> Heater motor resistor, Is there an easy way ?
Barrie
post 24 Feb 2016, 18:41
At 63,000 my Logan MCV is still going well, except the heater/AC fan only works at full speed.
I've been quoted a kings ransom to fix it. My question is; Is there a simple way to replace the motor resistor ?
Barrie (SW France)
Dacia Logan Logan MCV Diesel - Not known yet 2008
sorin1983
post 24 Feb 2016, 18:47
this is the part responsible for the different speeds of the ventilation fan... on 4-th speed the current is sent directly to the motor of the fan. if you can find/buy another in 90% of the cases this solves the problem... or you replace the thermal fuse in the red circle.
it is situated on the left side under the steering wheel(position 8 in the picture)
This post has been edited by sorin1983: 24 Feb 2016, 18:53
berriebean
post 9 Dec 2018, 18:14
QUOTE(sorin1983 @ 24 Feb 2016, 18:47)
Wow, that is very helpfull information as I just bought a Logan MCV 2007 with the exact same problem. Does anyone know what parts of the dashboard I need to remove to access the location where the resistor is. Would it be possible to replace it by just removing the RPM and speedmeter unit? Or the center console cover?
Dacia Logan MCV 2007
post 10 Dec 2018, 09:52
passenger side footwell in your case (RHD I presume), no dashboard to remove.
Lo-Fi Version  Harta site  Parteneri  Jocuri online  Curs Valutar  HRH Haine din lana merinos Time is now: 4th August 2025 - 08:16
