5H
cristio_79 |
QUOTE(cj98czh @ 8 Dec 2015, 11:49) Bwwlan - atentie daca deconetezi bateria, este o procedura intreaga ... ca sa iti ramana sanatos si functional BSI-ul ![]() Poti scrie procedura respectiva, te rog? Am si eu una luata de pe un forum strain, pentru resetare BSI si geamuri, si as vrea sa vad daca este aceeasi. |
Citroen / Peugeot
C3 / 308
cj98czh |
![]() Membru de la Cluj ... Group: Moderatori Posts: 23.375 Joined: 27 March 06 From: Cluj-Napoca ![]() |
Daca doar ai treaba cu bateria ( schimbi sau trebuie sa o deconectezi) procedezi asa:
-Put the driver's window down, lift the bonnet and ensure all equipment is switched off. -Ensure all doors are closed and remove key from the ignition. -Wait for 3 minutes, disconnect the vehicle battery Daca ai erori sau ceva nu functioneaza cum trebuie mergi mai departe cu procedura de BSI reset: -Put the driver's window down, lift the bonnet and ensure all equipment is switched off. -Ensure all doors are closed and remove key from the ignition. -Wait for 3 minutes, disconnect the vehicle battery and wait 15 seconds. -Reconnect the vehicle battery, wait a further 10 seconds (do not open doors.). -Switch on the side lights through the driver's window. -Switch on the ignition and check system's functionality. -Hold lock button on key down for 10 seconds. -Remove key open & close door test central locking system. -Start the engine and complete the system's check. Sau mai simplu ... BSI reset cu testerul ... dar daca nu ai unul la indemana ... merge cu ce este scris mai sus .. |
Mazda 3
Zoom-Zoom
2018
cristio_79 |
Tot asta o aveam si eu.
Multumesc! |
Citroen / Peugeot
C3 / 308
bucatzel |
![]() Membru plictisit Group: Moderatori Posts: 6.503 Joined: 19 May 08 From: Timisoara ![]() |
Si daca uiti sa cobori naibii geamul inainte sa deconectezi bateria, ce te asteapta mai precis, ca la cat de important suna procedura, io ma astept la un fluierat prelung care precede o palma peste frunte, dupa care se cauta o caramida...
1981
Orice service care se respecta are echipamente ca să schimbe o baterie fără să uite mașină nici o setare, se poate cumpăra și pentru acasă , destul de eftin.
marksman |
Post mortem nihil est Group: Members Posts: 7.722 Joined: 1 November 04 From: sat ![]() |
Io ma-ntreb ce se-ntampla daca moare bateria subit.
Opel / Mazda
Crossland X / CX-30
2019 / 2020 Nick Ușor
Aerius |
Membru autentic Group: Members Posts: 243 Joined: 1 April 09 From: Bukarestburg ![]() |
Nu mai porneste
![]() Am schimbat bateria fara sa stiu de procedura asta si n-a patit nimic. E drept, nu e Citroen, dar e Peugeot. |
Cannondale
CAAD12 2019
Renault Megane RS 2020
marksman |
Eu am patit o faza de-asta. Am plecat ca in orice alta zi cu masina, am ajuns, am parcat. cand sa plec, am deschis usa (culmea ca mergea inchiderea centralizata), si cand am bagat cheia in contact am avut "pom de Craciun" pe bord. Am luat contactul, l-am pus din nou, nu s-a mai aprins nici macar un led. A pornit cu cabluri de curent, m-am dus la Metro si-am luat o baterie, am schimbat-o acolo in parcare, ca altfel nu mai plecam.
Opel / Mazda
Crossland X / CX-30
Lex Luthor |
![]() Membru autentic Group: Members Posts: 1.112 Joined: 25 April 05 ![]() |
QUOTE(cj98czh @ 8 Dec 2015, 14:23) Daca doar ai treaba cu bateria ( schimbi sau trebuie sa o deconectezi) procedezi asa: -Put the driver's window down, lift the bonnet and ensure all equipment is switched off. -Ensure all doors are closed and remove key from the ignition. .................................. -Remove key open & close door test central locking system. -Start the engine and complete the system's check. Sau mai simplu ... BSI reset cu testerul ... dar daca nu ai unul la indemana ... merge cu ce este scris mai sus .. Si eu care credeam ca la masina mea e complicat sa schimbi bateria (adica trebuie sa-i resetezi incuietoarea de la portbagaj si sa faci 1-2 inchideri cu cheia in broasca usii + mers in linie dreapta cca 50 m pt. calibrarea ESP-ului)! ![]() |
Bwwlan |
![]() Membru autentic Group: Members Posts: 1.606 Joined: 16 September 09 From: .de, ex Cluj ![]() |
Mda, cred ca de aia are indicatorul asta:
VW
Golf Sportsvan
2017 1.4 TSI 150CP DSG Comfortline "Degeaba ai bani, dacă nu ai mulți."
Anonymous |
Solon |
![]() Membru autentic Group: Members Posts: 7.034 Joined: 16 December 04 From: Bucuresti ![]() |
Ce ma? Are indicator de alternator? Oau, fix dasha 1300!
3 japoneze
2 nemtoaice
si cam atat
Laurentziu83 |
E voltmetru (ca la 1300) sau ampermetru (ca la Moskvitch)?
This post has been edited by Laurentziu83: 8 Dec 2015, 21:19 |
cj98czh |
Asa des trebuie schimbata bateria ... ca este intradevar o tragedie
![]() Merge si fara nici o procedura dar te poti trezii cu tot felul de erori sau ca una alta nu mai functioneaza .. de aia trebuie facuta .. Bwwlan - ca tot ziceai de anvelope de iarna ... sa o ridici maxim sus cand faci schimbul de anvelope ca sa nu vezi cum curge bunatate de ulei hidraulic ![]() This post has been edited by cj98czh: 8 Dec 2015, 21:38 |
Mazda 3
Zoom-Zoom
2018
![]() - Group: Members Posts: 22.684 Joined: 19 April 05 From: Romania ![]() |
Este valabil la orice ridicare. Chiar si pe elevator.
This post has been edited by IRONICK: 8 Dec 2015, 22:19 |
Bwwlan |
Nu, prietene, pana acum eram "zgarciob" si faceam treb'shoara asta in curte, da' acu'o s-o duc la Euromaster si ma rezolva aia. Mai mult de 25-30 Euro n-are cum sa coste.
Da' numa' sa-nteleg si eu: la ce te referi si care-i treaba? This post has been edited by Bwwlan: 8 Dec 2015, 23:00 |
VW
Golf Sportsvan
Anonymous |
Aerius |
Chiar, ai nevoie de cric pentru a schimba roata? Auzisem pe undeva ca sta si in 3 roti
Cannondale
CAAD12 2019
R19/16v |
Sta in 3 roti daca o scoti pe a 4a, da.
DS
5H
dr_mKe |
Citronelurile astea-s mai complicate ca Bufnițoiu . . . . . nu mă mai plâng
2010 / 2022
cj98czh |
sunt mai complicate dar un pic mai fiabile
Mazda 3
Zoom-Zoom
2018
cristio_79 |
#53
QUOTE(marksman @ 8 Dec 2015, 16:36) Daca moare subit, ceea ce mi s-a intamplat, cand am pus contactul au inceput sa tacane tot felul de chestii pe sub bord, probabil releele din BSI, s-a resetat data si ora, intensitatea bordului era foarte scazuta, iar stergatorul hayonului se invartea cu o viteza foarte mica fara sa-l fi actionat. La una din ele s-a resetat doar data si ora, setarile cd-ului si informatiile cb-ului ramanand memorate, iar la cealalta s-a sters tot, trebuind sa refac toate setarile cd-ului. Nici eu nu am urmat toata procedura aia, singura chestie respectata a fost sa decuplez plusul de pe baterie dupa ce si-au deconectat consumatorii. Se aude un "tac" la putin timp dupa ce se decupleaza contactul complet. Cand mi-au crapat mie bateriile s-a intamplat brusc si subit sa moara cate un element. Adica au pornit bine-merci, am oprit pentru cateva minute si cand sa plec, canci. Tacanituri, bipuri si mucles. Tensiunea la borne normala. This post has been edited by cristio_79: 8 Dec 2015, 23:24 |
Citroen / Peugeot
C3 / 308
cj98czh |
#54
Asa am patit si eu .., numai ca dupa nu mai vroiau neam sa porneasca stergatoarele ... asa am aflat de procedura de reset BSI
Mazda 3
Zoom-Zoom
2018
M.C. |
#55
Renault Megane
II Sedan Influence
cj98czh |
#56
Iti dai seama ca era o gluma, nu?
Mazda 3
Zoom-Zoom
2018
dizzy |
#57
![]() Work smart not hard! Group: Members Posts: 5.106 Joined: 11 February 04 ![]() |
De cand aveam Dacia Nova nu am mai avut asa bord complet:
Indicatorul din dreapta de la Citronel e presiune sau temperatura ulei? This post has been edited by dizzy: 9 Dec 2015, 09:32 Attached thumbnail(s) bord_nova.png ( Size: 411.68k ) Number of downloads: 659 |
Whirpool
ex Dacia Logan
Bwwlan |
#58
Stanga extrem, apa, dreapta extrem, ulei.
VW
Golf Sportsvan
Anonymous |
MuciX |
#59
Ai pus sageata pe ala de benzina sa nu te prinda M.C. cu plinul nefacut...
M.C. |
#60
![]() Nu se pune,ca e contactu' luat ,si sunt toate la 0 ..... ![]() Dar bine ca ai adus aminte,supraveghem in continuare..... ![]() |
Renault Megane
II Sedan Influence
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 9th July 2025 - 15:02 |
