> [Sandero 2017] Size of 2 Din Radio Compartment, How big is the 2 din radio compartment?
magen1
post 24 Apr 2017, 12:03
Hello everyone,
I'm new here.
My new Sandero Ambiance 2017 is under delivery so I can't check by myself.
Can't find the size of the 2 din radio.
I already have an Android 7" 2 din radio with the size of: 178x101mm
Can I use it ?
Thanks
Dacia Sandero Ambiance 2017
torquemada
post 24 Apr 2017, 15:17
torquemada
Hi,
the unit will require an adaptor like this
https://www.aliexpress.com/item/High-qualit...addresstype=600
and, most likely, a new console cover(like the one on Ambiance/Laureate) or you can cut the one that comes with the car (it is 2DIN divided into 1DIN + storage compartment)
DACIA Logan II 2012 / 0.9 TCe Laureate - B-xxx-xxx
Există două feluri de oameni:
1 - Cei care pot extrapola din date incomplete
magen1
post 24 Apr 2017, 16:33
QUOTE(torquemada @ 24 Apr 2017, 15:17)
Hi,
Thanks for the answer.
I'm also new in DIY radio replacement so I may ask stupid questions.
Don't I also need the metal *brackets ? or the original ones are detachable from the original radio unit ?
If the radio was 173x97mm (some vendor sells the same model with this two sizes) is the adapter still required?
BTW, the prices on EU market are damn crazy dry.gif .
thanks
This post has been edited by magen1: 24 Apr 2017, 20:08
torquemada
post 24 Apr 2017, 23:10
torquemada
You wrote Ambiance and I read Acces (Acces does not have a radio).
The metal brakets of the OEM radio(the one that has CD) could be used for your android unit, but you should wait for the car delivery to be sure (you might get the new radio model)
magen1
post 25 Apr 2017, 10:05
QUOTE(torquemada @ 24 Apr 2017, 23:10)
Looking on internet I just saw this model
that is (supposed to be) the last one, the one published on Dacia's website.
So let's say this is the one I'll get.
I should just need the frame right?
I'm in "rush" (insist for an answer, trying to understand and can't wait for the car) due a negotiating in progress for a better radiobetter radio with the same size of the one I already have. That's why my main question was if that size can fit in the radio's "hole". blush.gif
The thing is, if there are 2 standards 1 DIN and 2 DIN, why the company make the same 2 DIN model with few millimeter of difference?
Thanks
EDIT: oh, and BTW, even the Dacia support couldn't help me, they answered to go in a official repair shop and ask mad.gif (impossible for me right now, I'm in the middle of the sea with no mechanics around)
This post has been edited by magen1: 25 Apr 2017, 11:00
torquemada
post 25 Apr 2017, 13:09
torquemada
Forget the 1DIN is only for Acces.
You will need the adapter in post #2 and some brackets. The adapter has 3 inner dimensions 178x102 should be good for your android device (178x101mm )
First picture the new radio (depends on country), and an android unit using the adapter in #2
magen1
post 26 Apr 2017, 17:16
Thanks for the answers.
magen1
post 13 May 2017, 17:21
Still waiting for the car and still looking some knowledge.
Aparently the stock radio uses proprietary plugs for the radio and even the antenna dry.gif .
Rethoric question: WHY ? WHY ALL THIS DAMN ADAPTERS, CABLES AND PLUGS? mad.gif
This post has been edited by magen1: 13 May 2017, 17:22
magen1
post 27 Jul 2017, 16:04
Allright, I'm back.
I was finally free to install the radio in the car when I've discovered that the adaptor I had in the new radio's box is not compatible with Renault's proprietary plugs.
Because I don't want to cut the original wiring, I'm looking for the right adaptor but before I'll buy one I'm trying to understand the meaning of each plug and why some of that doesn't have the conversion wiring.
So, this is the adaptor I've found in the new radio's box:
and this is a common adaptor (for Renault/Dacia) with the stock radio's cables and plugs:
A ) this is the radio plug that I already have the conversion cable
B ) don't know what is this but the adaptor have the conversion plug
C ) is this the wire for the wheeling controls ? btw, this plug is not available in the adaptor. (maybe is one of the USB port available on the ne radio? EDIT: no, shape of the plug is different sad.gif )
D ) powering cable?
This is the back of the new radio:
The adaptor E have less pins than the plug B and D, is that normal?
tl;dr I need an adaptor to convert the STOCK RENAULT's poprietary plugs into a standard(?) plugs.
many, many, many thanks.
This post has been edited by magen1: 27 Jul 2017, 17:27
torquemada
post 27 Jul 2017, 23:34
torquemada
A ) radion antena
B ) power and speakers
C ) SWRC steering wheel remote control
D ) +ACCesories and +ILLumination, MICrophone and RearViewCamera wires
Is this good?
Yes, it has only wires for +ACCesories and +ILLumination
This post has been edited by torquemada: 27 Jul 2017, 23:38
magen1
post 28 Jul 2017, 00:11
Ok,
I found that maybe I need an extra control unit to manage that built in wheel's control system.
That control unit cost almost as the Radio unit itself (from 60 to 90 euro).
So for now I'll bypass that sleep.gif.
EDIT: oh, hey Torquemada, just saw your reply.
Many thanks for the info and all the support.
This post has been edited by magen1: 28 Jul 2017, 00:16
Lo-Fi Version  Harta site  Parteneri  Jocuri online  Curs Valutar  HRH Haine din lana merinos Time is now: 19th July 2025 - 07:22
