AC Blower is doing Noise & on Fan Speed 3 & 4, Air flow is very very very low at speed 1 & 2
dmkzeal |
Membru incepator Group: Members Posts: 1 Joined: 26 July 16 ![]() |
- DLCAS2532
RHodgett |
Membru incepator Group: Members Posts: 8 Joined: 24 August 18 ![]() |
I had this with a previous car (not Dacia) where a resistor failed, once replaced it worked fine. In my previous car the resister can be pulled out below the glove box.
I'm no expert but might be worth a Google. |
Logan MCV
2017 1.0
Victorine |
Check the cabin filter housing first, see if there is any filter installed, see if its clogged, check for debries between radiator fins. This is what I found in there after 5 months, WITH CABIN FILTER INSTALLED:20180823_122520.jpg ( Size: 2.87mb )
The fan noise may be also caused by debries. I managed to remove and clean the fan without dismantling the whole dashboard. This post has been edited by Victorine: 31 Aug 2018, 09:14 |
Toyota
Auris Touring Sports HSD
2014
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 4th August 2025 - 11:24 |
