Dacia 1410 Sport L s.s. 004929 1991
Patronu' |
Membru incepator Group: Members Posts: 27 Joined: 13 October 16 ![]() |
Attached thumbnail(s) FB_IMG_1476726936188.jpg ( Size: 47.36k ) Number of downloads: 776 20161017_132012.jpg ( Size: 4.45mb ) Number of downloads: 801 |
1410 Sport
1986/ 1991
dacia_gpg |
Membru autentic Group: Members Posts: 473 Joined: 2 November 07 From: POCREACA ![]() |
Spoilerul de sub bara fata e original?
DACIA 2000 ,
2000
Patronu' |
Da. Tip TLX cu decupaje.
Attached thumbnail(s) FB_IMG_1476727463724.jpg ( Size: 55.59k ) Number of downloads: 787 FB_IMG_1476727445735.jpg ( Size: 35.29k ) Number of downloads: 758 |
1410 Sport
1986/ 1991
sobolan |
capota si grila caloriferului par de pe un model mai nou un pic...cn1
Logan-1.5dci-2017--
Golf mk5 - syncro - 2007--
Daciotul_98 |
![]() membru foarte autentic!! Group: Members Posts: 1.572 Joined: 15 June 13 From: Serbanesti,Arges ![]() |
197x Pentru detalii nu ezitati
0732366741-claudiu |
sobolan |
stai calm ma,acum am vazut si eu ca-i din 91,eu am zis ca in 91 nu se mai faceau sport-uri,mea culpa ca n-am citit de la inceput atent,mai mult m-am uitat la poze
Logan-1.5dci-2017--
DACIOTUL_97 |
![]() Ne plac femeile,dar iubim masinile ! Group: Members Posts: 1.649 Joined: 8 July 13 From: Bd-ul Dacia ![]() |
Ar trebui sa incapa jante de 5.5,dar cu anvelope de 165/70 R13.
1310/Logan/
MLS 1986/MLS 1985/1.6 16v Prestige 2008 "Voi lupta pana la ultima mea picatura de sange,ca sa ai dreptul,sa nu fi de acord cu mine"
#Pasionat de fiare vechi# Ex.Dacia 1310-CN3 & 1310-ph1 |
Patronu' |
Nu e bai. Da, pe net am citit ca pana in 92 s au facut dar n am vazut nici una. Am vazut pe o injectata 5.5 cu 165/70 si dupa cum am vazut eu, daca ar fi fost joasa nu ar fi incaput. Ieri a avut ultimul drum. Intra la hibernare.
https://m.youtube.com/watch?v=Ge0ad45C-M4 Planetare uzate, ambreiaj uzat. Attached thumbnail(s) 20161019_130246.jpg ( Size: 4.57mb ) Number of downloads: 233 20161019_130236.jpg ( Size: 4.67mb ) Number of downloads: 193 |
1410 Sport
1986/ 1991
Raul90 |
![]() Membru Group: Members Posts: 175 Joined: 27 November 11 ![]() |
Am avut eu pe 1300 canada 5.5j cu 165 70 13. Era lasata si nu freca, deci nu ar trebui sa ai probleme...
Clio 2
sobolan |
cu suspensii stock n-ar trebui sa fie probleme cu 5,5 ......nici daca o lasi mai jos,acuma' depinde si cat e lasata....
Logan-1.5dci-2017--
Patronu' |
Are 8.5 cm garda in sarcina. O sa i au o roata de la cineva sa incerc.
1410 Sport
1986/ 1991
sobolan |
Logan-1.5dci-2017--
Alex1300BV |
![]() Membru autentic Group: Members Posts: 679 Joined: 20 November 08 ![]() |
Documentatie despre reglage carburator.
https://fr.scribd.com/doc/79429286/Reglaj-C...dere-Dacia-1310 http://www.masini.ro/forum/content/Berlina...-cu-carburator/ |
1410
1991 1397 cmc TLX Break
- xxxxxxxx
Patronu' |
Stiu cum se regleaza. As vrea sa aud motorul tau si mai mult, sa il vad. Ai servofrana? Elv? Poate am o problema electrica dar cu lumina de intalnire, elv, si piciorul pe frana imi scad 200 rpm. Nu am ni i un neajuns decat ca motorul scutura la o turatie mai joasa. Fa o filmare cu motorul cald la 800 cu farurile aprinse si un pahar plin cu apa pe capacul de la culbutori sa imi dau seama.
1410 Sport
1986/ 1991
sobolan |
scade ralantiul ca ai un alternator de 30A(posibil sa nu incarce corect) sau ai baterie cu amperaj mic.
Scutura in turatii mici,asta e un posibil inceput de neetanseitate la supape.O sa scuture mai rau si in alte turatii pe viitor. Gandeste-te ca un motor care sta mult nepornit se deterioreaza....cand e oprit,normal ca unele supape raman atacate,altele nu,depinde de positia in ca s-a oprit....daca ramane asa nepornit cativa ani supapele atacate se deterioreaza pe suprafata de inchidere(acolo unde e luciu metalic) si uite-asa incepe totul...... This post has been edited by sobolan: 27 Oct 2016, 20:15 |
Logan-1.5dci-2017--
Patronu' |
Asta da. Supapele sunt o posibila cauza pentru ca au probleme. O sa fie controlate, schimbate simeringurile, etc, sper sa se corecteze. Alternatorul nu stiu de cat e, de fabrica. Incarca suficient pentru ca am primit garantie la baterie. Caranda de 65. Tie nu iti scade turatia cand pornesti consumatori?
1410 Sport
1986/ 1991
sobolan |
simeringuri pe supape nu ai la modelul tau si daca incerci sa-i pui or sa sara,is patit.....
La mine nu scade nimic,nu se simte nimic,unde mai pui ca am si linia Alpine pe ea,alternatorul e din 99 si are 50A,bateria e rombat de 55AH |
Logan-1.5dci-2017--
Patronu' |
Inseamna ca am o problema electrica. Alternatorul incarca corect totusi.
27 Oct 2016, 21:26: Am citit ca e ok sa scada turatia de la consumatori cand intra alternatorul in sarcina, mai ales daca e mai mare, nu mai mic. Cu faruri cand ambala motorul la garantia bateriei, batea spre 15. 14.8. Incarca bine. Astept sa vad cum trebuie sa mearga o Dacie pe carburatie cu ralantiul la 800 si cu consumatori porniti. Pana atunci raman la parerea ca motorul e reglat bine. La mine nu mai sunt pe carburatie. This post has been edited by Patronu': 27 Oct 2016, 21:26 |
1410 Sport
1986/ 1991
sobolan |
ai trecut pe injectie ? de care ?
Logan-1.5dci-2017--
Dinica Mihnea |
Membru autentic Group: Members Posts: 239 Joined: 23 July 15 ![]() |
Nu stiu daca te ajuta, dar eu am avut fluctuatii la incarcare (cand puneam consumatori, cand turam) din cauza puntii de diode (ajungea chiar la 17V incarcarea), era intrerupta complet...
Dacia 1300
1975
- DJ 06 CGF
Patronu' |
Am lumini bune. Am avut probleme si cu tensiunea de mi se oprea motoru. Faza scurta era mai slaba decat pozitiile. Era de la curea. Acum nu sunt probleme. Turometrul scade normal. Nu e cpmputer sa corecteze automat.
Nu am injectie eu. Ma refer la altele pe carburatie sa fac comparatie. |
1410 Sport
1986/ 1991
Patronu' |
Mi-am readus aminte de topic. Am desfacut motorul si am descoperit: pistoane scobite, ambreiaj plin de ulei (aluneca desi nu era foarte), discul original. Cautand sa cumpar un set Mahle de 1400, am gasit unul de 1600, arbore aferent, chiulasa de 1.4 bibilita la pret bun si le-am cumparat. Am decis sa ii aduc modificari in ce priveste performantele. Estetic ramane 95% originala iar cele legate de performanta sunt complet reversibile sa nu imi para rau. Am cumparat jante canada de 5.5 cu anvelope de 165/70 si intra cam la limita, nu ating oricum. O sa ramana si carburatorul Carfil pana fac rodajul apoi o sa montez orizontale Dellorto si o sa confectionez o evacuare din inox cu serpisori. In ce priveste franarea, o sa montez discuri pline de fata pe spate si discuri aerisite pe fata, ramanand la canadele de 5.5, fara sa roluiesc sau ceva.
1410 Sport
1986/ 1991
Alex1300BV |
#53
cool!
1410
- xxxxxxxx
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 9th July 2025 - 04:20 |
