Interval inlocuire ulei CV
tynn |
23 Feb 2016, 11:43
Membru autentic Group: Members Posts: 1.222 Joined: 3 August 05 From: Constanta |
dstdan |
23 Feb 2016, 11:51
Damian Stefan Tolbariu-Dan dst Team Group: Members Posts: 343 Joined: 6 November 13 From: Mures autoservice Team DST Dan |
Uite aici. Gasesti cum, si cu ce se poate inlocui:
https://www.youtube.com/watch?v=VPPwWouHRf0 Capacitate ulei cutie de viteze 3-3,1 l Ulei cutie: Dacia Extragear SAE 75W80, API GL5 sau alta marca functie de banii din buzunar! http://www.xxx/forum/schimbat_car...teze-t1677.html This post has been edited by dstdan: 23 Feb 2016, 11:57 |
Dacia,Renault,VW -
1310, Megan, Tiguan
1997, 2003, 2008
- TAM Mintile luminate discuta idei, mintile mediocre discuta evenimente, mintile reduse discuta oameni!
D.S.T.DAN Team |
tynn |
23 Feb 2016, 16:11
OK, merci! Si ca interval recomandat, care ar fi?
DR.M |
23 Feb 2016, 20:19
Membru Group: Members Posts: 110 Joined: 14 August 10 |
Este topic special dedicat, cauta la piese auto.
Logan Ambiance
2005/1.4MPI
dstdan |
23 Feb 2016, 20:59
Regula generala, 10.000 km sau 1 an. Dar poti schimba linistit pe la 7-8000.
Dacia,Renault,VW -
1310, Megan, Tiguan
1997, 2003, 2008
D.S.T.DAN Team |
sobolan |
23 Feb 2016, 21:49
Logan-1.5dci-2017--
Golf mk5 - syncro - 2007--
dstdan |
23 Feb 2016, 22:21
scuze, scuze, gandul imi fu la motor si uleiul aferent, colegul intreba de c.v. manuala.
verificare de fiece 30.000 km, probabil ca scrie prin cartea masinii, legat de schimb/inlocuire ulei c.v., dar nu prea cred, mai nou la unele marci nici nu mai au buson de golire, doar de completare ulei. o seara buna si merci de atentionare, il, ,zapaceam,, pe coleg. This post has been edited by dstdan: 23 Feb 2016, 22:22 |
Dacia,Renault,VW -
1310, Megan, Tiguan
1997, 2003, 2008
D.S.T.DAN Team |
sobolan |
23 Feb 2016, 22:27
la unele modele de opel nu exista buson de golire,se separa carcasa diferentialului dar intram in alte probleme....uleiul la cv se poate schimba dupa primii 15oookm pentru ca se mai lasa prin el pilitura de la pinioane/inele/craboti etc ,adica pana se "pasuiesc" toate prin cutie si apoi se mai verifica nivelul .....in carte nu prea scrie nimic clar de cutia de logan.....la logan nu prea se pierde ulei din cutie,a se verica vizual burduful planetarei stanga dinspre cutie,daca se rupe ala adio ulei in cutie....
Logan-1.5dci-2017--
Andy_ACS |
23 Feb 2016, 23:24
Yes, I'm not! Group: Members Posts: 6.274 Joined: 19 July 04 From: Craiova |
Producatorul zice ca uleiul din cutie nu se schimba, se verifica periodic si se completeaza in caz de nevoie.
Totusi cred ca e bine sa fie schimbat din cand in cand, mai ales daca ai 178.000 km. Eu tot la 1.6 mpi din 2004 l-am schimbat la 70.000 (si 8 ani). Vizual parea ok, dar pentru ~150 de lei merita facuta operatiunea. . This post has been edited by Andy_ACS: 23 Feb 2016, 23:25 |
dstdan |
24 Feb 2016, 09:18
Rau nu-i faci, fiind vorba si de factorul timp, si nr. de km.
Ce pierzi? doar ceva banuti si 30 minute, ca timp. Schimbal! |
Dacia,Renault,VW -
1310, Megan, Tiguan
1997, 2003, 2008
D.S.T.DAN Team |
tynn |
24 Feb 2016, 11:00
Asa scria in manual si la renault 19 - boite graisse a vie ( cutie lubrifiata pe viata), insa afara, durata de viata a unei masini e max. 10 ani, dupa care ajung la noi, prin est... O sa-l schimb clar, pentru 100 de lei, chiar n-are rost sa ma zgarcesc
spik1 |
24 Feb 2016, 16:23
Membru autentic Group: Members Posts: 227 Joined: 14 February 13 |
Am o cunostinta ce este inginer mecanic auto.
Acesta spune ca orice ulei se schimba periodic. La cv se schimba la 4-5 ani. Orice ulei isi pierde calitatile in timp. Mai spune ca la cutie se schimba atunci cand este cald si el si vremea(cel mai bine vara) si se lasa cam 6 ore pt. o scurgere cat mai completa. This post has been edited by spik1: 24 Feb 2016, 16:24 |
Sandero
2012
- IF 08 GTA
dstdan |
24 Feb 2016, 19:10
S-a discutat! Ce te faci daca nu ai pe unde sa-i dai drumul, fara buson golire. Folosesti o pompa electrica/manuala de golire. Pe acest forum, mai toti sunt ingineri mecanici/AR sau practicieni
Dacia,Renault,VW -
1310, Megan, Tiguan
1997, 2003, 2008
D.S.T.DAN Team |
25 Feb 2016, 09:57
As fi foarte curios cum golesti tu o cutie de viteze fara buson (daca o exista asa ceva...), cu cutia pe masina.
Cutia de viteze e ceva care arata usor diferit de motor... |
dstdan |
25 Feb 2016, 10:15
Dam o gaura si-i punem buson
Pe la cel de umplere, etc. This post has been edited by dstdan: 25 Feb 2016, 10:17 |
Dacia,Renault,VW -
1310, Megan, Tiguan
1997, 2003, 2008
D.S.T.DAN Team |
25 Feb 2016, 10:41
dstdan |
25 Feb 2016, 11:22
Am explicat doar cum am facut in atelier pe o cutie blocata si care era data jos de pe masina si clientul a dorit printre altele buson de golire (cerinta musai), avea doar de umplere si completare. Nu s-a dorit nicio polemica la intrebarea ta si a altora. Inainte cutia a fost golita de ulei cu o pompa electrica de absorbtie +furtun cauciuc pe la gaura de completare.
This post has been edited by dstdan: 25 Feb 2016, 11:24 |
Dacia,Renault,VW -
1310, Megan, Tiguan
1997, 2003, 2008
D.S.T.DAN Team |
25 Feb 2016, 12:16
A, data jos de pe masina. Cu ea data jos trebuie doar sa o scurgi intr-o rana, nu-i trebuie pompa.
Si la ce masina era trebulita, daca nu e cu suparare? Sa stiu si eu care nu are gaura de golire. |
dstdan |
25 Feb 2016, 15:05
Ford, cutie IB5 - ungere pe viata, doar completare de ulei.
La cutia de care facuram vorbire anterior, intai s-a golit apoi s-a dat jos (s-a crezut initial ca alta e baiul si trebuie doar schib ulei, dar n-a fost sa fie ) Mai sus colegii prezinta si alte masini cu acest ,,avantaj,, Renault, Opel. This post has been edited by dstdan: 25 Feb 2016, 15:27 |
Dacia,Renault,VW -
1310, Megan, Tiguan
1997, 2003, 2008
D.S.T.DAN Team |
25 Feb 2016, 16:51
Renault fara buson de golire? Care-s alea?
bcg |
9 Mar 2016, 23:25
Membru incepator Group: Members Posts: 90 Joined: 18 May 07 |
Scrie in manualul de intretinere ca trebuie inlocuit? Daca nu scrie, pa si la revedere. Ca asa, nici sa-i facem masinii toate mofturile si s-o "cautam in coarne"...ca dam faliment.
sobolan |
10 Mar 2016, 00:12
QUOTE(bcg @ 10 Mar 2016, 00:25) Scrie in manualul de intretinere ca trebuie inlocuit? Daca nu scrie, pa si la revedere. Ca asa, nici sa-i facem masinii toate mofturile si s-o "cautam in coarne"...ca dam faliment. Dapai asa trag unii de ele la maxim,apoi dupa vreo 7-8 ani le rujeaza pe buze si pune vreun amarat mana pe ea de-si blesteama zilele.... Omule,cutia are roti dintate in ea,rulmenti,bucse de bronz,franele de la mansoanele sincron de bronz,crabotii de bronz,furci de bronz/alu .....etc......acolo totul e in miscare/frecare....daca tot are buson de golire/umplere(deci e o cutie cu intretinere)n-ar fi ok ca dupa primii 15-20k km pana se pasuiesc toate celea prin ea sa schimbi uleiul ala cu pilitura in el si apoi sa mergi linistit pana o dai ? This post has been edited by sobolan: 10 Mar 2016, 00:13 |
Logan-1.5dci-2017--
bcg |
10 Mar 2016, 07:17
Aici ai dreptate, ar trebui schimbat dupa rodaj.
SorinXp |
11 Apr 2016, 00:39
Membru Group: Members Posts: 196 Joined: 30 June 05 |
Totusi sa nu exageram. Uleiul nu isi pierde din proprietati decat dupa ceva mai multi ani.
In cutie exista un magnet, tocmai pentru pilitura. Cand ala nu mai face fata sa acumuleze pilitura, cred ca e momentul de o cutie noua. Pentru condus normal cred ca uleiul isi face treaba cu brio minim 4 ani. Mai mult depinde de soferi cat caraie cutia, daca conduc turat in oras (turatiile mari pot insemna o uzura mai mare la sincroane, mai ales retrogradarile daca se foloseste frana de motor), daca trag de maciuca aia cu toata forta sau trag finut de ea, asteaptand sincronul sa-si faca treaba. Calcatul la blana mai rupe pelicula de ulei(daca uleiul are prea multi ani sau nu e potrivit pentru cutie) si freaca pinioanele metal pe metal... |
Prestige 1.6 16v Dec2008
- B97GCT
Victoras2001 |
11 Apr 2016, 08:06
Membru autentic Group: Members Posts: 2.840 Joined: 15 February 08 |
O fi rezolvat problema pana acum. Desi, daca tot vrea sa umble la cutie, mai bine se uita si prin topicul cu pinioane tr 5 de dci.
ZAZ
Zaporojeț
Fanez |
12 Apr 2016, 08:14
Membru Group: Members Posts: 132 Joined: 10 December 09 |
QUOTE(sobolan @ 10 Mar 2016, 00:12) .... Omule,cutia are roti dintate in ea,rulmenti,bucse de bronz,franele de la mansoanele sincron de bronz,crabotii de bronz,furci de bronz/alu .....etc..... QUOTE(SorinXp @ 11 Apr 2016, 00:39) ....In cutie exista un magnet, tocmai pentru pilitura. Cand ala nu mai face fata sa acumuleze pilitura, cred ca e momentul de o cutie noua.... Chiar exista magnet pentru pilitura in cutie? In cazul asta se poate curata, dar trebuie sa fie cumva electric (electromagnet) pentru pilitura din cutie. Unde ar fi situat? |
1.2 16v
SorinXp |
12 Apr 2016, 13:00
Nu am demontat o cutie pana acum, am vazut in service candva si era la imbinarea dintre capacele de la cutie.
Nu trebuie curatat, cutia de logan e facuta sa mearga (in conditii de teste Renault) 500.000 km. Tot de prin service de pe la cativa mecanici. E sau nu adevarat nu stiu. |
- B97GCT
trabinatorccc |
9 Jun 2016, 09:20
Membru incepator Group: Members Posts: 99 Joined: 12 January 15 From: radauti |
QUOTE(SorinXp @ 11 Apr 2016, 00:39) Totusi sa nu exageram. Uleiul nu isi pierde din proprietati decat dupa ceva mai multi ani. In cutie exista un magnet, tocmai pentru pilitura. Cand ala nu mai face fata sa acumuleze pilitura, cred ca e momentul de o cutie noua. Pentru condus normal cred ca uleiul isi face treaba cu brio minim 4 ani. QUOTE(SorinXp @ 12 Apr 2016, 13:00) Nu am demontat o cutie pana acum, am vazut in service candva si era la imbinarea dintre capacele de la cutie. Nu trebuie curatat, cutia de logan e facuta sa mearga (in conditii de teste Renault) 500.000 km. Tot de prin service de pe la cativa mecanici. E sau nu adevarat nu stiu. ce timpenie,sa pui magnetul la imbinarea dintre capace! ca sa trebuiasca sa demontezi si sa desfaci cutia pentru a-l curata. la TRABANT,de prin 1985 incoace(parca),magnetul era pus in dopul de golire al uleiului si il curatai la fiecare schimb de ulei.era un magnet mic,cilindric si cu o gaura in care se aduna pilitura,iar dopul era din fier. revenind la logan,am schimbat si eu uleiul in cutie(uleiul din fabrica) dupa aproape 5ani si 35000km si nu am gasit nici macar un firicel de pilitura metalica.deci e posibil sa fie totusi vreun magnet pe undeva.uleiul era cam inchis la culoare,maroniu,dar se prezenta inca bine.era gras si nu avea aspect de apa.cred ca mai mergea un an.dar pentru 60lei se merita schimbat. nu mai credeti tot ce auziti pe la mecanici prin service.pun pariu ca o cutie nu rezista 500000km, fara sa schimbi uleiul din ea.asta la o utilizare normala,adica vreo 10-15ani. |
2011 1,5dci laureate
uponten |
9 Jun 2016, 09:49
Arhanghel M Group: Members Posts: 56 Joined: 14 April 16 |
Chestii de marketing. Daca tine o viata , ar da faliment fabricile. Uite asa par cutii ,,pe viata,,, , si alte elemente de unica folosinta, ca si masina ca intreg de altfel.
1976
- 1-SB-4116 „De la orice om ai întotdeauna de învățat, chiar și când tace.“ De la tine ce invat ?
cosstti |
9 Jun 2016, 17:28
Membru autentic Group: Members Posts: 487 Joined: 26 April 11 |
Ar fi interesant daca am afla informatii de la taximetristi.
In Iasi sunt din aia cu Logane vechi care au intre 600.000 si 800.000 Km. |
sandero stepway 1.6, 8V, 62Kw.
2o11
- is xx xxx
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 18th June 2024 - 19:53 |
