Aprindere electronica
#2401
aly |
#2402
![]() Membru autentic Group: Members Posts: 274 Joined: 7 January 05 From: Iasi ![]() |
Gotronic ce se mai aude cu aprinderea aia?
1310 tlx
- is-xx-yy
gotronic |
#2403
Se lucreaza la Pregatirea fabricatiei. Scule de injectare, Stante, documentatie, ..... Si nu in ultimul rand, posibilitatea de implementare si pe alte masini. (delcouri). Adica, ca si pe Dacia, s-au facut modele si trimis pentru probe in tara mai ales pentru VW Broasca, Opel, unde era un club mai activ. Spun asta deoarece senzorul pentru VW Broasca (delcou Bosch), se potriveste pe o mai larga gama de autoturisme fabricate in Vest (si motociclete.)
![]() Imi pare rau ca nu sa discutat pe forum si problemele de pe autoturismele Dacia, la care eu am trimis "sample" mai multe aprinderi cu senzor. Poate o sa se discute si aici prin bunavointa celor care au primit gratis (sample) aceste Aprinderi cu senzor in loc de platina.!!! ![]() Variante de senzor (Aprinderea este aceeasi), incerc sa va prezint mai jos.: http://vwforum.vwforum.ro/index.php?showtopic=6358&st=360 http://vwforum.vwforum.ro/index.php?showtopic=20871&st=120 Scuze ptr. calitatea pozelor, sunt facute de posesorii Aprinderilor cu senzori.!!! This post has been edited by gotronic: 2 May 2007, 13:49 Attached thumbnail(s) Resize_of_IMG_3289.JPG ( Size: 100.64k ) Number of downloads: 278 Resize_of_IMG_3321.JPG ( Size: 66.57k ) Number of downloads: 278 Resize_of_IMG_3324.JPG ( Size: 79.76k ) Number of downloads: 282 senzor2.jpg ( Size: 25.73k ) Number of downloads: 279 Senzor_Hall_in_loc_de_platina.JPG ( Size: 151.11k ) Number of downloads: 254 Resize_of_IMG_3315.JPG ( Size: 68.36k ) Number of downloads: 166 Resize_of_IMG_3320.JPG ( Size: 83.11k ) Number of downloads: 126 Resize_of_IMG_3322.JPG ( Size: 93.95k ) Number of downloads: 108 normal_Resize_of_PIC_0013.jpg ( Size: 63.74k ) Number of downloads: 109 normal_Resize_of_PIC_0014.jpg ( Size: 65.08k ) Number of downloads: 110 normal_Resize_of_PIC_0015.jpg ( Size: 59.7k ) Number of downloads: 88 normal_Resize_of_PIC_0017.jpg ( Size: 102.22k ) Number of downloads: 105 |
2020 Iulie
- MS-10-GOT MS-10-GOT
mihai1677 |
#2404
![]() Membru autentic Group: Members Posts: 1.369 Joined: 23 December 03 From: Bucuresti ![]() |
In sfarsit dupa o saptamana de lucru este gata programul pt aprinderea cu PIC varianta jumostatica (bobina cu 4 fise), cu posibilitate de corectie detonatie, vacum (depresiune sau presiune).
Urmeaza cablajul, cutia, si testarea pe motor. Pe simulator totul este ok. |
Renault 5 Campus,
Hyundai Sonata,
1988 / 2001
#2405
Am ars 2 IR2155 , fratilor nu imi mere cum trebuie aprinderea jhon clarke. Functioneaza ostilatorul e ok am 320V iar partea de comanda in loc sa fie multi scintee e mono si foate slaba de ce oare ? ,vi s-a intimplat circuitu pe cablaj e perfect realizat . Ciudate e atunci cind dau jos rezistentza de 33k cea care e inseriata cu condensatorul C3 de 120nf lucreaza multi spark dar lucreaza necontrolat. Daca ating eletrodul de comanda scade numarul de scintei dar e tot multi spark daca las liber eletrodul de comanda si nu-l mai pun la masa apar mai multe scintei . Oare voua cum va functioneaza vorbesc sincer . Ati avut probleme ......... astept comentari si dezvoltatile sal pe liviu si pe gotronik si pe toata lumea!
This post has been edited by diaconuliviu: 2 May 2007, 11:39 |
diaconuliviu |
#2406
Nu, n-am avut probleme si nici nu am.
Esti sigur ca acel 120nF e de valoarea aia? Cind scoti R=33K teoretic ar trebui ca montajul, la "deschiderea" platinii sa dea scintei in tren continuu, pentru ca acel C nu se mai incarca si nici tensiunea pe el nu atinge o valoare care sa deschida dioda aia 1N914 (sau 4148) si sa blocheze oscilatorul. Atentie la valori; pe oscilatorul chopper are un C=0.001 uF, adia 1nF; am pus unul polonez pe care scria 1k(de fapt mai multi marcat identic), ei bine, nu oscila nici batut, era alta valoare. Am pus altul de alta productie, a pornit chopperul din prima. Apoi, exista C1=100uF/16Vvv, se pune de minim 25V si atentie la polarizare/montare, altfel nu vei avea scintei si se va si distruge. Atentie, de asemenea si la polarizarile diodelor. Si, nu in ultimul rind, la trasee, o lipitura rece pe traseul de masa arde IR2155 al doilea. Deci, montajul functioneaza, orice abatere de la o functionare corecta iti apartine-lipitura rece, piese proaste, de valori diferite (vezi sistemele de codare care in timp s-au mai schimbat - cel mai bine verifici valorile pe ohmetru sau capacimetru). De fapt, ziceai ca stii electronica, ce naiba, te invatam noi? ![]() This post has been edited by diaconuliviu: 2 May 2007, 11:43 |
Corsa
#2407
nu imi mere multi sparkul:( doar oscilatoru da bine 320 vsi sta si in sarcina rezistiva pe 1k /10w partea naspa e cu modulul de comanda
diaconuliviu |
#2408
Am vorbit si cu Dodo; la inceputul materialului (si exista si traseele pe placa) ai un modul de atac, cu o rezistenta la + si o dioda de sens (pt cazul atac pe doua platine). Tu ai pus acea rezistenta catre +? Chiar si de 1K e buna pentru probe (caz in care nu ai nevoie de autocuratare).
This post has been edited by diaconuliviu: 2 May 2007, 12:16 |
Corsa
cd_i |
#2409
participant la trafic Group: Members Posts: 123 Joined: 21 June 06 ![]() |
Gotronic,
O sa pui in vanzare si "platina" separat sau va fi doar in set cu aprinderea? Ma intereseaza fiindca as vrea sa cuplez un senzor magnetic cu cdi john clarke. Diaconuliviu, pentru turometru ai facut exact montajul din schema (condensator + primar de trafo) sau ai facut un artificiu cu o bobina de inductanta echivalenta dar volum mai mic? nu ma prea incanta ideea de a pune acolo un trafo de retea doar pentru inductanta primara. (e prea mare) multumesc This post has been edited by cd_i: 2 May 2007, 13:37 |
1310L
'94
- CS-01-GBE
gotronic |
#2410
O sa fie, dar este greu cu interfata (termostata). Altfel o sa ai probleme.!! Si Liviu a avut.!!
2020 Iulie
diaconuliviu |
#2411
Nu e prea mare; e traf de retea de pe la casetofoanele duble de cartier; Poti folosi si unul de la "adaptor redresor" din comert, ala gen 3-4,5-6....12V; are cam 3x4x3 cm, are loc pe o laterala a carcasei, chiar in zona placii unde sint traseele pentru al doilea tranzistor - cel ce da semnat mic pentru turometrele cu asemenea atac. Eu am facut o placuta separata pe care am montat acel adaptor, impreuna cu traful. Acel C de 0,033uF e posibil a fi nevoie sa fie "tatonat" ca valoare; la mine, din cauza acelui traf, cu alta inductanta pe primar, a fost nevoie de 1 nF[/1300V] (asa am gasit printr-un ELCROM, pe partea de baleiaj orizontal). Cu cel de 33 nF turometrul nu indica nimic.
Pe la VW Golf cu motor Diesel exista niste bobine parca ce fac o ridicare de tensiune pentru turometru, dar nu stiu cum is si ce caracteristici au. |
Corsa
gotronic |
#2412
Revin. Nu stiu daca la toate diesel-urile, dar turometrul isi ia semnal de pe alternator.!?
This post has been edited by gotronic: 2 May 2007, 14:02 |
2020 Iulie
diaconuliviu |
#2413
Posibil, la unele; stiu ca cel de pe linga mine cu motor Golf Diesel pe Dacia Break avea ceva de genul unei bobine adaptoare luate de pe Golf-ul "mama".
Corsa
cd_i |
#2414
Eu ma gandeam la un artificiu care sa inlocuiasca traful. Daca tot am la dispozitie tensiunea inalta de la convertizor, ar trebui sa functioneze daca in locul circuitului rezonant de acolo sa pun doi tranzistori de inalta tensiune care sa fie comandati de platina. La iesirea din cei doi tranzistori ar trebui sa am impulsuri dreptunghiulare cu nivel intre 0 si cei 3xx v ai convertizorului. Cel putin teoretic...
1310L
'94
- CS-01-GBE
#2415
diaconU liviu am condensatori de valoare exact oscilatorul lucreaza adica cioparul am deja 320 v si sta stabil ok . Da cum am spus si cum ai spus daca scot rezistentza de 33k cea care e inseriata cu C3 =120n am un tren de impulsuri 6 la numar pe osciloscop bun pun la loc nu mi am e IC2 pun eletrodul la masa imi apare scinteie e ok dar e mica
![]() .............................................................................................................. GATA FUNCTIONEAZA BRICI AM MODIFICAT REZISTENTZA DE 33K CU UNA DE 220KO IESE FLACARA TOTI CARE AU JHON CLARKE SA MODIFICE DOAR ACEA REZISTENTA DE 33K CARE E INSERIATA CU CONDENSATORUL C3 = 120NF SI PE BOBINA DE INDUCTIE VA AVEA FLACARA AM DAT FOC LA HIRTIE ![]() ![]() ![]() Nu vrei sa renunti la IRC? This post has been edited by diaconuliviu: 3 May 2007, 06:43 |
gotronic |
#2416
Cu 320Vcc pe condensatorul de descarcare, nu ai cum sa ajungi la tensoiunea aia in secundar. Raportul de transformare este acelasi la Bobina. Poate vrei sa spui ca ai avea o scanteie mai puternica, da tensiunea cum ai masurat-o aproximativ.??? ![]() |
2020 Iulie
diaconuliviu |
#2417
@djasu82: eu inca mai cred ca ai oarece belele pe placa sau printre piese; valorile la mine sint exact cele din schema si nu am probleme, deci acea valoare de 33K e in regula.
Tu spui ca daca ai scos-o complet din circuit, ai avut 6 scintei. Ori, limitarea numarului de scintei il face tocmai incarcarea acelui C3 la o tensiune. Daca montajul ar fi corect, odata cu scoaterea R=33K, acel C3 nu s-ar mai incarca, trenul de scintei nu s-ar bloca, fiind continuu; la tine avind numai 6 scintei inseamna ca el se incarca fara acea 33K, deci, as banui polarizarea D8 si D10 - le banuiesc montate invers, asa incit acel C3 se incarca pe acel traseu. Altfel, mi se pare SF. Sau, poate ai desenat placa cu un traseu gresit. Repet, altfel nu vad cum la tine nu vrea si la mine da. |
Corsa
#2418
Nu am absolut nimic gresit sincer totul e corect , numai ca in locul r=33k am pus de 220k si mai am inca doi amici si confirma da devine sf montajul trage 3A si scintee
bertro |
#2419
Membru dezmembrat Group: Members Posts: 592 Joined: 3 June 05 From: IASI, rumenia ![]() |
Aly, maine cand ne-om intalni sa facem schimbul cu carburatoarele, o sa-ti arat aprinderea Gotronic cu senzor montata pe Nova mea.
Despre functionare: dupa cum i-am zis si lui Gotronic pe PM, nu am intampinat probleme, nici macar acele fluctuatii de turometru de care se temea el. In schimb, am observat ca e ceva mai dificil sa nimeresti punctul optim al avansului decat era pe clasic si AT01. |
Nova GT
- xx xx XXX posesor de DrACIA NOVA GT
gotronic |
#2420
Eu tot nu inteleg de ce ar fi mai greu de gasit punctul optim. In speta senzorul cu aprinderea prin acel LED Control iti spune exact cand da scanteie. Astfel se poate regla avansul static, si in jurul acestuia se poate tatona avansul dinamic. Exact ca si pe clasic sau cu aprinderea AT01.???!!!
![]() Am gresit eu cu ceva.? ![]() ![]() |
2020 Iulie
#2421
Am montat aprinderea john clarke asa cum am zis eu cu acea modificare R=33k inlocuit cu R=220k si merge super si cu faza lunga scurta nu se modifica nici turatzia evident am realizat si acel montaj pentru turometru . Transformator tip sunerie mere bine si cu 220nf/300v. Asadar Liviu ma descurc si daca e ajut si doresc sa fiu ajutat , nus genul eu le stiu pe toate cum s-a inteles. Apropo Gotronic nu cred ca mere prin acel led de pe aprinderea realizata de tine
gotronic |
#2422
Pai da, ce am zis eu ca nu e asa.? In schimb nu-ti mai trebuie bec si sarme.!! Spun ca reglajul static (la semnul de pe volanta) este relativ, deoarece daca arcurile centrifugalului sau a capsulei vacumatice sunt usor decalibrate, la fel si daca membrana de la vacumatic scapa aer fals, avansul dinamic difera un pic de la motor la motor. Asta era valabila si poate nici atunci (perfect) la masinile noi din fabrica cand nu numai aceste elemente erau in parametri ci si compresia motorului, jocurile din distributie....etc. Cam asa vad eu lucrurile.
2020 Iulie
#2423
Asa e gotronic stiu ca ai greptate , eu trebuie sa reglez culbutori si sa fac un test de noxe , iar pe 25 la inspectia tehnica
diaconuliviu |
#2424
QUOTE(djasu82 @ 3 May 2007, 20:34) [...] 1. Acea parte cu 220K in loc de 33 K (diferenta enorma) inca ma pune pe ginduri; pe linga faptul ca ai ars 2 IR 2155 ele nici nu lucreaza cu 33K. Inca mai banuiesc acel C3 ca fiind 12 nF in loc de 120 sau gafa de desen/montaj. 2. Sa ne fie iertat, dar tu ai aparut pe aici cu "bai, nu stiti electronica, uite ce tare-s eu" (exista pe topic postarile tale), de acolo si miniatacul. 3. Traf de sonerie...nu e cam maricel? |
Corsa
#2425
Uite Liviu care e treaba tu daca esti moderator te dai mare ok ,vrei sa pun poze sa observi ca e identic ca cel din schema in format pdf!!! O sa pun un filmulet sa iti arat tie si la toti oameni cum functioneaza!!!! Asa e rominu pina cind nu vede cu ochii nu crede am ars doua ir2155 fiindca am umblat cu buna stiinta la acel condensator sa modific ceva fiindca nu mia functionat
![]() This post has been edited by djasu82: 4 May 2007, 14:56 |
diaconuliviu |
#2426
1. Aceeasi atitudine de "ce tare-s eu".
2. Poze cu aprinderea am pus ceva pagini mai in spate. Si chiar si aici: http://www.daciaclub.ro/aprindere-electron...2993-s1170.html http://www.renault8.3xforum.ro/post/544/1/...e_si_aprindere/ http://www.daciaclub.ro/aprindere-electron...2993-s1470.html Prima schema de gestionar cu PIC, ulterior modificata. 3. Se poare ca ce am spus in legatura cu acea diferenta enorma 33k/220k asupra ta a avut efect invers; eu o spusesem in sensul "e prea mare diferenta aia incit CI sa aiba o asa dispersie, deci trebuie sa cauti eroarea care, in timp poate genera alte probleme, cind te astepti mai putin". Ca tu ai inteles ca ma dau mare, problema ta; o sa te ignor total, exceptind regulamentul. 4. Filmulet, sorry, nu-s asa bogat sa-mi cumpar o camera si nici n-o consider o prioritate; daca si cind voi avea, o sa postez si filmulete. Si nici nu caut, sincer, sa-ti demonstrez tie ca merge. Incercam sa te pun in garda cu ceva, orgoliul tau a inteles pe dos. This post has been edited by diaconuliviu: 5 May 2007, 07:58 |
Corsa
#2427
Sal eu zic hai sa nu ne mai certam ca nu ARE SENS . Cred ca dupa ce o sa se faca toate nebuniile la aceste daci model vechi vor veni cei cu solentele si loganurile
diaconuliviu |
#2428
Desi am zis ca te ignor, nu ma abtin, macar pentru cei ce inteleg: pai 3 impulsuri alea sint de fapt 6 scintei, iar 1 impuls = 2 scintei! Citeste PDF-ul sa vezi si DE CE!
Daca pastrezi la 5000 rpm 6 scintei (6x0,5 ms=3 ms ~ 90 grade RAC, adica ai scintei pe cursa de detenta, cind in zona bujiilor deja e ars amestecul, la ce bun?) Norocul aici e ca platina isi face treaba si taie scinteile inaintea acelui C3, dupa 30 grade RAC, adica dupa 1 ms (la 5000 rpm), raminind de fapt tot 2 scintei. This post has been edited by diaconuliviu: 5 May 2007, 09:10 |
Corsa
#2429
Dar totusi Liviu sincer energia dezvoltata e mai mare cu 4-6 impulsuri adica 8-12 scintei! asta am observat , iar pe bujie scinteia devine mult mai groasa in jur la 0,9-1mm , asadar e o energie mult mai mare dezvoltata intre electrozi. Si eu ma apuc acum de gestionarea avansului vacumatic , am picul trebuie sa-l bag la programat
![]() This post has been edited by djasu82: 6 May 2007, 00:09 |
gotronic |
#2430
Am realizat niste videoclipuri in atelier cu un delcou nou de Sacele complet.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() 1. Turometrul (de Oltcit) conectat la stand ![]() 2. Turometrul+Platina pe clasic ![]() 3. Platina cu condensator(pe clasic) ![]() 4. Platina + Aprindere Tranzistorizata AT01 si bobina de 3 Ohmi ![]() ![]() ![]() 5. Platina + Aprindere Tranzistorizata AT01 si bobina de 2 Ohmi ![]() ![]() 6. Platina + Aprindere Tranzistorizata AT011 (Bobina 2 Ohmi - de Oltcit) si curent prin platina de cca 100 mA ![]() ![]() 7. Platina fara condensator (sau defect, ![]() ![]() ![]() ![]() ![]() ![]() This post has been edited by gotronic: 12 May 2007, 20:57 |
2020 Iulie
DaciaClub - Reno Bot |
![]() Mesaj automat ![]() |
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 5th June 2025 - 20:39 |
