Jante in 3 prezoane
Jante in 3 prezoane
#961
nalodaniel |
#962
![]() a3a oara scriu corect Group: Members Posts: 361 Joined: 24 March 08 From: suceava ![]() |
pe mine astia doi m-au derutat, scuze de confuzie, si mersi de lamuriri
![]() http://www.gbsalpine.com/wheel/gotti/eng/x13.html http://www.gbsalpine.com/wheel/gotti/eng/r17.html |
1986
BH 59 FIF |
#963
![]() Membru cu Break Group: Members Posts: 1.456 Joined: 13 July 06 From: Tara Crisului ![]() |
Site-ul GBS Alpine mai contine si anumite erori din pacate
![]() This post has been edited by BH 59 FIF: 11 Apr 2011, 10:50 |
1310 Break Alpineliebe
1986
- BH 59 FIF http://www.youtube.com/watch?feature...&v=-qRd8N3XU5Y
Cumpar priza aer capota R19 16v ph2. |
gmx4speed |
#964
![]() Membru incepator Group: Members Posts: 38 Joined: 27 February 11 From: DAMBOVITA ![]() |
dj_13055
vinzi pragurile alea? |
1986
- B 75 CDE
aditza579 |
#965
![]() Membru autentic Group: Members Posts: 1.195 Joined: 30 January 11 From: Bucuresti ![]() |
QUOTE(nalodaniel @ 11 Apr 2011, 09:34) pe mine astia doi m-au derutat, scuze de confuzie, si mersi de lamuriri ![]() http://www.gbsalpine.com/wheel/gotti/eng/x13.html http://www.gbsalpine.com/wheel/gotti/eng/r17.html Tot site-ul ala m-a derutat si pe mine. Am masurat la fuzeta de dacie si distanta dintre prezoane e 130mm iar PCD-ul este 150mm. Conform site-ului ala cele de R17 nu merg pe dacie. O sa le dau un e-mail si o sa-i intreb 11 Apr 2011, 16:20: QUOTE Hello, I saw on your website that the R17 Gotti Rims fits well on R12 but the PCD that it's write there show's a wrong information. The R12's PCD is 150 mm, and the distance between the bolts is 130 mm. I want to ask you what are the right values for that informations and if that wheels fits on R12. I waint your answer. Adiel from Romania Astept raspunsul si va comunic This post has been edited by aditza579: 11 Apr 2011, 15:20 |
1610
RS '99
BH 59 FIF |
#966
Indicat ar fi sa le trimiti mail-ul in franceza. Oamenii is relativ prompti in a-ti raspunde, doar ca au probleme destul de mari cu limba engleza si exista riscul sa nu intelegi mare lucru (asta iti spun din proprie experienta).
L.E: Acuma am vazut ca ai editat postul. Nu o zic cu rautate, da' nici engleza ta nu e prea stralucita ![]() This post has been edited by BH 59 FIF: 11 Apr 2011, 15:24 |
1986
aditza579 |
#967
Nu ma laud cu engleza. Punteam sa le trimit cu google translate sau ca alte moduri de a traduce. Franceza nu stio o boaba. Daca vor le scriu in germana ca pe aia o stiu. Sa vedem daca rsp e bn daca nu le trimit in franceza. Ms pt atentionare
1610
RS '99
maho |
#968
![]() Membru rigido-flexibil Group: Members Posts: 5.219 Joined: 7 April 10 From: Brașov, orașul olimpic ![]() |
Nu te sfatuiesc sa folosesti "google translate", e mai slab decat engleza ta. Mai bine rogi un prieten care le are cu franceza.
aditza579 |
#969
QUOTE Hello, Thank you for your email. In response to your inquiry about Gotti wheels. If you need fuller information please contact Gotti Factory : * * * GOTTI * * * ******* Raspunsul cel asteptat. Nici ei nu stiu. Daca vreau informatii vorbim la fabrica This post has been edited by bucatzel: 11 Apr 2011, 20:04 |
1610
RS '99
1310CL |
#970
![]() 1310 DRIVER Group: Members Posts: 1.232 Joined: 25 January 10 From: Arad ![]() |
Canada in 4 prezoane,foarte misto arata
Dacia 1310
TLX
1990
- AR06GKI CREM 427
nalodaniel |
#971
QUOTE(BH 59 FIF @ 10 Apr 2011, 20:11) Distanta dintre centrul gaurilor prezoanelor este de 130 mm atat la Renault 8 cat si la Dauphine, 10, 12, 15, 16, 17, 18 ph. 1. PCD-ul (diametrul cercului imaginar format de cele 3 prezoane) in schimb este de 150 mm. Ca sa incheiem discutia, are perfecta dreptate. Am rasfoit pe topicul asta si in alte cateva locuri si am ajuns la concluzia ca sunt destui francezi care habar n-au ce spun, si cativa romani care au pus ruleta pe janta si au confirmat ca PCDul este 150. La renault 8 e tot 150. Si PCD 130 e la renault 5. Sfarsit. @1310CL : exista asa ceva sau spui ca ar arata fain? ![]() This post has been edited by nalodaniel: 12 Apr 2011, 09:36 |
1986
#972
Normal ca exista, era si o poza mai sus, si inca una
Attached thumbnail(s) Renault_30_TS_V6_1975.jpg ( Size: 76.96k ) Number of downloads: 1359 |
aditza579 |
#973
QUOTE(nalodaniel @ 12 Apr 2011, 10:30) Ca sa incheiem discutia, are perfecta dreptate. Am rasfoit pe topicul asta si in alte cateva locuri si am ajuns la concluzia ca sunt destui francezi care habar n-au ce spun, si cativa romani care au pus ruleta pe janta si au confirmat ca PCDul este 150. La renault 8 e tot 150. Si PCD 130 e la renault 5. Sfarsit. @1310CL : exista asa ceva sau spui ca ar arata fain? ![]() Ca sa incheiem am pus ieri sublerul pe fuzeta de dacie si distanta dintre prezoane este 130mm iar pcd-ul este 150mm(masurate) |
1610
RS '99
raku18 |
#974
![]() Membru incepator Group: Members Posts: 37 Joined: 10 January 11 ![]() |
jantele de r5 se potrivesc pe dacia 1310? replica ca si cms taurus
Attached thumbnail(s) renault_5_alpine_turbo_122b_8120_2l.jpg ( Size: 98.77k ) Number of downloads: 1426 |
1310 li
2000 li
- cj 25 mod
bucatzel |
#975
![]() Membru plictisit Group: Moderatori Posts: 6.464 Joined: 19 May 08 From: Timisoara ![]() |
Ia incearca sa citesti topicul, si vei afla raspunsul cu siguranta. Sau imprieteneste-te cu functia SEARCH.
1981
BH 59 FIF |
#976
Un alt exemplu de "CN" (sau ma rog, alta explicatie eu nu gasesc).
Attached thumbnail(s) RENAULT20_medium_2045_4.jpg ( Size: 91.54k ) Number of downloads: 1384 Image009.jpg ( Size: 264.49k ) Number of downloads: 1369 |
1986
AndreiTGV |
#977
![]() Uite ce spun eu ->>>>>> Group: Members Posts: 72 Joined: 13 January 11 From: Targoviste ![]() |
Am gasit pe alt topic o poza cu jantele asta, mi se par a fi de Renault 5, nu-s sigur...
Attached thumbnail(s) d0_1_b.jpg ( Size: 20.95k ) Number of downloads: 1356 |
Break
2000 REMAT
hyena |
#978
![]() Old School Fan Group: Members Posts: 2.556 Joined: 25 September 08 From: B. Ghencea ![]() |
dupa proportii sigur sunt de reno
Dacia/Dacia/Suzuki
1310MLS/750s BIG
1986/1989
- B986ZBY Dacia mea 1310 '86 http://www.daciaclub.ro/index.php?act=ST&f=126&t=223323&st=0#entry3169331
EX Dacia 1310 '98 /index.php?showtopic=160866&st=330 |
Sauber |
#979
![]() Membru autentic Group: Members Posts: 5 Joined: 14 April 11 From: Bucuresti ![]() |
Sunt de Renault si nu se potrivesc pe dacie decat cu flansa(nu e cea mai stralucita idee si nici nu o agreez)
1975
ZerO_CooL |
#980
![]() Membru incepator Group: Members Posts: 85 Joined: 5 December 10 From: Bucuresti ![]() |
1978
- 1-B-1014
Muttley |
#981
Distanta dintre prezoane e MASURABILA.
Ai 3 prezoane, adica un triunghi echilateral. Latura acestui triunghi echilateral e de 130mm. Cercul circumscris triunghiului are diametrul de 150mm. Geometrie de clasa a 7-a, inaltimea unui triunghi echilateral e [L x 3^(1/2)] / 2. Cum inaltimea unui triunghi echilateral = mediana, centrul cercului circumscris se va afla la o distanta de 2/3 x inaltimea. Distanta dintre centrul cercului circumscris si varful triunghiului e raza cercului. Inmulteste cu 2. Cat da? Mie mi-a dat 150,11106998. This post has been edited by Muttley: 14 Apr 2011, 20:51 |
1310 TLX
ZerO_CooL |
#982
150.11
![]() Multumesc pentru explicatie. Nu m-am gandit ca nu se poate masura diametrul de asezare a gaurilor si, din moment ce am vazut ambele valori, nu intelegeam de ce a mai dat-o si pe prima. |
1978
- 1-B-1014
Sauber |
#983
QUOTE(ZerO_CooL @ 14 Apr 2011, 21:24) Imagineaza-ti ca te duci si iti iei niste jante in 3 prezoane, frumoase, dar ai dat si ceva bani pe ele. cand ajungi acasa iti dai seama ca distanta dintre gaurile prezoanelor este mai mica. Nu o sa te bati tu singur ca ai dat banii pe niste jante frumoaste dar fara folos si pt ca nu ai fost atent la scoala in clasa a 7-a ca stii inste amarate de formule pe care ti le-a enumerat Muttley mai sus? Gandeste-te |
1975
ZerO_CooL |
#984
Muttley a inteles ce am intrebat, tu nu. Distanta in sine nu conteaza, ci diametrul de asezare a gaurilor (PCD), si din moment ce vazusem data valoarea diametrului, nu intelegeam de ce a mai masurat si distanta dintre prezoane.
1978
- 1-B-1014
Muttley |
#985
Distanta dintre prezoane e doar o interpretare a diametrului cercului purtator.
Un fel de "cum iti dai seama daca afara e noapte daca esti mort de beat si nu te poti da jos din pat ca sa te uiti pe fereastra?" Raspuns: te uiti la ceas sa vezi cat e ora. Mai simplu, in cazul de fata, axioma: "daca distanta dintre prezoane e 130, atunci diametrul cercului e 150". 15 Apr 2011, 00:37: QUOTE(ZerO_CooL @ 14 Apr 2011, 21:59) Se poate, masori distanta de la prezon la centrul jantei si obtii raza. Da' parca nu e atat de elegant ![]() This post has been edited by Muttley: 14 Apr 2011, 23:37 |
1310 TLX
Siconi |
#986
Nu e atat de elegant, dar e al naibii de simplu, fara sa trebuiasca sa tii minte 'n'spe formule pe care oricum ar fi trebuit sa le inveti la vremea potrivita.
Deci variante exista!!! O simpla remarca: se masoara distanta de la CENTRUL prezonului la centrul jantei pentru o mai mare acuratete a datelor cautate. Evident, rezultatul este raza care, din matematica, este jumatate din diametru, adica 2 x R = D (phi). |
Mercury
Mariner Premier 3.0L V6 4WD
raku18 |
#987
jantele de reno 5 alpin turbo potrivesc pe dacia 1310 li?
1310 li
2000 li
- cj 25 mod
Muttley |
#988
DA! Cumpara-le!
1310 TLX
bucatzel |
#989
QUOTE(raku18 @ 13 Apr 2011, 18:48) QUOTE(bucatzel @ 13 Apr 2011, 18:55) Ia incearca sa citesti topicul, si vei afla raspunsul cu siguranta. Sau imprieteneste-te cu functia SEARCH. QUOTE(raku18 @ 20 Apr 2011, 18:40) Tu chiar nu vrei sa citesti doua pagini? trebuie sa-ti dea lumea chiar mura-n gura? Nu se potrivesc. Era greu... o trebuit doar sa dau un pic scroll. QUOTE(BH 59 FIF @ 11 Apr 2011, 10:19) Tot in linkul postat mai sus se indica ca jantele Gotti model R17 pentru R12 s-ar potrivi si pe R5. Asta e o alta informatie eronata, singurul R5 care avea distanta dintre prezoane de 130 fiind ala de Gr. 2. |
1981
Tiristu' |
#990
Membru Group: Members Posts: 102 Joined: 20 April 09 ![]() |
Salut baieti, am achizitionat si eu 4 cms-uri, si au o mica problema sa zic asa. Acolo pe langa emblema, este vopseaua un picut umflata, si imi lipseste si o emblema,...stiti cum este...i-a trebuit altuia si na...asa se practica la Braila... este un loc unde le-as putea reconditiona? Eu sunt din BR sau CT, pot merge si colo..si colo...
This post has been edited by Tiristu': 23 Apr 2011, 10:51 |
97/S
- 02 BUJ
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 12th May 2025 - 12:13 |
