speedometer stops , goes to 0 km/h and so on, speedometer stops , goes to 0 km/h and so on
Dick Put |
Membru incepator Group: Members Posts: 6 Joined: 1 October 16 ![]() |
Logan 1.4
2006 laurette
- 17-TL-TJ
![]() Membru autentic Group: Members Posts: 8.177 Joined: 12 May 06 From: BUCURESTI ![]() |
help you ? https://youtu.be/yRt6Z-559Cw
CAPTUR E-Tech full hybrid 145
2024
Dick Put |
Some, not the same engine or car i think.
Thanks anyway Dick 1 Oct 2016, 22:57: Is there the same for the DAcia 1.4? This post has been edited by Dick Put: 1 Oct 2016, 23:57 |
Logan 1.4
2006 laurette
- 17-TL-TJ
it is logan 1,6 16 v, positioning sensor is motor should be the same, the sensor of 3-wire
+ 12V signal grownd the signal wire must have pulses depending on speed try reading this topic with google translation http://www.daciaclub.ro/index.php?showtopi...dpost&p=2011010 This post has been edited by bygy007: 2 Oct 2016, 00:43 |
2024
Dick Put |
Can not read all.
But where is the position of the sensor by the 1.4? Also on the back? Can I remove the sensor from the above side or from the bottom from the engine. Car must be put on a bridge? Thanks for so far. Dick |
Logan 1.4
2006 laurette
- 17-TL-TJ
torquemada |
![]() torquemada Group: Members Posts: 1.902 Joined: 17 January 05 From: Bucuresti ![]() |
Logan II
2012 / 0.9 TCe Laureate
Dick Put |
Thanks so far.
I can find it now. |
Logan 1.4
2006 laurette
- 17-TL-TJ
Bladerunnercro |
Membru incepator Group: Members Posts: 2 Joined: 30 December 18 ![]() |
Do you have picture for three cilindra engine where is position of speed sensor.2018 model
Thank you I advance |
Sandero
2018
torquemada |
In the new Logan II/Sandero II TCe/dCI/SCe there is no VSS(vehicle speed sensor), the ABS delivers this information via CAN
Logan II
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 9th May 2025 - 06:54 |
